Adding the base patch for Exynos based SMDK5420.
This shall enable compilation and basic boot support for
SMDK5420.
Signed-off-by: Rajeshwari S Shinde <rajeshwari.s@samsung.com>
Signed-off-by: Akshay Saraswat <akshay.s@samsung.com>
Create a common board.c file for all functions which are common across
all EXYNOS5 platforms.
exynos_init function is provided for platform specific code.
GP EVM has 1GB DDR3 attached(Part no: MT41K512M8RH).
Adding details for the same.
Below is the brief description of DDR3 init sequence(SW leveling):
-> Enable VTT regulator
-> Configure VTP
-> Configure DDR IO settings
-> Disable initialization and refreshes until EMIF registers are programmed.
-> Program Timing registers
-> Program leveling registers
-> Program PHY control and Temp alert and ZQ config registers.
-> Enable initialization and refreshes and configure SDRAM CONFIG register
AM4372 EPOS EVM has 1GB LPDDR2(Part no: MT42L256M32D2LG-25 WT:A)
Adding LPDDR2 init sequence and register details for the same.
Below is the brief description of LPDDR2 init sequence:
-> Configure VTP
-> Wait till initialization is complete and the configure MR registers.
Currently same value is programmed for all ioregs. This is not
the case for all SoC's like AM4372. So adding a structure for ioregs
and updating in all board files. And also return from config_cmd_ctrl()
and config_ddr_data() functions if data is not passed.
[trini: Fixup dxr2, cm_t335, adapt pcm051 rev3]
Updating the Multiplier and Dividers value for all DPLLs.
Safest OPP is read from DEV ATTRIBUTE register. Accoring to the value
returned the MPU DPLL is locked.
At different OPPs follwoing are the MPU locked frequencies.
OPP50 300MHz
OPP100 600MHz
OPP120 720MHz
OPPTB 800MHz
OPPNT 1000MHz
According to the latest DM following is the OPP table dependencies:
VDD_CORE VDD_MPU
OPP50 OPP50
OPP50 OPP100
OPP100 OPP50
OPP100 OPP100
OPP100 OPP120
So at different OPPs of MPU it is safest to lock CORE at OPP_NOM.
Following are the DPLL locking frequencies at OPP NOM:
Core locks at 1000MHz
Per locks at 960MHz
LPDDR2 locks at 266MHz
DDR3 locks at 400MHz
Touching AM33xx files also to get DPLL values specific to board but no
functionality difference.
Updating the mux data for UART, adding data for i2c0 and mmc.
And also updating pad_signals structure.
CONFIG_ENV_VARS_UBOOT_CONFIG, CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG and
CONFIG_BOARD_LATE_INIT is already set. Adding support to detect the
board. These variables are used by findfdt.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Add support for reading onboard EEPROM to enable
board detection.
Use ti_armv7_common.h config file to inclde the common
configs.
Add support for the new Tamonten™ NG platform from Avionic Design.
Currently only I2C, MMC, USB and ethernet have been tested.
Signed-off-by: Alban Bedel <alban.bedel@avionic-design.de>
Signed-off-by: Tom Warren <twarren@nvidia.com>
When DT define aliases for etherner0 and ethernet1, U-Boot
automatically patched MAC addresses using ethaddr and eth1addr
environment variables respectively.
Custom initialization is no longer needed.
Signed-off-by: Sergei Ianovich <ynvich@gmail.com>
CC: Marek Vasut <marex@denx.de>
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
The koelsch board has one sh-ether device.
This supports sh-ether.
The lager board uses I2C for reset.
The lager board has one sh-ether device.
As the cs for spi is worked in gpio mode, so no need to configure
it as peripheral and then configure to gpio. Configure it to gpio
directly.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Pin 30 is connected to PHY's RESET# signal, so it must be
put to high. Otherwise PHY won't be found via MDIO interface.
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
Add SPL U-Boot support to replace x-loader on the Compulab cm_t35
board. Currently only the 256MiB SDRAM board versions are supported.
Tested by booting via MMC and NAND.
Cc: Tom Rini <trini@ti.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
The Head acoustics (HA) baseboard used the Technexion TAO3530 SOM
and has only some minor differences to the Technexion Thunder baseboard.
This patch adds support for this HA baseboard / TAO3530 as the "omap3_ha"
build target.
Cc: Tapani Utriainen <tapani@technexion.com>
Cc: Thorsten Eisbein <thorsten.eisbein@head-acoustics.de>
The memory size is autodetected and is passed to the Linux kernel
either via ATAGs or device-tree (dtb). So there is no need to
pass it via the bootargs.
