The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
When planning for more generalization and Makefile cleanup it became
obvious that the introduction of a separate CONFIG_MK_ name space for
config options that were set through scripting in the Makefile was
not a good idea.
Originally the idea was to provide a script-free approach to supply
configuration options - there was no real need for a separate name
space. But when we now convert the existing Makefile entries to make
use of this approach, it would mean that we have to touch a large
number of board config files and add #ifdef / #define sequences to
"convert" from the CONFIG_MK_ to the CONFIG_ name space.
It seems much cleaner to get rid of this somewhat arbitrary _MK
string now for the few boards that actually use it.
commit 6aa3d3bfaa986f1aff5e21a9b9f68d087715b1a9
"83xx: Remove warmboot parameter from PCI init functions" missed
one mpc83xx_pcie_init callsite, causing this build error:
Configuring for MPC837XEMDS_HOST board...
pci.c: In function 'pci_init_board':
pci.c:141: error: too many arguments to function 'mpc83xx_pcie_init'
this patch extends the commit to include that callsite.
Doubled use of DECLARE_GLOBAL_DATA_PTR caused compile warning:
pci.c:71: warning: register used for two global register variables
Cc: Kim Phillips <kim.phillips@freescale.com>
The logodl board has long been unmaintained and left broken.
As obviously nobody is interestedin that code any more, we may as well
remove it.
Cc: August Hoeraendl <august.hoerandl@gmx.at>
Cc: Robert Schwebel <r.schwebel@pengutronix.de>
Cc: Marek Vasut <marek.vasut@gmail.com>
commit 6d014adf dropped support for the forceenv() function, but failed
to remove references to it from board/davinci/schmoogie/schmoogie.c
Replace forceenv() by setenv() and set CONFIG_ENV_OVERWRITE instead in
the board config file to allow overwriting the serial number.
Cc: Sergey Kubushyn <ksi@koi8.net>
Acked-by: Sergey Kubushyn <ksi@koi8.net>
The current da850evm support in u-boot/master omits any use of
the davinci EMAC. This patch adds basic support for the EMAC using
the MII PHY found on the baseboard of the EVM. The MAC address is
read from the environment variable 'ethadd'. Note that this is
different from the da850evm support in the u-boot omapl1 tree
where the MAC address is read from SPI flash.
Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca>
CC: Sandeep Paulraj <s-paulraj@ti.com>
CC: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
CC: Ben Warren <biggerbadderben@gmail.com>
CC: Mike Frysinger <vapier@gentoo.org>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
The default NAND flash timings are very conservative. This patch assigns the
timings reccomended in the recent linux kernel patch [1] from Sekhar Nori. The
speedup, as reported in that patch, is 5.3x for reads.
[1] http://www.spinics.net/lists/arm-kernel/msg100278.html
CC: Sekhar Nori <nsekhar@ti.com>
There is currently no NAND pinmux enabled by the da850evm board setup code.
This is fine when booting from NAND since the early boot code (UBL) will setup
the pinmux; however, when the boot mode is any other setting NAND is unusable
when enabled in the config.
This patch adds a pinmux list for NAND and enables it when NAND is enabled in
the config. Tested by booting from SPI on the da850evm and verifying NAND
was usable.
CC: Nick Thompson <nick.thompson@ge.com>
The IGEP module is a low-power, high performance production-ready
system-on-module (SOM) based on TI's OMAP3 family.The IGEP module
solution based upon TI OMAP3 provides a low-power/low-cost platform
for a variety of consumer/industrial/medical devices.
Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com>
The IGEP v2 board is a low-cost, fan-less and industrial temperature
range single board computer that unleashes laptop-like performance and
expandability without the bulk, expense, or noise of typical desktop
machines. Its architecture shares much in common with other OMAP3 boards.
Acked-by: Steve Sakoman <steve.sakoman@linaro.org>
Tested-by: Steve Sakoman <steve.sakoman@linaro.org>
This patch fixes the build breakage introduced by the recent relocation
changes for ARMV7
Signed-off-by: Steve Sakoman <steve@sakoman.com>
changes for ARMV7
This patch switches from the legacy mmc driver to the new generic mmc driver
Signed-off-by: Sukumar Ghorai <s-ghorai@ti.com>
Tested-by: Steve Sakoman <steve@sakoman.com>
Signed-off-by: Loic Minier <loic.minier@linaro.org>
CC: stefano babic <sbabic@denx.de>
Originally the Makefile defines CONFIG_ADS5121_REV2 when configuring
for board mpc5121ads_rev2. The config in include/configs/mpc5121ads.h
expects a define CONFIG_MPC5121ADS_REV2 for this.
Therefore there are two defines used but only 1 is defined.
This patch renames references to CONFIG_ADS5121_REV2 to CONFIG_MPC5121ADS_REV2
to have one common define.
This patch fixes faulty mem size detection caused by wrong config in
Signed-off-by: Mark Vels <mark.vels@team-embedded.nl>
The patch adds the possibility to update the QONG
FPGA (a Lattice XP2-5E) with u-boot using some GPIOs
to drive the JTAG interface.
This patch fixes an error when running MAKEALL for ARM9.
On OS X /bin/sh uses builtin echo which does not utilise '-n' switch.
GNU manual for builtins recomend to use here-document style to solve
this portability issue.
This patch removes the usage of 'echo -n' and replace by here-document
style or a oneline echo command.
