path: root/board
2011-09-30mx31pdk: Place machine ID into board configFabio Estevam
Let common code set the machine ID. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-30imx31_litekit: Remove dram_init_banksize()Fabio Estevam
As only one RAM bank is used we can rely on the code from arch/arm/lib/board.c Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-30mx31ads: Remove dram_init_banksize()Fabio Estevam
2011-09-30mx25pdk: Remove dram_init_banksize()Fabio Estevam
2011-09-30mx31pdk: Remove dram_init_banksize()Fabio Estevam
2011-09-30MX25: Add initial support for MX25PDKFabio Estevam
Add the initial support for MX25PDK booting from SD card via internal boot. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-30MX25: tx25: Avoid the usage of extern in C fileFabio Estevam
Avoid the usage of extern in C file as pointed out by checkpatch. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-30devkit8000: Add nand-spl support for new SPLSimon Schwarz
Add NAND SPL support to the devkit8000 config Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-30overo: Set IEN on GPMC_CLK to support synchronous clocking.Philip Balister
Without this change CS's configured for synchronous clocking cannot read data. Signed-off-by: Philip Balister <philip@opensdr.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-30OMAP3: Overo: Update GPMC timing for ethernet chipPhilip Balister
The existing timing does not quite meet the minimum requirements in the LAN9221 datasheet. The timing in this patch solves problems noticed on some parts. The patch also combines the CS configuration for the overo and igep0020 boards per request. Signed-off-by: Philip Balister <philip@opensdr.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-30Armada100: Enable 88E3015 PHY support for GplugDAjay Bhargav
This patch adds support for 88E3015 PHY for Marvell GplugD board. This patch depends on series of patch which adds support for Marvell GuruPlug-Display. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-09-30Armada100: Enable Ethernet support for GplugDAjay Bhargav
This patch enables ethernet support for Marvell GplugD board. Network related commands works. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-09-28ARM: versatile: delete split_by_variant.shLinus Walleij
Since commit d388298a59ba375c76597b8f95b560afa971a0fb by Stefano Babic this file is no longer needed so delete it. Cc: Stefano Babic <sbabic@denx.de> Cc: Loïc Minier <loic.minier@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-27ARM: remove broken "ixdp425" and "ixpdg425" boardsAlbert ARIBAUD
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Stefan Roese <sr@denx.de>
2011-09-22OMAP3: beagle: Fix build warning in beagle.cDirk Behme
Fix build warning beagle.c:532: warning: initialization from incompatible pointer type Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> CC: Jason Kridner <jkridner@beagleboard.org> CC: Koen Kooi <koen@dominion.thruhere.net> CC: Joel A Fernandes <agnel.joel@gmail.com> Cc: Greg Turner <gregturner@ti.com> CC: Sandeep Paulraj <s-paulraj@ti.com> Acked-by: Jason Kridner <jkridner@beagleboard.org>
2011-09-21km/common: fix bug in IVM mac address accessHolger Brunck
The MAC address stored in the inventory eeprom begins at offset 1. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Wolfgang Denk <wd@denx.de>
2011-09-13led: remove camel casing of led identifiers globallyJason Kridner
Result of running the following command to address Wolfgang's comment about camel case: for file in `find . | grep '\.[chS]$'`; do perl -i -pe 's/(green|yellow|red|blue)_LED_(on|off)/$1_led_$2/g' $file; done Discussion: http://patchwork.ozlabs.org/patch/84988/ Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-13omap4: fix pad configuration settings for SDP and PandaAneesh V
omap4: fix pad configuration settings for SDP and Panda Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sebastien Jan <s-jan@ti.com> Signed-off-by: David Anders <x0132446@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-13omap: gpio: Adapt board files to use generic APISanjeev Premi
This patch contains updates the sources in the board files to use the generic API. Signed-off-by: Sanjeev Premi <premi@ti.com>
