path: root/boards.cfg
2013-01-30powerpc/85xx: Add BSC9132QDS supportPrabhakar Kushwaha
BSC9132QDS is a Freescale reference design board for BSC9132 SoC. BSC9132 SOC is an integrated device that targets the evolving Microcell, Picocell, and Enterprise-Femto base station market subsegments. It combines Power Architecture e500v2 and DSP StarCore SC3850 core technologies with MAPLE-B2F baseband acceleration processing elements. BSC9132QDS Overview -------------------- 2Gbyte DDR3 (on board DDR), Dual Ranki 32Mbyte 16bit NOR flash 128Mbyte 2K page size NAND Flash 256 Kbit M24256 I2C EEPROM 128 Mbit SPI Flash memory SD slot USB-ULPI eTSEC1: Connected to SGMII PHY eTSEC2: Connected to SGMII PHY PCIe CPRI SerDes I2C RTC DUART interface: supports one UARTs up to 115200 bps for console display Apart from the above it also consists various peripherals to support DSP functionalities. This patch adds support for mainly Power side functionalities and peripherals Signed-off-by: Naveen Burmi <NaveenBurmi@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-01-30powerpc/b4860qds: Added Support for B4860QDSYork Sun
B4860QDS is a high-performance computing evaluation, development and test platform supporting the B4860 QorIQ Power Architecture processor. B4860QDS Overview ------------------ - DDRC1: Ten separate DDR3 parts of 16-bit to support 72-bit (ECC) at 1866MT/s, ECC, 4 GB of memory in two ranks of 2 GB. - DDRC2: Five separate DDR3 parts of 16-bit to support 72-bit (ECC) at 1866MT/s, ECC, 2 GB of memory. Single rank. - SerDes 1 multiplexing: Two Vitesse (transmit and receive path) cross-point 16x16 switch VSC3316 - SerDes 2 multiplexing: Two Vitesse (transmit and receive path) cross-point 8x8 switch VSC3308 - USB 2.0 ULPI PHY USB3315 by SMSC supports USB port in host mode. - B4860 UART port is available over USB-to-UART translator USB2SER or over RS232 flat cable. - A Vitesse dual SGMII phy VSC8662 links the B4860 SGMII lines to 2xRJ-45 copper connectors for Stand-alone mode and to the 1000Base-X over AMC MicroTCA connector ports 0 and 2 for AMC mode. - The B4860 configuration may be loaded from nine bits coded reset configuration reset source. The RCW source is set by appropriate DIP-switches: - 16-bit NOR Flash / PROMJet - QIXIS 8-bit NOR Flash Emulator - 8-bit NAND Flash - 24-bit SPI Flash - Long address I2C EEPROM - Available debug interfaces are: - On-board eCWTAP controller with ETH and USB I/F - JTAG/COP 16-pin header for any external TAP controller - External JTAG source over AMC to support B2B configuration - 70-pin Aurora debug connector - QIXIS (FPGA) logic: - 2 KB internal memory space including - IDT840NT4 clock synthesizer provides B4860 essential clocks : SYSCLK, DDRCLK1, 2 and RTCCLK. - Two 8T49N222A SerDes ref clock devices support two SerDes port clocks - total four refclk, including CPRI clock scheme Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Shaveta Leekha <shaveta@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Sandeep Singh <Sandeep@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-01-16Merge remote-tracking branch 'mpc83xx/next'Kim Phillips
2013-01-12arm: at91sam9x5: add dataflash boot supportBo Shen
Add dataflash boot support on at91sam9x5ek board Signed-off-by: Bo Shen <voice.shen@atmel.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-01-11Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-01-09ARM: lacie_kw: add support for WIRELESS_SPACEAlbert ARIBAUD
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-12-22Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-12-20Merge branch 'master' of git://git.denx.de/u-boot-shTom Rini
2012-12-20sh: add support for sh7752evb boardYoshihiro Shimoda
The R0P7752C00000RZ board has SH7752, 512MB DDR3-SDRAM, SPI ROM, Gigabit Ethernet, and eMMC. This patch supports the following functions: - 512MB DDR3-SDRAM, SCIF4, SPI ROM, Gigabit Ethernet, eMMC Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-12-19powerpc/mpc83xx: convert MPC8313ERDB to new-SPLScott Wood
This converts MPC8313ERDB NAND boot to use the new SPL infrastructure. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-12-19coldfire: eb_cpu5282: fix: boot from internal flashJens Scharsig (BuS Elektronik)
