path: root/boards.cfg
2011-04-10Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2011-04-10powerpc/85xx: Add PBL boot from SPI flash support on P4080DSShaohui Xie
PBL(pre-boot loader): SPI flash used as RCW(Reset Configuration Word) and PBI(pre-boot initialization) source, CPC(CoreNet Platform Cache) used as 1M SRAM where PBL will copy whole U-BOOT image to, U-boot can boot from CPC after PBL completes RCW and PBI phases. Signed-off-by: Chunhe Lan <b25806@freescale.com> Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Shaohui Xie <b21989@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-08Blackfin: bf506f-ezkit: new board portMike Frysinger
2011-04-08Blackfin: bf525-ucr2: new board portChong Huang
Signed-off-by: Chong Huang <chuang@ucrobotics.com> Signed-off-by: Haitao Zhang <minipanda@linuxrobot.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: dnp5370: new board portAndreas Schallenberg
Info about the hardware can be found here: http://www.dilnetpc.com/dnp0086.htm Signed-off-by: Andreas Schallenberg <Andreas.Schallenberg@3alitydigital.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-05Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
Conflicts: drivers/usb/host/ehci-pci.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-04-04powerpc/85xx: Enable eSDHC boot support on P2020 DSJerry Huang
We implement our own mmc_get_env_addr since the environment variables are written to just after the u-boot image on SDCard, so we must read the MBR to get the start address and code length of the u-boot image, then calculate the address of the env. Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Zhao Chenhui <b35336@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/85xx: Add 36-bit address map support to P1022DSJiang Yutang
Signed-off-by: Jiang Yutang <b14898@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/85xx: Add 36-bit physical addressing support for P1_P2_RDBPoonam Aggrwal
Add support for 36-bit address map for NOR, SD, and SPI boot cfgs. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Priyanka Jain <priyanka.jain@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-02MIPS: Au1x00: Move all Au1x00 specific code to separate subdirectoryDaniel Schwierzeck
Au1x00 is a SoC and its specific code should reside in an own SoC subdirectory. Also add -mtune=4kc flag for CPU optimization. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Thomas Lange <thomas@corelatus.se> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-04-02MIPS: IncaIP: Move all IncaIP specific code to separate subdirectoryDaniel Schwierzeck
IncaIP is a SoC and its specific code should reside in an own SoC subdirectory. Also add -mtune=4kc flag for CPU optimization. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-04-02MIPS: Move content of arch/mips/cpu to arch/mips/cpu/mips32Daniel Schwierzeck
All current CPUs and SoCs are based on MIPS32 arch. The complete code resides in the global arch/mips/cpu directory. This is not suitable if other MIPS architectures like MIPS64 or Octeon should be supported in the future. To achieve this the current CPU code is moved to its own mips32 subdirectory. All MIPS32 boards have to use mips32 as config switch in board.cfg. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Thomas Lange <thomas@corelatus.se> Cc: Vlad Lungu <vlad.lungu@windriver.com> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-04-02MIPS: Purple: Remove Purple supportDaniel Schwierzeck
The Purple SoC and eval board are not actively maintained since years. This patch removes the support completely as aggreed with Wolfgang Denk. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-02-21Pantheon: Add Board Support for Marvell dkb boardLei Wen
DKB is a Development Board for PANTHEON TD/TTC(pxa920/pxa910) with * Processor upto 806Mhz * LPDDR1/2 * x8/x16 SLC/MLC NAND * Footprints for eMMC & MMC x8 card With Peripherals: * Parallel LCD I/F * Audio codecs (88PM8607) * MIPI CSI-2 camera * Marvell 88W8787 802.11n/BT module * Marvell 2G/3G RF * Dual analog mics & speakers, headset jack, LED, ambient * USB2.0 HS host, OTG (mini AB) * GPIO, GPIO expander with DIP switches for easier selection * UART serial over USB, CIR This patch adds basic board support with DRAM and UART functionality Signed-off-by: Lei Wen <leiwen@marvell.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2011-02-21arm: Tegra2: Add support for NVIDIA Seaboard boardTom Warren
Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-02-21arm: Tegra2: Add support for NVIDIA Harmony boardTom Warren
2011-02-12Merge branch 'master' of git://git.denx.de/u-boot-mipsWolfgang Denk
