path: root/boards.cfg
2012-05-15MX53: Add support to ESG ima3 boardStefano Babic
The ESG ima3-mx53 board is based on the Freescale i.MX53 SOC. It boots from NOR (128 MB) and supports Ethernet (FEC), SATA. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-05-15OMAP3: igep00x0: Reduce lines of code for IGEP-based boards.Enric Balletbò i Serra
This is rework on config files of IGEP-based boards with the aim to remove duplicated code to be more maintainable. Basically this patch creates a common configuration file for both boards and only sets the specific option in the board config file. On board files the hardcored mach type was replaced in favour of using the CONFIG_MACH_TYPE option. More than 200 duplicated lines have been deleted. Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com>
2012-05-15kirkwood: add support for Cloud Engines Pogoplug E02David Purdy
This patch adds support for Cloud Engines Pogoplug E02 Information regarding the CE Pogoplug E02 board can be found at: http://archlinuxarm.org/platforms/armv5/pogoplug-v2-pinkgray Signed-off-by: Dave Purdy <david.c.purdy@gmail.com> Cc: prafulla@marvell.com Cc: albert.u.boot@aribaud.net
2012-05-15kirkwood: add NAS62x0 board supportLuka Perkov
Add support for new boards RaidSonic ICY BOX NAS6210 and NAS6220. NAS6210 has 1 SATA and 1 eSATA port while NAS6220 has 2 SATA ports. More information about the boards can be found here: http://www.raidsonic.de/en/products/nas-systems.php?we_objectID=7036 http://www.raidsonic.de/en/products/nas-systems.php?we_objectID=7515 Signed-off-by: Luka Perkov <uboot@lukaperkov.net> Signed-off-by: Gerald Kerma <dreagle@doukki.net> Signed-off-by: Simon Baatz <gmbnomis@gmail.com>
2012-05-15devkit3250: add Timll DevKit3250 board initial supportVladimir Zapolskiy
This change adds a basic support for Embest/Timll DevKit3250 board, NOR and UART are the only supported peripherals for a moment. The board doesn't require low-level init, because the initial SDRAM and GPIO configuration is performed during kickstart bootloader execution. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2012-04-30Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-ppc4xx: powerpc/ppc4xx: Remove typedefs for gdsys FPGA powerpc/ppc4xx: Fix typo in gdsys_fpga.h powerpc/ppc4xx: Update gdsys board configurations powerpc/ppc4xx: Support gdsys dlvision-10g hardware 1.20 powerpc/ppc4xx: Adapt gdsys 405ep boards to platform changes powerpc/ppc4xx: Make gdsys 405ep boards reset more generic powerpc/ppc4xx: Adjust environment size on neo
2012-04-30Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mpc85xx: powerpc/85xx: don't touch MAS7 on e500v1 when relocating CCSR powerpc/85xx: don't display address map size (32-bit vs. 36-bit) during boot cmd_bdinfo: display the address map size (32-bit vs. 36-bit) PowerPC: correct the SATA for p1/p2 rdb-pc platform powerpc/corenet_ds: Slave core in holdoff when boot from SRIO powerpc/corenet_ds: Slave reads ENV from master when boot from SRIO powerpc/corenet_ds: Slave uploads ucode when boot from SRIO powerpc/corenet_ds: Slave module for boot from SRIO powerpc/corenet_ds: Master module for boot from SRIO powerpc/corenet_ds: Document for the boot from SRIO powerpc/corenet_ds: Correct the compilation errors about ENV powerpc/srio: Rewrite the struct ccsr_rio powerpc/85xx:Fix lds for nand boot debug info powerpc/p2041rdb: add env in NAND support powerpc/p2041rdb: add NAND and NAND boot support powerpc/mpc8xxx: Fix CONFIG_DDR_RAW_TIMING for two boards powerpc/85xx:Avoid vector table compilation for nand_spl powerpc/85xx:Fix IVORs addr after vector table relocation powerpc/85xx:Avoid hardcoded vector address for IVORs powerpc/p1023rds: Disable nor flash node and enable nand flash node
2012-04-30powerpc/ppc4xx: Make gdsys 405ep boards reset more genericDirk Eibach
In order to add boards that have different hardware for fpga reset, any 405ep gdsys board now provides these functions: void gd405ep_init(void); void gd405ep_set_fpga_reset(unsigned state); void gd405ep_setup_hw(void); int gd405ep_get_fpga_done(unsigned fpga); Signed-off-by: Dirk Eibach <eibach@gdsys.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-04-24powerpc/corenet_ds: Slave module for boot from SRIOLiu Gang
