path: root/boards.cfg
2014-01-21powerpc/mpc85xx:Increase binary size for P, B & T series boards.Prabhakar Kushwaha
u-boot binary size for Freescale mpc85xx platforms is 512KB. This has been reached to upper limit for some of the platforms causig linker error. So, Increase the u-boot binary size to 768KB. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2014-01-21powerpc/c29xpcie: 8k page size NAND boot support base on TPL/SPLPo Liu
Using the TPL/SPL method to booting from 8k page NAND flash. - Add 256kB size SRAM tlb for second step booting; - Add spl.c for TPL image boot; - Add spl_minimal.c for minimal SPL image; - Add C29XPCIE_NAND configure; - Modify C29XPCIE.h for nand config and enviroment; Signed-off-by: Po Liu <Po.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-15Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-01-15mx6: Add initial support for the Hummingboard soloFabio Estevam
SolidRun has designed the Hummingboard board based on mx6q/dl/solo. Add the initial support for the mx6 solo variant. More information about this hardware can be found at: http://imx.solid-run.com/wiki/index.php?title=Carrier-One_Hardware (Carrier-One was the previous name of Hummingboard). Based on the work from Jon Nettleton <jon.nettleton@gmail.com>. Signed-off-by: Jon Nettleton <jon.nettleton@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-01-14mx1ads: remove board supportAlbert ARIBAUD
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Stefano Babic <sbabic@denx.de>
2014-01-14mini2440: remove board supportAlbert ARIBAUD
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2014-01-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Bringing in the MMC tree means that CONFIG_BOUNCE_BUFFER needed to be added to include/configs/exynos5-dt.h now. Conflicts: include/configs/exynos5250-dt.h Signed-off-by: Tom Rini <trini@ti.com>
2014-01-10zynq: Add zynq_zc770 xm012 board supportJagannadha Sutradharudu Teki
ZC770 is a complete development board based on the Xilinx Zynq-7000 All Programmable SoC, similar to ZC70x board but which has four different daughter cards, like XM010, XM011, XM012 and XM013 ZC770 XM012: - 1GB DDR3 - 64MiB Numonyx NOR flash - USB-UART Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Cc: Stefan Roese <sr@denx.de>
2014-01-10zynq: Add zynq_zc770 xm013 board supportJagannadha Sutradharudu Teki
ZC770 is a complete development board based on the Xilinx Zynq-7000 All Programmable SoC, similar to ZC70x board but which has four different daughter cards, like XM010, XM011, XM012 and XM013 ZC770 XM013: - 1GB DDR3 - 128 Mb Quad-SPI Flash(dual parallel) - USB-UART Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq: Add zynq_zc770 xm010 board supportJagannadha Sutradharudu Teki
ZC770 is a complete development board based on the Xilinx Zynq-7000 All Programmable SoC, similar to ZC70x board but which has four different daughter cards, like XM010, XM011, XM012 and XM013 ZC770 XM010: - 1Gb DDR3 - 1Mb SST SPI flash - 128 Mb Quad-SPI Flash - 8 Mb SST SI flash - Full size SD/MMC card cage - 10/100/1000 Ethernet - USB-UART Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq: Add zynq microzed board supportJagannadha Sutradharudu Teki
MicroZed is a low-cost development board based on the Xilinx Zynq-7000 All Programmable SoC. APSOC: - XC7Z010-1CLG400C Memory: - 1 GB of DDR3 SDRAM - 128Mb of QSPI flash(S25FL128SAGBHI200) - Micro SD card interface Communication: - 10/100/1000 Ethernet - USB 2.0 - USB-UART User I/O: - 100 User I/O (50 per connector) - Configurable as up to 48 LVDS pairs or 100 single-ended I/O Misc: - Xilinx PC4 JTAG configuration port - PS JTAG pins accessible via Pmod - 33.33 MHz oscillator - User LED and push switch For more info - http://zedboard.org/product/microzed Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq: Add zynq zed board supportJagannadha Sutradharudu Teki
