path: root/board
2013-05-15Merge branch 'master' of git://www.denx.de/git/u-boot-mpc85xxTom Rini
2013-05-15Power: remove support for Freescale MPC8220Wolfgang Denk
The Freescale MPC8220 Power Architecture processors have long reached EOL; Freescale does not even list these any more on their web site. Remove the code to avoid wasting maitaining efforts on dead stuff. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andy Fleming <afleming@gmail.com>
2013-05-14T4240/eth: fix SGMII card PHY addressShaohui Xie
QSGMII card assumed to be used by default, but if SGMII card is used, it will use different PHY address, but we don't know which card is used until we access PHY on the card. So we check the card type slot by slot, if we can read a PHY ID by reading a SGMII PHY address on a slot, then the slot must have a SGMII card pluged, we mark all ports on that slot, and fix dts to use the SGMII card PHY address when doing dts fixup for the marked ports. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14powerpc/t4qds: Fix disabling remote I2C connectionEd Swarthout
Only clear IRE bit in qixis brdcfg5 register and keep other bits unchanged. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14powerpc/b4860qds: Assign DDR address in board fileYork Sun
B4860QDS requires DDRC2 has 0 as base address and DDRC1 has higher address. This is the requirement for DSP cores to run in 32-bit address space. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14T4240/net: use QSGMII card PHY address by defaultShaohui Xie
Use QSGMII card PHY address as default SGMII card PHY address, QSGMII card PHY address is variable depends on different slot. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14t4240qds/eth: fixup ethernet for t4240qdsShengzhou Liu
1, Implemented board_ft_fman_fixup_port() to fix port for kernel. 2, Implemented fdt_fixup_board_enet() to fix node status of different slots and interfaces. 3, Adding detection of slot present for XGMII interface. 4, There is no PHY for XFI, so removed related phy address settings. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14powerpc/t4240qds: Add voltage ID supportYork Sun
T4240 has voltage ID fuse. Read the fuse and configure the voltage correctly. Core voltage has higher tolerance on over side than below. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14powerpc/t4240qds: Update DDR timing tableYork Sun
Update the timing table to support more rank density, based on the theory that similar density DIMMs have similar clock adjust and write level start timing. Update the timing for 1600 and 1866 MT/s. Tested with Micron MT18JSF1G72AZ-1G9E1 DIMMs, iDIMM M3CN-4GMJ3C0C-M92. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14T4/serdes: fix the serdes clock frequencyRoy Zang
Reverse the bit sequence to set and display serdes clock frequency correctly. The correct bit maps in BRDCFG2 are 0 1 2 3 4 5 6 7 S1RATE[1:0] S2RATE[1:0] S3RATE[1:0] S4RATE[1:0] Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-13blackfin: bf609: add softswitch config commandBob Liu
Add softswitch_output command for bf609-ezkit to enable softswitches. Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2013-05-13blackfin: bf609: implement soft switchSonic Zhang
Set up soft switch pins properly in board init code. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Scott Jiang <scott.jiang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2013-05-10openrisc: move board linker script(s) to a common in cpu/Stefan Kristiansson
Unifies the openrisc boards linker scripts into a common one. Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
2013-05-10openrisc: specify a memory region for u_boot_listsStefan Kristiansson
Since there are two memory areas defined, vectors and ram, the linker will error when neither of them are specified for a section. Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
2013-05-10Fix references to the documentation filesAnatolij Gustschin
Many boot image configuration files refer to the appropriate documentation file, but these references contain typos in the directory and file name. Fix them. Also fix reference to doc/README.SPL file. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2013-05-09gpio: Add support for microblaze xilinx GPIOMichal Simek
Microblaze uses gpio which is connected to the system reset. Currently gpio subsystem wasn't used for it. Add gpio driver and change Microblaze reset logic to be done via gpio subsystem. There are various configurations which Microblaze can have that's why gpio_alloc/gpio_alloc_dual(for dual channel) function has been introduced and gpio can be allocated dynamically. Adding several gpios IP is also possible and supported. For listing gpio configuration please use "gpio status" command This patch also remove one compilation warning: microblaze-generic.c: In function 'do_reset': microblaze-generic.c:38:47: warning: operation on '*1073741824u' may be undefined [-Wsequence-point] Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-05-02Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2013-05-02powerpc/p1_p2_rdb_pc: Add a pin to reset the DDR chip for P1021RDB-PCXu Jiucheng
