Remove the autogenerated ECC handling header, and instead create
multiple U-Boot configurations. This is closer to the way that
upstream would handle things.
From Logic BSP-2.0-5-01
* 'master' of git://git.denx.de/u-boot-arm:
run arm_pci_init after relocation
IXP42x PCI rewrite
update/fix PDNB3 board
update/fix IXDP425 / IXDPG425 boards
add dvlhost (dLAN 200 AV Wireless G) board
IXP NPE: add support for fixed-speed MII ports
update/fix AcTux4 board
update/fix AcTux3 board
update/fix AcTux2 board
update/fix AcTux1 board
use -ffunction-sections / --gc-sections on IXP42x
support CONFIG_SYS_LDSCRIPT on ARM
fix "depend" target in npe directory
Fix IXP code to work after relocation was added
trigger hardware watchdog in IXP42x serial driver
add support for IXP42x Rev. B1 and newer
add XScale sub architecture (IXP/PXA) to maintainer list
arch/arm/lib/board.c
Signed-off-by: Michael Schwingen <michael@schwingen.org>
The 'trab' board configuration is broken, and there is nobody who is
interested and willing to fix it. Drop it.
This includes support for VFD displays which have always been used by
this board only.
Make AFEB9260 build again.
Based on fix for AT91SAM9260EK.
Signed-off-by: Sergey Lapin <slapin@ossfans.org>
Signed-off-by: Eric Bénard <eric@eukrea.com>
Fix EMK TOP9000 board to build again:
- changes required due to ATMEL rework
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
Make ATMEL's at91sam9260/9g20/9xe-ek boards build again
Add support for Bluewater Systems AT91 based Snapper 9260 and 9G20
single board computer modules. Includes NAND flash and Ethernet
support.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
* convert at91rm9200ek and eb_cpux9k2 board to ATMEL_xxx name scheme
* Fix: timer.c compile error io.h not found with arm/at91rm9200
* update arm920t/at91 to ATMEL_xxx name scheme
* update arm920t/at91 soc lib
* update at91_emac driver
Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
Tested-by: Andreas Bießmann <andreas.devel@gmail.com>
Remove obsolete config.mk from QONG board.
The clock-frequency property in an audio codec's device tree node is set to
the input clock frequency for that codec. On the Freescale P1022DS board,
the input clock is enabled only if the hwconfig 'audclk' option is set.
Therefore, the property should only be set in the device tree if the clock
is actually enabled.
SMDK6400: fix the compiler error
imx27lite: Remove local config.mk
mx31ads: Fix environment location on flash
imx31_litekit: Remove local config.mk
mx31litekit: Fix boot with the new relocation scheme.
mx31ads: Use the new relocation scheme
This patch adds _end for fix following compiler error
arch/arm/cpu/arm1176/start.o: In function `_end_ofs':
arch/arm/cpu/arm1176/start.S:61: undefined reference to `_end'
Local board config.mk should be avoided.
Place CONFIG_SYS_TEXT_BASE definition into the board config file instead.
imx31_litekit has been converted to the new relocation scheme, but it does not boot.
Make the boot functional by using board_early_init_f .
Tested-by: Magnus Lilja <lilja.magnus@gmail.com>
This fixes the MX31ADS build by using the new relocation scheme.
Tested-by: Felix Radensky <felix@embedded-sol.com>
Now that the zlib code has been relocated to a dedicated subdir, make
sure we still build it with -O2 for boards that want speed over size.
* 'master' of git://git.denx.de/u-boot-sh:
sh: sh7785lcr: Update BSC of USB area
Fix the incorrect macro check for MIU linear mapping conditional compilation.
Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org>
Acked-by: Minkyu Kang <mk7.kang@samsung.com>
Modifies CPU Frequency to 1GHz and removes hard coding of mmc_pre_ratio for
MMC Channel2 in FSYS2 register.
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
Minimal platform support to boot linux from SD.
Supported devices/hw limited to external MMC/SD slot,
GPIO, I2C and minimal PRCMU.
Signed-off-by: John Rigby <john.rigby@linaro.org>
CC: Albert Aribaud <albert.aribaud@free.fr>
A value of BSC of the USB was wrong.
This updates this.
Add a header file with the missing function prototype to fix
ca9x4_ct_vxp.c: In function 'cpu_mmc_init':
ca9x4_ct_vxp.c:93: warning: implicit declaration of function 'arm_pl180_mmci_init'
introduced by commit "ARMV7: Vexpress: Add MMC support"
(f0c64526b7e51ba997a0f1baf9e74e6d497b957e)
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
CC: Andy Fleming <afleming@freescale.com>
CC: Matt Waddel <matt.waddel@linaro.org>
We change default settings for egiga on mgcoge3un.
The reason we need this is that we have the gig port on mgcoge3un
connected using a back-to-back pair of PHYs. There are no magnetics and
because of that the port has to be run with a fixd configuration and
auto-negotiation must be disabled. In the default mode the egiga driver
uses autoneg to determine port speed - which defaults to 1G (we need
100M full duplex).
Add wait for the GPIO line connected to mgcoge3ne before
starting mgcoge3un. A board specific ethernet present function
was added, because on this board ethernet is always present.
The BOCO FPGA access was enhanced and changed to use register
definitions.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Acked-by: Heiko Schocher <hs@denx.de>
cc: Wolfgang Denk <wd@denx.de>
cc: Detlev Zundel <dzu@denx.de>
cc: Prafulla Wadaskar <prafulla@marvell.com>
The mgcoge2un target was only an intermediate step to mgcoge3un.
For this reason the mgcoge2un support was moved to mgcoge3un,
because it isn't needed to support both targets.
We add the BootROM init file for the mgcoge3un memphis RAM.
We also move the suen3 and suen8 boards into the correct category
in the MAINTAINERS file.
This environment variable is used to set the bootcount address
for the kernel.
last_stage_init is not available for arm platforms. So the
calls to set_km_var and set_bootcount_addr are done in
misc_init_r.
Additionally some unneeded printouts were removed.
SMDKV310 board is based on Samsung S5PV310 SOC. This SOC is very much
similar to S5PC210.
Signed-off-by: Tushar Behera <tushar.behera@linaro.org>
SROM config code is made common for S5P series of boards.
smdkc100.c now refers to s5p-common/sromc.c for SROM related
subroutines.
Signed-off-by: David Müller <d.mueller@elsoft.ch>
Without this patch, you should get a warning.
Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
CC: Marek Vasut <marek.vasut@gmail.com>