Zed is a complete development board based on the Xilinx Zynq-7000 All Programmable SoC. APSOC: - XC7Z020-CLG484-1 Memory: - 512 MB DDR3 - 256 Mb Quad-SPI Flash( - Full size SD/MMC card cage Connectivity: - 10/100/1000 Ethernet - USB OTG (Device/Host/OTG) - USB-UART Expansion: - FMC (Low Pin Count) - Pmod. headers (2x6) Video/Display: - HDMI output (1080p60 + audio) - VGA connector - 128 x 32 OLED - User LEDs (9) User inputs: - Slide switches (8) - Push button switches (7) Audio: - 24-bit stereo audio CODEC - Stereo line in/out - Headphone - Microphone input Analog: - Xilinx XADC header - Supports 4 analog inputs - 2 Differential / 4 Single-ended Debug: - On-board USB JTAG programming port - ARM Debug Access Port (DAP) For more info - http://zedboard.org/product/zedboard Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq: Add zynq zc70x board supportJagannadha Sutradharudu Teki
The Zynq-7000 APSOC zc702 and zc706 enabled complte embedded processing includes ASIC and FPGA design. ZC702-: APSOC: - XC7Z020-CLG484-1 Memory: - DDR3 Component Memory 1GB - 16MB Quad SPI Flash - IIC - 1 KB EEPROM Connectivity: - Gigabit Ethernet GMII, RGMII and SGMII. - USB OTG - Host USB - IIC Bus Headers/HUB - 1 CAN with Wake on CAN - USB-UART Video/Display: - HDMI Video OUT - 8X LEDs Control & I/O: - 3 User Push Buttons - 2 User Switches - 8 User LEDs For more info on zc702 board: - http://www.xilinx.com/products/boards-and-kits/EK-Z7-ZC702-G.htm ZC706-: APSOC: - XC7Z045 FFG900 -2 AP SoC Memory: - DDR3 Component Memory 1GB (PS) - DDR3 SODIM Memory 1GB (PL) - 2X16MB Quad SPI Flash (dual parallel) - IIC - 1 KB EEPROM Connectivity: - PCIe Gen2x4 - SFP+ and SMA Pairs - GigE RGMII Ethernet (PS) - USB OTG 1 (PS) - Host USB - IIC Bus Headers/HUB (PS) - 1 CAN with Wake on CAN (PS) - USB-UART Video/Display: - HDMI 8 color RGB 4.4.4 1080P-60 OUT - HDMI IN 8 color RGB 4.4.4 Control & I/O: - 2 User Push Buttons/Dip Switch, 2 User LEDs - IIC access to GPIO - SDIO (SD Card slot) - 3 User Push Buttons, 2 User Switches, 8 User LEDs For more info on zc706 board: - http://www.xilinx.com/products/boards-and-kits/EK-Z7-ZC706-G.htm Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq-common: Rename zynq with zynq-commonJagannadha Sutradharudu Teki
zynq.h -> zynq-common.h, zynq-common is Common configuration options for all Zynq boards. zynq.h is no longer exists hense removed from boards.cfg Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10arm: make 'MAKEALL -a' distinguish between arm and aarch64Albert ARIBAUD
The vexpress_aemv8a is the first aarch64 board in U-Boot. As it was introduced, it gets built when "MAKEALL -a arm" is invoked, and fails as this command is run with a 32-bit, not 64-bit, toolchain as the cross-compiler. Introduce 'aarch64' as a valid 'MAKEALL -a' argument, treated as 'arm' for all other intents, and change the architecture of the vexpress_aemv8a entry in boards.cfg from 'arm' to 'aarch64'.
2014-01-09arm64: board support of vexpress_aemv8aDavid Feng
Signed-off-by: David Feng <fenghua@phytium.com.cn> Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com>
2014-01-08Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-01-07TI:omap3: Drop omap3_zoom2Tom Rini
The omap3_zoom2 board has not been updated for a correct CONFIG_SYS_HZ and Tom Rix's email has long been bouncing. Signed-off-by: Tom Rini <trini@ti.com>
2014-01-06Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2014-01-06arm/km: add support for km_kirkwood_128m16 boardKarlheinz Jerg
The board is similar to the standard km_kirkwood board. From a u-boot point of view, the only difference is an increased 256 MiB DRAM (128M16). A board based on this design is for example the SUP12. Signed-off-by: Karlheinz Jerg <karlheinz.jerg@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2014-01-06Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-01-06Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: include/micrel.h The conflict above was trivial, caused by four lines being added in both branches with different whitepace.