When P1021RDB-PC reboot system, the board will hung at uboot DDR configuration. For P1021RDB-PC DDR reset pin is multiplex with QE, so uboot will reserve this pin for QE and skip DDR reset. Other platforms without QE will do this reset. This patch adds a slight code to reset DDR chip by QE CE_PB8 pin for NAND and NOR FLASH boot. For booting from SPI FALSH and SD card, it seems possible to use the rom on chip to write to the GPIO pins before configuring the DDR. Signed-off-by: Xu Jiucheng <B37781@freescale.com> Signed-off-by: Xie Xiaobo <X.Xie@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-02powerpc/p1010rdb: Change flexcan compatible stringShengzhou Liu
Change flexcan compatible string from "fsl,flexcan-v1.0" to "fsl,p1010-flexcan" to match the device tree. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-02qoriq/p1_p2_rdb_pc: USB device-tree fixups for P1020Zhicheng Fan
Resolve P1020 second USB controller multiplexing with eLBC - mandatory to mention USB2 in hwconfig string to select it over eLBC, otherwise USB2 node is removed - works only for SPI and SD boot Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Zhicheng Fan <B32736@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-02powerpc/b4860qds: Add the tlb entries for SRIO interfacesLiu Gang
Add the tlb entries based on the configuration of the SRIO interfaces. Every SRIO interface has 256M space: #define CONFIG_SYS_SRIO1_MEM_VIRT 0xa0000000 #define CONFIG_SYS_SRIO1_MEM_PHYS 0xc20000000ull #define CONFIG_SYS_SRIO2_MEM_VIRT 0xb0000000 #define CONFIG_SYS_SRIO2_MEM_PHYS 0xc30000000ull Signed-off-by: Liu Gang <Gang.Liu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-02powerpc/p1022ds: Add support for NAND and NAND boot using SPLMatthew McClintock
Add defines needed to access NAND, remove second flash bank that is actually connected to NAND. Add nand booting support for P1022DS with hardcoded DDR config using SPL framework from 2011 Signed-off-by: Matthew McClintock <msm@freescale.com> Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Jiang Yutang <b14898@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-02board/freescale/common/cds_pci_ft.c: Fix rotate wrong cells in interrupt-map ↵Jiang Bin
property For linux 3.x, the size of each item in interrupt-map property is 9 not 7. Don't use the static value and calculate the size with following cells: PCI #address-cells, PCI #interrupt-cells, PIC address, PIC #address-cells, PIC #interrupt-cells. Signed-off-by: Bin Jiang <bin.jiang@windriver.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-02Merge branch 'master' of git://git.denx.de/u-boot-mpc5xxxTom Rini
2013-05-02mpc5200: a3m071/a4m2k: Miscellaneous updates and fixesStefan Roese
The changes to a3m071/a4m2k in summary are: - Enable CAN1 on I2C in GPS Port Configuration - Enable SPI on PSC2 - Activate network console - New flash partitioning - Fix some typos - Pass host name to Linux - Change rootfs to squashfs,jffs2 - Enable UBI/UBIFS support - Enable FIT support Signed-off-by: Stefan Roese <sr@denx.de>
2013-05-01env_mmc: add support for redundant environmentMichael Heimpold
This patch add support for storing the environment redundant on mmc devices. Substantially it re-uses the logic from the NAND implementation, that means using an incremental counter for marking newer data. Signed-off-by: Michael Heimpold <mhei@heimpold.de>
2013-05-01sandbox: Switch over to generic boardSimon Glass
Add generic board support for sandbox. and remove the old board init code. Select CONFIG_SYS_GENERIC_BOARD for sandbox now that this is supported. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-05-01Merge branch 'microblaze' of git://www.denx.de/git/u-boot-microblazeTom Rini
2013-04-30watchdog: Add support for Xilinx Microblaze watchdogMichal Simek
Watchdog can be used on Microblaze, PPC and Zynq hw designs. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-30microblaze: Disable all cpu features before resetMichal Simek
Fix microblaze soft reset function and disable all cpu features. Especially disable caches because IRQs were off by disable_interrupts(). Reported-by: John Williams <john.williams@xilinx.com> Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-04-30microblaze: Fix reset functionMichal Simek
Remove CONFIG_SYS_RESET_ADDRESS macro. It was there from historical point of view when soft reset was just jump to u-boot text start (not used right now). Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-04-22ppc4xx: Add lcd4_lwmon5 supportStefan Roese
This patch adds the fast booting LWMON5 derivat "lcd4_lwmon5". Its a stripped down version of the full blown lwmon5 support, without ECC, USB, POST and some other stuff. It used the newly introduced SPL infrastrucure for SPL from NOR flash booting on the PPC4xx. By setting the environment variable "boot_os" to "yes", Linux will be started from the SPL version. If not, the "normal" U-Boot will be started. Signed-off-by: Stefan Roese <sr@denx.de>
2013-04-17exynos: fdt: Add TMU node for snowSimon Glass
Snow is missing a TMU node, and with TMU support this is not allowed, so it fails to boot. Add it. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-04-17Exynos5: Add support for USB download boot modeVivek Gautam
