path: root/board
2013-09-24ARM: atmel: add RNDIS gadget supportBo Shen
Add RNDIS gadget support to test atmel usba udc driver Signed-off-by: Bo Shen <voice.shen@atmel.com>
2013-09-24DTS: Addition of I2S0 channel and replacing I2S1Dani Krishna Mohan
This patch enables default I2S0 channel.And I2S platform parameter has been moved to a common file viz exynos5.dtsi. Signed-off-by: Dani Krishna Mohan <krishna.md@samsung.com>
2013-09-20SPDX: fix IBM-pibs license identifierWolfgang Denk
The SPDX License List version 1.19 now contains an official entry for the IBM-pibs license. However, instead of our suggestion "ibm-pibs", the SPDX License List uses "IBM-pibs", with the following rationale: "The reason being that all other SPDX License List short identifiers tend towards using capital letters unless spelling a word. I'd prefer to be consistent to this end". Change the license IDs to use the official name. Signed-off-by: Wolfgang Denk <wd@denx.de>
2013-09-20Cosmetic: Fix a number of typos, no functional changes.Robert P. J. Day
Fix various misspellings of things like "environment", "kernel", "default" and "volatile", and throw in a couple grammar fixes. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2013-09-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-09-11Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: tools/Makefile
2013-09-11arm:goni:mmc: Add sd card detection and initialization.Przemyslaw Marczak
This change allow to use sd card on Goni the same like mmc 0. SD card is mmc dev 1, so it can be used like this: "fatls mmc 1:2". SD card is inited even if eMMC initialization fails. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> CC: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-09-11dts: samsung: arndale: Fix include pathChander Kashyap
As per new convention ARCH_CPU_DTS is not defined in "dtc/Makefile". Hence Arndale comilation is failing. Fix this by adding proper include file in "board/samsung/dts/exynos5250-arndale.dts". Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-09-09Merge branch 'master' of git://www.denx.de/git/u-boot-ppc4xxTom Rini
2013-09-09Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
2013-09-09SPL: P1022DS: switch to new multibus/multiadapter supportYing Zhang
- Added section "u_boot_list" in arch/powerpc/cpu/mpc85xx/u-boot-spl.lds - Use the function i2c_init_all instead of i2c_init Signed-off-by: Ying Zhang <b40530@freescale.com>
2013-09-07ppc4xx: Fix GPIO handling in lwmon5 and lcd4_lwmon5 BSPStefan Roese
LCD4 needs a slightly different GPIO configuration than the original LWMON5 variant. GPIO49 needs to be configured to a default output value of 0 (permanent voltage supply). Additionally lcd4 also needs to enable the LSB transmitter. Signed-off-by: Stefan Roese <sr@denx.de>
2013-09-06Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-09-06cam_enc_4xx: Move CONFIG_SPL_PAD_TO to a config headerMasahiro Yamada
For most boards which define CONFIG_SPL_PAD_TO, it is defined in config header files. Currently, there exists only one exception, cam_enc_4xx board. This patch moves CONFIG_SPL_PAD_TO definition from board/ait/cam_enc_4xx/config.mk to include/configs/cam_enc_4xx.h. With this modification, we can delete a glue code in the top level config.mk: ifneq ($(CONFIG_SPL_PAD_TO),) CPPFLAGS += -DCONFIG_SPL_PAD_TO=$(CONFIG_SPL_PAD_TO) endif Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Heiko Schocher <hs@denx.de>
2013-09-05Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/serial/serial.c The conflict above was a trivial case of adding one init function in each branch, and manually resolved in merge.
2013-09-04Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-09-04Merge branch 'u-boot-atmel/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-09-03Merge 'u-boot-microblaze/zynq' into (u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/include/asm/arch-zynq/hardware.h The conflict above was trivial and solved during merge.