2011-02-12eNET: Create distinct board configurationsGraeme Russ
Position independant functionality is due for removal from the x86 architecture, so create two distinct configurations - One for Flash and one for SRAM
2011-02-09powerpc/85xx: Fix p1_p2_rdb boards.cfgKumar Gala
We should have been defining the actual board name in the options, not the processor. Fix this for P1011RDB, P1020RDB, P2010RDB, and P2020RDB. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-02-09Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2011-02-07MIPS: Move VCT boards to boards.cfgShinya Kuribayashi
Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com> Acked-by: Stefan Roese <sr@denx.de>
2011-02-07ppc4xx: Add DLVision-10G board supportDirk Eibach
Board support for the Guntermann & Drunck DLVision-10G. Adds support for multiple FPGAs per board for gdsys 405ep architecture. Adds support for dual link osd hardware for gdsys 405ep. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2011-02-05MIPS: Move Inca-IP targets to boards.cfgShinya Kuribayashi
At the same time, fix up CPU_CLOCK_RATE to have the CONFIG_ prefix to work with boards.cfg. Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-02-05MIPS: Move Qemu MIPS target to boards.cfgShinya Kuribayashi
CONFIG_QEMU_MIPS is already provided by <configs/qemu-mips.h>, so we don't generate it using the options fields in boards.cfg. Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-02-05MIPS: Move Alchemy Au1x00 based boards to boards.cfgShinya Kuribayashi
CONFIG_GTH2 is already provided by <configs/gth2.h>, so we don't generate it using the options fields in boards.cfg. Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-02-04Merge branch 'master' of git://git.denx.de/u-boot-shWolfgang Denk
2011-02-02sh: add support for sh7757lcr boardYoshihiro Shimoda
The R0P7757LC0030RL board has SH7757, 256MB DDR3-SDRAM, SPI ROM, Ethernet, and more. This patch supports the following functions: - 256MB DDR3-SDRAM - SPI ROM - Ethernet Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-02-02armv7: add support for s5pc210 universal boardMinkyu Kang
This patch adds support for Samsung s5pc210 universal board Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2011-02-02OMAP3: add CM-T35 boardMike Rapoport
This patch adds support for CM-T35 board Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-02-02Add support for Freescale's mx35pdk board.Stefano Babic
The patch adds suupport for the Freescale's mx35pdk board (known as well as mx35_3stack). The board boots from the NOR flash. Following devices are supported: - two ethernet devices (FEC and SMC911x on debug board) - I2C - PMIC (MC13892) via I2C interface - UART - NOR flash (64MB) - NAND flash (2GB) - basic access to mc9sdz60 registers via I2C interface Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-02-02iMX5: EfikaMX: Preliminary board supportMarek Vasut
Supported: MMC IDE PMIC SPI flash LEDs I can boot the kernel supplied by freescale/genesi with this from MMC card and/or PATA disk. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2011-02-02MX5:MX53: add initial support for MX53EVK boardLiu Hui-R64343
Add initial support for MX53EVK board support. FEC, SD/MMC, UART, I2C, have been supported. Signed-off-by: Jason Liu <r64343@freescale.com>
2011-01-26mpq101: initial support for Mercury Computer Systems MPQ101 boardAlex Dubov
Mpq101 is a RapidIO development board in AMC form factor, featuring MPC8548 processor, 512MB of hardwired DDR2 RAM, 128MB of hardwired NAND flash memory, real time clock and additional serial EEPROM on i2c bus (enabled). USB controller is available, but not presently enabled. Additional board information is available at: http://www.mc.com/products/boards/ensemble_mpq101_rapidio_powerquicc_iii.aspx Environment is configured to precede the actual u-boot image so that it's located at the beginning of flash erase block (made necessary by the recent changes to the embedded environment handling). This is achieved by means of custom ld script. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-19sh: Fix MigoR of boards.cfgNobuhiro Iwamatsu
There is not break character between board name and CPU. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-01-18mpc5200, digsy_mtc: add support for rev5 board versionHeiko Schocher
