path: root/board
2012-04-30Merge branch 'agust@denx.de' of git://git.denx.de/u-boot-stagingWolfgang Denk
* 'agust@denx.de' of git://git.denx.de/u-boot-staging: lin_gadget: use common linux/compat.h linux/compat.h: rename from linux/mtd/compat.h lin_gadget: use common mdelay gunzip: rename z{alloc, free} to gz{alloc, free} fs/fat: align disk buffers on cache line to enable DMA and cache part_dos: align disk buffers on cache line to enable DMA and cache
2012-04-30Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-ppc4xx: powerpc/ppc4xx: Remove typedefs for gdsys FPGA powerpc/ppc4xx: Fix typo in gdsys_fpga.h powerpc/ppc4xx: Update gdsys board configurations powerpc/ppc4xx: Support gdsys dlvision-10g hardware 1.20 powerpc/ppc4xx: Adapt gdsys 405ep boards to platform changes powerpc/ppc4xx: Make gdsys 405ep boards reset more generic powerpc/ppc4xx: Adjust environment size on neo
2012-04-30linux/compat.h: rename from linux/mtd/compat.hMike Frysinger
This lets us use it in more places than just mtd code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-04-30Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mpc85xx: powerpc/85xx: don't touch MAS7 on e500v1 when relocating CCSR powerpc/85xx: don't display address map size (32-bit vs. 36-bit) during boot cmd_bdinfo: display the address map size (32-bit vs. 36-bit) PowerPC: correct the SATA for p1/p2 rdb-pc platform powerpc/corenet_ds: Slave core in holdoff when boot from SRIO powerpc/corenet_ds: Slave reads ENV from master when boot from SRIO powerpc/corenet_ds: Slave uploads ucode when boot from SRIO powerpc/corenet_ds: Slave module for boot from SRIO powerpc/corenet_ds: Master module for boot from SRIO powerpc/corenet_ds: Document for the boot from SRIO powerpc/corenet_ds: Correct the compilation errors about ENV powerpc/srio: Rewrite the struct ccsr_rio powerpc/85xx:Fix lds for nand boot debug info powerpc/p2041rdb: add env in NAND support powerpc/p2041rdb: add NAND and NAND boot support powerpc/mpc8xxx: Fix CONFIG_DDR_RAW_TIMING for two boards powerpc/85xx:Avoid vector table compilation for nand_spl powerpc/85xx:Fix IVORs addr after vector table relocation powerpc/85xx:Avoid hardcoded vector address for IVORs powerpc/p1023rds: Disable nor flash node and enable nand flash node
2012-04-30powerpc/ppc4xx: Remove typedefs for gdsys FPGADirk Eibach
Signed-off-by: Dirk Eibach <eibach@gdsys.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-04-30powerpc/ppc4xx: Support gdsys dlvision-10g hardware 1.20Dirk Eibach
In hardware revision 1.20 one more fan controller is added to dlvision-10g. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-04-30powerpc/ppc4xx: Adapt gdsys 405ep boards to platform changesDirk Eibach
Print fpga info at last_stage_init on gdsys 405ep boards. Use dtt_init() to startup fans. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-04-30powerpc/ppc4xx: Make gdsys 405ep boards reset more genericDirk Eibach
In order to add boards that have different hardware for fpga reset, any 405ep gdsys board now provides these functions: void gd405ep_init(void); void gd405ep_set_fpga_reset(unsigned state); void gd405ep_setup_hw(void); int gd405ep_get_fpga_done(unsigned fpga); Signed-off-by: Dirk Eibach <eibach@gdsys.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-04-24powerpc/85xx: don't display address map size (32-bit vs. 36-bit) during bootTimur Tabi
Most 85xx boards can be built as a 32-bit or a 36-bit. Current code sometimes displays which of these is actually built, but it's inconsistent. This is especially problematic since the "default" build for a given 85xx board can be either one, so if you don't see a message, you can't always know which size is being used. Not only that, but each board includes code that displays the message, so there is duplication. The 'bdinfo' command has been updated to display this information, so we don't need to display it at boot time. The board-specific code is deleted. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-04-24powerpc/corenet_ds: Slave uploads ucode when boot from SRIOLiu Gang