2014-01-02powerpc/t4240: enable NAND boot supportShaohui Xie
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
2013-12-30Exynos5420: Add base patch for SMDK5420Rajeshwari Birje
Adding the base patch for Exynos based SMDK5420. This shall enable compilation and basic boot support for SMDK5420. Signed-off-by: Rajeshwari S Shinde <rajeshwari.s@samsung.com> Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-12-20PowerPC: Drop linkstation_HGLAN supportTom Rini
With changes to the rtl8169 ethernet to improve cache support, we have needed additional cache functions for mpc8245. As the board maintainer has been unresponsive, remove this board. Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Tom Rini <trini@ti.com>
2013-12-20ARM: Samsung: Change GONI and Universal_C210 maintainers.Łukasz Majewski
Update boards.cfg entries for Samsung's GONI and Universal_C210 maintainers entry. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2013-12-18ARM: AM43xx: Add MaintainerLokesh Vutla
Adding Maintainer for AM43xx. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-12-18ARM: tegra: Add the Tamonten™ NG Evaluation Carrier boardAlban Bedel
Add support for the new Tamonten™ NG platform from Avionic Design. Currently only I2C, MMC, USB and ethernet have been tested. Signed-off-by: Alban Bedel <alban.bedel@avionic-design.de> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-12-18Change maintainer for Avionic Design boardsThierry Reding
I no longer work for Avionic Design and don't have access to hardware, so I'll pass on maintainership to Alban. Acked-by: Alban Bedel <alban.bedel@avionic-design.de> Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-12-18sh: add support for sh7753evb boardYoshihiro Shimoda
The SH7753 EVB board has SH7753, 512MB DDR3-SDRAM, SPI ROM, Gigabit Ethernet, and eMMC. This patch support the following functions: - 512MB DDR3-SDRAM, SCIF4, SPI ROM, Gigabit Ethernet, eMMC Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-12-12arm: omap3: Add HEAD acoustics (HA) board variant omap3_ha to tao3530Stefan Roese
The Head acoustics (HA) baseboard used the Technexion TAO3530 SOM and has only some minor differences to the Technexion Thunder baseboard. This patch adds support for this HA baseboard / TAO3530 as the "omap3_ha" build target. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Tapani Utriainen <tapani@technexion.com> Cc: Thorsten Eisbein <thorsten.eisbein@head-acoustics.de> Cc: Tom Rini <trini@ti.com>
2013-12-12arm, omap3: Add support for TechNexion modulesTapani Utriainen
Add support for TechNexion TAO3530 SoM This patch has been posted quite a long time ago. I ported it to the latest mainline U-Boot version. With some additional cleanup and enhancements. Signed-off-by: Tapani Utriainen <tapani@technexion.com> CC: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Stefan Roese <sr@denx.de> Cc: Thorsten Eisbein <thorsten.eisbein@head-acoustics.de> Cc: Tom Rini <trini@ti.com>
2013-12-10Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/armv7/rmobile/Makefile doc/README.scrapyard Needed manual fix: arch/arm/cpu/armv7/omap-common/Makefile board/compulab/cm_t335/u-boot.lds
2013-12-09arm: at91: support for the Calao USB-A9263 board (based on AT91SAM9263)Mateusz Kulikowski
Add support for USB-A9263 board manufactured by Calao Systems (http://www.calao-systems.com/). Code is based on old U-Boot sources (2010.09) released by Calao. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-12-09arm, at91: add siemens corvus boardHeiko Schocher
enable support for the siemens AT91SAM9G20 based board corvus. Signed-off-by: Boris Schmidt <boris.schmidt@siemens.com> Reviewed-by: Heiko Schocher <hs@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-12-09arm, at91: add Siemens board taurus and axmHeiko Schocher
enable support for the siemens AT91SAM9G20 based boards taurus and axm. Signed-off-by: Roger Meier <r.meier@siemens.com> Reviewed-by: Heiko Schocher <hs@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-12-06Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-12-04pcm051: Support for revision 3Lars Poeschel