Exynos5250 supports secondary USB device boot mode. If the iROM fails to download u-boot from the primary boot device (such as SD or eMMC), it will try to retrieve from the secondary boot device (such as USB). Signed-off-by: Naveen Krishna Ch <ch.naveen@samsung.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-04-15Tegra: T30: Beaver board support.Tom Warren
Beaver is a Tegra30 board that is nearly 100% compatible w/Cardhu. Add a Beaver build so it can begin to be differentiated, if need be. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-04-15Tegra: Split tegra_get_chip_type() into soc & sku funcsTom Warren
As suggested by Stephen Warren, use tegra_get_chip() to return the pure CHIPID for a Tegra SoC (i.e. 0x20 for Tegra20, 0x30 for Tegra30, etc.) and rename tegra_get_chip_type() to reflect its true function, i.e. tegra_get_chip_sku(), which returns an ID like TEGRA_SOC_T25, TEGRA_SOC_T33, etc. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-04-15Tegra: All Tamonten-derived boards use onboard NANDThierry Reding
Move the nand-controller node to the tegra20-tamonten.dtsi so that it can be shared between all derived boards. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-04-14smdk5250, snow: convert to CONFIG_SPL_MAX_FOOTPRINTAlbert ARIBAUD
This target wants to check full SPL size, BSS included. Remove CONFIG_SPL_MAX_SIZE definition and instead define CONFIG_SPL_MAX_FOOTPRINT. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-04-14da850evm, da850_am18xxevm: convert to CONFIG_SPL_MAX_FOOTPRINTAlbert ARIBAUD
2013-04-14cam_enc_4xx: convert to CONFIG_SPL_MAX_FOOTPRINTAlbert ARIBAUD
2013-04-13ARM: Fix __bss_start and __bss_end in linker scriptsAlbert ARIBAUD
Commit 3ebd1cbc introduced compiler-generated __bss_start and __bss_end__ and commit c23561e7 rewrote all __bss_end__ as __bss_end. Their merge caused silent and harmless but potentially bug-inducing clashes between compiler- and linker- generated __bss_end symbols. Make __bss_end and __bss_start compiler-only, and create __bss_base and __bss_limit for linker-only use. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Reported-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/video/exynos_fb.c
2013-04-12Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-04-12arm: Make all linker scripts compatible with per-symbol sectionsBenoît Thébaudeau
Let all ARM linker scripts handle properly -ffunction-sections and -fdata-sections. This will be useful for future changes in order to create symbol-specific sections in common .S files. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12arm: Remove support for smdk6400Benoît Thébaudeau
The migration of boards from Makefile to boards.cfg was due for v2012.03, but smdk6400 did not follow, and it does not build, so move it to scrapyard. It will still be possible to restore it from the Git history before fixing it. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12arm: Remove unused relocate_code() parametersBenoît Thébaudeau
Commit e05e5de7fae5bec79617e113916dac6631251156 made the 2 1st parameters of ARM's relocate_code() useless since it moved the code handling them to crt0.S. So, drop these parameters. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12nand: mxc: Switch NAND SPL to generic SPLBenoît Thébaudeau
This also fixes support for mx31pdk and tx25, which had been broken by commit e05e5de7fae5bec79617e113916dac6631251156. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Acked-by: Scott Wood <scottwood@freescale.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-04-12arm: relocate_code(): Use __image_copy_end for end of relocationBenoît Thébaudeau
Use __image_copy_end instead of __bss_start for the end of the image to relocate. This is the same as commit 033ca72, but applied to all ARM start.S. This is a more appropriate symbol naming for an image copy & relocate feature, and this also saves a useless copy of data put between __image_copy_end and __bss_start in linker scripts (e.g. relocation information, or MMU initialization tables used only before jumping to the relocated image). Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12imx: mx53ard: Add support for NAND FlashBenoît Thébaudeau
Add support for the Samsung K9LAG08U0M NAND Flash (2-GiB MLC NAND Flash, 2-kiB pages, 256-kiB blocks, 30-ns R/W cycles, 1 CS) on mx53ard. eNFC_CLK_ROOT is set up with a cycle time of 37.5 ns (400 MHz / 3 / 5) for this board, which satisfies the 30-ns NF R/W cycle requirement. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-04-10omap5912-osk: Fix device initialisationJon Hunter
In the current u-boot, the device pin multiplexing and clock initialisation needs to be early during the boot process and before board_init() is called. U-boot is currently crashing on this board because this is not being done early enough. Therefore, add a s_init() function for the omap5912-osk board to do this. Also fix the stack pointer so that it is pointing to the end of the internal RAM and not the beginning as this was also causing the device to crash. Signed-off-by: Jon Hunter <jon-hunter@ti.com>