When boot from SRIO, slave's ucode can be stored in master's memory space, then slave can fetch the ucode image through SRIO interface. For the corenet platform, ucode is for Fman. Master needs to: 1. Put the slave's ucode image into it's own memory space. 2. Set an inbound SRIO window covered slave's ucode stored in master's memory space. Slave needs to: 1. Set a specific TLB entry in order to fetch ucode from master. 2. Set a LAW entry with the TargetID SRIO1 or SRIO2 for ucode. Signed-off-by: Liu Gang <Gang.Liu@freescale.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
2012-04-24powerpc/corenet_ds: Slave module for boot from SRIOLiu Gang
For the powerpc processors with SRIO interface, boot location can be configured from SRIO1 or SRIO2 by RCW. The processor booting from SRIO can do without flash for u-boot image. The image can be fetched from another processor's memory space by SRIO link connected between them. The processor boots from SRIO is slave, the processor boots from normal flash memory space and can help slave to boot from its memory space is master. They are different environments and requirements: master: 1. NOR flash for its own u-boot image, ucode and ENV space. 2. Slave's u-boot image in master NOR flash. 3. Normally boot from local NOR flash. 4. Configure SRIO switch system if needed. slave: 1. Just has EEPROM for RCW. No flash for u-boot image, ucode and ENV. 2. Boot location should be set to SRIO1 or SRIO2 by RCW. 3. RCW should configure the SerDes, SRIO interfaces correctly. 4. Slave must be powered on after master's boot. 5. Must define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE because of no ucode locally. For the slave module, need to finish these processes: 1. Set the boot location to SRIO1 or SRIO2 by RCW. 2. Set a specific TLB entry for the boot process. 3. Set a LAW entry with the TargetID SRIO1 or SRIO2 for the boot. 4. Slave's u-boot image should be generated specifically by make xxxx_SRIOBOOT_SLAVE_config. This will set SYS_TEXT_BASE=0xFFF80000 and other configurations. Signed-off-by: Liu Gang <Gang.Liu@freescale.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
2012-04-24powerpc/mpc8xxx: Fix CONFIG_DDR_RAW_TIMING for two boardsYork Sun
P1010RDB and p1_pc_rdb_pc has incorrect configuration for CONFIG_DDR_RAW_TIMING. It should be CONFIG_SYS_DDR_RAW_TIMING. Incorrect setting causes DDR failure in case of SPD absent. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-04-24powerpc/p1023rds: Disable nor flash node and enable nand flash nodeChunhe Lan
In the p1023rds, when system boots from nor flash, kernel only accesses nor flash and can not access nand flash with BR0/OR0; when system boots from nand flash, kernel only accesses nand flash and can not access nor flash with BR0/OR0. Default device tree nor and nand node should have the following structure: Example: nor_flash: nor@0,0 { #address-cells = <1>; #size-cells = <1>; compatible = "cfi-flash"; reg = <0x0 0x0 0x02000000>; bank-width = <2>; device-width = <1>; status = "okay"; partition@0 { label = "ramdisk"; reg = <0x00000000 0x01c00000>; }; } nand_flash: nand@1,0 { #address-cells = <1>; #size-cells = <1>; compatible = "fsl,p1023-fcm-nand", "fsl,elbc-fcm-nand"; reg = <0x2 0x0 0x00040000>; status = "disabled"; u-boot-nand@0 { /* This location must not be altered */ /* 1MB for u-boot Bootloader Image */ reg = <0x0 0x00100000>; read-only; }; } When booting from nor flash, the status of nor node is enabled and the status of nand node is disabled in the default dts file, so do not do anything. But, when booting from nand flash, need to do some operations: o Disable the NOR node by setting status = "disabled"; o Enable the NAND node by setting status = "okay"; Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-04-22board/adp-ag102: add board specific filesMacpaul Lin
