Signed-off-by: Dirk Eibach <eibach@gdsys.de>
The Arches Evaluation board is based on the AMCC 460GT SoC chip.
This board is a dual processor board with each processor providing
independent resources for Rapid IO, Gigabit Ethernet, and serial
communications. Each 460GT has it's own 512MB DDR2 memory, 32MB NOR
FLASH, UART, EEPROM and temperature sensor, along with a shared debug
port. The two 460GT's will communicate with each other via shared
memory, Gigabit Ethernet and x1 PCI-Express.
Signed-off-by: Adam Graham <agraham@amcc.com>
Signed-off-by: Victor Gallardo <vgallardo@amcc.com>
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
This patch based on Andy's work.
Including command 'pixis_set_sgmii' support.
Signed-off-by: Liu Yu <yu.liu@freescale.com>
The pixis sgmii command depend on the FPGA support on the board, some 85xx
boards support SGMII riser card but did not support this command, define
CONFIG_PIXIS_SGMII_CMD for those boards which support the sgmii command.
Not like 8544, 8572 has 4 eTsec so that the other two's pixis bits
are not supported by 8544. Therefor, define PIXIS_VSPEED2_MASK and
PIXIS_VCFGEN1_MASK in header file for both boards.
mpc8572 supports all pcie controllers as end-points with cfg_host_agent=0.
Include host_agent == 0 decode for end-point determination.
This is not needed for the ds reference board since pcie3 will be a host
in order to connect to the uli chip. Include it here as a reference for
other mpc8572 boards.
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
* Add board specific parameter table to choose correct cpo, clk_adjust,
write_data_delay based on board ddr frequency and n_ranks.
* Set odt_rd_cfg and odt_wr_cfg based on the dimm# and CS#.
Signed-off-by: James Yang <James.Yang@freescale.com>
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
write_data_delay, 2T based on board ddr frequency and n_ranks.
* Set memory controller interleaving mode to bank interleaving, and disable
bank(chip select) interleaving mode by default, because the default on-board
DDR DIMMs are 2x512MB single-rank.
* Change CONFIG_ICS307_REFCLK_HZ from 33333333 to 33333000.
Because some dimm parameters like n_ranks needs to be used with the board
frequency to choose the board parameters like clk_adjust etc. in the
board_specific_paramesters table of the board ddr file, we need to pass
the dimm parameters to the board file.
* move ddr dimm parameters header file from /cpu to /include directory.
* add ddr dimm parameters to populate board specific options.
* Fix fsl_ddr_board_options() for all the 8xxx boards which call this function.
Changing the flash from cacheable to cache-inhibited was taking a significant
amount of time due to the fact that we were iterating over the full 256M of
flash. Instead we can just flush the L1 d-cache and invalidate the i-cache.
in ft_blob_update () for both boards was an unneccessary
repetition of code, which this patch moves in a common
function for this boards.
The EEprom contains some Manufacturerinformation,
which are read from u-boot at boot time, and saved
in same hush shell variables.
As documented in doc/I2C_Edge_Conditions, adding a
board specific deblocking mechanism via CFG_I2C_INIT_BOARD
for the mgcoge and mgsuvd board.
This code was originally written by Keymile in association
with Anatech and Atmel in 1998. The Code toggels the SCL
until the SCA line goes to HIGH (max. 16 times).
And after this, a start condition is sent.
This is another approach to deblock the I2C Bus. The
soft I2C driver actually sends 9 clocks with SDA High,
and then a stop at the end, to deblock the I2C Bus.
Maybe we should use the approach from Keymile as
the new standard?
There are some more extensions, which are for both boards
and some more boards from this manufacturer will follow soon.
Fix compiler warning introduced by commit 0f8cbc18
SGMII and SATA share the serdes on MPC8536 CPU, When SATA disabled and the
driver still try to access the SATA registers, the cpu will hangup.
This patch try to fix this by reading the serdes status before the SATA
initialize.
Acked-by: Andy Fleming <afleming@freescale.com>
When aligning malloc()ed screen_base, invalid offset was added.
This not only caused misaligned result (which did not cause hardware
misbehaviour), but - worse - caused screen_base + smem_len to
be out of malloc()ed space, which in turn caused breakage of
futher malloc()/free() operation.
This patch fixes screen_base alignment.
Also this patch makes memset() that cleans framebuffer to be executed
on first initialization of diu, not only on re-initialization. It looks
correct to clean the framebuffer instead of displaying random garbage;
I believe that was disabled only because that memset caused breakage
of malloc/free described above - which no longer happens with the fix
described above.
Signed-off-by: Nikita V. Youshchenko <yoush@debian.org>
This is no longer necessary now that the GD_FLG_RELOC flag is set for
all ARM boards.
Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
This patch fixes USB 2.0 communication issues on some DU440 boards.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
get_cpu_board_revision() returned board revision based on information stored
in global static struct eeprom. It should instead use one from local struct
board_eeprom, to which the data is actually read from EEPROM. The bug led to
system hang after printing L1 cache information on U-Boot startup. The problem
was observed on MPC8555CDS system and possibly affects other Freescale MPC85xx
boards using CFG_I2C_EEPROM_CCID.
The change has been successfully tested on MPC8555CDS system.
Signed-off-by: Rafal Czubak <rcz@semihalf.com>
The spd_dram code shifts the base address, then masks 20 bits, but
forgets to shift the base address back. Fix this by just masking the
base address correctly.
Found this bug while trying to relocate a DDR memory at the base != 0.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Depending on the configuration jumper "SATA SELECT", U-Boot disabled
either one PCIe node or the SATA node in the device tree blob. This
patch removes the unnecessary and even confusing warning, when the node
is not found at all.
Currently U-Boot crashes after relocation to RAM.
Changing the CPO value of the DDR SDRAM TIMING_CFG_2
register to READ_LAT + 1 (to the value it was before
conversion of socrates to new DDR code) fixes the
problem.
Add function of smc911x, pkt_data_pull and pkt_data_push.
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
After switching to using the CFI flash driver, the correct remapping
of the flash banks was forgotten.
Also, some boards were not adapted, and the old legacy flash driver
was not removed yet.
This patch is an attempt to implement autoprobing for the Lime
presence on the bus.
Configure GPCM for Lime CS2 and try to access chip ID registers.
Second read atempt delivers register values if the chip is present.
netdev.h was not include by r2dplus.
This patch fixes a problem introdiced with patch
bbeff30c [ppc4xx: Remove superfluous dram_init() call or replace it by
initdram()].
The boards affected are:
- PCI405
- PPChameleonEVB
- quad100hd
- taihu
- zeus
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es>
Signed-off-by: Claudio Scordino <claudio@evidence.eu.com>