For the powerpc processors with SRIO interface, boot location can be configured from SRIO1 or SRIO2 by RCW. The processor booting from SRIO can do without flash for u-boot image. The image can be fetched from another processor's memory space by SRIO link connected between them. The processor boots from SRIO is slave, the processor boots from normal flash memory space and can help slave to boot from its memory space is master. They are different environments and requirements: master: 1. NOR flash for its own u-boot image, ucode and ENV space. 2. Slave's u-boot image in master NOR flash. 3. Normally boot from local NOR flash. 4. Configure SRIO switch system if needed. slave: 1. Just has EEPROM for RCW. No flash for u-boot image, ucode and ENV. 2. Boot location should be set to SRIO1 or SRIO2 by RCW. 3. RCW should configure the SerDes, SRIO interfaces correctly. 4. Slave must be powered on after master's boot. 5. Must define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE because of no ucode locally. For the slave module, need to finish these processes: 1. Set the boot location to SRIO1 or SRIO2 by RCW. 2. Set a specific TLB entry for the boot process. 3. Set a LAW entry with the TargetID SRIO1 or SRIO2 for the boot. 4. Slave's u-boot image should be generated specifically by make xxxx_SRIOBOOT_SLAVE_config. This will set SYS_TEXT_BASE=0xFFF80000 and other configurations. Signed-off-by: Liu Gang <Gang.Liu@freescale.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
2012-04-24powerpc/corenet_ds: Master module for boot from SRIOLiu Gang
For the powerpc processors with SRIO interface, boot location can be configured from SRIO1 or SRIO2 by RCW. The processor booting from SRIO can do without flash for u-boot image. The image can be fetched from another processor's memory space by SRIO link connected between them. The processor boots from SRIO is slave, the processor boots from normal flash memory space and can help slave to boot from its memory space is master. They are different environments and requirements: master: 1. NOR flash for its own u-boot image, ucode and ENV space. 2. Slave's u-boot image in master NOR flash. 3. Normally boot from local NOR flash. 4. Configure SRIO switch system if needed. slave: 1. Just has EEPROM for RCW. No flash for u-boot image, ucode and ENV. 2. Boot location should be set to SRIO1 or SRIO2 by RCW. 3. RCW should configure the SerDes, SRIO interfaces correctly. 4. Slave must be powered on after master's boot. For the master module, need to finish these processes: 1. Initialize the SRIO port and address space. 2. Set inbound SRIO windows covered slave's u-boot image stored in master's NOR flash. 3. Master's u-boot image should be generated specifically by make xxxx_SRIOBOOT_MASTER_config 4. Master must boot first, and then slave can be powered on. Signed-off-by: Liu Gang <Gang.Liu@freescale.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
2012-04-24powerpc/p2041rdb: add NAND and NAND boot supportShaohui Xie
New P2041RDB board will add a NAND chip, so add support for NAND and NAND boot. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-04-22board/adp-ag102: add configuration of adp-ag102Macpaul Lin
board: Add config file of board adp-ag102 Add adp-ag102 into boards.cfg Add adp-ag102 into MAINTAINERS doc: add README of ag102 Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2012-04-02MIPS: fix endianess handlingDaniel Schwierzeck
Make endianess of target CPU configurable. Use the new config option for dbau1550_el and pb1000 boards. Adapt linking of standalone applications to pass through endianess options to LD. Build tested with: - ELDK 4 mips_4KC- and mips4KCle - Sourcery CodeBench Lite 2011.03-93 With this patch all 26 MIPS boards can be compiled now in one step by running "MAKEALL -a mips". Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2012-03-29OMAP: Remove omap1610inn-based boardsTom Rini
The CS_AUTOBOOT configurations have been broken for a long time. Kshitij Gupta is no longer at TI making these broken and orphaned boards, so remove. Signed-off-by: Tom Rini <trini@ti.com>
2012-03-26IXP: Move PDNB3 and SCPU from Makefile to boards.cfgMarek Vasut
Signed-off-by: Marek Vasut <marex@denx.de> Cc: Bryan Hundven <bryanhundven@gmail.com> Cc: Michael Schwingen <rincewind@discworld.dascon.de>
2012-02-27dm6467Tevm: Use a common configuration file for davinci_dm6467evm and ↵prabhakar.csengg@gmail.com