* By a sequence of unfavorable conditions in the config header file, the eb_cpu5282 booting from internal stopped after relocation. Blame it is a faulty value of CONFIG_SYS_MONITOR_BASE. This patch fix this by replace the wrong condition in config header with option in board.cfg Signed-off-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
2012-12-10Merge branch 'master' of git://git.denx.de/u-boot into resolveMinkyu Kang
Conflicts: README board/samsung/universal_c210/universal.c drivers/misc/Makefile drivers/power/power_fsl.c include/configs/mx35pdk.h include/configs/mx53loco.h include/configs/seaboard.h
2012-12-06x86: Override calculate_relocation_address to use the e820 mapGabe Black
Because calculate_relocation_address now uses the e820 map, it will be able to avoid addresses over 32 bits and regions that are at high addresses but not big enough for U-Boot. It also means we can remove the hack which limitted U-Boot's idea of the size of memory to less than 4GB. Also take into account the space needed for the heap and stack, so we avoid picking a very small region those areas might overlap with something it shouldn't. Signed-off-by: Gabe Black <gabeblack@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-12-05mpc5200: Add a3m071 board supportStefan Roese
This patch adds support for the a3m071 board based on the MPC5200. Signed-off-by: Stefan Roese <sr@denx.de>
2012-11-28Merge branch 'master' of git://www.denx.de/git/u-boot-mpc85xxTom Rini
2012-11-27powerpc/85xx: add support for the Freescale P5040DS Superhydra reference boardTimur Tabi
The P5040DS reference board (a.k.a "Superhydra") is an enhanced version of P3041DS/P5020DS ("Hydra") reference board. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-11-27mmc: at91sam9x5: support to save environment in mmcWu, Josh
Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-11-14M68K: eb_cpu5282: general update and enhanced board supportJens Scharsig (BuS Elektronik)
- update clock settings for higher perfomance - change standard baud rate to 115200 - fix flash base address - remove unused defines - add I2C support - switch form board dependent flash to cfi - remove board dependent flash code - use sdram bank 0 instead of bank 1 on boot - enable on board frame buffer instead external - remove fake mac address form config - add watchdog support - add status led support Signed-off-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de> [agust: fixed small style issues and build warning] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-11-10Merge git://git.denx.de/u-bootStefano Babic
2012-11-05Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-11-03Merge remote-tracking branch 'u-boot-ti/master'Albert ARIBAUD
2012-10-30eco5pk: Add new board and default configRaphael Assenat
Signed-off-by: Raphael Assenat <raph@8d.com> [trini: Squash boards.cfg / MAINTAINERS change into main patch] Signed-off-by: Tom Rini <trini@ti.com>
2012-10-30New board support: Nokia RX-51 aka N900Pali Rohár
Based on previous work by: Alistair Buxton <a.j.buxton@gmail.com> Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Cc: Ивайло Димитров <freemangordon@abv.bg>
2012-10-29tegra: add Colibri T20 board supportLucas Stach
This adds board support for the Toradex Colibri T20 module. Working functions: - SD card boot - USB boot - Network - NAND environment Signed-off-by: Lucas Stach <dev@lynxeye.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-28PPC: remove dead boards (AMX860, c2mon, ETX094, IAD210, LANTEC, SCM)Wolfgang Denk
These boards have long reached EOL, and there has been no indication of any active users of such hardware for years. Get rid of the dead weight. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Wolfgang Grandegger <wg@denx.de>
2012-10-26MX35: add support for woodburn boardStefano Babic
The woodburn board is based on the MX35 SOC. Support for both external (NOR) and internal (SD Card) boot mode are added. It uses the generic SPL framework to implement the internal boot mode. The following peripherals are supported: - Ethernet (FEC) - SD Card - NAND (512 MB) - NOR Flash In the internal boot mode, a simple imximage header is generated to set the address in internal RAM where the SOC must copy the SPL code. The initial setup is then demanded to the SPL itself. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-10-25am335x_evm: Enable use of UART{1,2,3,4,5}Andrew Bradford
