path: root/boards.cfg
2011-09-03integrator: convert to new build systemLinus Walleij
This deletes the integrator split_by_variant.sh script and defines a number of unique board types for the core modules that are meaningful to support for the Integrator AP/CP, i.e. the ones that did not just say "unsupported core module" in split_by_variant.sh. If more core modules need to be supported they are easy to add. We delete all the old cruft in Makefile and MAKEALL that was working around the old way of building boards. We create a unique config file per board to satisfy the build system, but they are just oneliners that include the existing integratorap.h and integratorcp.h configs. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-03atmel: Update support of board AT91SAM9M10G45-EK to new styleThomas Petazzoni
Based on earlier work by Alex Waterman <awaterman@dawning.com>. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2011-09-03make pm9g45 buildable for v2011.06 releaseAsen Dimov
Signed-off-by: Asen Chavdarov Dimov <dimov@ronetix.at> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de> changed at91_serial_hw_init to at91_seriald_hw_init
2011-09-03make pm9263 buildable for v2011.06 releaseAsen Dimov
2011-09-03pm9261: compiles with the AT91 reworked schemeAsen Dimov
2011-09-03tny_a9260/tny_a9g20: update board to the new AT91 organizationThomas Petazzoni
Cc: Albin Tonnerre <tonnerrealbin@gmail.com> CC: Gregory Hermant <gregory.hermant@calao-systems.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2011-09-03sbc35_a9g20: update board to the new AT91 organizationThomas Petazzoni
Cc: Albin Tonnerre <tonnerrealbin@gmail.com> Cc: Gregory Hermant <gregory.hermant@calao-systems.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de> Removed SBC35 from MAKEALL
2011-08-22sh: Add Renesas rsk7264 boardPhil Edworthy
The rsk7264 (also know as rsk2+sh7264) is an SH2A based board with 64MB NAND flash and 64MB SDRAM. It is very similar to the rsk7203 board. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-04Armada100: Add Board Support for Marvell GuruPlug-DisplayAjay Bhargav
This patch adds basic board support with DRAM and UART functionality Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com> Acked-by: Tanmay Upadhyay <tanmay.upadhyay@einfochips.com>
2011-08-04ARM: versatile: fix board supportStefano Babic
Versatile board is used as example to run u-boot under qemu. The patch fixes relocation for all versatile boards and adds a versatileqemu target to be used under qemu. Patch tested only under qemu, not on real boards. Tested with QEMU emulator version 0.14.50. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Alessandro Rubini <rubini-list@gnudd.com> CC: Loïc Minier <loic.minier@linaro.org>
2011-08-03avr32: add grasshopper (ICnova AP7000) boardAndreas Bießmann
The grasshopper board is a neat avr32 evaluation kit produced by In-Circuit GmbH. See http://www.ic-board.de/product_info.php?info=p75_ICnova-AP7000-Base.html for detailed information about this device. Signed-off-by: Andreas Bießmann <biessmann@corscience.de> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-08-03AT91: Makes AT91SAM9263-EK build correctly against u-boot-atmel/masterXu, Hong
Rework for AT91SAM9263-EK, makes it build again. Based on the work for AT91SAM9260-EK. Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Reinhard Meyer <uboot@emk-elektronik.de>
2011-08-03AT91: Board fix for AT91SAM9261-EKXu, Hong
Fix board part of AT91SAM9261-EK according to the new scheme Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-08-03AT91: Makes AT91SAM9RL-EK build correctly against u-boot-atmel/masterXu, Hong
Rework for AT91SAM9RL-EK, makes it build again. Based on the work for AT91SAM9260-EK. V4: added changes to MAKEALL Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-07-28Removed obsolete Netstal boardsNiklaus Giger
Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org>
2011-07-27digsy_mtc: move board into vendor dir and add vendor logoAnatolij Gustschin