Add board specific files. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2012-04-18Merge branch 'master' of git://git.denx.de/u-boot-shWolfgang Denk
* 'master' of git://git.denx.de/u-boot-sh: sh: ecovec: Change macro from BOARD_LATE_INIT to CONFIG_BOARD_LATE_INIT sh: Fix rsk7264 pin setup for on-board ethernet
2012-04-18sh: Fix rsk7264 pin setup for on-board ethernetPhil Edworthy
This sets up the external ethernet IRQ pin. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-04-17i.MX6: arm2: Add AXI cache and Qos settingDirk Behme
Do the same AXI cache and Qos settings done already in the SabreLite imximage.cfg for the ARM2 board, too. It fixes a display flash issue caused by low priority of the display IDMA channel. Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> CC: Jason Chen <b02280@freescale.com> CC: Jason Liu <r64343@freescale.com> CC: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <festevam@gmail.com> Acked-by: Jason Liu <r64343@freescale.com>
2012-04-16Prepare v2012.04-rc2; minor Coding Style cleanupv2012.04-rc2Wolfgang Denk
2012-04-16MX35: mx35pdk: wrong board revisionStefano Babic
The board revision is detected accessing to the pmic, that is not available before relocation (I2C). This generates the following error: CPU: Freescale i.MX35 rev 2.0 at 532 MHz. Reset cause: WDOG <reg num> = 7 is invalid. Should be less than 0 Board: MX35 PDK 1.0 The revision number is wrong, as a default value is printed (tested on a mx35pdk Rev. 2.0). Move the output in the board_late_init(), when pmic can be accessed. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-04-16MX31: mx31pdk: drop enable_caches from board fileStefano Babic
enable_caches() is implemented now in cpu.c for ARM1136. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-04-16MX53: DDR: Fix ZQHWCTRL field TZQ_CSTroy Kisky
Currently, board files are setting this field to 0x01 which the manual says is a reserved value. Change to use the default of 0x02 - 128 cycles. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-04-16cm-t35: fix Ethernet reset timingIgor Grinberg
The reset_net_chip() function has wrong timings for the reset pulse. This appeared to work until: 0607e2b (ARMV7: OMAP: Write more than 1 byte at a time in i2c_write) Fix the Ethernet support by introducing right timings. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-04-16BeagleBoard: Remove userbutton command and use gpio command insteadJoel Fernandes
Remove userbutton command and do the detection in board config file using the gpio command Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
2012-04-09Merge branch 'master' of git://git.denx.de/u-boot-netWolfgang Denk
* 'master' of git://git.denx.de/u-boot-net: net/designware: Change timeout loop implementation net/designware: Set ANAR to 0x1e1 net/designware: Program phy registers when auto-negotiation is ON net/designware: Try configuring phy on each dw_eth_init net/designware: Consecutive writes must have delay net/designware: Phy address fix net/designware: Fix the max frame length size net/designware: Fix to restore hw mac address microblaze: Wire up LL_TEMAC driver initialization microblaze: Add faked LL_TEMAC driver configuration microblaze: Enable several ethernet driver compilation net: ll_temac: Add LL TEMAC driver to u-boot Update net subsystem maintainer in doc/git-mailrc net/eth.c: fix eth_write_hwaddr() to use dev->enetaddr as fall back mvgbe: remove warning for unused methods
2012-04-09Merge branch 'master' of git://git.denx.de/u-boot-onenandWolfgang Denk