davinci_dm6467Tevm In commit 2d575e46859dd9127a9cec731ace77523e6ea2ab a separate header file was introduced for the DM6467T EVM, include/configs/davinci_dm6467Tevm.h. The substantial difference between the davinci_dm6467evm and the davinci_dm6467Tevm configuration is a single bit in the hardware revision that is passed to the Linux kernel and davinci_dm6467evm has REFCLK_FREQ = 27000000 where as davinci_dm6467Tevm.h has a REFCLK_FREQ = 33000000. This patch removes include/configs/davinci_dm6467Tevm.h. Instead the include/configs/davinci_dm6467evm.h configuration is used for DM6467T EVMs and renamed CFG_REFCLK_FREQ to CONFIG_REFCLK_FREQ and CONFIG_REFCLK_FREQ is defined in boards.cfg. Signed-off-by: Prabhakar Lad <prabhakar.csengg@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-02-27da850evm: read mac address from I2C EEPROM on AM18x EVMHadli, Manjunath
add support to read mac address for AM18x EVM manufactured from Spectrum digital which have mac address stored in I2C EEPROM manufactured by WINBOND. This patch reads mac address from I2C EEPROM and sets the environment variable if not set, If mac address is already present in environment compare it with the mac address in EEPROM and warn on mismatch.Introduced a config option CONFIG_MAC_ADDR_IN_EEPROM to where to look for the mac address. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Cc: Tom Rini <trini@ti.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Wolfgang Denk <wd@denx.de>
2012-02-27da850evm: add support to read mac address from SPI flashHadli, Manjunath
add support to read mac address for da850/L138 evm manufactured by Logic PD which store mac address in SPI flash manufactured by ST Microelectronics. This patch adds support to read mac address from SPI flash and set the mac address if it hasn't been set in environment, If it has been set in the environment it compares the value one with SPI flash and warns on mismatch. Introduced a config option CONFIG_MAC_ADDR_IN_SPIFLASH indicating where to look mac address for. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Cc: Tom Rini <trini@ti.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Wolfgang Denk <wd@denx.de>
2012-02-13Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
* 'master' of git://git.denx.de/u-boot-blackfin: Blackfin: pata_bfin: fix printf warning Blackfin: bfin_nand: mark local func static linkage.h: move from blackfin to common includes Blackfin: br4: new board port Blackfin: add in/out le32 variants post: add blackfin to the post_time_ms list Blackfin: bf537-stamp: drop board reset workaround Blackfin: pr1: new board port
2012-02-12Blackfin: br4: new board portDimitar Penev
This adds support for the BR4 Appliance. It is a quad channel ISDN BRI board based on Blackfin BF537 CPU. Signed-off-by: Dimitar Penev <dpn@switchfin.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-02-12Blackfin: pr1: new board portDimitar Penev
This add support for the PR1 Appliance - Asterisk based ISDN PRI PBX. This board is Blackfin BF537 based. The schematics are not fully opened. Signed-off-by: Dimitar Penev <dpn@switchfin.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-02-12arm, davinci: Add support for the Calimain board from OMICRON electronicsChristian Riesch
This patch adds support for the Calimain board from OMICRON electronics GmbH. The board features a Texas Instruments AM1808 SoC, 128 MB DDR2 memory, and 64 MB NOR flash memory connected to CS2 and CS3. Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
2012-02-12Changes to move hawkboard to the new spl infrastructureSughosh Ganu
This patch moves hawkboard to the new spl infrastructure from the older nand_spl one. Removed the hawkboard_nand_config build option -- The spl code now gets compiled with hawkboard_config, after building the main u-boot image, using the CONFIG_SPL_TEXT_BASE. Modified the README.hawkboard to reflect the same. Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com> Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Christian Riesch <christian.riesch@omicron.at> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Tom Rini <trini@ti.com> Acked-by: Christian Riesch <christian.riesch@omicron.at>
2012-02-12mcx: support for HTKW mcx boardIlya Yanok
This patch adds support for the HTKW mcx AM3517-based board. Serial, Ethernet, NAND, MMC, RTC, EHCI USB host and both NAND and MMC SPLs are supported. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tom Rini <tom.rini@gmail.com> Cc: Detlev Zundel <dzu@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-02-12ARM: omap3: Added Teejet mt_ventouxStefano Babic