CC: Peter Pearse <peter.pearse@arm.com>
Adds support for the ARM quad-core Cortex-A9 processor
This system includes a motherboard(Versatile Express), daughterboard
(Coretile), and SOC(Cortex-A9 quad core). The serial port, ethernet,
and flash systems work with these additions. The naming convention
is:
SOC -> CortexA9 quad core = ca9x4
daughterboard -> Coretile = ct
motherboard -> Versatile Express = vxp
This gives ca9x4_ct_vxp.c as the board support file.
Signed-off-by: Matt Waddel <matt.waddel@linaro.org>
For all Kirkwood boards so far dram_init function is duplicated
dram_init function is moved to dram.c and relevant code from all
board specific files removed
If any board needs specific dram init handling than standard one,
then, a macro CONFIG_SYS_BOARD_DRAM_INIT should be defined in
board config header file and the dram_init function can be put
in board specific source file
For ex. keymile boards
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
Previously the _warm_start label was used as an entry point. These 2
entry points should be functionally identical after the removal of the
BOOTFLAG_WARM define.
This patch adds support for displaying boot progress codes on a4m072 board
using LED display. As we can display only one symbol at any time on the hardware
(two symbols with blinking) we can't display progress codes directly and have
to map them to 2-symbol codes.
We use the following mapping on the a4m972 board:
[1, 8] U [100, 108] -> 5
[-9, -1] U [-101, -100] U [-113, -103] -> -5
[9, 14] U [120, 123] U [125, 129] -> 8
[-13, -10] U [-122, -120] U [-127, -124] U {-129} -> -8
{15} -> 9
[-32, -30] -> -A
[-40, -35] U [-51, -42] U [-58, -53] U
[-83, -80] U {-64, -130, -140, -150} -> -B
Other progress code are ignored. One symbol codes are displayed steady while
two-symbol codes are displayed using blinking. Boot progress codes are
displayed with decimal got unset (as opposed to 'display' command output).
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
This patch adds support for LED display on a4m072 board. Hardware is
capable of displaying only one symbol at any time. We support displaying
two symbols in software (via blinking).
This patch provides support for the A4M072 board with the following features:
UART
NOR flash
FEC Ethernet
External SRAM
I2C EEPROM
CompactFlash cards on IDE/ATA port
USB Host
PCI initialization
The 7-segment LED indicator is not yet supported.
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
PDM360NG board uses this functionality to pass display
timing info to the Linux Framebuffer driver.
Acked-by: Detlev Zundel <dzu@denx.de>
Microblaze hasn't supported NET_MULTI support.
This patch proposes to migrate the davinci_emac driver to using the
eth_device->write_hwaddr function pointer as suggested by Ben Warren.
All the davinci boards had the behaviour, prior to this patch, of
sync'ing the environment variable enetaddr with the MAC address read
from non-volatile storage on boot -- when the two locations disagreed,
the environment variable value took precendence. This patch keeps the
same behaviour but lets eth_initialize take care of it.
This patch refactors davinci_emac setup in the boards so that the MAC
address is read from non-volatile storage into the environment variable
and then the environment variable value is use in eth_intialize. The
only exception is the direct call to davinci_eth_set_mac_addr made by
the da830evm board init which was changed into an assignment of the
enetaddr field.
Tested-by: Nick Thompson <nick.thompson@ge.com>
Freescale application note AN3638 describes an update to the NXID format,
which stores MAC addresses and related data on an on-board EEPROM. The new
version adds support for up to 23 MAC addresses, instead of just 8. Since
the initial implementation of NXID had a "0" in the 'version' field, this
new version is called "v1".
Boards that are shipped with EEPROMs in the NXID v1 format should define
CONFIG_SYS_I2C_EEPROM_NXID_1 instead of CONFIG_SYS_I2C_EEPROM_NXID.
We configure the controller but dont have virtual address space thus any
devices on the 4th controller are not accessible in u-boot.
Update the code which writes to the on-board EEPROM so that it can detect if
the write failed because the EEPROM is write-protected. Most of the 8xxx-class
Freescale reference boards use an AT24C02 EEPROM to store MAC addresses and
similar information. With this patch, if the EEPROM is protected, the
"mac save" command will display an error message indicating that the write
has not succeeded.
The Freescale P1022DS can use either a 12.288MHz or a 11.2896MHz reference
clock for the audio codec, but by default both are disabled. Add a 'audclk'
hwconfig option that allows the user to choose which clock he wants.
The 12.288MHz clock allows the codec to use sampling rates of 16, 24, 32, 48,
64, and 96KHz. The 11.2896 clock allows 14700, 22050, 29400, 44100, 58800, and
88200Hz.
Also configure a pin muxing to select some SSI signals, which will disable
I2C1.
Enable half drive strength, set RTT to 60Ohm and set write leveling override.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
The original code maps boot flash as non-cacheable region. When calling
relocate_code in flash to copy u-boot from flash to ddr, every loop copy command
is read from flash. The flash read speed will be the bottleneck, which consuming
long time to do this operation. To resovle this, map the boot flash as
write-through cache via tlb. And set tlb to remap the flash after code
executing in ddr, to confirm flash erase operation properly done.
Signed-off-by: Kai.Jiang <Kai.Jiang@freescale.com>
Provides a small speed increase and prepares for fully relocatable image.
Downside is the TEXT_BASE, bss, load address etc must ALL be aligned on a
a 4-byte boundary which is not such a terrible restriction as everything
is already 4-byte aligned anyway
Tidy up the linker script and discard some sections to save space
Create more generic names for the symbols exported from the linker script
Using %ebp as a return pointer prevents creating 'load anywhere' images
Progress indication is not relocation friendly so remove it in
preperation for full relocatability support
Follow the discussion of Charles Manning and Mike Frysinger.
Using gc_sections helps reduce image size.