Phytec sells revision or version 3 of pcm051. It is labeled 1358.3 on the board. The difference for u-boot is that is has other DDR3 RAM on it: 1 x MT41K256M16HA125E instead of 2 x MT41J256M8HX15E on revisions 1 and 2. Both configurations are 512 MiB. Configure your u-boot build with pcm051_rev3 for the new RAM and pcm051_rev1 for the old RAM configuration. Board revision 2 has to use pcm051_rev1 also. Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
2013-12-04cm_t335: add cm_t335 board supportIlya Ledvich
Add cm_t335 board directory, config file. Enable build. Signed-off-by: Ilya Ledvich <ilya@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> [trini: Adapt Makefile] Signed-off-by: Tom Rini <trini@ti.com>
2013-12-03arm: rmobile: Add support koelsch boardNobuhiro Iwamatsu
The koelsch board has R8A7791, 2GB DDR3-SDRAM, USB, Quad SPI, Ethernet, and more. This patch supports the following functions: - DDR3-SDRAM - SCIF Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Albert Aribaud <albert.u.boot@aribaud.net>
2013-12-03arm: rmobile: Add support lager boardNobuhiro Iwamatsu
The lager board has R8A7790, 4GB DDR3-SDRAM, USB, Ethernet, and more. This patch supports the following functions: - DDR3-SDRAM - SCIF Signed-off-by: Kouei Abe <kouei.abe.cp@renesas.com> Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Ryo Kataoka <ryo.kataoka.wt@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Albert Aribaud <albert.u.boot@aribaud.net>
2013-11-28udoo: Move and optimize platform register setting.Giuseppe Pagano
Previous uDoo configuration adopts register settings for DDR3, clock, muxing, etc. taken from Nitrogen6x. uDoo schematics is rather different from that board, and it needs customized setting for most of the registers. All this changes can be considered atomical since it is part of initial support of the board. Patch changes uDoo configuration files path to a specific one, and adopt optimized value for every configured register. Signed-off-by: Giuseppe Pagano <giuseppe.pagano@seco.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com> CC: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com>
2013-11-25t2080qds/ramboot: enable PBL tool for t2080qdsShengzhou Liu
Add the default RCW(SerDes 0x66_0x16) and PBI configure file for T2080QDS board, so we can use PBL tool to generate the ramboot image to support boot from NAND/SPI/SD. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
2013-11-25powerpc/t2080qds: add support for t2080qds boardShengzhou Liu
The T2080QDS is a high-performance computing evaluation, development and test platform supporting the T2080 QorIQ Power Architecture processor. T2080QDS feature overview Processor: - T2080 SoC integrating four 64-bit dual-threads e6500 cores up to 1.8GHz Memory: - Single memory controller capable of supporting DDR3 and DDR3-LV devices - Two DDR3 DIMMs up to 4GB, Dual rank @ 2133MT/s and ECC support Ethernet interfaces: - Two 1Gbps RGMII on-board ports - Four 10Gbps XFI on-board cages - 1Gbps/2.5Gbps SGMII Riser card - 10Gbps XAUI Riser card Accelerator: - DPAA components consist of FMan, BMan, QMan, PME, DCE and SEC SerDes: - 16 lanes up to 10.3125GHz - Supports Aurora debug, PEX, SATA, SGMII, sRIO, HiGig, XFI and XAUI IFC: - 128MB NOR Flash, 512MB NAND Flash, PromJet debug port and FPGA eSPI: - Three SPI flash (16MB N25Q128A + 16MB EN25S64 + 512KB SST25WF040) USB: - Two USB2.0 ports with internal PHY (one Type-A + one micro Type-AB) PCIE: - Four PCI Express controllers (two PCIe 2.0 and two PCIe 3.0 with SR-IOV) SATA: - Two SATA 2.0 ports on-board SRIO: - Two Serial RapidIO 2.0 ports up to 5 GHz eSDHC: - Supports SD/SDHC/SDXC/eMMC Card I2C: - Four I2C controllers. UART: - Dual 4-pins UART serial ports System Logic: - QIXIS-II FPGA system controll Debug Features: - Support Legacy, COP/JTAG, Aurora, Event and EVT Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> [York Sun: removed Makefile blank line at EOF, fix conflicts with moving DDR driver] Acked-by: York Sun <yorksun@freescale.com>
2013-11-25powerpc/t1040qds: Correct Maintainer name in boards.cfgPriyanka Jain
Update T1040QDS naem to Poonam Aggrwal. Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
2013-11-13powerpc/t104xrdb: Add T1042RDB_PI board supportPriyanka Jain