2013-08-31i.MX6: nitrogen6x: Don't bother setting PLL3(480) PFD1 divisorEric Nelson
This clock isn't feeding anything under U-Boot, so there's no point in changing it from power-on default. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2013-08-31ARM: Congatec: README updateSARTRE Leo
README: U-boot works both on SPI-NOR and SDcard Signed-off-by: Leo Sartre <lsartre@adeneo-embedded.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2013-08-30exynos5250: arndale: Add mmc supportInderpal Singh
This patch adds mmc support to the arndale board. Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-08-30exynos5250: Add arndale board supportChander Kashyap
Arndale board is based on samsung's exynos5250 soc. Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org> Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-08-28arm, am335x: add support for 3 siemens boardsHeiko Schocher
add support for the am335x based boards from siemens: dxr2: - DDR3 128MiB - NAND 256MiB - Ethernet with external Switch SMSC LAN9303 - no PMIC - internal Watchdog - DFU support pxm2: - DDR2 512 MiB - NAND 1024 MiB - PMIC - PHY atheros ar803x - USB Host - internal Watchdog - DFU support rut: - DDR3 256 MiB - NAND 256 MiB - PMIC - PHY natsemi dp83630 - external Watchdog - DFU support Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Roger Meier <r.meier@siemens.com> Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Cc: Pascal Bach <pascal.bach@siemens.com> Cc: Tom Rini <trini@ti.com>
2013-08-28arm, am33xx: add defines for gmii_sel_register bitsHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
2013-08-28am335x_evm: Update README for customizationTom Rini
As this is a reference platform, update the README to note which IP blocks are required for use due to design choices of the reference rather than required by the SoC itself. Signed-off-by: Tom Rini <trini@ti.com>
2013-08-28ARM: OMAP4460: sdp: Limit TPS mux config to 4460Taras Kondratiuk
TPS mux config is 4460 specific, so it should be limited to 4460 only. Signed-off-by: Taras Kondratiuk <taras@ti.com>
2013-08-28sdp4430: Initialize board id using CONFIG_MACH_TYPEOleksandr Tyshchenko
Use CONFIG_MACH_TYPE generic macro to set the machine type number in the common arm code instead of setting it in the board code. Signed-off-by: Oleksandr Tyshchenko <oleksandr.tyshchenko@ti.com>
2013-08-28arm: goni: remove config.mk fileMinkyu Kang
Since config.mk is deprecated, remove this file, and move CONFIG_SYS_TEXT_BASE define to config file. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-08-28arm: smdkc100: remove config.mk fileMinkyu Kang
Since config.mk is deprecated, remove this file, and move CONFIG_SYS_TEXT_BASE define to config file. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Cc: Wolfgang Denk <wd@denx.de>
2013-08-26ARM: OMAP5-uevm: Add usb device reset APIDan Murphy
Add the call back to reset the LAN9730 after the FEAT_POWER has been called. Signed-off-by: Dan Murphy <dmurphy@ti.com>
2013-08-26ARM: OMAP5-uevm: Add USB MAC ethernet addressDan Murphy
Set the usbethaddr based on the OMAP DIE_ID registers which should be unique for each processor. Then set this as the usb ethernet MAC address. Signed-off-by: Dan Murphy <dmurphy@ti.com>
2013-08-26ARM: OMAP5-uevm: Add USB ehci support for the uEVMDan Murphy
Add the USB ehci support for the OMAP5 uEVM. Configure the uEVM mux data Add the flags to build the appropriate modules Add the usb call backs to initialize the EHCI controller Signed-off-by: Dan Murphy <dmurphy@ti.com>
2013-08-26omap5: uevm: Change the board name to correct nameDan Murphy
Change the board name for the sys info to 5432 uEVM Signed-off-by: Dan Murphy <dmurphy@ti.com> Acked-by: Marek Vasut <marex@denx.de>
2013-08-22arm: atmel: remove the config.mk fileBo Shen
remove the config.mk file move text base define to board config file for following boards - at91sam9m10g45ek - at91sam9x5ek Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-08-22arm: atmel: add gmac support for sama5d3xek boardBo Shen
add gmac support for sama5d3xek board, the gmac embedded in: - sama5d33, sama5d34, sama5d35 Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-08-21Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2013-08-21i.MX6: nitrogen6x: force HDMI onto IPU0/DI0Eric Nelson
