This adds a first support of the FPGA download for a PCIe FPGA based
on the BOCO2 CPLD.
This takes place in 3 steps, all done accessing the SPICTRL reg of the
BOCO2:
1) start the FPGA config with an access to the FPGA_PROG bit
2) later in the boot sequence, wait for the FPGA_DONE bit to toggle to 1
for the end of the FPGA configuration (with a timeout)
3) reset the FPGA
4) finally remove the access to its config EEPROM from the FPGA so that
the CPU can update the FPGA configuration when the kernel is running
The boards with a PCIe FPGA but without BOCO2 still are supported.
The config option name is CONFIG_KM_FPGA_CONFIG
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
cc: Gerlando Falauto <gerlando.falauto@keymile.com>
cc: Prafulla Wadaskar <prafulla@marvell.com>
The additional headerfile is unneeded here, we can use the generic
km_kirkwood.h instead. And we can use the better config option
KM_PIGGY4_88E6061 for the specific features for boards with this
design in km_arm.c.
Use the generic header km_kirkwood.h and get rid of the
board specific header.
changes for v2: rebased because of changes in other patches
For u-boot this board is similar to mgcoge3un. But some differences
are present. We have a different SDRAM on it and therefore a new
SDRAM config file. Additionaly this board has a direct MAC/MAC
connection from the kirkwood to a marvell simple switch without a
phy inbetween, this needs a new configuration for the mvgbe driver.
This board is similar to portl2, but it has the u-boot environment
in a SPI NOR flash and not in an i2c eeprom like portl2 have.
Some other details:
- IVM EEPROM is at adress: pca9547:70:9
- PCI is enabled
- PIGGY4 is connected via MV88E6352 simple switch. There is no phy
between the simple switch and the kirkwood.
Cc: Prafulla Wadaskar <prafulla@marvell.com>
This patch adds support for both the Linkstation Live (LS-CHLv2) and
Linkstation Pro (LS-XHL) by Buffalo.
Signed-off-by: Michael Walle <michael@walle.cc>
Some other kirkwood boards from keymile will follow. They will have some
small differences, but we want to use the km_kirkwood.h for all to
distinguish them. This patch a preparation for this.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Whistler is a highly configurable Tegra evaluation and development board.
This change adds support for the following specific configuration:
E1120 motherboard
E1108 CPU board
E1116 PMU board
The motherboard configuration switches are set as follows:
SW1=0 SW2=0 SW3=5
S1/S2/S3/S4 all on, except S3 7/8 are off.
Other combinations of daugher boards may work to varying degrees, but will
likely require some SW adjustment.
This board is a MPC8360 board. Two flashes are present
a NOR flash were u-boot and the u-boot environment is stored
and a NAND flash for the application code. This board has 512MB
SDRAM.
Additionaly we introduce a common km8360.h file and convert kmeter1 to
use this.
Signed-off-by: Christian Herzig <christian.herzig@keymile.com>
cc: Kim Phillips <kim.phillips@freescale.com>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Heiko Schocher <hs@denx.de>
This additional header is unneeded, we can use the tuxx1.h for this
target.
This is an sh2a device (max 266MHz) with FPU, video display
controller (VDC), 8 serial ports, 4 I2C channels, 3 CAN ports,
SD and on-chip USB.
The RSK2+SH7269 board uses the SH7269 processor. It is often
referred to as just rsk7269.
Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com>
The AP-SH4A-4A board has SH7734, 64MB DDR2-SDRAM, USB,
Ethernet, and more.
This patch supports the following functions:
- 64MB DDR2-SDRAM
- 16MB NOR Flash memory
- Serial console (SCIF)
- Ethernet (SH-Ether with Gigabit)
- I2C
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
The r0p7734 board has SH7734, 128MB DDR2-SDRAM, USB,
Ethernet, and more.
- 128MB DDR2-SDRAM
- 32MB NOR Flash memory
- Ethernet (SH-Ether/SMSC)
The ESG ima3-mx53 board is based on the Freescale
i.MX53 SOC. It boots from NOR (128 MB) and
supports Ethernet (FEC), SATA.
This is rework on config files of IGEP-based boards with the aim to remove
duplicated code to be more maintainable. Basically this patch creates a
common configuration file for both boards and only sets the specific option
in the board config file.
On board files the hardcored mach type was replaced in favour of using the
CONFIG_MACH_TYPE option.