* 'master' of git://git.denx.de/u-boot-onenand: onenand: samsung: Enable OneNAND support at Samsung's Exynos4210 onenand: Replace ONENAND_IS_MLC() with ONENAND_HAS_4KB() onenand:samsung OneNAND chip probe functions added for GONI and Exynos4210 onenand:samsung Target dependent OneNAND chip probe function
2012-04-04microblaze: Wire up LL_TEMAC driver initializationStephan Linz
Initialize ll_temac driver. Reported-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Stephan Linz <linz@li-pro.net>
2012-04-04microblaze: Add faked LL_TEMAC driver configurationStephan Linz
Expand the specific configuration for the microblaze-generic board in xparameters.h with a faked setup to enable the LL_TEMAC driver. Note: From now the microblaze-generic board is no longer a valid board configuration for a real piece of hardware. Rather than, we use the file config.mk and xparameters.h as a faked board configuration to force the compilation of all potential driver code for Microblaze systems. Signed-off-by: Stephan Linz <linz@li-pro.net>
2012-04-04onenand:samsung OneNAND chip probe functions added for GONI and Exynos4210Lukasz Majewski
Separate callback for probing OneNAND memory chip. Tested at: Samsung S5PC110 GONI Samsung Exynos4210 (S5PC210 Universal) Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com>
2012-04-01x86: Remove dead code in eNETSimon Glass
This avoids a compiler warning about unused variables. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-By: Graeme Russ <graeme.russ@gmail.com>
2012-03-30pci: get rid of local prototypesLinus Walleij
two boards were redeclaring pciauto_region_allocate() in their local scope for no obvious reason, the function is in <pci.h> anyway, this is probably just copying artifacts and old cruft. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-30Merge branch 'agust@denx.de' of git://git.denx.de/u-boot-stagingWolfgang Denk
* 'agust@denx.de' of git://git.denx.de/u-boot-staging: lzma: fix printf warnings Remove CONFIG_SYS_EXTBDINFO from snapper9260.h cmd_pxe.c: fix strict-aliasing warnings net: smc91111: use mdelay() doc: Fix some typos in different files disk/part.c: Fix device enumeration through API mkenvimage: Really set the redundant byte when applicable mkenvimage: Don't try to detect comments in the input file mkenvimage: Use mmap() when reading from a regular file mkenvimage: Read/Write from/to stdin/out by default or if the filename is "-" mkenvimage: More error handling mkenvimage: Correct an include and add a missing one mkenvimage: correct and clarify comments and error messages MAKEALL: display SPL size if present ARMV7/Vexpress: add missing get_ticks() and get_tbclk() mkenvimage: fix usage message cmd_fat: add FAT write command fs/fat/fat_write.c: Fix GCC 4.6 warnings FAT write: Fix compile errors
2012-03-30Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: (146 commits) arm: Use common .lds file where possible arm: add a common .lds link script arm: Remove unneeded setting of LDCSRIPT Define CPUDIR for the .lds link script arm: Remove zipitz2 link script Allow arch directory to contain .lds without requiring Makefile OMAP: Remove omap1610inn-based boards arch/arm/cpu/armv7/omap-common/clocks-common.c: Fix build warnings board/ti/beagle/beagle.c: Fix build warnings sdrc.c: Fix typo in do_sdrc_init() for SPL tegra: i2c: Add I2C driver tegra: fdt: i2c: Add extra I2C bindings for U-Boot tegra: i2c: Select I2C ordering for Seaboard tegra: i2c: Enable I2C on Seaboard tegra: i2c: Select number of controllers for Tegra2 boards tegra: i2c: Initialise I2C on Nvidia boards tegra: Enhance clock support to handle 16-bit clock divisors fdt: Add function to allow aliases to refer to multiple nodes tegra: Rename NV_PA_PMC_BASE to TEGRA2_PMC_BASE tegra: fdt: Enable FDT support for Ventana tegra: fdt: Enable FDT support for Seaboard