path: root/board
2008-04-18ppc4xx: Change Canyonlands to support booting from 2k page NAND devicesStefan Roese
2008-04-18Use jr as register jump instructionShinya Kuribayashi
Current assembler codes are inconsistent in the way of register jump instruction usage; some use jr, some use j. Of course GNU as allows both usages, but as can be expected from `Jump Register' the mnemonic `jr' is more intuitive than `j'. For example, Linux doesn't have `j <reg>' usage at all. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-04-18Clean up dataflash partitioningUlf Samuelsson
This patch removes the board dependent parts from "drivers/mtd/dataflash.c". Each board relying on this, will have the appropriate code in a new file, "partition.c" in the board directory. board Makefiles updated to use the file. The dataflash partitions are aligned on sector/page boundaries. The CONFIG_NEW_DF_PARTITION was used to create named partitions This is now the default operation, and the CONFIG variable is removed. Signed-off-by: Ulf Samuelsson <ulf@atmel.com>
2008-04-17TQM5200: fix default IDE reset levelMartin Krause
Before the first call of ide_reset(), the level of the IDE reset signal on the TQM5200 is low (reset asserted). This patch sets the default value to high (reset not asserted). Currently this patch fixes no real problem, but it is cleaner to assert the reset signal only on demand, and not permanently. Signed-off-by: Martin Krause <martin.krause@tqs.de>
2008-04-13Support for LinkStation / KuroBox HD and HG PPC modelsGuennadi Liakhovetski
This patch is based on the port by Mihai Georgian (see linkstation.c for Copyright information) and implements support for LinkStation / KuroBox HD and HG PPC models from Buffalo Technology, whereby HD is deactivated at the moment, pending network driver fixing. Notice to users: this is pretty much a barebone port. Support for network on HG models is already in the U-Boot mainline, but you might also want patches to switch fan / phy modes depending on the negotiated ethernet parameters. This patch also doesn't support console switching, booting EM mode, Buffalo specific ext2 magic number. So, if you want to use any of those, you need additional patches. Otherwise this patche provides a fully functional u-boot with a network console on your system. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-13Add CONFIG_MII_INIT support to related boardsTsiChung Liew
Replace CONFIG_8xx and CONFIG_MCF532x to CONFIG_MII_INIT in cmd_init.c. Add CONFIG_MII_INIT to board configuration files that use mii_init() in cmd_init.c. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2008-04-13Phytec Phycore-i.MX31 supportSascha Hauer
This patch adds support for the Phytec Phycore-i.MX31 board Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-13mx31 litekit supportSascha Hauer
This patch adds support for the mx31 litekit board Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-13ppc: Get rid of unused machine type definitionsWolfgang Denk
2008-04-13Coding Style cleanup; update CHANGELOGWolfgang Denk
2008-04-13Merge branch 'master' of git://www.denx.de/git/u-boot-mpc83xxWolfgang Denk
2008-04-13Merge branch 'master' of git://www.denx.de/git/u-boot-microblazeWolfgang Denk
2008-04-13Merge branch 'master' of git://www.denx.de/git/u-boot-sparcWolfgang Denk
2008-04-11mpc83xx: Fix the bug of serdes initializationDave Liu
Currently the serdes will not be initializated due to the partid's error. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-04-11mpc837xerdb: Fix warning: implicit declaration of function 'fdt_fixup_dr_usb'Jean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-04-11Revert merge of git://www.denx.de/git/u-boot-arm, commit 62479b18:Wolfgang Denk
Reverting became necessary after it turned out that the patches in the u-boot-arm repo were modified, and in some cases corrupted. This reverts the following commits: 066bebd6353e33af3adefc3404560871699e9961 7a837b7310166ae8fc8b8d66d7ef01b60a80f9d6 c88ae20580b2b01487b4cdcc8b2a113f551aee36 a147e56f03871bba4f05058d5e04ce7deb010b04 d6674e0e2a6a1f033945f78838566210d3f28c95 8c8463cce44d849e37744749b32d38e1dfb12e50 c98b47ad24b2d91f41c09a3d62d7f70ad84f4b7d 8bf69d81782619187933a605f1a95ee1d069478d 8c16cb0d3b971f46fbe77c072664c0f2dcd4471d a574a73852a527779234e73e17e7597fd8128882 1377b5583a48021d983e1fd565f7d40c89e84d63 1704dc20917b4f71e373e2c888497ee666d40380 Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-08microblaze: clean uart16550 and uartlite handlingMichal Simek
2008-04-08microblaze: remove old setting for emac driverMichal Simek
2008-04-08microblaze: Clean Makefile from ancient emac driverMichal Simek
