There are a number of issues when building the Sequoia U-Boot with
Timesys toolchains.
* GCC 4.3.3 builds an image that is too large
* 64-bit cross-toolchains run into interesting linking errors
* abort is not defined for the toolchain when using GCC 4.3.3
This patch addresses these issues in various ways, allowing builds using
the newer toolchains.
MPC8569 UART1 signals are muxed with PortF bit[9-12], we need to define
those pins before using UART1.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
Tested-by: Mikhail Zaturenskiy <mzaturenskiy@shoppertrak.com>
The BCSR17[7] = 1 will unlock the write protect of FLASH.
The WP# pin only controls the write protect of top/bottom sector,
That is why we can save env, but we can't write the first sector
before the patch.
Signed-off-by: Dave Liu <daveliu@freescale.com>
Currently the clk_adj is 6 (3/4 cycle), The settings will cause
the DDR controller hang at the data init. Change the clk_adj
from 6 to 4 (1/2 cycle), make the memory system stable.
Some boards do not have SROM support for the DM9000 network adapter.
Instead of listing these board names in the driver code, make this
option configurable from the board config file.
It also removes a build warning for the at91sam9261ek board:
'dm9000x.c:545: warning: 'read_srom_word' defined but not used'
And it repaires the trizepsiv board build which was broken around the
same routines
Signed-off-by: Remy Bohmer <linux@bohmer.net>
Several boards used different ways to specify the size of the
protected area when enabling flash write protection for the sectors
holding the environment variables: some used CONFIG_ENV_SIZE and
CONFIG_ENV_SIZE_REDUND, some used CONFIG_ENV_SECT_SIZE, and some even
a mix of both for the "normal" and the "redundant" areas.
Normally, this makes no difference at all. However, things are
different when you have to deal with boards that can come with
different types of flash chips, which may have different sector
sizes.
Here we may have to chose CONFIG_ENV_SECT_SIZE such that it fits the
biggest sector size, which may include several sectors on boards using
the smaller sector flash types. In such a case, using CONFIG_ENV_SIZE
or CONFIG_ENV_SIZE_REDUND to enable the protection may lead to the
case that only the first of these sectors get protected, while the
following ones aren't.
This is no real problem, but it can be confusing for the user -
especially on boards that use CONFIG_ENV_SECT_SIZE to protect the
"normal" areas, while using CONFIG_ENV_SIZE_REDUND for the
"redundant" area.
To avoid such inconsistencies, I changed all sucn boards that I found
to consistently use CONFIG_ENV_SECT_SIZE for protection. This should
not cause any functional changes to the code.
Cc: Paul Ruhland
Cc: Pantelis Antoniou <panto@intracom.gr>
Cc: Stefan Roese <sr@denx.de>
Cc: Gary Jennejohn <garyj@denx.de>
Cc: Dave Ellis <DGE@sixnetio.com>
The pins for async memory where parallel flash lives are not enabled by
default, so make sure we mux them as needed.
Signed-off-by: Graf Yang <graf.yang@analog.com>
Signed-off-by: Detlev Zundel <dzu@denx.de>
The pin which was used in preliminary versions of the board for ide
reset is really connected to the rtc clock.
Cc: Sascha Hauer <s.hauer@pengutronix.de>
AFEB9260 uses PA10, PA11 for ETX2 and ETX3.
Also, due to extarnal pull-up on IRQ line, Micrel PHY ID is 1 after reset sequence,
not 0.
Signed-off-by: Sergey Lapin <slapin@ossfans.org>
We don't know what state the ethernet PHY is in when starting up, so make
sure we set it to a sane state. This fixes troubles seen when Linux boots
up, configures the PHY is a non-default state, and then the system reboots
into U-Boot which previously expected a reset state only.
When dropping jump block support, the assumption was that all bootroms
supported entry point redirection via the EVT1 register. Unfortunately,
this turned out to be incorrect for the oldest Blackfin parts (BF533-0.2
and older and BF561). No one really noticed earlier because these parts
usually are booted by bypassing the bootrom entirely, and older BF533
parts are not supported at all (too many anomalies).