More than 200 duplicated lines have been deleted.
Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com>
This patch adds support for Cloud Engines Pogoplug E02
Information regarding the CE Pogoplug E02 board can be found at:
http://archlinuxarm.org/platforms/armv5/pogoplug-v2-pinkgray
Signed-off-by: Dave Purdy <david.c.purdy@gmail.com>
Cc: prafulla@marvell.com
Cc: albert.u.boot@aribaud.net
Add support for new boards RaidSonic ICY BOX NAS6210 and NAS6220.
NAS6210 has 1 SATA and 1 eSATA port while NAS6220 has 2 SATA ports.
More information about the boards can be found here:
http://www.raidsonic.de/en/products/nas-systems.php?we_objectID=7036
http://www.raidsonic.de/en/products/nas-systems.php?we_objectID=7515
Signed-off-by: Luka Perkov <uboot@lukaperkov.net>
Signed-off-by: Gerald Kerma <dreagle@doukki.net>
Signed-off-by: Simon Baatz <gmbnomis@gmail.com>
This change adds a basic support for Embest/Timll DevKit3250 board,
NOR and UART are the only supported peripherals for a moment. The board
doesn't require low-level init, because the initial SDRAM and GPIO
configuration is performed during kickstart bootloader execution.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
* 'master' of git://git.denx.de/u-boot-ppc4xx:
powerpc/ppc4xx: Remove typedefs for gdsys FPGA
powerpc/ppc4xx: Fix typo in gdsys_fpga.h
powerpc/ppc4xx: Update gdsys board configurations
powerpc/ppc4xx: Support gdsys dlvision-10g hardware 1.20
powerpc/ppc4xx: Adapt gdsys 405ep boards to platform changes
powerpc/ppc4xx: Make gdsys 405ep boards reset more generic
powerpc/ppc4xx: Adjust environment size on neo
* 'master' of git://git.denx.de/u-boot-mpc85xx:
powerpc/85xx: don't touch MAS7 on e500v1 when relocating CCSR
powerpc/85xx: don't display address map size (32-bit vs. 36-bit) during boot
cmd_bdinfo: display the address map size (32-bit vs. 36-bit)
PowerPC: correct the SATA for p1/p2 rdb-pc platform
powerpc/corenet_ds: Slave core in holdoff when boot from SRIO
powerpc/corenet_ds: Slave reads ENV from master when boot from SRIO
powerpc/corenet_ds: Slave uploads ucode when boot from SRIO
powerpc/corenet_ds: Slave module for boot from SRIO
powerpc/corenet_ds: Master module for boot from SRIO
powerpc/corenet_ds: Document for the boot from SRIO
powerpc/corenet_ds: Correct the compilation errors about ENV
powerpc/srio: Rewrite the struct ccsr_rio
powerpc/85xx:Fix lds for nand boot debug info
powerpc/p2041rdb: add env in NAND support
powerpc/p2041rdb: add NAND and NAND boot support
powerpc/mpc8xxx: Fix CONFIG_DDR_RAW_TIMING for two boards
powerpc/85xx:Avoid vector table compilation for nand_spl
powerpc/85xx:Fix IVORs addr after vector table relocation
powerpc/85xx:Avoid hardcoded vector address for IVORs
powerpc/p1023rds: Disable nor flash node and enable nand flash node
In order to add boards that have different hardware for fpga reset,
any 405ep gdsys board now provides these functions:
void gd405ep_init(void);
void gd405ep_set_fpga_reset(unsigned state);
void gd405ep_setup_hw(void);
int gd405ep_get_fpga_done(unsigned fpga);
Signed-off-by: Dirk Eibach <eibach@gdsys.de>
Cc: Stefan Roese <sr@denx.de>
For the powerpc processors with SRIO interface, boot location can be configured
from SRIO1 or SRIO2 by RCW. The processor booting from SRIO can do without flash
for u-boot image. The image can be fetched from another processor's memory
space by SRIO link connected between them.
The processor boots from SRIO is slave, the processor boots from normal flash
memory space and can help slave to boot from its memory space is master.