2011-07-18Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: ARM: MX5: Fix broken leftover TO-2 errata workaround MX31: Cleanup clock function scb9328: Add ARM relocation support am3517evm: change console device from ttyS2 to ttyO2 Remove volatile qualifier in get_ram_size() calls TI: TNETV107X Fix Build Error ARM: add missing CONFIG_SKIP_LOWLEVEL_INIT for armv7 arm: add CONFIG_MACH_TYPE setting and documentation arm: add __ilog2 function Timer: Fix misuse of ARM *timer_masked() functions outside arch/arm EfikaMX: Enable EXT2 booting EfikaMX: Add missing CONFIG_SYS_TEXT_BASE EfikaMX: Use correct imximage.cfg MX27: Update to autogenerated asm-offsets.h MX5: Update to autogenerated asm-offsets.h imx: Add support for zmx25 board imx: Make imx25 compatible to mxc_gpio driver and fix in tx25 imx: Add auto generation of asm-offsets.h for imx25 imx: Add support for USB EHCI on imx25 imx: Use correct imx25 reset.c imx: Add get_tbclk() function for imx25 ARM: Update maintainer of board scb9328 mx27: Make the UART port number explicit build: Add targets for auto gen of asm-offsets.h and use it in imx35 mx31pdk: cosmetic: Fix line over 80 characters
2011-07-17powerpc/p2041rdb: Add p2041rdb board supportMingkai Hu
P2041RDB Specification: ----------------------- Memory subsystem: * 4Gbyte unbuffered DDR3 SDRAM SO-DIMM(64bit bus) * 128 Mbyte NOR flash single-chip memory * 256 Kbit M24256 I2C EEPROM * 16 Mbyte SPI memory * SD connector to interface with the SD memory card Ethernet: * dTSEC1: connected to the Vitesse SGMII PHY (VSC8221) * dTSEC2: connected to the Vitesse SGMII PHY (VSC8221) * dTSEC3: connected to the Vitesse SGMII PHY (VSC8221) * dTSEC4: connected to the Vitesse RGMII PHY (VSC8641) * dTSEC5: connected to the Vitesse RGMII PHY (VSC8641) PCIe: * Lanes E, F, G and H of Bank1 are connected to one x4 PCIe SLOT1 * Lanes C and Land D of Bank2 are connected to one x4 PCIe SLOT2 SATA: Lanes C and Land D of Bank2 are connected to two SATA connectors USB 2.0: connected via a internal UTMI PHY to two TYPE-A interfaces I2C: * I2C1: Real time clock, Temperature sensor, Memory module * I2C2: Vcore Regulator, 256Kbit I2C Bus EEPROM, PCIe slot1/2 UART: supports two UARTs up to 115200 bps for console Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-14EfikaMX: Use correct imximage.cfgJana Rapava
Signed-off-by: Jana Rapava <fermata7@gmail.com>
2011-07-14imx: Add support for zmx25 boardMatthias Weisser
zmx25 is a board based on imx25 SoC, 64 Megs of LPDDR, 32 Megs of NOR flash, an optional NAND flash. Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2011-07-11powerpc/85xx: Add basic support for P1023RDS boardRoy Zang
The P1023RDS board is the reference board for the P1023 SoC. Add support for booting it from NOR or NAND, with fixed 2G of DDR, PCIe, UART, I2C, etc. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com> Signed-off-by: Lei Xu <B33228@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/85xx: Add NAND boot support for P3041/P5020DSShaohui Xie
When booting from NAND we get the environment and FMan ucode from NAND. Signed-off-by: Shaohui Xie <b21989@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-06mpc83xx: Add support for MergerBox boardAndre Schwarz
Includes board config file, documentation, maintainer and boards.cfg entries, and board specific files in vendor dir. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2011-07-04Add support for Network Space v2 and parentsSimon Guinot
This patch add support for the Network Space v2 board and parents, based on the Marvell Kirkwood 6281 SoC. This include Network Space (Max) v2 and Internet Space v2. Additional information is available at: http://lacie-nas.org/doku.php?id=network_space_v2 Signed-off-by: Simon Guinot <sguinot@lacie.com>
2011-07-04arm/km: add support for portl2 boardValentin Longchamp
This adds support for the keymile Kirkwood BEC portl2 board. This board relies on the km_arm (km_kirkwood) BEC. The egiga driver is configured for a 100M full-duplex, A/N off connnection to the backplane. This board has always ethernet present, because it is connected to the marvell switch similar to mgcoge3un. The reset_phy functionality is also the same to mgcoge3un. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Heiko Schocher <hs@denx.de>
2011-07-04arm/km: replace suenx targets with km_kirkwoodHolger Brunck
suen3 and suen8 were in first HW version quite different, but now they are from a u-boot point of view similar. So these two boards can use the same header file. Other keymile boards differ only in the usage of the PCI interface. Therefore a target km_kirkwood_pci was introduced. All targets use the same header file. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Heiko Schocher <hs@denx.de>
2011-07-04MX53: Add initial support for MX53ARDFabio Estevam
2011-06-30nios2: move generic config to boards.cfgMike Frysinger
I can't build test this, but just looking at the config files written and it seems OK ... Tested-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2011-06-23update/fix IXDP425 / IXDPG425 boardsMichael Schwingen
Signed-off-by: Michael Schwingen <michael@schwingen.org>
