path: root/boards.cfg
2013-04-22mx6sl: Add initial support for mx6slevk boardFabio Estevam
mx6slevk board is a development board from Freescale based on the mx6 solo-lite processor. For details about mx6slevk, please refer to: http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=IMX6SLEVK&parentCode=i.MX6SL&fpsp=1 Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-04-15Tegra: T30: Beaver board support.Tom Warren
Beaver is a Tegra30 board that is nearly 100% compatible w/Cardhu. Add a Beaver build so it can begin to be differentiated, if need be. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-04-12arm/km: add support for kmsuv31 boardHolger Brunck
This board is from a u-boot point of view a mixture between kmnusa and a standard km_kirkwood board. We have our u-boot environment in the spi NOR flash, but we have a direct connection between the kirkwood and the piggy. A FPGA is connected via the PCIe interface. So we only have to select the specific features in the board setup. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com> Acked-By: Prafulla Wadaskar <prafulla@marvell.com>
2013-04-12nand: mxc: Switch NAND SPL to generic SPLBenoît Thébaudeau
This also fixes support for mx31pdk and tx25, which had been broken by commit e05e5de7fae5bec79617e113916dac6631251156. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Acked-by: Scott Wood <scottwood@freescale.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-04-08ARM: OMAP5: Rename omap5_evm to omap5_uevmSRICHARAN R
The omap5-uevm is the reference board name for OMAP5 soc based platform. So rename it accordingly. Acked-by: Nishanth Menon <nm@ti.com> Signed-off-by: Sricharan R <r.sricharan@ti.com> Tested-by: Nishanth Menon <nm@ti.com>
2013-04-04Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-04-03mx28evk: Introduce a new target for saving env vars to NANDFabio Estevam
Introduce 'mx28evk_nand' target for saving environment variables into NAND. The mx28evk board does not come with a NAND flash populated from the factory. It comes with an empty slot (U23), which allows the insertion of a 48-pin TSOP flash device. Tested with a K9LBG08U0D. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Otavio Salvador <otavio@ossystems.com.br>
2013-03-26Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-03-24ti814x_evm: add ti814x evm board supportMatt Porter
Add TI814X EVM board directory, config file, and MAINTAINERS entry. Enable build. Signed-off-by: Matt Porter <mporter@ti.com> Reviewed-by: Tom Rini <trini@ti.com> [trini: Adapt to recent omap_hsmmc requirements, Matt re-tested] Signed-off-by: Tom Rini <trini@ti.com>
2013-03-20Add initial support for Wandboard dual lite and solo.Fabio Estevam
Wandboard is a development board that has two variants: one version based on mx6 dual lite and another one based on mx6 solo. For more details about Wandboard, please refer to: http://www.wandboard.org/ Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-03-15nitrogen6x: Fix RAM size variableFabio Estevam
Fix the following build error when buildig nitrogen6s1g: nitrogen6x.c:89:17: error: 'CONFIG_DDR_MB' undeclared (first use in this function) nitrogen6x.c:89:17: note: each undeclared identifier is reported only once for each function it appears in Reported-by: Albert Aribaud <albert.u.boot@aribaud.net> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-03-13Add Boundary Devices Nitrogen6X boardsEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2013-03-12Merge branch 'u-boot-atmel/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-03-12EXYNOS5: Snow: Add a configuration fileRajeshwari Shinde
This patch adds the configuration file for Snow Board and defines the same in boards.cfg. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-11ppc: Remove PCIPPC2 and PCIPPC6 boardsStefan Roese
These boards seem to be unmaintained for quite some time. So lets remove support for them completely. This also cleans up some common drivers/files. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Guillaume Alexandre <guillaume.alexandre@gespac.ch> Acked-by: Wolfgang Denk <wd@denx.de>
2013-03-11Merge u-boot/master into u-boot-ti/masterTom Rini
In master we had already taken a patch to fix the davinci GPIO code for CONFIG_SOC_DM646X and in u-boot-ti we have additional patches to support DA830 (which is CONFIG_SOC_DA8XX && !CONFIG_SOC_DA850). Resolve these conflicts manually and comment the #else/#endif lines for clarity. Conflicts: arch/arm/include/asm/arch-davinci/gpio.h drivers/gpio/da8xx_gpio.c Signed-off-by: Tom Rini <trini@ti.com>
2013-03-11arm: dra7xx: Add dra7xx_evm build supportLokesh Vutla
Adding the build support for dra7xx_evm. Reusing omap5_evm.h config by moving it to omap5_common.h Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: R Sricharan <r.sricharan@ti.com>
2013-03-09mpc512x: add ifm ac14xx boardAnatolij Gustschin
