path: root/board
2011-06-09powerpc/p1022ds: set the clock-frequency prop only if the clock is enabledTimur Tabi
The clock-frequency property in an audio codec's device tree node is set to the input clock frequency for that codec. On the Freescale P1022DS board, the input clock is enabled only if the hwconfig 'audclk' option is set. Therefore, the property should only be set in the device tree if the clock is actually enabled. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-06-08Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: SMDK6400: fix the compiler error imx27lite: Remove local config.mk mx31ads: Fix environment location on flash imx31_litekit: Remove local config.mk mx31litekit: Fix boot with the new relocation scheme. mx31ads: Use the new relocation scheme
2011-06-08SMDK6400: fix the compiler errorMinkyu Kang
This patch adds _end for fix following compiler error arch/arm/cpu/arm1176/start.o: In function `_end_ofs': arch/arm/cpu/arm1176/start.S:61: undefined reference to `_end' Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-06-07imx27lite: Remove local config.mkFabio Estevam
Local board config.mk should be avoided. Place CONFIG_SYS_TEXT_BASE definition into the board config file instead. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-06-07imx31_litekit: Remove local config.mkFabio Estevam
Local board config.mk should be avoided. Place CONFIG_SYS_TEXT_BASE definition into the board config file instead. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2011-06-06mx31litekit: Fix boot with the new relocation scheme.Fabio Estevam
imx31_litekit has been converted to the new relocation scheme, but it does not boot. Make the boot functional by using board_early_init_f . Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Magnus Lilja <lilja.magnus@gmail.com>
2011-06-06mx31ads: Use the new relocation schemeFabio Estevam
This fixes the MX31ADS build by using the new relocation scheme. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Felix Radensky <felix@embedded-sol.com>
2011-06-03Blackfin: boards: build zlib dir with -O2Mike Frysinger
Now that the zlib code has been relocated to a dedicated subdir, make sure we still build it with -O2 for boards that want speed over size. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-06-02Minor coding style cleanupWolfgang Denk
2011-06-01Merge branch 'master' of git://git.denx.de/u-boot-shWolfgang Denk
* 'master' of git://git.denx.de/u-boot-sh: sh: sh7785lcr: Update BSC of USB area
2011-06-01SMDKV310: Fix incorrect conditional compilation for MIU linear mappingThomas Abraham
Fix the incorrect macro check for MIU linear mapping conditional compilation. Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2011-06-01SMDKV310: CPU fequency and mmc_pre_ratio modifiedChander Kashyap
Modifies CPU Frequency to 1GHz and removes hard coding of mmc_pre_ratio for MMC Channel2 in FSYS2 register. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2011-06-01armv7: Add support for ST-Ericsson U8500 href platformJohn Rigby
Minimal platform support to boot linux from SD. Supported devices/hw limited to external MMC/SD slot, GPIO, I2C and minimal PRCMU. Signed-off-by: John Rigby <john.rigby@linaro.org> CC: Albert Aribaud <albert.aribaud@free.fr>
2011-06-01sh: sh7785lcr: Update BSC of USB areaNobuhiro Iwamatsu
A value of BSC of the USB was wrong. This updates this. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-05-31ARMV7: Vexpress: Add missing MMC headerDirk Behme
Add a header file with the missing function prototype to fix ca9x4_ct_vxp.c: In function 'cpu_mmc_init': ca9x4_ct_vxp.c:93: warning: implicit declaration of function 'arm_pl180_mmci_init' introduced by commit "ARMV7: Vexpress: Add MMC support" (f0c64526b7e51ba997a0f1baf9e74e6d497b957e) Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> CC: Andy Fleming <afleming@freescale.com> CC: Matt Waddel <matt.waddel@linaro.org>
2011-05-31arm/km: update mgcoge3un board supportHolger Brunck
We change default settings for egiga on mgcoge3un. The reason we need this is that we have the gig port on mgcoge3un connected using a back-to-back pair of PHYs. There are no magnetics and because of that the port has to be run with a fixd configuration and auto-negotiation must be disabled. In the default mode the egiga driver uses autoneg to determine port speed - which defaults to 1G (we need 100M full duplex). Add wait for the GPIO line connected to mgcoge3ne before starting mgcoge3un. A board specific ethernet present function was added, because on this board ethernet is always present. The BOCO FPGA access was enhanced and changed to use register definitions. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-05-31arm/km: rename mgcoge2un to mgcoge3unValentin Longchamp
