path: root/board
2008-07-15Merge branch 'master' of git://git.denx.de/u-boot-mpc5xxxWolfgang Denk
2008-07-15Merge branch 'master' of git://git.denx.de/u-boot-mpc86xxWolfgang Denk
2008-07-15Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2008-07-15mpc5xxx: Add MVBC_P board supportAndre Schwarz
The MVBC_P is a MPC5200B based camera system with Intel Gigabit ethernet controller (using e1000) and custom Altera Cyclone-II FPGA on PCI. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-07-15Update Freescale sys_eeprom.c to handle CCID formatsTimur Tabi
Update the sys_eeprom.c file to handle both NXID and CCID EEPROM formats. The NXID format replaces the older CCID format, but it's important to support both since most boards out there still use the CCID format. This change is in preparation for using one file to handle both formats. This will also unify EEPROM support for all Freescale 85xx and 86xx boards. Also update the 86xx board header files to use the standard CFG_I2C_EEPROM_ADDR instead of ID_EEPROM_ADDR. Signed-off-by: Timur Tabi <timur@freescale.com>
2008-07-14MPC8544DS: Add ATI Video card supportKumar Gala
Add support for using a PCIe ATI Video card on PCIe2. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-14MPC8544DS: Report board id, board version and fpga version.Kumar Gala
2008-07-14sbc8560: add in ft_board_setup()Paul Gortmaker
Add in for the sbc8560, the ft_board_setup() routine, based on what is in use for the Freescale MPC8560ADS board. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2008-07-14sbc8560: properly set cs0_bnds for 512MBPaul Gortmaker
The sbc8560 board ships with 512MB of memory installed, but the current cs0_bnds is hard coded for 256MB. Set the value based on CFG_SDRAM_SIZE. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2008-07-14ARM DaVinci: Remove extern phy_t declaration by moving code to proper placeHugo Villeneuve
ARM DaVinci: Remove extern phy_t declaration by moving code to proper place. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
2008-07-14ARM DaVinci: Remove duplicate definitions of MACH_TYPE and prototype of ↵Hugo Villeneuve
i2c_init() ARM DaVinci: Remove duplicate definitions of MACH_TYPE and prototype of i2c_init(). Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
2008-07-14Fix coding style; make code better parsable by external toolsWolfgang Denk
2008-07-14elppc board: Coding style cleanup.Wolfgang Denk
2008-07-14elppc board: fix syntax error.Wolfgang Denk
2008-07-14EB+MCF-EV123 board: fix coding style (alingment)Wolfgang Denk
2008-07-14EB+MCF-EV123 board: fix syntx errorWolfgang Denk
2008-07-14Remove LBC_CACHE_BASE from 8544 DSAndy Fleming
The 8544 DS doesn't have any cacheable Local Bus memories set up. By mapping space for some anyway, we were allowing speculative loads into unmapped space, which would cause an exception (annoying, even if ultimately harmless). Removing LBC_CACHE_BASE, and using LBC_NONCACHE_BASE for the LBC LAW solves the problem. Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-07-14Code cleanup: fix old style assignment ambiguities like "=-" etc.Wolfgang Denk
2008-07-14AmigaOneG3SE: remove dead and incomplete filesWolfgang Denk
2008-07-13ADS5121: Fix (delete) incorrect ads5121_diu_init() prototypeWolfgang Denk
2008-07-13Fix some more printf() format issues.Jean-Christophe PLAGNIOL-VILLARD
2008-07-13ppc4xx: Remove redundant ft_board_setup() functions from some 4xx boardsStefan Roese
This patch removes some ft_board_setup() functions from some 4xx boards. This can be done since we now have a default weak implementation for this in cpu/ppc4xx/fdt.c. Only board in need for a different/custom implementation like canyonlands need their own version. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-13Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
2008-07-13Merge branch 'master' of git://git.denx.de/u-boot-mpc512xWolfgang Denk