tegra: usb: Enable USB on Seaboard tegra: usb: Add common USB defines for tegra2 boards tegra: usb: Add USB support to nvidia boards arm: Check for valid FDT after console is up fdt: Avoid early panic() when there is no FDT present tegra: usb: Add support for Tegra USB peripheral tegra: fdt: Add function to return peripheral/clock ID usb: Add support for txfifo threshold tegra: usb: fdt: Add USB definitions for Tegra2 Seaboard tegra: usb: fdt: Add additional device tree definitions for USB ports tegra: fdt: Add clock bindings for Tegra2 Seaboard tegra: fdt: Add clock bindings tegra: fdt: Add additional USB binding fdt: Add tegra-usb bindings file from linux fdt: Add staging area for device tree binding documentation tegra: fdt: Add device tree file for Tegra2 Seaboard from kernel tegra: fdt: Add Tegra2x device tree file from kernel arm: fdt: Add skeleton device tree file from kernel fdt: Add basic support for decoding GPIO definitions fdt: Add functions to access phandles, arrays and bools fdt: Tidy up a few fdtdec problems fdt: Add tests for fdtdec fdt: Add fdtdec_find_aliases() to deal with alias nodes arm: Tegra2: Fix ELDK42 gcc failure with inline asm stack pointer load net: fec_mxc: allow use with cache enabled net: force PKTALIGN to ARCH_DMA_MINALIGN i.MX28: Enable caches by default i.MX28: Make use of the bounce buffer i.MX28: Do data transfers via DMA in MMC driver MMC: Implement generic bounce buffer i.MX28: Add cache support to MXS NAND driver i.MX28: Add cache support into the APBH DMA driver ARM926EJS: Implement cache operations board/vpac270/onenand.c: Fix build errors nhk8815: fix build errors atmel-boards: add missing atmel_mci.h ARM: highbank: setup env from boot source register ARM: highbank: change env config to use nvram ARM: highbank: add reset support ARM: highbank: Add boot counter support ARM: highbank: change TEXT_BASE to 0x8000 ARM: highbank: fix us_to_tick calculation ARM: highbank: add missing get_tbclk ARM: highbank: fix warning for calxedaxgmac_initialize net: calxedaxgmac: fix build due to missing __aligned definition EXYNOS: Add structure for Exynos4 DMC EXYNOS: SMDK5250: Support all 4 UARTs ARM: fix s3c2410 timer code ARM: davinci: fixes for cam_enc_4xx board omap3_spi: receive transmit mode calimain, enbw_cmc: Fix typo in comments Davinci: ea20: use gpio framework to access gpios OMAP3: mt_ventoux: sets its own mtdparts OMAP3: mt_ventoux: updated timing for FPGA twl4030: fix potential power supply handling issues NAND: TI: fix warnings in omap_gpmc.c cam_enc_4xx: Rename 'images' to 'imgs' arm: Add Prep subcommand support to bootm OMAP3: twister: add support to boot Linux from SPL SPL: call cleanup_before_linux() before booting Linux OMAP3: SPL: do not call I2C init if no I2C is set. Add cache functions to SPL for armv7 devkit8000: Implement and activate direct OS boot omap/spl: change output of spl_parse_image_header omap-common/spl: Add linux boot to SPL devkit8000/spl: init GPMC for dm9000 in SPL omap-common: Add NAND SPL linux booting devkit8000: add config for spl command Add cmd_spl command mx53ard: Initialize return code with error mx53: Make PLL2 to be the parent of UART clock configs: imx: Use CONFIG_SF_DEFAULT_CS mx28evk: Provide default values for SPI bus and chip select USB: ehci-mx6: Add proper IO accessors mx6: Read silicon revision from register i.MX28: Drop __naked function from spl_mem_init mxs_spi: Return proper timeout error i.MX28: Make the stabilization delays shorter pmic_i2c: Return error in case of invalid pmic_i2c_tx_num mx6: Remove duplicate definition of ANATOP_BASE_ADDR mx6: Fix reset cause for Power On Reset case i.MX6: mx6qsabrelite: add MACH_TYPE_MX6Q_SABRELITE i.MX6: mx6q_sabrelite: add CONFIG_REVISION_TAG i.MX28: Enable additional DRAM address bits mx6q: mx6qsabrelite: setup_spi() should