The mt_ventoux board is a custom board using the Technexion TAM3517 module. The patch fixes also the mtdparts variable in the TAM3517 common configuration file. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Ilya Yanok <yanok@emcraft.com> CC: Igor Grinberg <grinberg@compulab.co.il> CC: Tom Rini <tom.rini@gmail.com> Cc: Detlev Zundel <dzu@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-02-12ARM: Convert spear3xx and spear6xx boards to boards.cfgAmit Virdi
Signed-off-by: Amit Virdi <amit.virdi@st.com> Acked-by: Stefan Roese <sr@denx.de>
2012-02-12EXYNOS: Add SMDK5250 board supportChander Kashyap
SMDK5250 board is based on Samsungs EXYNOS5250 SoC. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-02-12ARMV7: Exynos4: Add support for TRATS boardHeungJun, Kim
This patch adds support for Samsung TRATS board Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-02-12kirkwood: add support for D-Link DNS-325Stefan
This patch adds support for D-Link DNS-325 ShareCenter NAS. Signed-off-by: Stefan Herbrechtsmeier <stefan@code.herbrechtsmeier.net> Cc: prafulla@marvell.com Cc: albert.u.boot@aribaud.net
2012-02-12OMAP3: Add Corscience Tricorder boardThomas Weber
Tricorder is a board which is very similar to the Devkit8000. It is designed as a base platform for further medical devices. www.corscience.de/en/medical-engineering/products/multiparameter/mp10-board.html Signed-off-by: Thomas Weber <weber@corscience.de>
2012-02-12tegra2: Add support for Compal Paz00 (Toshiba AC100)Stephen Warren
The Toshiba AC100 (Compal code-name Paz00, aka Dynabook AZ) is a netbook derived from the NVIDIA Tegra Harmony reference board. It ships with Android, but is often repurposed to run Linux. This patch adds just enough support to get a U-Boot serial console, and the ability access built-in eMMC and the external SD slot. v2: * Rebased on latest HEAD, incorporated changes made to other board files. * Moved board files from board/nvidia to board/compal. * Switched to correct odmdata value. This required add the previous patch to fix U-Boot's interpretation of the odmdata RAM size field. * Removed nvmem= from default Linux kernel command-line; no drivers use the reserved memory yet, so there's no point reserving it. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-01-16ARMV7: Add support For Logic OMAP35x/DM37x modulesPeter Barada
This patch adds basic support for OMAP35x/DM37x SOM LV/Torpedo reference boards. It assumes U-boot is loaded to SDRAM with the help of another small bootloader (x-load) running from SRAM. Signed-off-by: Peter Barada <peter.barada@logicpd.com> Cc: Tom Rini <tom.rini@gmail.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-01-16arm, davinci: Use a common configuration file for da850evm and da850_am18xxevmChristian Riesch
In commit 06194b6b65f701a9d6ef2d9b4123c4afe57d8783 a separate header file was introduced for the AM1808 EVM, include/configs/da850_am18xxevm.h. Before this commit, the da850evm.h configuration file was used for both the AM1808 and the OMAP-L138 EVMs. The only substantial difference between the da850evm and the da850_am18xxevm configuration is a single bit in the hardware revision that is passed to the Linux kernel. This patch removes include/configs/da850_am18xxevm.h. Instead the include/configs/da850evm.h configuration is used for AM18xx EVMs and CONFIG_DA850_AM18X_EVM is defined in boards.cfg. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Tom Rini <trini@ti.com>
2012-01-16i.mx: i.mx6q: add the initial support for i.mx6q Sabre Lite boardJason Liu
Add the initial support for Freescale i.MX6Q Sabre Lite board Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> Signed-off-by: Jason Liu <jason.hui@linaro.org> CC: Eric Nelson <eric.nelson@boundarydevices.com>
2012-01-16mx28evk: Add initial support for MX28EVK boardFabio Estevam
Add initial support for Freescale MX28EVK board. Tested boot via SD card and by loading a kernel via TFTP through the FEC interface. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-01-13openrisc: Add openrisc-generic example boardStefan Kristiansson
Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
2012-01-09powerpc/83xx/km: add support for 8321 based tuge1 boardHolger Brunck
This board is similar to our tuxx1 target. But on this board there is only one application specific chip select configured. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-01-09powerpc/83xx/km: merge tuxa and tuda1 boards to tuxx1Holger Brunck
These boards are from a u-boot point of view identical. So collect the two headerfiles to one, to decrease maintenance. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2011-12-24tegra2: Add Avionic Design Medcom support.Thierry Reding
