Update DDR calibration settings based on a larger test set.
The initial values were gathered on a small number of boards,
and have been found to fail on some boards under load.
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
Zeroing GD in board_init_f() is not needed any more. As its now done in
crt0.S. The patch that clears the GD in crt0.S is this one:
aae2aef9 [arm: Set up global data before board_init_f()] from Simon.
Cc: Tim Harvey <tharvey@gateworks.com>
Acked-by: Tim Harvey <tharvey@gateworks.com>
Update the ddr scripts for LPDDR2 and add two build configs for LPDDR2
arm2 board. Since the LPDDR2 arm2 board has different DDR size, use
CONFIG_DDR_MB in defconfig to replace the PHYS_SDRAM_SIZE.
Signed-off-by: Ye.Li <B37916@freescale.com>
This patch adds the i.MX6DL arm2 board support. The i.MX6DL ARM2
shared the same board with i.MX6Q ARM2 board since the i.MX6DL is
pin-pin compatible with i.MX6Q.
The patch also support the DDR 32-BIT mode option. Please define
CONFIG_DDR_32BIT in the board configure file to enable DDR 32-BIT
mode.But due to the board design, it's 64bit DDR buswidth physically,
so, if you CONFIG_DDR_32BIT, the DDR memory size will be half of it.
Add fine-tuning for the DRAM configuration according to the DRAM chip
datasheet. THis configuration applies to both Hynix HY5DU12622DTP and
Samsung K5H511538J-D43 .
Enable the power to the USB port only when the USB port is really needed.
Do not enable the power unconditionally.
Provide cgtqmx6eval board its own variant of ddr
setup config file. Move board/freescale/imx/ddr/
mx6q_4x_mt41j128.cfg to board/freescale/mx6sabresd/
as this is was designed for the mx6sabresd board.
Signed-off-by: Nitin Garg <nitin.garg@freescale.com>
Add NOR flash hardware init function, including SMC and PIO
configuration.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
This patch implements a workaround to fix DDR3 memory issue.
The code for workaround detects PGSR0 errors and then preps for
and executes a software-controlled hard reset.In board_early_init,
where logic has been added to identify whether or not the previous
reset was a PORz. PLL initialization is skipped in the case of a
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
Signed-off-by: Keegan Garcia <kgarcia@ti.com>
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
commit d6d07a9b... arm: vf610: add NAND support for vf610twr
generates the following warnings:
WARNING: no status info for 'vf610twr_nand'
WARNING: no maintainers for 'vf610twr_nand'WARNING: no status info for
'vf610twr_nand'
This is due to the fact that vf610twr_nand_defconfig has no Maintainer.
This patch proposed Alison as Maintainer and fix it.
Acked-by: Alison Wang <b18965@freescale.com>
CC: Stefan Agner <stefan@agner.ch>
We do not have to distinguish CONFIG_TARGET_VEXPRESS_AEMV8A_SEMI
from CONFIG_TARGET_VEXPRESS_AEMV8A. Rename the former to the latter.
Reviewed-by: Steve Rae <srae@broadcom.com>
Cc: David Feng <fenghua@phytium.com.cn>
Turn all local symbols into static in order to make sparse happy.
i2c_pad_info1 is only used locally, so it can be made static.
Fix the following sparse warning:
board/freescale/mx6sxsabresd/mx6sxsabresd.c:160:22: warning: symbol 'i2c_pad_info1' was not declared. Should it be static?
This adds NAND support for the Vybrid tower system (TWR-VF65GS10)
provided by the vf610_nfc driver. Full 16-Bit bus width is
supported. Also an aditional config vf610twr_nand is introduced
which gets the environment from NAND. However, booting U-Boot from
NAND is not yet possible due to missing boot configuration block
(BCB).
Signed-off-by: Stefan Agner <stefan@agner.ch>
Now the types of CONFIG_SYS_{ARCH, CPU, SOC, VENDOR, BOARD, CONFIG_NAME}
are specified in arch/Kconfig.
We can delete the ones in arch and board Kconfig files.
This commit can be easily reproduced by the following command:
find . -name Kconfig -a ! -path ./arch/Kconfig | xargs sed -i -e '
/config[[:space:]]SYS_\(ARCH\|CPU\|SOC\|\VENDOR\|BOARD\|CONFIG_NAME\)/ {
N
s/\n[[:space:]]*string//
This is an implementation of GPIOs for Tegra that uses driver model. It has
been tested on trimslice and also using the new iotrace feature.
The implementation uses a top-level GPIO device (which has no actual GPIOS).
Under this all the banks are created as separate GPIO devices.
The GPIOs are named as per the Tegra datasheet/header files: A0..A7, B0..B7,
..., Z0..Z7, AA0..AA7, etc.
Since driver model is not yet available before relocation, or in SPL, a
special function is provided for seaboard's SPL code.
Currently mx6dlsabresd shares the same DCD settings with the nitrogen board.
Provide a DCD configuration file specific to mx6dlsabresd with the settings
recommended by the Freescale hardware team.
