This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
a6b541b090: TI ARMv7: Don't use GD before crt0.S has set it
moves the init of the debug uart at the very end of SPL code.
Enable it for the siemens board earlier, as they print
ddr settings ... all debug output before board_init_r()
is here currently useless. Maybe we must rework this
globally?
arm: + lsxhl
w+board/buffalo/lsxl/lsxl.c: In function 'rescue_mode':
w+board/buffalo/lsxl/lsxl.c:230:8: warning: unused variable 'enetaddr' [-Wunused-variable]
arm: + lschlv2
Remove the unused variable.
DM3730 CPU used on beagleboard-xm doesn't have any gpio
multiplexed with wait0 pin,
but gpio_63 multiplexed with wait1, so it looks like typo.
At current form it has no sense,
because of wait0 have no function "4".
Signed-off-by: Evgneiy A. Dushistov <dushistov@mail.ru>
UART3 RX and TX pins are now moved to support uart download capability
on the platform. Old pins are now GPIOs routed to expansion ports.
All original boards should either have been returned for modifications
or already modified for the required change and maintaining
compatibility for older boards are no longer needed.
Signed-off-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
add support for imx6dl based aristainetos2 board
U-Boot 2015.04-rc5-00066-g60f6ed4 (Apr 10 2015 - 08:46:27)
CPU: Freescale i.MX6DL rev1.1 at 792 MHz
Reset cause: WDOG
Board: aristaitenos2
Watchdog enabled
I2C: ready
DRAM: 1 GiB
NAND: 1024 MiB
MMC: FSL_SDHC: 0
SF: Detected N25Q128A with page size 256 Bytes, erase size 64 KiB, total 16 MiB
Display: lg4573 (480x800)
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Hit any key to stop autoboot: 0
Due to licensing issues, the files ps7_init.c/h are not able to be
distributed with U-Boot source code. Recent Xilinx tools also
provide the GPL variants (ps7_init_gpl.c/h), compatible with U-Boot
license.
Prior to this commit, we had to copy ps7_init files into
board/xilinx/zynq/ before the compile.
To be more user-friendly, let's include ps7_init_gpl.c/h for
Zedboard, MicroZed, ZC702, ZC706.
These init code have been taken from the hwplatform_templates
directory of Xilinx SDK 2014.4.
You can still use customized ps7_init_gpl.c/h by enabling
CONFIG_ZYNQ_CUSTOM_INIT. The recommended directory for storing them
is now board/xilinx/zynq/custom_hw_platform, but board/xilinx/zynq
is still supported for backward compatibility. The latter emits
a warning message to prompt users to gradually switch to the new
directory.
Acked-by: Sören Brinkmann <soren.brinkmann@xilinx.com>
Prior to this commit, ZC702 and ZC706 shared the same configuration
and were built as follows:
ZC702: make zynq_zc70x_defconfig && make
ZC706: make zynq_zc70x_defconfig && make DEVICE_TREE=zynq-zc706
This commit introduces separate configuration for them, which makes
the next commit much easier.
Going forward, the recommended build commands are:
ZC702: make zynq_zc702_defconfig && make
ZC706: make zynq_zc706_defconfig && make
Although the old work flow is still supported, CONFIG_TARGET_ZC70X
has been marked as deprecated. If used, the warning message is
shown to prompt users to switch to the new scheme.
Falcon mode entails the SPL booting the OS directly instead of U-Boot.
Currently we need to build one U-boot image for each of the wandboard
variants: quad, dual-lite and solo.
By switching to SPL we can support all these variants with a single binary,
which is very convenient.
Based on the work from Richard Hu.
Tested kernel booting on the three boards.
Signed-off-by: Richard Hu <hakahu@gmail.com>
Tested-by: Vagrant Cascadian <vagrant@aikidev.net>
Reviewed-by: Stefano Babic <sbabic@denx.de>
ccsr_ddr structure is already defined in fsl_immap.h. Remove
this duplicated define. Move fixed timing into ls1021atwr.h.