They are different environments and requirements:
master:
1. NOR flash for its own u-boot image, ucode and ENV space.
2. Slave's u-boot image in master NOR flash.
3. Normally boot from local NOR flash.
4. Configure SRIO switch system if needed.
slave:
1. Just has EEPROM for RCW. No flash for u-boot image, ucode and ENV.
2. Boot location should be set to SRIO1 or SRIO2 by RCW.
3. RCW should configure the SerDes, SRIO interfaces correctly.
4. Slave must be powered on after master's boot.
5. Must define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE because of no ucode
locally.
For the slave module, need to finish these processes:
1. Set the boot location to SRIO1 or SRIO2 by RCW.
2. Set a specific TLB entry for the boot process.
3. Set a LAW entry with the TargetID SRIO1 or SRIO2 for the boot.
4. Slave's u-boot image should be generated specifically by
make xxxx_SRIOBOOT_SLAVE_config.
This will set SYS_TEXT_BASE=0xFFF80000 and other configurations.
Signed-off-by: Liu Gang <Gang.Liu@freescale.com>
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
master:
slave:
For the master module, need to finish these processes:
1. Initialize the SRIO port and address space.
2. Set inbound SRIO windows covered slave's u-boot image stored in
master's NOR flash.
3. Master's u-boot image should be generated specifically by
make xxxx_SRIOBOOT_MASTER_config
4. Master must boot first, and then slave can be powered on.
New P2041RDB board will add a NAND chip, so add support for NAND and
NAND boot.
Signed-off-by: Andy Fleming <afleming@freescale.com>
board:
Add config file of board adp-ag102
Add adp-ag102 into boards.cfg
Add adp-ag102 into MAINTAINERS
doc:
add README of ag102
Signed-off-by: Macpaul Lin <macpaul@andestech.com>
Make endianess of target CPU configurable. Use the new config
option for dbau1550_el and pb1000 boards.
Adapt linking of standalone applications to pass through
endianess options to LD.
Build tested with:
- ELDK 4 mips_4KC- and mips4KCle
- Sourcery CodeBench Lite 2011.03-93
With this patch all 26 MIPS boards can be compiled now in one step by
running "MAKEALL -a mips".
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
The CS_AUTOBOOT configurations have been broken for a long time.
Kshitij Gupta is no longer at TI making these broken and orphaned
boards, so remove.
Cc: Bryan Hundven <bryanhundven@gmail.com>
Cc: Michael Schwingen <rincewind@discworld.dascon.de>
davinci_dm6467Tevm
In commit 2d575e46859dd9127a9cec731ace77523e6ea2ab a separate header
file was introduced for the DM6467T EVM, include/configs/davinci_dm6467Tevm.h.
The substantial difference between the davinci_dm6467evm and the
davinci_dm6467Tevm configuration is a single bit in the hardware revision
that is passed to the Linux kernel and davinci_dm6467evm has
REFCLK_FREQ = 27000000 where as davinci_dm6467Tevm.h has a
REFCLK_FREQ = 33000000.
This patch removes include/configs/davinci_dm6467Tevm.h. Instead the
include/configs/davinci_dm6467evm.h configuration is used for DM6467T EVMs and
renamed CFG_REFCLK_FREQ to CONFIG_REFCLK_FREQ and CONFIG_REFCLK_FREQ is defined
in boards.cfg.
Signed-off-by: Prabhakar Lad <prabhakar.csengg@gmail.com>
Cc: Tom Rini <trini@ti.com>
add support to read mac address for AM18x EVM manufactured from
Spectrum digital which have mac address stored in I2C EEPROM manufactured
by WINBOND. This patch reads mac address from I2C EEPROM and sets the
environment variable if not set, If mac address is already present in
environment compare it with the mac address in EEPROM and warn on
mismatch.Introduced a config option CONFIG_MAC_ADDR_IN_EEPROM to where
to look for the mac address.
Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com>
Cc: Mike Frysinger <vapier@gentoo.org>
add support to read mac address for da850/L138 evm manufactured by
Logic PD which store mac address in SPI flash manufactured by ST
Microelectronics. This patch adds support to read mac address from
SPI flash and set the mac address if it hasn't been set in environment,
If it has been set in the environment it compares the value one with
SPI flash and warns on mismatch. Introduced a config option
CONFIG_MAC_ADDR_IN_SPIFLASH indicating where to look mac address for.