Add targets of am335x_evm_uart{1,2,3,4,5} to have serial input/output on UART{1,2,3,4,5} for use with the Beaglebone RS232 cape, am335x_evm daughterboard, and other custom configurations. Modify target for am335x_evm to include SERIAL1 and CONS_INDEX=1 options in order to clarify UART selection requirements. Signed-off-by: Andrew Bradford <andrew@bradfordembedded.com>
2012-10-24ColdFire: Add Freescale MCF54418TWR ColdFire development board supportAlison Wang
Add Freescale MCF54418TWR ColdFire development board support. Signed-off-by: TsiChung Liew <tsicliew@gmail.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com> Signed-off-by: Alison Wang <b18965@freescale.com>
2012-10-23km83xx: add kmvect1 boardGerlando Falauto
Add support for the new kmvect1 board powered by the mpc8309 processor. As this board is very similar to the existing suvd3, instead of adding a new config header file, just add a new config option to suvd3.h Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-10-22powerpc/t4qds: Add T4QDS boardYork Sun
The T4240QDS is a high-performance computing evaluation, development and test platform supporting the T4240 QorIQ Power Architecture™ processor. SERDES Connections 32 lanes grouped into four 8-lane banks Two “front side” banks dedicated to Ethernet Two “back side” banks dedicated to other protocols DDR Controllers Three independant 64-bit DDR3 controllers Supports rates up to 2133 MHz data-rate Supports two DDR3/DDR3LP UDIMM/RDIMMs per controller QIXIS System Logic FPGA Each DDR controller has two DIMM slots. The first slot of each controller has up to 4 chip selects to support single-, dual- and quad-rank DIMMs. The second slot has only 2 chip selects to support single- and dual-rank DIMMs. At any given time, up to total 4 chip selects can be used. Detail information can be found in doc/README.t4qds Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-19Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Conflicts: drivers/serial/serial_lh7a40x.c Signed-off-by: Tom Rini <trini@ti.com>
2012-10-17powerpc: delete Wind River SBC8560/8540 supportPaul Gortmaker
The sbc8548/60 (both similar, just variations in UART hardware) support has been removed from the linux kernel as of v3.6-rc1~132 so lets also now remove it from the u-boot tree as well. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-10-17Merge branch 'master' of git://git.denx.de/u-boot-mipsTom Rini
2012-10-17mpc82xx: Remove BMW board portStefan Roese
As the board seems to be unmaintained for some time, lets remove the support in mainline completely. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: James F. Dougherty <jfd@broadcom.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2012-10-16MIPS: add board qemu-mips64 supportZhi-zhou Zhang
Both big-endian and little-endian are tested with below commands: Rom version: (Default, Now we config it as rom version) qemu-system-mips64el -M mips -bios u-boot.bin -cpu MIPS64R2-generic -nographic qemu-system-mips64 -M mips -bios u-boot.bin -cpu MIPS64R2-generic -nographic Ram version: qemu-system-mips64el -M mips -cpu MIPS64R2-generic -kernel u-boot -nographic qemu-system-mips64 -M mips -cpu MIPS64R2-generic -kernel u-boot -nographic Signed-off-by: Zhizhou Zhang <etou.zh@gmail.com> Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2012-10-16h2200: Add support for iPAQ h2200 palmtopŁukasz Dałek
Add basic support for HP iPAQ h2200 palmtop. h2200 palmtop was targeted to general consumers. It has 64 MB of RAM, 32 MB flash. No intergrated Wi-Fi nor Ethernet. Based on Intel PXA255 processor. It was shipped with Windows CE 4.2 operating system. Signed-off-by: Lukasz Dalek <luk0104@gmail.com>
2012-10-15mx6q: Add basic support for mx6qsabreautoFabio Estevam
mx6qsabreauto is a board based on mx6q SoC with the following features: - 2GB of DDR3 - 2 USB ports - 1 HDMI output port - SPI NOR - 2 LVDS LCD ports - Gigabit Ethernet - Camera - eMMC and SD card slot - Multichannel Audio - CAN - SATA - NAND - PCIE - Video Input Add very basic support for it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-15mx6: Add basic support for mx6qsabresd board.Fabio Estevam