be called in board_init to allow use for environment mx31: add "ARM11P power gating" to get_reset_cause mx31pdk: Fix CONFIG_SYS_MEMTEST_END efikamx: Fix CONFIG_SYS_MEMTEST_END mx53smd: Fix CONFIG_SYS_MEMTEST_END mx53evk: Fix CONFIG_SYS_MEMTEST_END mx51evk: Fix CONFIG_SYS_MEMTEST_END i.MX6: mx6qsabrelite: add ext2 support imximage: Remove overwriting of flash_offset IXP: Fix GPIO_INT_ACT_LOW_SET() IXP: Fix NAND build warning on PDNB3 and SCPU IXP: Move PDNB3 and SCPU from Makefile to boards.cfg IXP: Squash warnings in IXP NPE IXP: Fix missing MACH_TYPE_{ACTUX?,PNB3,DVLHOST} IXP: Make IXP buildable with arm-linux- toolchains Examples: Properly append LDFLAGS to LD command SPL: Enable YMODEM support on BeagleBone and AM335x EVM SPL: Add YMODEM over UART load support SPL: Add README.omap3 README: document more SPL config options spl.c: Use __noreturn decorator config.mk: Check for -fstack-usage support config.mk: Make cc-option create a file under include/generated ...
2012-03-30arm: Remove zipitz2 link scriptSimon Glass
This link script doesn't appear to do anything useful or unique, so drop it, and rely on the CPU one. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-29OMAP: Remove omap1610inn-based boardsTom Rini
The CS_AUTOBOOT configurations have been broken for a long time. Kshitij Gupta is no longer at TI making these broken and orphaned boards, so remove. Signed-off-by: Tom Rini <trini@ti.com>
2012-03-29board/ti/beagle/beagle.c: Fix build warningsAnatolij Gustschin
Fix: beagle.c:257:13: warning: function declaration isn't a prototype [-Wstrict-prototypes] beagle.c:257:13: warning: function declaration isn't a prototype [-Wstrict-prototypes] Also make beagle_dvi_pup() checkpatch clean, fix: ERROR: open brace '{' following function declarations go on the next line Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Tom Rini <trini@ti.com>
2012-03-29tegra: i2c: Select I2C ordering for SeaboardSimon Glass
Select the port ordering for I2C on Seaboard. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29tegra: i2c: Initialise I2C on Nvidia boardsSimon Glass
This enables I2C on all Nvidia boards including Seaboard and Harmony. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29tegra: usb: Add USB support to nvidia boardsSimon Glass
This adds basic USB support for port 0. The other port is not supported yet. Tegra2 (SeaBoard) # usb start (Re)start USB... USB: Register 10011 NbrPorts 1 USB EHCI 1.00 scanning bus for devices... 5 USB Device(s) found scanning bus for storage devices... 1 Storage Device(s) found Tegra2 (SeaBoard) # ext2load usb 0:3 10000000 /boot/vmlinuz Loading file "/boot/vmlinuz" from usb device 0:3 (ROOT-A) 2932976 bytes read Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29tegra: usb: fdt: Add USB definitions for Tegra2 SeaboardSimon Glass
We set up two USB ports, one of which can be host or device. For some reason the kernel version does enable both ports. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29tegra: fdt: Add clock bindings for Tegra2 SeaboardSimon Glass
Add the definition of the oscillator clock frequency and the 32KHz clock. The latter is provided by a PMIC on I2C which we don't actually use at present, but we expect this definition to be used in the kernel and want to keep our .dts the same. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29tegra: fdt: Add device tree file for Tegra2 Seaboard from kernelSimon Glass
This was taken from commit b48c54e2 at: git://git.kernel.org/pub/scm/linux/kernel/git/olof/tegra.git Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-28board/vpac270/onenand.c: Fix build errorsAnatolij Gustschin