Add new mpc5121e based ac14xx board and a new pinmux config function for setting individual pinmux bit groups. This function is used in ac14xx board code. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-03-09mpc5200: Add a4m2k board portStefan Roese
This patch adds the a4m2k MPC5200B board port. Its a derivate of the a3m071 board with only minor changes. Additionally this patch includes some clean-up changes: - Remove I2C support from a3m071 as its unused - Fix/enhance default env variables - Fix some comments - Add newly introduced CONFIG_SPL_TARGET to automatically build "u-boot-img.bin" - Fix dtb patching in READ desciption for SPL Linux booting: "fdt chosen" needs to get called to patch/create the chosen node. - Add missing call to spl_board_init(): Define CONFIG_SPL_BOARD_INIT so that spl_board_init() will get called in the SPL version. Signed-off-by: Stefan Roese <sr@denx.de>
2013-03-08am335x_evm: Add am335x_evm_usbspl build targetTom Rini
We add USB (RNDIS gadget) SPL support as a separate target. We need to pull out YMODEM support in order to be a small enough target binary. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-04blackfin: bf60x: add board and headers files to support bf609Sonic Zhang
Board and config header files for bf609-ezkit support. Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
2013-02-21Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-02-21Merge 'u-boot-microblaze/mainline/arm' into 'u-boot-arm/master'Albert ARIBAUD
This pulls the three following ZYNQ commits into ARM master: 7dca54f8: xilinx: zynq: Enable DCC and create new zynq_dcc board 59c651f4: arm: zynq: Add SLCR support with system reset 00ed3458: arm: zynq: Add lowlevel initialization to C
2013-02-19ARM: atmel: add at91sam9g20ek_2mmc nand boot supportBo Shen
Add at91sam9g20_2mmc nand boot support. on this board, there is no dataflash, so disable it change one commet for at91sam9g20ek board Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-02-18am335x evm: Add am335x_evm_spiboot targetTom Rini
This target will move the environment into SPI flash and documents the expected layout. We correct the SPL define for where U-Boot is and remove an unused define. Signed-off-by: Tom Rini <trini@ti.com>
2013-02-18OMAP3: igep00x0: Add new IGEP COM PROTON.Enric Balletbo i Serra
The IGEP COM PROTON is a new ultra compact module design with an on-board ethernet controller. Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
2013-02-15powerpc/83xx/km: add support for kmopti2 boardHolger Brunck
This board is similar to TUXX1 but it has a different sized second FPGA. Therefore the configuration for the third chipselect is different. Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2013-02-15powerpc/83xx/km: cleanup tuxx1 supportHolger Brunck
This is a preparation for the upcoming kmopti2 board. This board has also a second fpga on board which is different to the tuxx1 target. But we want to use the same header file. So remove the config option KM_DISABLE_APP2 and simply use the board names to distinguish the features. Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2013-02-14x86: Remove eNET boardsSimon Glass
These are no longer used and should be removed. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Graeme Russ <graeme.russ@gmail.com>
2013-02-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-02-11Tegra114: Add/enable Dalmore build (T114 reference board)Tom Warren
This build is stripped down. It boots to the command prompt. GPIO is the only peripheral supported. Others TBD. Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-07pcm051: Add support for Phytec phyCORE-AM335xLars Poeschel
The board is named pcm051 and has this hardware: SOC: TI AM3359 DDR3-RAM: 2x MT41J256M8HX-15EIT:D 512MiB ETH 1: LAN8710AI SPI-Flash: W25Q64BVSSIG RTC: RV-4162-C7 I2C-EEPROM: CAT32WC32 NAND: MT29F4G08_VFPGA63 PMIC: TPS65910A3 LCD Supported: UART 1 MMC/SD ETH 1 USB I2C SPI Not yet supported: NAND RTC LCD Signed-off-by: Lars Poeschel <poeschel@lemonage.de> [trini: Add #define CONFIG_PHY_ADDR 0 to config] Signed-off-by: Tom Rini <trini@ti.com>
2013-02-07OMAP3: use a single board file for IGEP devicesJavier Martinez Canillas
Even when the IGEPv2 board and the IGEP Computer-on-Module are different from a form factor point of view, they are very similar in the fact that share many components and how they are wired. So, it is possible (and better) to have a single board file for both devices and just use the CONFIG_MACH_TYPE to make a differentiation between each board when needed. This change avoids code duplication by removing 298 lines of code and makes future maintenance easier. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-02-07xilinx: zynq: Enable DCC and create new zynq_dcc boardMichal Simek