T1042RDB_PI is Freescale Reference Design Board supporting the T1042 QorIQ Power Architecture™ processor. T1042 is a reduced personality of T1040 SoC without Integrated 8-port Gigabit. The board is designed with low power features targeted for Printing Image Market. T1042RDB_PI is similar to T1040RDB board with few differences like it has video interface, supports T1042 personality T1042RDB_PI board Overview ----------------------- - Four e5500 cores, each with a private 256 KB L2 cache - 256 KB shared L3 CoreNet platform cache (CPC) - Interconnect CoreNet platform - 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and interleaving support - Data Path Acceleration Architecture (DPAA) incorporating acceleration for the following functions: - Packet parsing, classification, and distribution - Queue management for scheduling, packet sequencing, and congestion management - Cryptography Acceleration - RegEx Pattern Matching Acceleration - IEEE Std 1588 support - Hardware buffer management for buffer allocation and deallocation - Ethernet interfaces - Two on-board RGMII 10/100/1G ethernet ports. - SERDES Connections, 8 lanes supporting: — PCI — SATA 2.0 - DDR Controller 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and Interleaving -IFC/Local Bus - NAND flash: 1GB 8-bit NAND flash - NOR: 128MB 16-bit NOR Flash - Ethernet - Two on-board RGMII 10/100/1G ethernet ports. - PHY #0 remains powered up during deep-sleep - CPLD - Clocks - System and DDR clock (SYSCLK, “DDRCLK”) - SERDES clocks - Video - DIU supports video at up to 1280x1024x32bpp - HDMI connector - Power Supplies - USB - Supports two USB 2.0 ports with integrated PHYs - Two type A ports with 5V@1.5A per port. - SDHC - SDHC/SDXC connector - SPI - On-board 64MB SPI flash - I2C - Device connected: EEPROM, thermal monitor, VID controller, RTC - Other IO - Two Serial ports - ProfiBus port - Four I2C ports Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
2013-11-13powerpc/t104xrdb: Add T1040RDB board supportPriyanka Jain
T1040RDB is Freescale Reference Design Board supporting the T1040 QorIQ Power Architecture™ processor. T1040RDB board Overview ----------------------- - Four e5500 cores, each with a private 256 KB L2 cache - 256 KB shared L3 CoreNet platform cache (CPC) - Interconnect CoreNet platform - 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and interleaving support - Data Path Acceleration Architecture (DPAA) incorporating acceleration for the following functions: - Packet parsing, classification, and distribution - Queue management for scheduling, packet sequencing, and congestion management - Cryptography Acceleration - RegEx Pattern Matching Acceleration - IEEE Std 1588 support - Hardware buffer management for buffer allocation and deallocation - Ethernet interfaces - Integrated 8-port Gigabit Ethernet switch - Four 1 Gbps Ethernet controllers - SERDES Connections, 8 lanes supporting: - PCI - SGMII - QSGMII - SATA 2.0 - DDR Controller 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and Interleaving -IFC/Local Bus - NAND flash: 1GB 8-bit NAND flash - NOR: 128MB 16-bit NOR Flash - Ethernet - Two on-board RGMII 10/100/1G ethernet ports. - PHY #0 remains powered up during deep-sleep - CPLD - Clocks - System and DDR clock (SYSCLK, “DDRCLK”) - SERDES clocks - Power Supplies - USB - Supports two USB 2.0 ports with integrated PHYs - Two type A ports with 5V@1.5A per port. - SDHC - SDHC/SDXC connector - SPI - On-board 64MB SPI flash - I2C - Devices connected: EEPROM, thermal monitor, VID controller - Other IO - Two Serial ports - ProfiBus port Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> [York Sun: fixed Makefile] Acked-by: York Sun <yorksun@freescale.com>
2013-11-13mx6: titanium: Move BSP code to barco board directoryStefan Roese
Since the titanium board is not a Freescale board, move its BSP code from the freescale board directory to the newly created barco board directory. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Peter Korsgaard <peter.korsgaard@barco.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Peter Korsgaard <peter.korsgaard@barco.com>
2013-11-11MPC824x: remove obsolete "PN62" boardWolfgang Denk
The MPC824x processors have long reached EOL, and the PN62 board has not seen any board-specific updates for more than a decade. It is now causing build issues. Instead of wasting time on things nobody is interested in any more, we rather drop this board. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Wolfgang Grandegger <wg@grandegger.com> cc: Tom Rini <trini@ti.com>
2013-11-11omap730p2: Remove boardTom Rini
