- fix: return-value of 'i2c_set_bus_speed' was interpreted wrong
Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
The switch HW reset results in a disconnection of the switch port daisy-
chain for a few seconds. This is not desired in the normal field use
case. So lets remove this switch reset from the normal bootup sequence
and move it into a board specific command. This way it can be executed
in the development environment when really needed.
Cc: Roger Meier <r.meier@siemens.com>
Cc: Lukas Stockmann <lukas.stockmann@siemens.com>
Cc: Tom Rini <trini@ti.com>
Many USB host controller drivers contain almost identical copies of the
same virtual root hub descriptors. Put these into a common file to avoid
duplication.
Note that there were some very minor differences between the descriptors
in the various files, such as:
- USB 1.0 vs. USB 1.1
- Manufacturer/Device ID
- Max packet size
- String content
I assume these aren't relevant.
Cc: Thomas Lange <thomas@corelatus.se>
Cc: Shinya Kuribayashi <skuribay@pobox.com>
Cc: Gary Jennejohn <garyj@denx.de>
Cc: Eric Millbrandt <emillbrandt@coldhaus.com>
Cc: Pierre Aubert <p.aubert@staubli.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Daniel Hellstrom <daniel@gaisler.com>
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Rodolfo Giometti <giometti@linux.it>
Cc: Zhang Wei <wei.zhang@freescale.com>
Cc: Mateusz Zalega <m.zalega@samsung.com>
Cc: Remy Bohmer <linux@bohmer.net>
Cc: Markus Klotzbuecher <mk@denx.de>
Cc: C Nauman <cnauman@diagraph.com>
Cc: David Müller <d.mueller@elsoft.ch>
Cc: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Cc: Thomas Abraham <t-abraham@ti.com>
Cc: Andrew Murray <amurray@embedded-bits.co.uk>
Cc: Matej Frančeškin <matej.franceskin@comtrade.com>
Cc: Cliff Cai <cliff.cai@analog.com>
Cc: Bryan Wu <cooloney@gmail.com>
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
Acked-by: Rob Herring <robh@kernel.org>
CONFIG_SYS_HZ must be always 1000, but M5271EVB.h defines it
as 1000000 and idmr.h defines it as (50000000 / 64).
When compiling these two boards, a warning message is displayed:
time.c:14:2: warning: #warning "CONFIG_SYS_HZ must be 1000
and should not be defined by platforms" [-Wcpp]
There are no board maintainers for them so this commit just
deletes them.
Cc: Jason Jin <Jason.jin@freescale.com>
Add NAND SPL boot support with hardware PMECC.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Add SPI SPL boot support for sama5d3xek board.
Add sama5d3 Xplained board support which use Atmel SAMA5D36 SoC.
Now it supports boot from NAND flash and SD/MMC card.
Features support:
- NAND flash
- SD/MMC card
- Two USB hosts
- Ethernet (one GMAC, one EMAC)
[reorder boards.cfg]
Add support for using the Atmel MCI driver on at91sam9263ek.
This change is modeled after the existing at91sam9260ek support.
Please note that this hooks up slot1 (MCI1) for SD. Not both.
Tested with at91bootstrap and u-boot on dataflash in slot 0
and fat-formatted 8GB SDHC in slot 1 on first revision
at91sam9263ek (which must use dataflash in slot0 to boot).
CONFIG_ATMEL_MCI_PORTB not tested.
Signed-off-by: Andreas Henriksson <andreas.henriksson@endian.se>
[remove empty line]
Update following DDR related settings for T1040RDB, T1042RDB_PI
-Correct number of chip selects to two as t1040 supports
two Chip selects.
-Update board_specific_parameters udimm structure with settings
derived via calibration.
-Update ddr_raw_timing sructure corresponding to DIMM.
-Set ODT to off. Typically on FSL board, ODT is set to 75 ohm,
but on T104xRDB, on setting this , DDR instability is observed.
Board-level debugging is in progress.
Verified the updated settings to be working fine with dual-ranked
Micron, MT18KSF51272AZ-1G6 DIMM at data rate 1600MT/s.
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
Signed-off-by: York Sun <yorksun@freescale.com>
T1040 has internal display interface unit (DIU) for driving video.
T1040QDS supports video mode via
-LCD using TI enconder
-HDMI type interface via HDMI encoder
Chrontel, CH7301C encoder which is I2C programmable is used as
HDMI connector on T1040QDS.
This patch add support to
-enable Video interface for T1040QDS
-route qixis multiplexing to enable DIU-HDMI interface on board
-program DIU pixel clock gerenartor for T1040
-program HDMI encoder via I2C on board
Reviewed-by: York Sun <yorksun@freescale.com>
T2080PCIe-RDB is a Freescale Reference Design Board that hosts the T2080 SoC.