The Medcom is a 16:9 15" terminal that is used for patient infotainment in hospitals. Changes in v3: * Remove unused implementation of gpio_config_uart(). * Implement MMC/SD card detection. * Drop board_mmc_getcd() which is now implemented by common Tegra2 code. * Add MAINTAINERS entry. Changes in v2: * No longer override the default CONFIG_SYS_TEXT_BASE setting. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra2: Add Avionic Design Plutux support.Thierry Reding
The Plutux is a set-top box device based on the Tamonten processor module. It can be connected to a display via an HDMI output. Changes in v3: * Remove unused implementation of gpio_config_uart(). * Implement MMC/SD card detection. * Drop board_mmc_getcd() which is now implemented by common Tegra2 code. * Add MAINTAINERS entry. Changes in v2: * No longer override the default CONFIG_SYS_TEXT_BASE setting. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24ARM: omap3: add support to Technexion twister boardStefano Babic
The twister board is a development board using the TAM3517 SOM. Support for NAND, 2 Ethernet (EMAC and SMC911), USB (EHCI_OMAP). Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tapani Utrianen <tapani@technexion.com> CC: Tom Rini <tom.rini@gmail.com> CC: Sandeep Paulraj <s-paulraj@ti.com>
2011-12-19x86: Initial commit for running as a coreboot payloadGabe Black
Add a target for running u-boot as a coreboot payload in boards.cfg, a board, CPU and a config. This is a skeleton implementation which always reports the size of memory as 64 MB. Signed-off-by: Gabe Black <gabeblack@chromium.org>
2011-12-12MIPS: remove broken "tb0229" boardWolfgang Denk
The "tb0229" board has long been unmaintained, and is broken. Remove it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-10ARM: convert "omap730p2" boards to boards.cfgWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Dave Peverley <dpeverley@mpc-data.co.uk> Acked-by: Tom Rini <trini@ti.com>
2011-12-10ARM: convert "omap16xx" boards to boards.cfgWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Kshitij Gupta <kshitij@ti.com> Acked-by: Tom Rini <trini@ti.com>
2011-12-10ARM: convert "apollon" board to use boards.cfgWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2011-12-10boards.cfg: sort listWolfgang Denk
2011-12-10Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: M28: Cleanup memsize.o OOT build i.MX28: Move SPL to arch/arm/cpu/arm926ejs/mx28 M28: Fix typo M28: Document that units has to be set to sectors on SD bootcard i.mx: i.mx6q: add the initial support for i.mx6q ARM2 board i.mx: mxc_gpio: add the i.mx6q support i.mx: add the initial support for freescale i.MX6Q processor i.mx: introduce the armv7/imx-common folder S5PC2XX: Rename S5pc2XX to exynos tegra2: Don't use board pointer before it is set up tegra2: Remove unneeded 'dynamic ram size' message tegra2: Remove unused low-level Tegra2 UART code tegra2: Remove unneeded config option tegra2: Remove unneeded boot code tegra2: Enable instruction cache arm: Move CP15 init out of cpu_init_crit() tegra2: Simplify tegra_start() boot path tegra2: Add arch_cpu_init() to fire up Cortex-A9 tegra2: Use new GPIO APIs in gpio_config_uart() tegra2: Add support for Ventana tegra2: Modify MMC driver to handle power and cd GPIOs tegra2: Move board_mmc_init into board files
2011-12-09i.mx: i.mx6q: add the initial support for i.mx6q ARM2 boardJason Liu
Add the initial support for Freescale i.MX6Q Armadillo2 board Support: MMC boot from slot 0/1, debug UART(UART4), usdhc. There is two MMC slots on the boards: mmc dev 0 -> connect USDHC3 -> the lower slot on the board, mmc dev 1 -> connect USDHC4 -> the upper slot on the board, Signed-off-by: Jason Liu <jason.hui@linaro.org> Cc: Stefano Babic <sbabic@denx.de> Tested-by: Dirk Behme <dirk.behme@de.bosch.com>
2011-12-09S5PC2XX: Rename S5pc2XX to exynosChander Kashyap
As per new naming convention for Samsung SoC's, all Cortex-A9 and Cortex-A15 based SoC's will be classified under the name Exynos. Cortex-A9 and Cortex-A15 based SoC's will be sub-classified as Exynos4 and Exynos5 respectively. In order to better adapt and reuse code across various upcoming Samsung Exynos based boards, all uses of s5pc210 prefix/suffix/directory-names are renamed in this patch. s5pc210 is renamed as exynos4210 and S5PC210/s5pc210 suffix/prefix are renamed as exynos4/EXYNOS4. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