2011-06-23add dvlhost (dLAN 200 AV Wireless G) boardMichael Schwingen
2011-06-23update/fix AcTux1 boardMichael Schwingen
2011-06-21AT91 rework: fix at91sam(9260/9g20/9xe)ek board port to build again:Reinhard Meyer
Make ATMEL's at91sam9260/9g20/9xe-ek boards build again Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-06-01armv7: Add support for ST-Ericsson U8500 href platformJohn Rigby
Minimal platform support to boot linux from SD. Supported devices/hw limited to external MMC/SD slot, GPIO, I2C and minimal PRCMU. Signed-off-by: John Rigby <john.rigby@linaro.org> CC: Albert Aribaud <albert.aribaud@free.fr>
2011-05-31arm/km: rename mgcoge2un to mgcoge3unValentin Longchamp
The mgcoge2un target was only an intermediate step to mgcoge3un. For this reason the mgcoge2un support was moved to mgcoge3un, because it isn't needed to support both targets. We add the BootROM init file for the mgcoge3un memphis RAM. We also move the suen3 and suen8 boards into the correct category in the MAINTAINERS file. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-05-26ARMV7: Add support for Samsung SMDKV310 BoardChander Kashyap
SMDKV310 board is based on Samsung S5PV310 SOC. This SOC is very much similar to S5PC210. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-05-23MX5: drop config.mk from efikamx boardStefano Babic
Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Marek Vasut <marek.vasut@gmail.com>
2011-05-23MX51: vision2: Fix build for vision2 board.Fabio Estevam
config.mk should not be used in board directory and should be removed. Use the same approach for building the image as other MX51/MX53 boards. After this change vision2 board can be built again. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-05-23MX53: Add initial support for MX53SMD board.Fabio Estevam
2011-05-23MX53: support for freescale MX53LOCO boardJason Liu
This patch add initial support for freescale MX53LOCO board. Network(FEC),SD/MMC,UART have been supported by this patch Signed-off-by: Jason Liu <jason.hui@linaro.org>
2011-05-18powerpc/85xx: add support for env in MMC/SPI on corenet ds boardsShaohui Xie
2011-05-18at91: reworked support for otc570 boardDaniel Gorsulowski
The otc570 board support was broken. Within this opportunity, I completely reworked the board files. Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
2011-05-18at91: reworked support for meesc boardDaniel Gorsulowski
The meesc board support was broken. Within this opportunity, I completely reworked the board files. Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
2011-05-18Add support for Bluewater Systems Snapper 9260 and 9G20 modulesRyan Mallon
Add support for Bluewater Systems AT91 based Snapper 9260 and 9G20 single board computer modules. Includes NAND flash and Ethernet support. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
2011-05-12mp2usb: finish the removalEric Bénard
- remove from boards.cfg - add to doc/README.scrapyard Signed-off-by: Eric Bénard <eric@eukrea.com>
2011-05-11Add definitions for OpenRD-Client and OpenRD-UltimateClint Adams
Signed-off-by: Clint Adams <clint@debian.org> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Julian Pidancet <julian.pidancet@citrix.com>
2011-05-11Rename openrd_base files to openrdClint Adams
2011-05-10powerpc/km82xx: add mgcoge3ne and remove mgcoge2ne supportHolger Brunck
This patch adds support for the MPC8247 based board mgcoge3ne. Additionaly mgcoge2ne board supprot was removed, because due to the mgcoge3ne, this board is obsolete and not longer maintained. The board is similar to mgcoge. The difference is that a NUMONYX flash is used and a different SDRAM (256MB). Also introduce CONFIG_KM_82XX to collect ppc82xx common settings and remove staticness from the common set_pin function. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de>
2011-05-10powerpc/km82xx: rename mgcoge files to km82xxHolger Brunck
The directory and file mgcoge was renamed to km82xx. Because other keymile 82xx will follow and will use the same platform code. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-04-30Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2011-04-30powerpc, 83xx: add kmsupx5 board supportHeiko Schocher
The Keymile SUPx5 board series is based on a PBEC8321 but contains an additional PBUS FPGA (LPXF) on local bus CS2. Signed-off-by: Thomas Reufer <thomas.reufer@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com> cc: Wolfgang Denk <wd@denx.de> cc: Kim Phillips <kim.phillips@freescale.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com>