difference to previous board version: - M29W128GH flash from Numonyx - SDRAM ISSI IS45S16800 (Option A2 105°C) - rev5 uses RTC RV-3029-C2 - update cs0 and cs1 baseaddr and length depending on the detected flash size. - added Werner Pfister <Pfister_Werner@intercontrol.de> as maintainer for the digsy board variants - As the M29W128GH needs a special flash_cmd_reset() document that in the new file doc/README.cfi. - move "#endif /* CONFIG_CMD_IDE */" to the right place - remove LOWBOOT config option for digsy_mtc and digsy_mtc_rev5 boards - change doc/README.cfi as Stefan Roese suggested Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de> cc: Wolfgang Denk <hs@denx.de> cc: Stefan Roese <sr@denx.de> cc: Werner Pfister <Pfister_Werner@intercontrol.de> cc: Detlev Zundel <dzu@denx.de>
2011-01-18ppc, 8xx: remove obsolete km8xx boards from keymileHolger Brunck
The MPC852 based mgsuvd and kmsupx4 boards from keymile were initially ported but later on not developed further. So the respective files were removed to avoid unneeded merging and maintenance. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Heiko Schocher<hs@denx.de>
2011-01-14powerpc/85xx: Add support for booting from NAND on MPC8572DSKumar Gala
Mimic support that exists on MPC8536DS on the MPC8572DS to allow booting from NAND. Signed-off-by: Jin Qing <b24347@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/85xx: Remove support for PM854/PM856 boardsKumar Gala
The PM854/PM856 boards are no longer maintained and thus we are removing support for them. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Wolfgang Denk <wd@denx.de>
2011-01-14powerpc/85xx: Removed support for MPC8540EVAL boardKumar Gala
The MPC8540EVAL board is no longer maintained and thus we are removing support for it. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/85xx: Removed support for ATUM8548 boardKumar Gala
The ATUM8548 board is no longer maintained and thus we are removing support for it. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-11sh: Add support shmin boardNobuhiro Iwamatsu
This adds support for the SHMIN SH7706 board(T-SH7706LAN). The CPU of this board is SH7706. There are SDRAM of 32M byte, Flash memory of 512K byte, Serial, 10Base Ether and MMC. http://web.kyoto-inet.or.jp/people/takagaki/T-SH7706/T-SH7706.htm Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2010-12-17xilinx-ppc4xx-generic: Use common u-boot.ldsRicardo Ribalda Delgado
Use common ppc4xx linker script for xilinx ppc440 and ppc405 related boards. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2010-12-16Armada100: Add Board Support for Marvell Aspenite-DBPrafulla Wadaskar
Aspenite is a Development Board for ASPEN/ARMADA168(88AP168) with * Processor upto 1.2GHz * Parallel 1Gb x8 DDR2-1066 MHz * 16 Mb x16 NOR, 4Gb x8 SLC NAND, footprint for SPI NOR * Footprints for eMMC/eSD NAND & MMC x8 card * 4-in-1 card reader (xD, MMC/SD/MS Pro), CF True IDE socket * SEAF memory board, subset of PISMO2 With Peripherals: * 4.3” WVGA 24-bit LCD * Audio codecs (AC97 & I2S), TSI * VGA camera * Video in via 3 RCA jacks, and HDMI type C out * Marvell 88W8688 802.11bg/BT module * GPS RF IC * Dual analog mics & speakers, headset jack, LED, ambient light sensor * USB2.0 HS host (A), OTG (micro AB) * FE PHY, PCIE Mini Card slot * GPIO, GPIO expander with DIP switches for easier selection UART serial over USB, CIR This patch adds basic board support with DRAM and UART functionality The patch is tested for boot from DRAM using XDB Signed-off-by: Mahavir Jain <mjain@marvell.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2010-12-16Merge branch 'master' of ../master into nextWolfgang Denk
2010-12-16mpc52xx: add support for tqm52xx based board charonHeiko Schocher
- serial console in PSC1 - 128MiB DRAM - 32MiB Flash - FEC Ethernet - 2 I2C busses - FPGA on CS3 - IDE - VGA SMI501 Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-12-08Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2010-12-07at91rm9200ek: add configure target for RAM bootAndreas Bießmann
This patch also removes now unnecessary config.mk in board directory and make usage of new features in boards.cfg. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2010-12-07AT91: add TOP9000 supportReinhard Meyer
Adds support for the EMK TOP9000 CPU Module which is based on ATMELs ARM926EJS AT91SAM9XE SoC. Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-12-0683xx NAND boot: fix boards.cfgScott Wood
This patch http://patchwork.ozlabs.org/patch/72962/ included a boards.cfg change, but it was omitted when applied as f1c574d4006d81301792e70fafc31ff39259e793 This fixes the NAND SPL build on MPC8315ERDB. Signed-off-by: Scott Wood <scottwood@freescale.com>
2010-11-30Davinci: add support for the ea20 boardStefano Babic
This board uses the OMAP-L138 SOM stacked on a custom baseboard. It supports SPI Flash, Ethernet with RMII. Signed-off-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