Signed-off-by: York Sun <yorksun@freescale.com>
CC: Alison Wang <alison.wang@freescale.com>
Acked-by: Alison Wang <alison.wang@freescale.com>
Remove the calls to net_random_ethaddr() that some boards and some
drivers are calling. This is now implemented inside of net/eth.c
Enable the feature for all boards that previously enabled it.
Acked-By: Michael Walle <michael@walle.cc> (for the lsxl board part)
Series-changes: 2
-Fixed bfin build errors
sunxi_usbc_vbus_detect was renamed to sunxi_usb_phy_vbus_detect but
g_dnl_board_usb_cable_connected was still using the old name, breaking the build
when USB gadget is enabled.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
The ga10h is an 10" tablet with an A33 or A23 soc, 1G RAM, 8G or 16G nand,
sdio wifi, 2 micro usb ports, 1 otg and 1 host and 1 micro sd slot.
This commit adds a defconfig for the v1.1 pcb with an a33 soc.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
Make DRAM_ODT_EN Kconfig setting a bool, add a separate DRAM_ODT_CORRECTION
setting for A23 SoCs and use DRAM_ODT_EN Kconfig everywhere instead of
only in dram_sun4i.c and hardcoding odt_en elsewhere.
Note this commit makes no functional changes for existing boards,
its purpose is to allow changing the odt_en value on future A33 boards.
For sun4i/sun5i/sun7i boards which set DRAM_ODT_EN=y (which no defconfigs
currently do) this patch turns on odt for both the DQ and the DQS lines,
whereas previously it was possibly (but not desirable) to turn odt on only
for one of them by setting the in DRAM_ODT_EN option to 1 or 2 instead of 3.
Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
We don't need this on sunxi, as we always use calloc or memset when
initialised memory is required. Clearing this shaves some time of our
boot time.
Acked-by: Hans de Goede <hdegoede@redhat.com>
Change PUZE_100_SW1ABCONF to PFUZE100_SW1ABCONF
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
The 'mx6-microsom' directory was only used for the previous mx6solo
hummingboard support, which has been removed in favour of the SPL
version.
Remove the remaining piece of the old mx6solo hummingboard support.
We need to do any PMIC setup in the SPL if we are to bypass U-Boot for
falcon mode.
Certain features we desire require a larger stack than is available by using
iRAM (most notably for us, env_mmc). Relocate the stack to DRAM so that
we can use these features.
If the SPL is to be used for Falcon mode then we need to make sure the SPL
disable the GSC boot watchdog.
If the SPL is to be used for Falcon mode then we need to make sure it
configures basic GPIO (iomux, padconf, and default output levels).
Now that uart and i2c setup functions have been moved to common.c we can
use these and remove code duplication.
Avoid requiring board-model and probe pmic by its i2c address.
This is in preparation for being able to call pmic_setup() from SPL
and not need board type.
Move the code that disables the GSC boot watchdog into gsc.c
Move shared functions used by both SPL and U-Boot to common.c:
- setup_iomux_uart() and uart pad config
- gpio pad config
In the process also moved the following to common.c in preparation for
calling it from the SPL:
- split i2c setup into a shared function
- move pmic init to setup_pmic() function to call directly from
power_init_board()
- split gpio setup into early (iomux and default pin config)
and late (output configuration based on env)
PCI enumeration occurs early, before we fully configure our GPIO's. Make
sure we steer the MSATA/PCI mux to PCI in board_init to ensure PCI is
selected before enumeration.
The re-assignment of pcie_rst gpio for GW522x needs to occur earlier, before
the PCI subsystem calls the toggle funciton.
mxc_serial supports DM so lets use it.
Prior to using a gpio a call to gpio_request() should be called to register
it with the gpio subsystem.
Display what device the SPL will fetch uboot.img from
Add support for USB OTG host mode. Only high speed devices supported so far
(e.g. usb 2.0 hub required to connect a keyboard).