It works in two mode: standalone mode and PCIe endpoint mode.
T2080PCIe-RDB Feature Overview
Processor:
- T2080 SoC integrating four 64-bit dual-threads e6500 cores up to 1.8GHz
DDR Memory:
- Single memory controller capable of supporting DDR3 and DDR3-LP devices
- 72bit 4GB DDR3-LP SODIMM in slot
Ethernet interfaces:
- Two 10M/100M/1G RGMII ports on-board
- Two 10Gbps SFP+ ports on-board
- Two 10Gbps Base-T ports on-board
Accelerator:
- DPAA components consist of FMan, BMan, QMan, PME, DCE and SEC
SerDes 16 lanes configuration:
- SerDes-1 Lane A-B: to two 10G XFI fiber (MAC9 & MAC10)
- SerDes-1 Lane C-D: to two 10G Base-T (MAC1 & MAC2)
- SerDes-1 Lane E-H: to PCIe Goldfinger (PCIe4 x4, Gen3)
- SerDes-2 Lane A-D: to PCIe Slot (PCIe1 x4, Gen2)
- SerDes-2 Lane E-F: to C293 secure co-processor (PCIe2 x2)
- SerDes-2 Lane G-H: to SATA1 & SATA2
IFC/Local Bus:
- NOR: 128MB 16-bit NOR flash
- NAND: 512MB 8-bit NAND flash
- CPLD: for system controlling with programable header on-board
eSPI:
- 64MB N25Q512 SPI flash
USB:
- Two USB2.0 ports with internal PHY (both Type-A)
PCIe:
- One PCIe x4 gold-finger
- One PCIe x4 connector
- One PCIe x2 end-point device (C293 Crypto co-processor)
SATA:
- Two SATA 2.0 ports on-board
SDHC:
- support a TF-card on-board
I2C:
- Four I2C controllers.
UART:
- Dual 4-pins UART serial ports
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Change QIXIS timing parameter CONFIG_SYS_CS3_FTIM2 to 8 from 0.
Fix EMI2 for t2080qds, which was caused by adding t2081qds.
SerDes PLLs may not lock reliably at 5 G VCO configuration(A006384)
and at cold temperatures(A006475), workaround recalibrate the
PLLs with some SerDes configuration
Both these errata are only applicable for b4 rev1.
So, make workaround for these errata conditional,
depending upon soc version.
Signed-off-by: Shaveta Leekha <shaveta@freescale.com>
Change setting of SerDes2 refclk2 to have the default value as it is
coming on board that is 156.25MHz, for XFI to work.
Also change PLL_NUM variable to the one defined in config_mpc85xx.h
for B4860 and B4420.
On B4860 and B4420, some serdes protocols can be used with LC VCO as
well as Ring VCO options.
Addded Alternate options with LC VCO for such protocols.
For example protocol 0x2a on srds 1 becomes 0x29 if it is LC VCO.
The alternate option has the same functionality as the original option;
the only difference being LC VCO rather than Ring VCO.
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
1) SerDes2 Refclks have been set properly to make
PCIe SATA to work as it work on SerDes refclk of 100MHz
2) Mask the SerDes's device reset request before changing
the Refclks for SerDes1 and SerDes2 for PLL locks to
happen properly, device reset request bit unmasked
after SerDes refclks configuration
1) Add new SerDes1 protocols having Aurora in them
2) Add VSC cross point connections for Aurora to work with
CPRI and SGMIIs
3) Configure VSC crossbar switch to connect SerDes1
lanes to aurora on board, by checking SerDes1 protocols
4) SerDes1 Refclks have been set properly to make
Aurora, CPRI and SGMIIs to work together properly
Before this commit, CONFIG_MPC8260 and CONFIG_8260
were used mixed-up.
All boards with mpc8260 cpu defined both of them:
- CONFIG_MPC8260 was defined in board config headers
and include/common.h
- CONFIG_8260 was defined arch/powerpc/cpu/mpc8260/config.mk
We do not need to have both of them.
This commit keeps only CONFIG_MPC8260.
This commit does:
- Delete CONFIG_8260 and CONFIG_MPC8260 definition
in config headers and include/common.h
- Rename CONFIG_8260 to CONFIG_MPC8260
in arch/powerpc/cpu/mpc8260/config.mk.
- Rename #ifdef CONFIG_8260 to #ifdef CONFIG_MPC8260
Many (but not all) of Blackfin boards give -O2 option
to compile under lib/ directory.
That means lib/ should be speed-optimized,
whereas other parts should be size-optimized.
We want to keep the same behavior,
but do not want to parse board/*/config.mk again and again.
We've got no choice but to invent a new method.
CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED, if it is enabled,
gives -O2 flag only for building under lib/ directory.
Dirty codes which I had marked as "FIX ME"
in board/${BOARD}/config.mk have been deleted.