The leds array within struct ventana has space for 3 elements, but the
setup_board_gpio() function tries to set up 4 GPIOs for LEDs. Recent
versions of GCC complain about that:
board/gateworks/gw_ventana/gw_ventana.c: In function 'setup_board_gpio':
board/gateworks/gw_ventana/gw_ventana.c:987:27: warning: iteration 3u invokes undefined behavior [-Waggressive-loop-optimizations]
if (gpio_cfg[board].leds[i])
board/gateworks/gw_ventana/gw_ventana.c:986:2: note: containing loop
for (i = 0; i < 4; i++) {
Fix this by making the upper bound of the loop match the array size.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Most Gateworks Ventana boards use a PLX PEX860x PCIe switch for PCIe expansion.
These boards use GPIO on the PLX device as PERST# for the downstream ports
thus we assert this when the PLX is enumerated.
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
Add support for SATA.
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Tom Rini <trini@ti.com>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
Use Compulab eeprom module to obtain revision number, serial number, and
mac address from the EEPROM.
Add support for all 3 I2C busses on Compulab CM-FX6 CoM.
Add USB and USB OTG host support for Compulab CM-FX6 CoM.
Add ethernet support for Compulab CM-FX6 CoM
Add NAND support for Compulab CM-FX6 CoM.
Add initial support for Compulab CM-FX6 CoM.
Support includes MMC, SPI flash, and SPL with dynamic DRAM detection.
Create CONFIG_SYS_I2C_EEPROM_BUS #define to tell the EEPROM
module what I2C bus the EEPROM is located at. Make cl_eeprom_read()
switch to that bus when reading EEPROM.
Cc: Dmitry Lifshitz <lifshitz@compulab.co.il>
Acked-by: Dmitry Lifshitz <lifshitz@compulab.co.il>
There are many similarities between the IMX6QUAD/IMX6DUAL and there are
many similarities between the IMX6SOLO/IMX6DUALITE. Add a 'soctype' env
variable that tells you which type you have.
The GW5520 has an IMX6Q SoC with 512MB of DDR3, 256MB of NAND flash as well as:
* 2x MiniPCIe sockets
* 2x USB host sockets
* 2x i210 GigE
* HDMI out
* digital I/O expansion
The IMX6 MMDC calibration registers depend on propagation delay and capacitive
loading between the SoC's MMDC and the DDR3 chips. On the Ventana boards the
board layout varies little in trace-lengths such that propagation delays are
irrelevant thus we can simply things by using calibration values obtained
from various board layouts based on a common SoC and DDR chip configuration.
This eliminates board-model from being needed allowing more flexibility. These
values were tested on a large sample size of Gateworks Ventana boards ranging
in layout, and memory configuration over the entire temperature range supported.
This patch adds the TWR_LCD_RGB card/HDMI options and the common
configuration for DCU on LS1021ATWR board.
Signed-off-by: Alison Wang <alison.wang@freescale.com>
On LS1021ATWR, Silicon's Sii9022A HDMI Transmitter
is used. This patch adds the common setting for this
chip.
LS102xA is an ARMv7 implementation. This patch is to add
basic support for LS1021ATWR board.
One DDR controller
DUART1 is used as the console
For the detail board information, please refer to README.
Signed-off-by: Chen Lu <chen.lu@freescale.com>
Signed-off-by: Yuan Yao <yao.yuan@freescale.com>
basic support for LS1021AQDS board.
One DDR controller
Signed-off-by: Jason Jin <jason.jin@freescale.com>
Signed-off-by: York Sun <yorksun@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
fsl_enet.h defines the mapping of the usual MII management
registers, which are included in the MDIO register block
common to Freescale ethernet controllers. So it shouldn't
depend on the CPU architecture but it should be actually
part of the arch independent fsl_mdio.h.
To remove the arch dependency, merge the content of
asm/fsl_enet.h into fsl_mdio.h.
Some files (like fm_eth.h) were simply including fsl_enet.h
only for phy.h. These were updated to include phy.h instead.
Signed-off-by: Claudiu Manoil <claudiu.manoil@freescale.com>
Add initialization code for peach_pit panel, parade bridge chip,
and backlight.
Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com>
Previously, we used to statically assign values for vl_col, vl_row and
vl_bpix using #defines like LCD_XRES, LCD_YRES and LCD_COLOR16.
Introducing the function exynos_lcd_early_init() would take care of this
assignment on the fly by parsing FIMD DT properties, thereby allowing us
to remove LCD_XRES and LCD_YRES from the main config file.
This patch adds support for Olimex A20-OLinuXino-LIME board.
Signed-off-by: FUKAUMI Naoki <naobsd@gmail.com>
Acked-by: Ian Campbell <ijc@hellion.org.uk>
Patch is the result of:
sed -i -e 's/FTDFILE/FDTFILE/g' board/sunxi/Kconfig configs/* include/configs/sunxi-common.h
sed -i -e 's/ftdfile/fdtfile/g' board/sunxi/Kconfig
Reported-by: Vagrant Cascadian <vagrant@debian.org>
Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
Acked-by: Hans de Goede <hdegoede@redhat.com>
[ ijc -- s/Spotted-by/Reported-by/ and resolve conflict vs "remove
redundant "SPL" from CONFIG_SYS_EXTRA_OPTIONS" ]
This patch changes MPLL from 800MHz to 880MHz on Odroid.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Inderpal's email address is not working any more.
Chander will be a new maintainer.
Cc: Chander Kashyap <k.chander@samsung.com>