2011-09-12MX25: tx25: Fix build by making use of GPIO frameworkFabio Estevam
Make use of GPIO framework and avoid the following build error: tx25.c: In function 'tx25_fec_init': tx25.c:73: error: dereferencing pointer to incomplete type tx25.c:74: error: dereferencing pointer to incomplete type tx25.c:75: error: dereferencing pointer to incomplete type tx25.c:76: error: dereferencing pointer to incomplete type tx25.c:83: error: dereferencing pointer to incomplete type tx25.c:84: error: dereferencing pointer to incomplete type tx25.c:114: error: dereferencing pointer to incomplete type tx25.c:115: error: dereferencing pointer to incomplete type tx25.c:116: error: dereferencing pointer to incomplete type tx25.c:117: error: dereferencing pointer to incomplete type tx25.c:124: error: dereferencing pointer to incomplete type tx25.c:125: error: dereferencing pointer to incomplete type tx25.c:126: error: dereferencing pointer to incomplete type Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2011-09-10ARM: hawkboard: fix compilation of nand_splWolfgang Denk
Fix build problem: nand_spl/board/davinci/da8xxevm/hawkboard_nand_spl.c: In function 'board_init_f': nand_spl/board/davinci/da8xxevm/hawkboard_nand_spl.c:132: warning: implicit declaration of function 'nand_boot' nand_spl/board/davinci/da8xxevm/hawkboard_nand_spl.c:133: warning: 'noreturn' function does return Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Syed Mohammed Khasim <sm.khasim@gmail.com> Cc: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-09-10cm4008, cm41xx: fix build warningsWolfgang Denk
Fix these: cm4008.c: In function 'board_eth_init': cm4008.c:79: warning: implicit declaration of function 'ks8695_eth_initialize' cm41xx.c: In function 'board_eth_init': cm41xx.c:79: warning: implicit declaration of function 'ks8695_eth_initialize' While we are at it, sort include list in netdev.h Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Greg Ungerer <greg.ungerer@opengear.com>
2011-09-10KS8695: convert KS8695 eth driver to CONFIG_MULTI_ETHGreg Ungerer
Trivial conversion of the ks8695eth driver to a CONFIG_MULTI_ETH type driver. Signed-off-by: Greg Ungerer <greg.ungerer@opengear.com>
2011-09-10CM41xx: fix signedness of env bootargs string pointerGreg Ungerer
The pointer to the flash based bootargs should be a "char *", not unsigned. Fixes: cm41xx.c: In function ‘env_flash_cmdline’: cm41xx.c:67: warning: pointer targets in passing argument 2 of ‘setenv’ differ in signedness Signed-off-by: Greg Ungerer <greg.ungerer@opengear.com>
2011-09-10CM4008: fix signedness of env bootargs string pointerGreg Ungerer
The pointer to the flash based bootargs should be a "char *", not unsigned. Fixes: cm4008.c: In function ‘env_flash_cmdline’: cm4008.c:67: warning: pointer targets in passing argument 2 of ‘setenv’ differ in signedness Signed-off-by: Greg Ungerer <greg.ungerer@opengear.com>
2011-09-10Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mpc85xx: powerpc/mpc8610hpcd: set pci1_hose.config_table after fsl_setup_hose powerpc/mpc8548cds: set pci1_hose.config_table after fsl_setup_hose powerpc/mpc8568mds: set pci1_hose.config_table after fsl_setup_hose
2011-09-10CM4000: fix broken flash base for OpenGear boardsGreg Ungerer
Use _bss_start_ofs as the size of the boot loader code+data that we want to protect in the flash. This replaces use of the no longer defined _armboot_start. Fixes: flash.c: In function ‘flash_init’: flash.c:75: error: ‘_bss_start’ undeclared (first use in this function) flash.c:75: error: (Each undeclared identifier is reported only once flash.c:75: error: for each function it appears in.) flash.c:75: error: ‘_armboot_start’ undeclared (first use in this function) Signed-off-by: <greg.ungerer@opengear.com>
2011-09-09powerpc/mpc8610hpcd: set pci1_hose.config_table after fsl_setup_hoseZhao Chenhui
The function fsl_setup_hose clears the variable pci1_hose. Set pci1_hose.config_table after it. Signed-off-by: Zhao Chenhui <chenhui.zhao@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-09-09powerpc/mpc8548cds: set pci1_hose.config_table after fsl_setup_hoseZhao Chenhui
2011-09-09powerpc/mpc8568mds: set pci1_hose.config_table after fsl_setup_hoseZhao Chenhui
