In order to add boards that have different hardware for fpga reset,
any 405ep gdsys board now provides these functions:
void gd405ep_init(void);
void gd405ep_set_fpga_reset(unsigned state);
void gd405ep_setup_hw(void);
int gd405ep_get_fpga_done(unsigned fpga);
Signed-off-by: Dirk Eibach <eibach@gdsys.de>
Cc: Stefan Roese <sr@denx.de>
Make endianess of target CPU configurable. Use the new config
option for dbau1550_el and pb1000 boards.
Adapt linking of standalone applications to pass through
endianess options to LD.
Build tested with:
- ELDK 4 mips_4KC- and mips4KCle
- Sourcery CodeBench Lite 2011.03-93
With this patch all 26 MIPS boards can be compiled now in one step by
running "MAKEALL -a mips".
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
The CS_AUTOBOOT configurations have been broken for a long time.
Kshitij Gupta is no longer at TI making these broken and orphaned
boards, so remove.
Cc: Bryan Hundven <bryanhundven@gmail.com>
Cc: Michael Schwingen <rincewind@discworld.dascon.de>
davinci_dm6467Tevm
In commit 2d575e46859dd9127a9cec731ace77523e6ea2ab a separate header
file was introduced for the DM6467T EVM, include/configs/davinci_dm6467Tevm.h.
The substantial difference between the davinci_dm6467evm and the
davinci_dm6467Tevm configuration is a single bit in the hardware revision
that is passed to the Linux kernel and davinci_dm6467evm has
REFCLK_FREQ = 27000000 where as davinci_dm6467Tevm.h has a
REFCLK_FREQ = 33000000.
This patch removes include/configs/davinci_dm6467Tevm.h. Instead the
include/configs/davinci_dm6467evm.h configuration is used for DM6467T EVMs and
renamed CFG_REFCLK_FREQ to CONFIG_REFCLK_FREQ and CONFIG_REFCLK_FREQ is defined
in boards.cfg.
Signed-off-by: Prabhakar Lad <prabhakar.csengg@gmail.com>
Cc: Tom Rini <trini@ti.com>
add support to read mac address for AM18x EVM manufactured from
Spectrum digital which have mac address stored in I2C EEPROM manufactured
by WINBOND. This patch reads mac address from I2C EEPROM and sets the
environment variable if not set, If mac address is already present in
environment compare it with the mac address in EEPROM and warn on
mismatch.Introduced a config option CONFIG_MAC_ADDR_IN_EEPROM to where
to look for the mac address.
Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com>
Cc: Mike Frysinger <vapier@gentoo.org>
add support to read mac address for da850/L138 evm manufactured by
Logic PD which store mac address in SPI flash manufactured by ST
Microelectronics. This patch adds support to read mac address from
SPI flash and set the mac address if it hasn't been set in environment,
If it has been set in the environment it compares the value one with
SPI flash and warns on mismatch. Introduced a config option
CONFIG_MAC_ADDR_IN_SPIFLASH indicating where to look mac address for.
* 'master' of git://git.denx.de/u-boot-blackfin:
Blackfin: pata_bfin: fix printf warning
Blackfin: bfin_nand: mark local func static
linkage.h: move from blackfin to common includes
Blackfin: br4: new board port
Blackfin: add in/out le32 variants
post: add blackfin to the post_time_ms list
Blackfin: bf537-stamp: drop board reset workaround
Blackfin: pr1: new board port
This adds support for the BR4 Appliance. It is a quad channel ISDN BRI
board based on Blackfin BF537 CPU.
Signed-off-by: Dimitar Penev <dpn@switchfin.org>
This add support for the PR1 Appliance - Asterisk based ISDN PRI PBX.
This board is Blackfin BF537 based. The schematics are not fully opened.
This patch adds support for the Calimain board from
OMICRON electronics GmbH. The board features a Texas Instruments AM1808
SoC, 128 MB DDR2 memory, and 64 MB NOR flash memory connected to CS2 and
CS3.
Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
This patch moves hawkboard to the new spl infrastructure from the
older nand_spl one.
Removed the hawkboard_nand_config build option -- The spl code now
gets compiled with hawkboard_config, after building the main u-boot
image, using the CONFIG_SPL_TEXT_BASE. Modified the README.hawkboard
to reflect the same.
Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com>
Cc: Christian Riesch <christian.riesch@omicron.at>
Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Acked-by: Christian Riesch <christian.riesch@omicron.at>
This patch adds support for the HTKW mcx AM3517-based board.
Serial, Ethernet, NAND, MMC, RTC, EHCI USB host and both
NAND and MMC SPLs are supported.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
CC: Tom Rini <tom.rini@gmail.com>
Cc: Detlev Zundel <dzu@denx.de>
The mt_ventoux board is a custom board using
the Technexion TAM3517 module.