The mgcoge2un target was only an intermediate step to mgcoge3un. For this reason the mgcoge2un support was moved to mgcoge3un, because it isn't needed to support both targets. We add the BootROM init file for the mgcoge3un memphis RAM. We also move the suen3 and suen8 boards into the correct category in the MAINTAINERS file. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-05-31arm/km: introduce bootcount env variable and clean km_armValentin Longchamp
This environment variable is used to set the bootcount address for the kernel. last_stage_init is not available for arm platforms. So the calls to set_km_var and set_bootcount_addr are done in misc_init_r. Additionally some unneeded printouts were removed. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-05-26ARMV7: Add support for Samsung SMDKV310 BoardChander Kashyap
SMDKV310 board is based on Samsung S5PV310 SOC. This SOC is very much similar to S5PC210. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-05-26S5P:SROM config code moved to s5p-common directoryChander Kashyap
SROM config code is made common for S5P series of boards. smdkc100.c now refers to s5p-common/sromc.c for SROM related subroutines. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-05-26SMDK2410: various cleanup/code style fixesDavid Müller (ELSOFT AG)
Signed-off-by: David Müller <d.mueller@elsoft.ch> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-05-26SMDK2410: use the CFI driver (and remove the old one)David Müller (ELSOFT AG)
2011-05-26SMDK2410: remove unneeded config.mkDavid Müller (ELSOFT AG)
2011-05-23BeagleBoard: fixed typo in typecastJason Kridner
Without this patch, you should get a warning. Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
2011-05-23MX5: drop config.mk from efikamx boardStefano Babic
Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Marek Vasut <marek.vasut@gmail.com>
2011-05-23mx5: board: code clean up for checkboard codeJason Liu
The boot cause code has been factor out to soc common code,we need drop the part from the board support code This patch also remove the redundant cpu version print Signed-off-by: Jason Liu <jason.hui@linaro.org>
2011-05-23MX51: vision2: Fix build for vision2 board.Fabio Estevam
config.mk should not be used in board directory and should be removed. Use the same approach for building the image as other MX51/MX53 boards. After this change vision2 board can be built again. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-05-23MX51: vision: Let video mode struct be independant of watchdog.Fabio Estevam
Currently the fb_videomode struct is only declared if CONFIG_HW_WATCHDOG is defined. Remove this dependancy and let the video struct always be declared. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-05-23MX53: Add initial support for MX53SMD board.Fabio Estevam
2011-05-23MX53: support for freescale MX53LOCO boardJason Liu
This patch add initial support for freescale MX53LOCO board. Network(FEC),SD/MMC,UART have been supported by this patch Signed-off-by: Jason Liu <jason.hui@linaro.org>
2011-05-22MPC8xx: Make SPD823TS board build againWolfgang Denk
Commit e59e356 "TFTP: net/tftp.c: add server mode receive" caused the size of some object files to grow which breaks the manually optimized linking for the SPD823TS board. Adjust linker script as needed. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-05-19Minor coding style cleanup.Wolfgang Denk
2011-05-19Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mpc85xx: powerpc/85xx: add support for env in MMC/SPI on corenet ds boards powerpc/85xx: Enable eSPI support on corenet ds boards
2011-05-18km/common: simplify default environmentHolger Brunck
This is a first step to simplify the default environment. Move all the environment variables which are only needed for debugging purpose to textfiles in the scripts directory. In case of debugging these files can be loaded via tftp into RAM and set via the env import command. Other variables are identified as obsolete and were removed. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de>
2011-05-18km/common: implement boardId HWkey checks as u-boot cmdThomas Herzmann