* 'master' of git://git.denx.de/u-boot-blackfin:
Blackfin: pata_bfin: fix printf warning
Blackfin: bfin_nand: mark local func static
linkage.h: move from blackfin to common includes
Blackfin: br4: new board port
Blackfin: add in/out le32 variants
post: add blackfin to the post_time_ms list
Blackfin: bf537-stamp: drop board reset workaround
Blackfin: pr1: new board port
This adds support for the BR4 Appliance. It is a quad channel ISDN BRI
board based on Blackfin BF537 CPU.
Signed-off-by: Dimitar Penev <dpn@switchfin.org>
This add support for the PR1 Appliance - Asterisk based ISDN PRI PBX.
This board is Blackfin BF537 based. The schematics are not fully opened.
This patch adds support for the Calimain board from
OMICRON electronics GmbH. The board features a Texas Instruments AM1808
SoC, 128 MB DDR2 memory, and 64 MB NOR flash memory connected to CS2 and
CS3.
Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
This patch moves hawkboard to the new spl infrastructure from the
older nand_spl one.
Removed the hawkboard_nand_config build option -- The spl code now
gets compiled with hawkboard_config, after building the main u-boot
image, using the CONFIG_SPL_TEXT_BASE. Modified the README.hawkboard
to reflect the same.
Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com>
Cc: Christian Riesch <christian.riesch@omicron.at>
Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Acked-by: Christian Riesch <christian.riesch@omicron.at>
This patch adds support for the HTKW mcx AM3517-based board.
Serial, Ethernet, NAND, MMC, RTC, EHCI USB host and both
NAND and MMC SPLs are supported.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
CC: Tom Rini <tom.rini@gmail.com>
Cc: Detlev Zundel <dzu@denx.de>
The mt_ventoux board is a custom board using
the Technexion TAM3517 module.
The patch fixes also the mtdparts variable in the
TAM3517 common configuration file.
CC: Ilya Yanok <yanok@emcraft.com>
CC: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Amit Virdi <amit.virdi@st.com>
SMDK5250 board is based on Samsungs EXYNOS5250 SoC.
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
This patch adds support for Samsung TRATS board
Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com>
This patch adds support for D-Link DNS-325 ShareCenter NAS.
Signed-off-by: Stefan Herbrechtsmeier <stefan@code.herbrechtsmeier.net>
Tricorder is a board which is very similar to the Devkit8000. It
is designed as a base platform for further medical devices.
www.corscience.de/en/medical-engineering/products/multiparameter/mp10-board.html
Signed-off-by: Thomas Weber <weber@corscience.de>
The Toshiba AC100 (Compal code-name Paz00, aka Dynabook AZ) is a netbook
derived from the NVIDIA Tegra Harmony reference board. It ships with
Android, but is often repurposed to run Linux. This patch adds just enough
support to get a U-Boot serial console, and the ability access built-in
eMMC and the external SD slot.
v2:
* Rebased on latest HEAD, incorporated changes made to other board files.
* Moved board files from board/nvidia to board/compal.
* Switched to correct odmdata value. This required add the previous patch
to fix U-Boot's interpretation of the odmdata RAM size field.
* Removed nvmem= from default Linux kernel command-line; no drivers use the
reserved memory yet, so there's no point reserving it.
This patch adds basic support for OMAP35x/DM37x SOM LV/Torpedo
reference boards. It assumes U-boot is loaded to SDRAM with the
help of another small bootloader (x-load) running from SRAM.
Signed-off-by: Peter Barada <peter.barada@logicpd.com>
Cc: Tom Rini <tom.rini@gmail.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
In commit 06194b6b65f701a9d6ef2d9b4123c4afe57d8783 a separate header
file was introduced for the AM1808 EVM, include/configs/da850_am18xxevm.h.
Before this commit, the da850evm.h configuration file was used for both
the AM1808 and the OMAP-L138 EVMs. The only substantial difference
between the da850evm and the da850_am18xxevm configuration is a single
bit in the hardware revision that is passed to the Linux kernel.
This patch removes include/configs/da850_am18xxevm.h. Instead the
include/configs/da850evm.h configuration is used for AM18xx EVMs and
CONFIG_DA850_AM18X_EVM is defined in boards.cfg.
Add the initial support for Freescale i.MX6Q Sabre Lite board
Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com>
Signed-off-by: Jason Liu <jason.hui@linaro.org>
CC: Eric Nelson <eric.nelson@boundarydevices.com>
Add initial support for Freescale MX28EVK board.
Tested boot via SD card and by loading a kernel via TFTP through
the FEC interface.