Our Linux kernel switches the HDMI connector onto IPU0/DI1, but the U-Boot display driver only supports IPU0/DI0 for the time being. Because of this, a soft re-boot will leave the HDMI output connected to the wrong display port and prevent video from being displayed. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2013-08-20powerpc/p1010rdb: fix calculating ddr_freq_mhzShengzhou Liu
There was a bug for calculating ddr_freq_mhz, it should be divided by 1000000 rather than 0x1000000. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-20powerpc/t4240: add QSGMII interface supportShaohui Xie
Also some fix for QSGMII. 1. fix QSGMII configure of Serdes2. 2. fix PHY address of QSGMII MAC9 & MAC10 for each FMAN. 3. fix dtb for QSGMII interface. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-20powerpc/t4240: fix lanes routing for QSGMII protocolsShaohui Xie
When using QSGMII protocols, the first lane and third lane on each slot need to be swapped. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-20powerpc/common/vsc3316: remove const from vsc3316_config parameter defineShaohui Xie
Since the parameters need to be modified according to different Serdes protocols at runtime, the const will block this. Also remove const from arrays define used by vsc3316_config. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-20SPDX-License-Identifier: clean up license headerYork Sun
This patch cleans up license header in these files: board/freescale/p1022ds/spl.c drivers/mmc/fsl_esdhc_spl.c drivers/mtd/spi/fsl_espi_spl.c Signed-off-by: York Sun <yorksun@freescale.com>
2013-08-20powerpc: Fix CamelCase checkpatch warningsPrabhakar Kushwaha
85xx, 86xx PowerPC folders have code variables with CamelCase naming conventions. because of this code checkpatch script generates "WARNING: Avoid CamelCase". Convert variables name to normal naming convention and modify board, driver files with updated the new structure. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-20powerpc: p1022ds: add TPL for p1022ds nand bootYing Zhang
TPL is introduced in the patch "NAND: TPL : introduce the TPL based on the SPL", here enable TPL for p1022ds nand boot. Signed-off-by: Ying Zhang <b40530@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-20powerpc : p1022ds : Enable p1022ds to start from eSPI with SPLYing Zhang
Enable p1022ds to start from eSPI with SPL. Signed-off-by: Ying Zhang <b40530@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-20powerpc: p1022ds: Enable P1022DS to boot from SD Card with SPLYing Zhang
Enable p1022ds to start from eSDHC with SPL. Signed-off-by: Ying Zhang <b40530@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-20ppc4xx: Remove CANBT boardMatthias Fuchs
This board and especially the CPU (PPC405CR) is EOL. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Acked-by: Wolfgang Denk <wd@denx.de>
2013-08-20i2c:samsung: Adjust Trats, GONI and Universal_c210 boards to work with new ↵Łukasz Majewski
I2C framework New I2C framework, introduced after v2013.07 final release, imposed I2C code adjustment for some Samsung boards - namely Trats, GONI and Universal_c210. Those boards were using schematic based I2C enumeration (I2C_5, I2C_9). However, new I2C framework imposes usage of logical I2C adapters numbering (e.g. I2C_0, I2C_1, etc). Additionally, I2C_GET_* macros were replaced with i2c_*_bus_num() functions. Trats board gained definition of second soft I2C adapter. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Heiko Schocher <hs@denx.de>
2013-08-19SPDX-License-Identifier: convert BSD-3-Clause filesWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini Don't remove some copyrights by accident] Signed-off-by: Tom Rini <trini@ti.com>
2013-08-19board/esd/cpci750/mv_eth.c: Fix licenseWolfgang Denk
The file header indicated that this file was GPL-2.0+, but actually the code was derived from (Marvell based) Linux source code which is only GPL-2.0. Fix this. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Acked-by: Stefan Roese <sr@denx.de>