Building for vpac270_ond_256 configuration fails: arch/arm/lib/libarm.o: In function `icache_disable': /home/ag/git/u-boot/arch/arm/lib/cache-cp15.c:156: multiple definition of `icache_disable' board/vpac270/libvpac270.o:/home/ag/git/u-boot/board/vpac270/onenand.c:65: first defined here arch/arm/lib/libarm.o: In function `dcache_disable': /home/ag/git/u-boot/arch/arm/lib/cache-cp15.c:188: multiple definition of `dcache_disable' board/vpac270/libvpac270.o:/home/ag/git/u-boot/board/vpac270/onenand.c:66: first defined here make[1]: *** [/home/ag/git/u-boot/spl/u-boot-spl] Error 1 Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Acked-by: Marek Vasut <marex@denx.de>
2012-03-28atmel-boards: add missing atmel_mci.hAndreas Bießmann
commit 72fa467988e7944407a634ddc4bc6a2df685c04c moved atmel_mci_init() into include/atmel_mci.h. Some AT91 boards are also using this interface and need to include atmel_mci.h now. This patch fixes MAKEALL complaints like this: ---8<--- Configuring for ethernut5 - Board: ethernut5, Options: AT91SAM9XE ethernut5.c: In function 'board_mmc_init': ethernut5.c:235:2: warning: implicit declaration of function 'atmel_mci_init' [-Wimplicit-function-declaration] --->8--- Signed-off-by: Andreas Bießmann <biessmann@corscience.de> CC: Albert Aribaud <albert.u.boot@aribaud.net> CC: Reinhard Meyer <u-boot@emk-elektronik.de> CC: egnite GmbH <info@egnite.de>
2012-03-28ARM: highbank: setup env from boot source registerRob Herring
Add support to read the boot src register and set bootcmd env from the selected bootcmdX env setting. Based on Linkstation boot choice selection. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-03-28ARM: highbank: add reset supportRob Herring
Implement reset for highbank platform. Reset is triggered via a wfi instruction, so enabling armv7 for the compiler is necessary. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-03-28ARM: highbank: Add boot counter supportRob Herring
Add boot counter support using an sysreg which is persistent across reset. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-03-28ARM: highbank: fix warning for calxedaxgmac_initializeRob Herring
Add include of netdev.h to pick-up declaration of calxedaxgmac_initialize. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-03-27EXYNOS: SMDK5250: Support all 4 UARTsDoug Anderson
This properly configures the mux to enable all UARTs. This also fixes things so that we don't configure balls XUCTSN_1 and XURTSN_1 as UART1 configuration (RTS/CTS), since they aren't connected. Signed-off-by: Doug Anderson <dianders@chromium.org> Acked-by: Chander kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-03-27ARM: davinci: fixes for cam_enc_4xx boardHeiko Schocher
- change CONFIG_ENV_RANGE to contain 2 nand erase blocks, one for bad block reserve. - remove from the envvariable "img_writeramdisk" the ubifsmount command, as it is not needed. - erase the hole mtd partition containing u-boot - save environment variable "dvn_app_vers" and "dvn_boot_vers" only after installing the new image. changes requested from Marek Vasut: - arm, davinci: fix eldk-4.2 warnings for cam_enc_4xx board - get rid of run_command2 usage needed since patch: commit 009dde1955583e306cf904c864068f3acb0db499 Author: Simon Glass <sjg@chromium.org> Date: Tue Feb 14 19:59:20 2012 +0000 Rename run_command2() to run_command() is now in mainline. - add CONFIG_SPL_LIBGENERIC_SUPPORT support - remove CONFIG_CMD_PXE support - fix warning: cam_enc_4xx.c: In function 'menu_handle': cam_enc_4xx.c:609: warning: dereferencing type-punned pointer will break strict-aliasing rules - fix error: arm-linux-ld: u-boot-spl: Not enough room for program headers, try linking with -N Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Tom Rini <tom.rini@gmail.com> Cc: Fletzer Martin <Martin.Fletzer@ait.ac.at> Cc: Wolfgang Denk <wd@denx.de>
2012-03-27calimain, enbw_cmc: Fix typo in commentsChristian Riesch
Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@ti.com>