Signed-off-by: Soeren Moch <smoch@web.de>
Fix the spelling of 'successful'.
Cubox-i boards are also supported, so update the README file.
Hummingboard dual, dual-lite and solo are now supported via SPL mechanism.
Remove the previous hummingboard support, which does not use SPL and supported
only the solo variant.
This fixes a regression caused by e25fbe3fe531029dc7b100ea4c79dbc802e17fc2
(gw_ventana: Move the DCD settings to spl code)
The clock gating must be setup prior to calling arch_cpu_init(). Without this
booting to SD (directly via eFuse or via bmode) will hang.
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
By making the tqma6_iomuxc_spi() weak, this patch adds the possibility to
add a different function for this SPI configuration. This can be used
by other baseboards, that might have a different SPI setup.
This patch will be used by the upcoming WRU-IV board support which also
uses the TQMa6 SoM.
Configure PAD_ENET_RXD0/RXD1 pads as pull down because these pads are directly
connected to the Atheros 8035/8030 although they should be functional
only in the RMII mode - 8030.
Signed-off-by: Rabeeh Khoury <rabeeh@solid-run.com>
Tested-By: Vagrant Cascadian <vagrant@aikidev.net>
mx6cuboxi sometimes fails to recognize the Ethernet PHY:
Net: Phy 0 not found
The explanation for this behavior comes from from Rabeeh Khoury:
"The LED_ACT pin on the carrier-one boards had a pull down that
forces the phy address to 0x0; where on CuBox-i and the production
HummingBoard that pin is connected directly to LED that depending
on the pull down strength of the LED it might be sampled as '0' or '1' thus
the phy address might appear as either address 0x0 or 0x4."
"This is AR8035 implementation; in reset stage the LED pin is configured as
input, and pull up/down does matter. In this case it configures the PHY
address.
After reset is deasserted the same LED pin becomes output and then
according to the previous pull/up it should be active high/low"
One way to properly fix this behavior is to place external pull-up/down
resistors in the LED line, but from a software standpoint we can fix it
by telling phy_find_by_mask() to scan the PHY at addresses
0x0 and 0x4.
Reported-by: Vagrant Cascadian <vagrant@aikidev.net>
Enable USB Host1 port.
Add HDMI output using PLL5 as the source for the IPU clocks,
and accurate VESA timings.
These settings are based on the patch from Soeren Moch <smoch@web.de>
submitted for the tbs2910 mx6 based board.
It allows the display to work properly at 1024x768@60.
This should make the hdmi output signal compatible with most if not all
modern displays.
Signed-off-by: Jon Nettleton <jon.nettleton@gmail.com>
Tested-by: Tom Rini <trini@konsulko.com>
This cleanup includes:
- remove of the preprocessor macros which pointed to long name functions
- update of the names of some regulator uclass driver functions
- cleanup of the function regulator_autoset()
- reword of some comments of regulator uclass header file
- regulator_get_by_platname: check error for uclass_find_* function calls
- add function: regulator_name_is_unique
- regulator post_bind(): check regulator name uniqueness
- fix mistakes in: regulator/Kconfig
- regulator.h: update comments
- odroid u3: cleanup the regulator calls
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Tested on sandbox:
This change enables the configs required to init and setup max77686
regulator driver, using the new driver model pmic and regulator API.
And also changes the old pmic framework calls to the new ones.
This commits enables:
- CONFIG_ERRNO_STR
- CONFIG_DM_PMIC
- CONFIG_DM_PMIC_CMD
- CONFIG_DM_PMIC_MAX77686
- CONFIG_DM_REGULATOR
- CONFIG_DM_REGULATOR_CMD
- CONFIG_DM_REGULATOR_MAX77686
And removes the unused:
- CONFIG_DM_I2C_COMPAT
- CONFIG_POWER
- CONFIG_POWER_I2C
- CONFIG_POWER_MAX77686
In the power_init_board function call, regulator driver init is called,
so before compile, make sure that any power framework is defined.