mx6qsabresd is a board based on mx6q SoC with the following features: - 1GB of DDR3 - 1 USB OTG port - 1 HDMI output port - SPI NOR - LVDS panel - Gigabit Ethernet - Camera Connector - eMMC and SD card slot - Audio Add very basic support for it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-15mx6q: Factor out common DDR3 init codeFabio Estevam
Factor out common DDR3 initialization code, allowing easier maintainance of such scripts. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-15tegra: Rename Medcom to Medcom-WideThierry Reding
Medcom is the marketing name for an older, PXA-based version of the same device. In order to avoid confusion, rename the Tegra-based version to the new marketing name. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15ppc4xx: Remove AP1000 board supportStefan Roese
As the board seems to be unmaintained for some time, lets remove the support in mainline completely. Signed-off-by: Stefan Roese <sr@denx.de> Cc: James MacAulay <james.macaulay@amirix.com> Acked-by: Marek Vasut <marex@denx.de>
2012-10-15ppc4xx: Remove ML2 board supportStefan Roese
As the board seems to be unmaintained for some time, lets remove the support in mainline completely. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Peter De Schrijver <p2@mind.be> Acked-by: Marek Vasut <marex@denx.de>
2012-10-15ppc4xx: Remove IOP480 supportStefan Roese
Since the IOP480 (PPC401/3 variant from PLX) is only used on 2 boards that are not actively maintained, lets remove support for it completely. This way the ppc4xx code will get a bit cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu> Acked-by: Marek Vasut <marex@denx.de>
2012-10-15gth2: Remove this platformTom Rini
After taking with the former maintainer, delete this platform. The patch is from the former maintainer. Signed-off-by: Tom Rini <trini@ti.com>
2012-10-05MPC85xx: remove support for TQM85xx boardsWolfgang Denk
Due to grown code sizes the TQM85xx boards don't build any more with some older tool chains (like ELDK 4.2). As these boards have long reached EOL it seems a waste of effort trying to fix them. The vendor has agreed to drop support for them, too. So let's get rid of them. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> cc: Kim Phillips <kim.phillips@freescale.com> Acked-by: Stefan Roese <sr@denx.de>
2012-10-04ARM: Add Altera SOCFPGA Cyclone5Dinh Nguyen
Add minimal support for Altera's SOCFPGA Cyclone 5 hardware. Signed-off-by: Dinh Nguyen <dinguyen@altera.com> Signed-off-by: Chin Liang See <clsee@altera.com> Signed-off-by: Pavel Machek <pavel@denx.de> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Tom Trini <trini@ti.com> Cc: Wolfgang Denx <wd@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Stefan Roese <sr@denx.de> ---- v8: Remove no_return attribute for reset_cpu Based on v2012.10-rc2
2012-10-04xilinx: Add new Zynq boardMichal Simek
Add support for Xilinx Zynq board. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Marek Vasut <marex@denx.de> CC: Joe Hershberger <joe.hershberger@gmail.com>
2012-10-04ARM: Add X600 board support (SPEAr600 based)Stefan Roese
This patch adds support for the X600 SPEAr600 based board. Its also the first SPEAr600 board that uses the newly introduced SPEAr600 SPL support. Xloader is not necessary any more. By using the new "u-boot.spr" make target, one image will generated containing both, U-Boot SPL (with mkimage header as needed by the SPEAr BootROM, and the main U-Boot with mkimage header. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Amit Virdi <amit.virdi@st.com> Cc: Vipin Kumar <vipin.kumar@st.com>
2012-10-03Merge remote-tracking branch 'u-boot-marvell/master'Albert ARIBAUD
2012-10-03kirkwood: add support for Iomega iConnect boardLuka Perkov
Add support for new board iConnect from Iomega. More information about the device can be found here: http://go.iomega.com/en/products/network-storage-desktop/wireless-data-station/network-hard-drive-iconnect/?partner=4735 Signed-off-by: Luka Perkov <uboot@lukaperkov.net> Tested-by: Wojciech Dubowik <wojciech.dubowik@neratec.com> Tested-by: Tim Fletcher <tim@night-shade.org.uk>