Add SPL support for the Technexion TAO3530 SOM to replace
x-loader. Tested with the Thunder baseboard. Currently this is
only tested with the TAO3530 SOM revision (Ax/Bx).
Add support for TechNexion TAO3530 SoM
This patch has been posted quite a long time ago. I ported it to
the latest mainline U-Boot version. With some additional cleanup
and enhancements.
Signed-off-by: Tapani Utriainen <tapani@technexion.com>
CC: Sandeep Paulraj <s-paulraj@ti.com>
Test on Beaglebone white over cpsw, usb ether and SD card (read and
write), performance increased, crc32 of data matches.
board/samsung/trats2/trats2.c
include/configs/exynos5250-dt.h
arch/arm/cpu/armv7/rmobile/Makefile
doc/README.scrapyard
Needed manual fix:
arch/arm/cpu/armv7/omap-common/Makefile
board/compulab/cm_t335/u-boot.lds
This adds a SPI flash driver which simulates SPI flash clients.
Currently supports the bare min that U-Boot requires: you can
probe, read, erase, and write. Should be easy to extend to make
it behave more exactly like a real SPI flash, but this is good
enough to merge now.
sjg@chromium.org added a README and tidied up code a little.
Added a required map_sysmem() for sandbox.
Add support for USB-A9263 board manufactured by Calao Systems
(http://www.calao-systems.com/).
Code is based on old U-Boot sources (2010.09) released by Calao.
Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com>
enable support for the siemens AT91SAM9G20 based board corvus.
Signed-off-by: Boris Schmidt <boris.schmidt@siemens.com>
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Cc: Bo Shen <voice.shen@atmel.com>
enable support for the siemens AT91SAM9G20 based boards taurus
and axm.
Signed-off-by: Roger Meier <r.meier@siemens.com>
Acked-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de>
Tested-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de>
Acked-by: Scott Wood <scottwood@freescale.com>
Current LDS files /DISCARD/ a lot of sections when linking ELF
files, causing diagnostic tools such as readelf or objdump to
produce partial output. Keep all section at link stage, filter
only at objcopy time so that .bin remains minimal.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
This patch adapts the s3c24x0 driver to the new i2c framework.
Config file is modified for all the boards that use the driver.
Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com>
CC: Minkyu Kang <mk7.kang@samsung.com>
CC: Heiko Schocher <hs@denx.de>
CC: Inderpal Singh <inderpal.singh@linaro.org>
CC: David Müller <d.mueller@elsoft.ch>
CC: Chander Kashyap <k.chander@samsung.com>
CC: Lukasz Majewski <l.majewski@samsung.com>
Tested-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
Reviewed-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
Currently, there is only one EEPROM on c29xpcie board which is AT24C1024.
We program the SPD data at beginning of the AT24C1024.But the AT24C1024
has a 16-bit sub-address mode. This patch is tomake it work when getting
SPD in a 16-bit sub-address EEPROM.
Signed-off-by: Po Liu <Po.Liu@freescale.com>
Acked-by: York Sun <yorksun@freescale.com>
Signed-off-by: Hardik Patel <hardik.patel@volansystech.com>
The evm has a SATA port. Enable SATA configuration and
inititialize the SATA controller.
Signed-off-by: Roger Quadros <rogerq@ti.com>
The uevm has a SATA port. Inititialize the SATA controller.
Based on the definitive guide to EMIF configuration[1] certain registers
that we have been modifying (and are documented registers) should be
left in their reset values rather than modified. This has been tested
on AM335x GP EVM and Beaglebone White.
[1]: http://processors.wiki.ti.com/index.php/AM335x_EMIF_Configuration_tips
Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com>
Cc: Javier Martinez Canillas <javier@dowhile0.org>
Cc: Lars Poeschel <poeschel@lemonage.de>
Tested-by: Matt Porter <matt.porter@linaro.org>
Phytec sells revision or version 3 of pcm051. It is labeled 1358.3 on
the board. The difference for u-boot is that is has other DDR3 RAM on it:
1 x MT41K256M16HA125E instead of 2 x MT41J256M8HX15E on revisions 1 and
2. Both configurations are 512 MiB.
Configure your u-boot build with pcm051_rev3 for the new RAM and
pcm051_rev1 for the old RAM configuration. Board revision 2 has to use
pcm051_rev1 also.
Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
Add support for status LED. Use the STATUS_LED APIs for indicating a
boot progress.
Signed-off-by: Ilya Ledvich <ilya@compulab.co.il>
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