The patch fixes also the mtdparts variable in the
TAM3517 common configuration file.
CC: Ilya Yanok <yanok@emcraft.com>
CC: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Amit Virdi <amit.virdi@st.com>
SMDK5250 board is based on Samsungs EXYNOS5250 SoC.
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
This patch adds support for Samsung TRATS board
Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com>
This patch adds support for D-Link DNS-325 ShareCenter NAS.
Signed-off-by: Stefan Herbrechtsmeier <stefan@code.herbrechtsmeier.net>
Cc: prafulla@marvell.com
Cc: albert.u.boot@aribaud.net
Tricorder is a board which is very similar to the Devkit8000. It
is designed as a base platform for further medical devices.
www.corscience.de/en/medical-engineering/products/multiparameter/mp10-board.html
Signed-off-by: Thomas Weber <weber@corscience.de>
The Toshiba AC100 (Compal code-name Paz00, aka Dynabook AZ) is a netbook
derived from the NVIDIA Tegra Harmony reference board. It ships with
Android, but is often repurposed to run Linux. This patch adds just enough
support to get a U-Boot serial console, and the ability access built-in
eMMC and the external SD slot.
v2:
* Rebased on latest HEAD, incorporated changes made to other board files.
* Moved board files from board/nvidia to board/compal.
* Switched to correct odmdata value. This required add the previous patch
to fix U-Boot's interpretation of the odmdata RAM size field.
* Removed nvmem= from default Linux kernel command-line; no drivers use the
reserved memory yet, so there's no point reserving it.
Signed-off-by: Tom Warren <twarren@nvidia.com>
This patch adds basic support for OMAP35x/DM37x SOM LV/Torpedo
reference boards. It assumes U-boot is loaded to SDRAM with the
help of another small bootloader (x-load) running from SRAM.
Signed-off-by: Peter Barada <peter.barada@logicpd.com>
Cc: Tom Rini <tom.rini@gmail.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
In commit 06194b6b65f701a9d6ef2d9b4123c4afe57d8783 a separate header
file was introduced for the AM1808 EVM, include/configs/da850_am18xxevm.h.
Before this commit, the da850evm.h configuration file was used for both
the AM1808 and the OMAP-L138 EVMs. The only substantial difference
between the da850evm and the da850_am18xxevm configuration is a single
bit in the hardware revision that is passed to the Linux kernel.
This patch removes include/configs/da850_am18xxevm.h. Instead the
include/configs/da850evm.h configuration is used for AM18xx EVMs and
CONFIG_DA850_AM18X_EVM is defined in boards.cfg.
Add the initial support for Freescale i.MX6Q Sabre Lite board
Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com>
Signed-off-by: Jason Liu <jason.hui@linaro.org>
CC: Eric Nelson <eric.nelson@boundarydevices.com>
Add initial support for Freescale MX28EVK board.
Tested boot via SD card and by loading a kernel via TFTP through
the FEC interface.
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
This board is similar to our tuxx1 target. But on this board there
is only one application specific chip select configured.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
Acked-by: Heiko Schocher <hs@denx.de>
These boards are from a u-boot point of view identical. So collect
the two headerfiles to one, to decrease maintenance.
cc: Heiko Schocher <hs@denx.de>
The Medcom is a 16:9 15" terminal that is used for patient infotainment
in hospitals.
Changes in v3:
* Remove unused implementation of gpio_config_uart().
* Implement MMC/SD card detection.
* Drop board_mmc_getcd() which is now implemented by common Tegra2
code.
* Add MAINTAINERS entry.
Changes in v2:
* No longer override the default CONFIG_SYS_TEXT_BASE setting.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
The Plutux is a set-top box device based on the Tamonten processor
module. It can be connected to a display via an HDMI output.
Changes in v3:
code.
Changes in v2:
The twister board is a development board using
the TAM3517 SOM.
Support for NAND, 2 Ethernet (EMAC and SMC911),
USB (EHCI_OMAP).
CC: Tapani Utrianen <tapani@technexion.com>
CC: Sandeep Paulraj <s-paulraj@ti.com>
Add a target for running u-boot as a coreboot payload in boards.cfg, a
board, CPU and a config. This is a skeleton implementation which always
reports the size of memory as 64 MB.
Signed-off-by: Gabe Black <gabeblack@chromium.org>
The "tb0229" board has long been unmaintained, and is broken.
Remove it.
