path: root/boards.cfg
2011-09-07ARM: PXA: remove broken "zylonite" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Marek Vasut <marek.vasut@gmail.com> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-09-07ARM: remove broken "shannon" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Rolf Offermanns <rof@sysgo.de>
2011-09-07ARM: remove broken "modnet50" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Thomas Elste <info@elste.org>
2011-09-07ARM: remove broken "lpc2292sodimm" board.Wolfgang Denk
2011-09-07ARM: remove broken "lart" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Alex Züpke <azu@sysgo.de>
2011-09-07ARM: remove broken "impa7" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Marius Gröger <mag@sysgo.de>
2011-09-07ARM: remove broken "gcplus" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: George G. Davis <gdavis@mvista.com>
2011-09-07ARM: remove broken "evb4510" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Curt Brune <curt@cucy.com>
2011-09-07ARM: remove broken "ep7312" board.Wolfgang Denk
2011-09-07ARM: remove broken "dnp1110" board.Wolfgang Denk
2011-09-07ARM: remove broken "SMN42" board.Wolfgang Denk
2011-09-04Merge branch 'master' of git://git.denx.de/u-boot-coldfireWolfgang Denk
* 'master' of git://git.denx.de/u-boot-coldfire: ColdFire:Clean up the CONFIG_STANDALONE_LOAD_ADDR usage ColdFire:Add mb for 5253 dram initialization ColdFire:Define the DM9000 byteswap for M5253 board. ColdFire:Update the env settings for several boards. ColdFire:disable the NFS define for 52277 board. ColdFire:Update the timer_init since it was unified. ColdFire: Cleanup for partial linking and --gc-sections ColdFire: Update compile flags for each CPUs ColdFire:Fix the configuration broken for some boards.
2011-09-04ColdFire:Fix the configuration broken for some boards.Jason Jin
Some typoes in Makefile and boards.cfg make the M54455 board and M53017 board configuration broken. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2011-09-04ARMV7: Add support for Samsung ORIGEN boardChander Kashyap
Origen board is based upon S5PV310 SoC which is similiar to S5PC210 SoC. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-09-04ARM: remove broken "at91rm9200dk" boardWolfgang Denk
2011-09-04ARM: remove broken "m501sk" boardWolfgang Denk
2011-09-04ARM: remove broken "kb9202" boardWolfgang Denk
2011-09-04ARM: remove broken "csb637" boardWolfgang Denk
2011-09-04ARM: remove broken "cmc_pu2" boardWolfgang Denk
2011-09-04ARM: remove broken "at91cap9adk" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stelian Pop <stelian.pop@leadtechdesign.com>
2011-09-04ARM: remove broken "voiceblue" boardWolfgang Denk
2011-09-04ARM: remove broken "smdk2400" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Gary Jennejohn <garyj@denx.de>
2011-09-04ARM: remove broken "sbc2410x" boardWolfgang Denk
2011-09-04ARM: remove broken "netstar" boardWolfgang Denk
2011-09-04ARM: remove broken "mx1fs2" boardWolfgang Denk
2011-09-04ARM: remove broken "lpd7a40x" boardsWolfgang Denk
Remove lpd7a400 and lpd7a404 boards. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-09-04ARM: remove broken "B2" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andrea Scian <andrea.scian@dave-tech.it>
2011-09-04ARM: remove broken "armadillo" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Rowel Atienza <rowel@diwalabs.com>
2011-09-04ARM: remove broken "assabet" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: George G. Davis <gdavis@mvista.com>
2011-09-04ARM: versatilepb : drop warnings due to double definitionsStefano Babic
CONFIG_ARCH_VERSATILE_PB is defined twice - drop the define from config.h. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-09-03integrator: convert to new build systemLinus Walleij
This deletes the integrator split_by_variant.sh script and defines a number of unique board types for the core modules that are meaningful to support for the Integrator AP/CP, i.e. the ones that did not just say "unsupported core module" in split_by_variant.sh. If more core modules need to be supported they are easy to add. We delete all the old cruft in Makefile and MAKEALL that was working around the old way of building boards. We create a unique config file per board to satisfy the build system, but they are just oneliners that include the existing integratorap.h and integratorcp.h configs. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-03atmel: Update support of board AT91SAM9M10G45-EK to new styleThomas Petazzoni
Based on earlier work by Alex Waterman <awaterman@dawning.com>. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2011-09-03make pm9g45 buildable for v2011.06 releaseAsen Dimov
Signed-off-by: Asen Chavdarov Dimov <dimov@ronetix.at> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de> changed at91_serial_hw_init to at91_seriald_hw_init
2011-09-03make pm9263 buildable for v2011.06 releaseAsen Dimov
2011-09-03pm9261: compiles with the AT91 reworked schemeAsen Dimov
2011-09-03tny_a9260/tny_a9g20: update board to the new AT91 organizationThomas Petazzoni