BoardId and HWKey are used to identify the HW class of a given board. The correct values are stored in the inventory eeprom. During creation time of a boot package the boardId and HWkey for the SW is stored in the default environment and burned into the flash. During boottime the values in the inventory and in the environment are compared to avoid starting of a SW which is not authorized for this board. Some bootpackages are allowed to run on a set of different boardId hwKey. In this case the environment variable boardIdListHex was added to the default environment. In this case the command iterates over the pair values and compares them with the values read from the inventory eeprom. The syntax of such a boardIdListHex value is e.g.: 158_1 159_1 159_2 Signed-off-by: Thomas Herzmann <thomas.herzmann@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de>
2011-05-18powerpc/85xx: add support for env in MMC/SPI on corenet ds boardsShaohui Xie
Signed-off-by: Shaohui Xie <b21989@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-05-18at91: reworked support for otc570 boardDaniel Gorsulowski
The otc570 board support was broken. Within this opportunity, I completely reworked the board files. Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
2011-05-18hammerhead: move CONFIG_SYS_TEXT_BASE to headerAndreas Bießmann
Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-05-18mimc200: move CONFIG_SYS_TEXT_BASE to headerAndreas Bießmann
2011-05-18favr-32-ezkit: move CONFIG_SYS_TEXT_BASE to headerAndreas Bießmann
2011-05-18atstk100x: move CONFIG_SYS_TEXT_BASE to headerAndreas Bießmann
2011-05-18atngw100: move CONFIG_SYS_TEXT_BASE to headerAndreas Bießmann
2011-05-18avr32: use single linker scriptAndreas Bießmann
This patch move the atstk100x linker script to $(CPUDIR) and delete other pure copies of this file in each board directory. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-05-18avr32/config.mk: simplify PLATFORM_RELFLAGSAndreas Bießmann
This patch removes PLATFORM_RELFLAGS from board specific config.mk files and define them in arch specific config.mk file. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-05-18avr32: fix linkingAndreas Bießmann
This patch fixes following error: ---8<--- avr32-linux-ld: --gc-sections and -r may not be used together --->8--- Since 8aba9dceebb14144e07d19593111ee3a999c37fc all avr32 boards are broken due to linking error as seen above. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-05-18avr32: fixup definitions to ATMEL_BASE_xxxAndreas Bießmann
2011-05-18avr32: rename memory-map.h -> hardware.hAndreas Bießmann
2011-05-12Fix a few gcc warnings.Joakim Tjernlund
Noticed while building all of mpc8xx. Also constify usage string in timer.c Warnings fixed are: timer.c: In function 'timer': timer.c:189: warning: format not a string literal and no format arguments timer.c:258: warning: format not a string literal and no format arguments atm.c: In function 'atmUnload': atm.c:99: warning: array subscript is above array bounds atm.c: In function 'atmLoad': atm.c:65: warning: array subscript is above array bounds codec.c: In function 'codsp_write_pop_int': codec.c:678: warning: array subscript is above array bounds codec.c: In function 'codsp_write_cop_short': codec.c:585: warning: array subscript is above array bounds codec.c: In function 'codsp_write_sop_int': codec.c:512: warning: array subscript is above array bounds Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2011-05-12Fix incorrect use of getenv() before relocationWolfgang Denk
A large number of boards incorrectly used getenv() in their board init code running before relocation. In some cases this caused U-Boot to hang when certain environment variables grew too long. Fix the code to use getenv_r(). Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: The LEOX team <team@leox.org> Cc: Michael Schwingen <michael@schwingen.org> Cc: Georg Schardt <schardt@team-ctech.de> Cc: Werner Pfister <Pfister_Werner@intercontrol.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Peter De Schrijver <p2@mind.be> Cc: John Zhan <zhanz@sinovee.com> Cc: Rishi Bhattacharya <rishi@ti.com> Cc: Peter Tyser <ptyser@xes-inc.com>
2011-05-12MPC8260: Fix compile problems with "hymod" boardWolfgang Denk
Commit 9d8fbd1 "powerpc, 8xx: Fixup all 8xx u-boot.lds scripts" broke building of the MPC8260 based "hymod" board. Fix this. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Murray Jensen <Murray.Jensen@csiro.au> Cc: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