Dave Peverley <dpeverley@mpc-data.co.uk>
Acked-by: Tom Rini <trini@ti.com>
Cc: Kshitij Gupta <kshitij@ti.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
* 'master' of git://git.denx.de/u-boot-arm:
M28: Cleanup memsize.o OOT build
i.MX28: Move SPL to arch/arm/cpu/arm926ejs/mx28
M28: Fix typo
M28: Document that units has to be set to sectors on SD bootcard
i.mx: i.mx6q: add the initial support for i.mx6q ARM2 board
i.mx: mxc_gpio: add the i.mx6q support
i.mx: add the initial support for freescale i.MX6Q processor
i.mx: introduce the armv7/imx-common folder
S5PC2XX: Rename S5pc2XX to exynos
tegra2: Don't use board pointer before it is set up
tegra2: Remove unneeded 'dynamic ram size' message
tegra2: Remove unused low-level Tegra2 UART code
tegra2: Remove unneeded config option
tegra2: Remove unneeded boot code
tegra2: Enable instruction cache
arm: Move CP15 init out of cpu_init_crit()
tegra2: Simplify tegra_start() boot path
tegra2: Add arch_cpu_init() to fire up Cortex-A9
tegra2: Use new GPIO APIs in gpio_config_uart()
tegra2: Add support for Ventana
tegra2: Modify MMC driver to handle power and cd GPIOs
tegra2: Move board_mmc_init into board files
Add the initial support for Freescale i.MX6Q Armadillo2 board
Support: MMC boot from slot 0/1, debug UART(UART4), usdhc.
There is two MMC slots on the boards:
mmc dev 0 -> connect USDHC3 -> the lower slot on the board,
mmc dev 1 -> connect USDHC4 -> the upper slot on the board,
Tested-by: Dirk Behme <dirk.behme@de.bosch.com>
As per new naming convention for Samsung SoC's, all Cortex-A9 and Cortex-A15
based SoC's will be classified under the name Exynos. Cortex-A9 and Cortex-A15
based SoC's will be sub-classified as Exynos4 and Exynos5 respectively.
In order to better adapt and reuse code across various upcoming Samsung Exynos
based boards, all uses of s5pc210 prefix/suffix/directory-names are renamed in
this patch. s5pc210 is renamed as exynos4210 and S5PC210/s5pc210 suffix/prefix
are renamed as exynos4/EXYNOS4.
Ventana is a board which is very similar to Seaboard. Support it by
re-using board/nvidia/seaboard/seaboard.c with minor run-time conditionals.
v5: Makefile: Use cmd_link_o_target, remove unused clean/distclean targets.
v6: Make gpio_config_uart_seaboard() static.
v7: Add MAINTAINERS entry for Ventana. Tom Warren doesn't have Ventana, so
he asked me to add myself for this board.
The eXMeritus HWW-1U-1A unit is a DO-160-certified 13lb 1U chassis
with 3 independent TEMPEST zones. Two independent P2020 computers may
be found inside each zone. Complete hardware support is included.
High-level hardware overview:
* DO-160 certified for passenger aircraft (noncritical)
* TEMPEST ceritified for RED/BLACK separation
* 3 zones per chassis, 2 computers per zone (total of 6)
* Dual-core 1.066GHz P2020 per computer
* One 2GB DDR2 SO-RDIMM module per computer (upgradable to 4GB)
* Removable 80GB or 160GB Intel X18-M SSD per computer
* Front-accessible dual-port E1000E per computer
* Front-accessible serial console per computer
* Front-accessible USB port per computer
* Internal Gigabit crossover within each TEMPEST zone
* Internal unidirectional fiber links across TEMPEST zones
* Battery-backed DS1339 I2C RTC on each CPU.
Combined, each 13lb 1U chassis contains 12GB RAM, 12 cores @ 1.066GHz,
12 front-accessible Gigabit Ethernet ports and 960GB of solid-state
storage with a total power consumption of ~200W.
Additional notes:
* SPD detection is only known to work with the DO-160-certified DIMMs
* CPU reset is a little quirky due to hardware misfeature. Proper
support for the hardware reset mechanism has been left for a later
patch series to address.
Signed-off-by: Kyle Moffett <Kyle.D.Moffett@boeing.com>
Cc: Andy Fleming <afleming@gmail.com>
The "rmu" board has long been unmaintained, and is broken.
Remove it.
The OXC board has long been unmaintained, and is broken.
Remove it.
The BAB7xx boards are almost deceased. They cause build warnings, an
it's not worth the effort to fix these. Remove the dead body.
Cc: Frank Gottschling <fgottschling@eltec.de>
- booting from NOR Flash with direct boot method
- POST support
- LOGBUF support
Cc: Paulraj Sandeep <s-paulraj@ti.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
The board is unmaintained and maintainer doesn't respond.