Cc: Albin Tonnerre <tonnerrealbin@gmail.com> CC: Gregory Hermant <gregory.hermant@calao-systems.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2011-09-03sbc35_a9g20: update board to the new AT91 organizationThomas Petazzoni
Cc: Albin Tonnerre <tonnerrealbin@gmail.com> Cc: Gregory Hermant <gregory.hermant@calao-systems.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de> Removed SBC35 from MAKEALL
2011-08-22sh: Add Renesas rsk7264 boardPhil Edworthy
The rsk7264 (also know as rsk2+sh7264) is an SH2A based board with 64MB NAND flash and 64MB SDRAM. It is very similar to the rsk7203 board. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-04Armada100: Add Board Support for Marvell GuruPlug-DisplayAjay Bhargav
This patch adds basic board support with DRAM and UART functionality Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com> Acked-by: Tanmay Upadhyay <tanmay.upadhyay@einfochips.com>
2011-08-04ARM: versatile: fix board supportStefano Babic
Versatile board is used as example to run u-boot under qemu. The patch fixes relocation for all versatile boards and adds a versatileqemu target to be used under qemu. Patch tested only under qemu, not on real boards. Tested with QEMU emulator version 0.14.50. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Alessandro Rubini <rubini-list@gnudd.com> CC: Loïc Minier <loic.minier@linaro.org>
2011-08-03avr32: add grasshopper (ICnova AP7000) boardAndreas Bießmann
The grasshopper board is a neat avr32 evaluation kit produced by In-Circuit GmbH. See http://www.ic-board.de/product_info.php?info=p75_ICnova-AP7000-Base.html for detailed information about this device. Signed-off-by: Andreas Bießmann <biessmann@corscience.de> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-08-03AT91: Makes AT91SAM9263-EK build correctly against u-boot-atmel/masterXu, Hong
Rework for AT91SAM9263-EK, makes it build again. Based on the work for AT91SAM9260-EK. Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Reinhard Meyer <uboot@emk-elektronik.de>
2011-08-03AT91: Board fix for AT91SAM9261-EKXu, Hong
Fix board part of AT91SAM9261-EK according to the new scheme Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-08-03AT91: Makes AT91SAM9RL-EK build correctly against u-boot-atmel/masterXu, Hong
Rework for AT91SAM9RL-EK, makes it build again. Based on the work for AT91SAM9260-EK. V4: added changes to MAKEALL Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-07-28Removed obsolete Netstal boardsNiklaus Giger
Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org>
2011-07-27digsy_mtc: move board into vendor dir and add vendor logoAnatolij Gustschin
2011-07-18Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: ARM: MX5: Fix broken leftover TO-2 errata workaround MX31: Cleanup clock function scb9328: Add ARM relocation support am3517evm: change console device from ttyS2 to ttyO2 Remove volatile qualifier in get_ram_size() calls TI: TNETV107X Fix Build Error ARM: add missing CONFIG_SKIP_LOWLEVEL_INIT for armv7 arm: add CONFIG_MACH_TYPE setting and documentation arm: add __ilog2 function Timer: Fix misuse of ARM *timer_masked() functions outside arch/arm EfikaMX: Enable EXT2 booting EfikaMX: Add missing CONFIG_SYS_TEXT_BASE EfikaMX: Use correct imximage.cfg MX27: Update to autogenerated asm-offsets.h MX5: Update to autogenerated asm-offsets.h imx: Add support for zmx25 board imx: Make imx25 compatible to mxc_gpio driver and fix in tx25 imx: Add auto generation of asm-offsets.h for imx25 imx: Add support for USB EHCI on imx25 imx: Use correct imx25 reset.c imx: Add get_tbclk() function for imx25 ARM: Update maintainer of board scb9328 mx27: Make the UART port number explicit build: Add targets for auto gen of asm-offsets.h and use it in imx35 mx31pdk: cosmetic: Fix line over 80 characters
2011-07-17powerpc/p2041rdb: Add p2041rdb board supportMingkai Hu
P2041RDB Specification: ----------------------- Memory subsystem: * 4Gbyte unbuffered DDR3 SDRAM SO-DIMM(64bit bus) * 128 Mbyte NOR flash single-chip memory * 256 Kbit M24256 I2C EEPROM * 16 Mbyte SPI memory * SD connector to interface with the SD memory card Ethernet: * dTSEC1: connected to the Vitesse SGMII PHY (VSC8221) * dTSEC2: connected to the Vitesse SGMII PHY (VSC8221) * dTSEC3: connected to the Vitesse SGMII PHY (VSC8221) * dTSEC4: connected to the Vitesse RGMII PHY (VSC8641) * dTSEC5: connected to the Vitesse RGMII PHY (VSC8641) PCIe: * Lanes E, F, G and H of Bank1 are connected to one x4 PCIe SLOT1 * Lanes C and Land D of Bank2 are connected to one x4 PCIe SLOT2 SATA: Lanes C and Land D of Bank2 are connected to two SATA connectors USB 2.0: connected via a internal UTMI PHY to two TYPE-A interfaces I2C: * I2C1: Real time clock, Temperature sensor, Memory module * I2C2: Vcore Regulator, 256Kbit I2C Bus EEPROM, PCIe slot1/2 UART: supports two UARTs up to 115200 bps for console Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-14EfikaMX: Use correct imximage.cfgJana Rapava
Signed-off-by: Jana Rapava <fermata7@gmail.com>
2011-07-14imx: Add support for zmx25 boardMatthias Weisser
zmx25 is a board based on imx25 SoC, 64 Megs of LPDDR, 32 Megs of NOR flash, an optional NAND flash. Signed-off-by: Matthias Weisser <weisserm@arcor.de>