2008-04-08SPARC/LEON2: added support for Gaisler simulator GRSIM/TSIM for SPARC/LEON2 ↵Daniel Hellstrom
targets. See www.gaisler.com for information. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2008-04-08SPARC/LEON3: added support for GR-CPCI-AX2000 FPGA AX board. The FPGA is ↵Daniel Hellstrom
exchangeable but a standard LEON3 design is assumed. See www.gaisler.com for information. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2008-04-08SPARC/LEON3: added support for Altera NIOS Development kit (STRATIX II ↵Daniel Hellstrom
Edition) with GRLIB template design. See www.gaisler.com for information. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2008-04-08SPARC/LEON3: added support for Gaisler GRSIM/TSIM2 SPARC/LEON3 simulatorn. ↵Daniel Hellstrom
2008-04-08SPARC/LEON3: added support for GR-XC3S-1500 board with GRLIB template ↵Daniel Hellstrom
design. See www.gaisler.com for board information. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-at91Wolfgang Denk
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-coldfireWolfgang Denk
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-blackfinWolfgang Denk
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-armWolfgang Denk
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-shWolfgang Denk
2008-04-07Merge branch 'master' of git://www.denx.de/git/u-boot-mpc83xxWolfgang Denk
Conflicts: lib_ppc/board.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-02ppc4xx: Canyonlands: Init SATA/PCIe port correctlyStefan Roese
Canyonlands (460EX) shares the first PCIe interface with the SoC SATA interface. This usage can be configured with the jumper J6. This patch correctly configures the SATA/PCIe PHY for SATA usage when this jumper is installed. Signed-off-by: Stefan Roese <sr@denx.de>
2008-04-01AT91SAM9260EK: Move CONFIG_CMD_NAND to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-04-01Add support for AT91SAM9260EKStelian Pop
Support for booting from internal DataFlash, external DataFlash card or NAND flash is available. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-04-01AT91CAP9ADK: Move CONFIG_CMD_NAND to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-04-01Port AT91CAP9 to the new headersStelian Pop
Adapt the existing AT91CAP9 code to the new headers and APIs. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-03-31ColdFire: Add dspi and serial flash support for MCF5445xTsiChung Liew
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: John Rigby <jrigby@freescale.com>
2008-03-31ColdFire: Remove R5200 boardTsiChung Liew
This board never went into production Signed-off-by: Zachary P. Landau <zachary.landau@labxtechnologies.com> Acked-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: John Rigby <jrigby@freescale.com>
2008-03-31ColdFire: Added M5275EVB support.Matthew Fettke
Signed-off-by: Matthew Fettke <mfettke@videon-central.com> Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: John Rigby <jrigby@freescale.com>
2008-03-31ColdFire: Fix second memory Chipselect for M5475EVBTsiChung Liew
2008-03-31ppc4xx: Small whitespace fix of esd patchesStefan Roese
2008-03-31ppc4xx: Cleanup PMC440 board supportMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2008-03-31ppc4xx: Add ptm configuration variables for PMC440Matthias Fuchs
Add support for the ptm1la, ptm1ms, ptm2la and ptm2ms environment variables. Cleanup pci_target_init. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2008-03-31ppc4xx: Minor updates for DU440 boardsMatthias Fuchs
2008-03-30Blackfin: unify cpu and boot modesMike Frysinger
All of the duplicated code for Blackfin processors and boot modes have been unified. After all, the core is the same for all processors, just the peripheral set differs (which gets handled in the drivers). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-30Blackfin: BF537-stamp: cleanup spi flash driverMike Frysinger
This punts the old spi flash driver for a new/generalized one until the common one can be integrated. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-30use correct at91rm9200 register name in m501sk boardJean-Christophe PLAGNIOL-VILLARD
This fixes a naming bug for at91rm9200 lowlevel init code: NOR boot flash is on chipselect 0, not chipselect 2. This makes code use the register name from chip datasheets. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-03-30Support for the MX31ADS evaluation board from FreescaleGuennadi Liakhovetski
This patch adds support for the MX31ADS evaluation board from Freescale, initialization code is copied from RedBoot sources, also provided by Freescale. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-03-30Phytec Phycore-i.MX31 supportSascha Hauer
2008-03-30mx31 litekit supportSascha Hauer