The Beagle Rev C boards pull UART2 from an alternate set of balls.
Signed-off-by: Steve Sakoman <steve@sakoman.com>
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
The board-types defined in struct omap3_sysinfo seem to be
unused. The function display_board_info() is passed
board type as an argument; which is ignored.
This patch removes all uses of board-type, related definitions
and functions.
Signed-off-by: Sanjeev Premi <premi@ti.com>
because legacy NAND support is deprecated converting to current
NAND interface. !This just compile, because I have no more the
hardware to test it.
__asm__ follows gcc's documented syntax and is generally more common
than __asm. This change is only asthetic and should not affect
functionality.
The PM9263 board is based on the AT91SAM9263-EK board.
Here is the page on Ronetix website:
http://www.ronetix.at/starter_kit_9263.html
Signed-off-by: Ilko Iliev <iliev@ronetix.at>
calculate dynamically the clock rate and pllb setting for usb
The current define of get_bus_freq() in the CONFIG_NAND_SPL #ifdef is not
used at all. This patch changes it's define to the currently used value of
133333333 and removes the unnecessary code.
Currently the NOR & NAND support in Linux only works for the "standard"
Sequoia, the version booting for NOR flash. The NAND-booting version
has the chip-selects swapped. Here the chip-select mappings:
"Standard" NOR-booting version:
CS0 NOR
CS3 NAND
NAND-booting version:
CS0 NAND
CS3 NOR
With this path the dtb gets fixed-up, so that the correct chip-select
numbers are patched in the dtb enabling correct NOR & NAND support
in Linux on the NAND-booting Sequoia version.
A new Overo expansion board uses GPIO 14, 21, 22 and 23 for LED's and
switches. This patch changes the pinmux configuration for those pins.
They were previously set up for unused MMC3_DAT4-7.
unify arm cache management except for non standard cache as ARM7TDMI
Move machine specific code to smdk6400.
Some board use OneNAND instead of NAND.
Some register MP0_CS_CFG[5:0] are controled by both h/w and s/w.
So it's better to use macro instead of hard-coded value.
Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
This is just a small fix to get u-boot on m5282evb.
Signed-off-by: Alan Carvalho de Assis <acassis@gmail.com>
Update the rm9200 reset sequence to try executing a board-specific reset
function and move specific board reset to board.
The AT91RM9200-EK Evaluation Board supports the AT91RM9200
ARM9-based 32-bit RISC microcontroller and enables real-time code development
and evaluation.
Here is the chip page on Atmel website:
http://www.atmel.com/dyn/products/tools_card.asp?tool_id=3507
with
- NOR (cfi driver)
- DataFlash
- USB OHCI
- Net
- I2C (hard)
Signed-off-by: Ulf Samuelsson <ulf@atmel.com>
Rename the pci header for FSL HW so we can move some prototypes
in there and stop doing explicit externs
Fix problems introduced in commit
7b5611cdd12ca0cc33f994f0d4a4454788fc3124 [inka4x0: Add hardware
diagnosis functions for inka4x0] which redefined MSR_RI which is
already used on PowerPC systems.
Also eliminate redundant definitions in ps2mult.h. More cleanup will
be needed for other redundant occurrences though.
According to the doc/feature-removal-schedule.txt, the "autoscr"
command will be replaced by the "source" command in approximately 6
months from now.
This patch prepares this change and starts a 6 month transition
period as follows:
- The new "source" command has been added, which implements exactly
the same functionlaity as the old "autoscr" command before
- The old "autoscr" command name is kept as an alias for compatibility
- Command sequences, script files atc. have been adapted to use the
- Related environment variables ("autoscript", "autoscript_uname")
have *not* been adapted yet; these will be renamed resp. removed in
a separate patch when the support for the "autoscr" command get's
finally dropped.
Now that the common SPI flash code supports all the flashes, we can stop
using the old driver.