2011-09-07arm: tegra2: fix out-of-tree buildChe-liang Chiou
The out-of-tree build fails because the Makefiles in question depend on source files of another directory but do not explicitly mkdir that directory. As a matter of fact, other Makefiles under board/*/ directory that refer to source files under another directory explicitly call mkdir. This patch adds explicit mkdir's to the Makefiles in question, and verifies that out-of-tree build is working. Signed-off-by: Che-Liang Chiou <clchiou@chromium.org> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2011-09-07da8xxevm: Fix warning: unused variable 'val'Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
2011-09-07ARM: PXA: remove broken "zylonite" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Marek Vasut <marek.vasut@gmail.com> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-09-07ARM: remove broken "shannon" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Rolf Offermanns <rof@sysgo.de>
2011-09-07ARM: remove broken "modnet50" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Thomas Elste <info@elste.org>
2011-09-07ARM: remove broken "lpc2292sodimm" board.Wolfgang Denk
2011-09-07ARM: remove broken "lart" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Alex Züpke <azu@sysgo.de>
2011-09-07ARM: remove broken "impa7" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Marius Gröger <mag@sysgo.de>
2011-09-07ARM: remove broken "gcplus" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: George G. Davis <gdavis@mvista.com>
2011-09-07ARM: remove broken "evb4510" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Curt Brune <curt@cucy.com>
2011-09-07ARM: remove broken "ep7312" board.Wolfgang Denk
2011-09-07ARM: remove broken "dnp1110" board.Wolfgang Denk
2011-09-07ARM: remove broken "SMN42" board.Wolfgang Denk
2011-09-07Makefile : fix generation of cpu related asm-offsets.hStefano Babic
commit 0edf8b5b2fa0d210ebc4d6da0fd1aceeb7e44e47 breaks building on a different directory with the O= parameter. The patch wil fix this issue, generating always asm-offsets.h before the other targets. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Matthias Weisser <weisserm@arcor.de> CC: Wolfgang Denk <wd@denx.de>
2011-09-05board/prodrive/alpr/fpga.c: Coding style cleanupWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2011-09-05PPC4xx: ALPR: constify FPGA codeWolfgang Denk
The ALPR custom FPGA code was missed by commit e6a857d "fpga: constify to fix build warning" resulting in such warnings: fpga.c:226: warning: initialization from incompatible pointer type Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2011-09-05MPC8xx: fix build problem for ETX094 boardWolfgang Denk
Commit 58c583b "net: Check network device driver name" increased the code size and broke building for the ETX094 board. Adjust the linker script to make it build again. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-09-05linkstation: fix warning: "CONFIG_IDENT_STRING" redefinedWolfgang Denk
Commit 09c2e90 "unify version_string" defines a default value for CONFIG_IDENT_STRING in version.h, so any private settings musty be done before including this file. Move the include for version.h after the one for common.h to fix the build problem. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
2011-09-04Merge branch 'master' of git://git.denx.de/u-boot-coldfireWolfgang Denk
* 'master' of git://git.denx.de/u-boot-coldfire: ColdFire:Clean up the CONFIG_STANDALONE_LOAD_ADDR usage ColdFire:Add mb for 5253 dram initialization ColdFire:Define the DM9000 byteswap for M5253 board. ColdFire:Update the env settings for several boards. ColdFire:disable the NFS define for 52277 board. ColdFire:Update the timer_init since it was unified. ColdFire: Cleanup for partial linking and --gc-sections ColdFire: Update compile flags for each CPUs ColdFire:Fix the configuration broken for some boards.
2011-09-04ColdFire:Add mb for 5253 dram initializationJason Jin
The dram initialization sequence should be in order. This patch add mb for the dram intialization code to make sure the compiler do not disorder the code. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