Enable DCC driver for arm zynq platform to be compiled. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-02-02Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-01-30powerpc/85xx: Add BSC9132QDS supportPrabhakar Kushwaha
BSC9132QDS is a Freescale reference design board for BSC9132 SoC. BSC9132 SOC is an integrated device that targets the evolving Microcell, Picocell, and Enterprise-Femto base station market subsegments. It combines Power Architecture e500v2 and DSP StarCore SC3850 core technologies with MAPLE-B2F baseband acceleration processing elements. BSC9132QDS Overview -------------------- 2Gbyte DDR3 (on board DDR), Dual Ranki 32Mbyte 16bit NOR flash 128Mbyte 2K page size NAND Flash 256 Kbit M24256 I2C EEPROM 128 Mbit SPI Flash memory SD slot USB-ULPI eTSEC1: Connected to SGMII PHY eTSEC2: Connected to SGMII PHY PCIe CPRI SerDes I2C RTC DUART interface: supports one UARTs up to 115200 bps for console display Apart from the above it also consists various peripherals to support DSP functionalities. This patch adds support for mainly Power side functionalities and peripherals Signed-off-by: Naveen Burmi <NaveenBurmi@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-01-30powerpc/b4860qds: Added Support for B4860QDSYork Sun
B4860QDS is a high-performance computing evaluation, development and test platform supporting the B4860 QorIQ Power Architecture processor. B4860QDS Overview ------------------ - DDRC1: Ten separate DDR3 parts of 16-bit to support 72-bit (ECC) at 1866MT/s, ECC, 4 GB of memory in two ranks of 2 GB. - DDRC2: Five separate DDR3 parts of 16-bit to support 72-bit (ECC) at 1866MT/s, ECC, 2 GB of memory. Single rank. - SerDes 1 multiplexing: Two Vitesse (transmit and receive path) cross-point 16x16 switch VSC3316 - SerDes 2 multiplexing: Two Vitesse (transmit and receive path) cross-point 8x8 switch VSC3308 - USB 2.0 ULPI PHY USB3315 by SMSC supports USB port in host mode. - B4860 UART port is available over USB-to-UART translator USB2SER or over RS232 flat cable. - A Vitesse dual SGMII phy VSC8662 links the B4860 SGMII lines to 2xRJ-45 copper connectors for Stand-alone mode and to the 1000Base-X over AMC MicroTCA connector ports 0 and 2 for AMC mode. - The B4860 configuration may be loaded from nine bits coded reset configuration reset source. The RCW source is set by appropriate DIP-switches: - 16-bit NOR Flash / PROMJet - QIXIS 8-bit NOR Flash Emulator - 8-bit NAND Flash - 24-bit SPI Flash - Long address I2C EEPROM - Available debug interfaces are: - On-board eCWTAP controller with ETH and USB I/F - JTAG/COP 16-pin header for any external TAP controller - External JTAG source over AMC to support B2B configuration - 70-pin Aurora debug connector - QIXIS (FPGA) logic: - 2 KB internal memory space including - IDT840NT4 clock synthesizer provides B4860 essential clocks : SYSCLK, DDRCLK1, 2 and RTCCLK. - Two 8T49N222A SerDes ref clock devices support two SerDes port clocks - total four refclk, including CPRI clock scheme Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Shaveta Leekha <shaveta@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Sandeep Singh <Sandeep@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-01-28mx23evk: Add initial board supportOtavio Salvador
The following features are supported: * 128 MB DDR1 SDRAM * DUART * SD/MMC Card Socket Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-01-21mxs: Add MX23 olinuxino board supportMarek Vasut
This patch adds support for MX23-based Olinuxino board. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2013-01-16Merge remote-tracking branch 'mpc83xx/next'Kim Phillips
2013-01-16Tegra30: Add/enable Cardhu build (T30 reference board)Tom Warren
This build is stripped down. It boots to the command prompt. GPIO is the only peripheral supported. Others TBD. include/configs/tegra-common.h now holds common config options for Tegra SoCs. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-01-12arm: at91sam9x5: add dataflash boot supportBo Shen
Add dataflash boot support on at91sam9x5ek board Signed-off-by: Bo Shen <voice.shen@atmel.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-01-11Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-01-09ARM: lacie_kw: add support for WIRELESS_SPACEAlbert ARIBAUD
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-12-22Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-12-20Merge branch 'master' of git://git.denx.de/u-boot-shTom Rini
2012-12-20sh: add support for sh7752evb boardYoshihiro Shimoda
The R0P7752C00000RZ board has SH7752, 512MB DDR3-SDRAM, SPI ROM, Gigabit Ethernet, and eMMC. This patch supports the following functions: - 512MB DDR3-SDRAM, SCIF4, SPI ROM, Gigabit Ethernet, eMMC Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-12-19powerpc/mpc83xx: convert MPC8313ERDB to new-SPLScott Wood
This converts MPC8313ERDB NAND boot to use the new SPL infrastructure. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