Instead, CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED has been
defined in include/configs/${BOARD}.h.
Cc: Sonic Zhang <sonic.zhang@analog.com>
As ppc4xx currently only supports the deprecated nand_spl infrastructure
and nobody seems to have time / resources to port this over to the newer
SPL infrastructure, lets remove NAND booting completely.
This should not affect the "normal", non NAND-booting ppc4xx platforms
that are currently supported.
Cc: Tirumala Marri <tmarri@apm.com>
Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Tested-by: Matthias Fuchs <matthias.fuchs@esd.eu>
config.tmp is never generated
Cc: Michal Simek <michal.simek@xilinx.com>
Acked-by: Michal Simek <michal.simek@xilinx.com>
B&R boards are using Phy Addresses 'one' and 'two', prior this was
defined through #define PHYADDR 1 within a header file.
Now this is addresses are given with device-driver structure.
omap_gpmc.h is a generic header used by OMAP NAND driver for all TI platfoms.
Hence this file should be present in generic folder instead of architecture
specific include folder.
Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5
Signed-off-by: Pekon Gupta <pekon@ti.com>
There are no source files in board/synopsys/arcangel4/
directory.
Cc: Alexey Brodkin <Alexey.Brodkin@synopsys.com>
config.tmp is not there.
Ignore
- board/cray/L1/bootscript.{c|image}
- board/matrix_vision/mvblm7/bootscript.img
- board/maxtir_vision/mvsmr/bootscript.img
Cc: Andre Schwarz <andre.schwarz@matrix-vision.de>
The same outputs are generated with or without -I$(TOPDIR)/board.
I cannot understand why it is necessary. Remove.
Convert sandbox over to use driver model GPIOs.
Copied from Linux sources "include/linux/sizes.h" commit
413541dd66d51f791a0b169d9b9014e4f56be13c
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Acked-by: Tom Rini <trini@ti.com>
[trini: Add bcm Kona platforms to the patch]
Since the switch may be re-configured for VLAN usage in Linux (or any
other OS), lets reset the switch to its default register values upon
power-up. Otherwise network might not be available in U-Boot.
Add Ethernet Boot support to SPL
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
Updating EMIF_PHY_CTRL and adding EMIF_READ_WRITE_EXECUTION_THRESHOLD
registers.
In EMIF_PHY_CTRL:
Updating [4:0]READ_LATENCY to 8, because at higher frequencies like
400MHz the read latency expected will be CL+3 as per tests from HW
folks.
Clearing [19]PHY_DIS_CALIB_RST bit as this is used onl for debug
purpose. With out this resume is not working(Still waiting for PHY team
to come back for better explanation).
Adding support for reading cpsw 2nd mac address from efuse and pass it
to kernel via dtb which will be used in dual emac mode of cpsw.
Also correct the bit masking of mac id read from the efuse.
Also adding mii command support to am335x common config.
Adding support for CPSW to AM43xx EPOS nad GP EVM which is connected
to RMII and RGMII phy respectively and enable cpsw in config.
Reviewed-by: Felipe Balbi <balbi@ti.com>
Some platforms like AM437x have different EVMs with different phy addresses,
so this patch adds support for passing phy address via cpsw plaform data.
Also renamed phy_id to phy_addr so better understanding of the code.
[trini: Update BuR am335x_igep0033 pcm051_rev3 pcm051_rev1 cm_t335
pengwyn boards]
board/sheldon/simpc8313/config.mk is used only for nand_spl.
So it should go into nand_spl/board/sheldon/simpc8313/.
Read ram size directly from DTB.
NAND boot mode on AM335x EVM has been verified, and steps
to use it has been documented and update in this README
Acked-by: Peter Korsgaard <jacmet@sunsite.dk>
arch/arm/cpu/armv7/config.mk
board/ti/am43xx/mux.c
include/configs/am43xx_evm.h
Remove the last uses of symbol offsets in ARM U-Boot.
Remove some needless uses of _TEXT_BASE.
Remove all _TEXT_BASE definitions.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
This prevents references to _end from generating absolute
relocation records.
This change is binary invariant for ARM targets.
Newly added cm_t335 was missed in commit 47ed5dd0 which
made ARM targets produce full ELF files. Fix its linker
script.
This change is binary-invariant when only .dynsym, .dynstr,
.dynamic, .plt, .interp and .gun sections are declared.
Sections .hash, .got.plt, .dynbss and .ARM.exidx are also
declared so that their (unused) content is moved out of the
u-boot binary.
With this, fixup a trivial build error of get_effective_memsize needing
to be updated in the new board/freescale/p1010rdb/spl.c
Rename OBJCFLAGS to OBJCOPYFLAGS beforehand to use
"cmd_objcopy" in scripts/Makefile.lib in an upcoming commit.