2008-07-13Merge branch 'master' of git://git.denx.de/u-boot-coldfireWolfgang Denk
2008-07-13at91: Fix to enable using Teridian MII phy (78Q21x3) with at91sam9260Anatolij Gustschin
On the at91sam9260ep development board there is an EEPROM connected to the TWI interface (PA23, PA24 Peripheral A multiplexing), so we cannot use these pins as ETX2, ETX3. This patch configures PA10, PA11 pins for ETX2, ETX3 instead of PA23, PA24 pins. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Manuel Sahm <Manuel.Sahm@feig.de>
2008-07-12fix DIU for small screensKenneth Johansson
The DIU_DIV register is 8 bit not 5 bit. This prevented large DIV values so it was not possible to set a slow pixel clock and thus prevented display on small screens. Signed-off-by: Kenneth Johansson <kenneth@southpole.se> Acked-by: John Rigby <jrigby@freescale.com>
2008-07-12ADS5121 cleanup compile warningsJohn Rigby
board/ads5121/iopin.c Replace bit fields in struct iopin_t with a single field and intialize it via plain old macros. This fixes the type pun warnings and makes the code more readable. board/ads5121/ads5121.c Add include iopin.h to ads5121.c for the iopin_initialize prototype. Add an extern void ads5121_diu_init(void) Signed-off-by: John Rigby <jrigby@freescale.com>
2008-07-11Fix some more printf() format issues.Wolfgang Denk
2008-07-11Fixed some out-of-tree build issuesWolfgang Denk
2008-07-11Fix compile error caused by incorrect function return typeTsiChung Liew
Rename int mii_init(void) to void mii_init(void) Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-07-11ColdFire: Fix power up issue for MCF5235TsiChung Liew
2008-07-11Fix some more print() format errors.Wolfgang Denk
2008-07-10Merge branch 'master' of git://git.denx.de/u-boot-mpc512xWolfgang Denk
2008-07-10Configuration changes for ADS5121 Rev 3Martha Marx
ADS5121 Rev 3 board is now the default config config targets are now ads5121_config Rev 3 board with PCI M41T62 on board RTC 512MB DRAM ads5121_rev2_config Rev 2 board with No PCI 256MB DRAM Signed-off-by: Martha Marx <mmarx@silicontkx.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: John Rigby <jrigby@freescale.com>
2008-07-10Consolidate ADS5121 IO Pin configurationMartha Marx
Consolidate ADS5121 IO Pin configuration to one file board/ads5121/iopin.c. Remove pin config from cpu/mpc512x/fec.c Signed-off-by: Martha Marx <mmarx@silicontkx.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: John Rigby <jrigby@freescale.com>
2008-07-10Merge commit 'wd/master'Jon Loeliger
2008-07-10Fix some more print() format errors.Wolfgang Denk
2008-07-10ppc4xx: Fix printf format warnings now visible with the updated format checkStefan Roese
This patch fixes ppc4xx related printf format warning. Those warnings are now visible since patch dc4b0b38d4aadf08826f6c31270f1eecd27964fd [Fix printf errors.] by Andrew Klossner has been applied. Thanks, this is really helpful. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-10ppc4xx: Remove implementation of testdram() from Korat board supportLarry Johnson
Signed-off-by: Larry Johnson <lrj@acm.org> Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-10ppc4xx: Update and add FDT to Korat board supportLarry Johnson
2008-07-10ARM: Fix for wrong patch version applied for Lyrtech SFF-SDR board (ARM926EJS)Hugo Villeneuve
ARM: Fix for incorrect version of patch applied when adding support for the Lyrtech SFF-SDR board. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com> Signed-off-by: Philip Balister, OpenSDR <philip@opensdr.com>
2008-07-10Remove useless print message at apollonKyungmin Park
Remove useless print message at apollon Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-07-09Some copy-n-paste fixes in printf usageMatvejchikov Ilya
Signed-off-by: Matvejchikov Ilya <matvejchikov@gmail.com>
2008-07-09FDT memory and pci node fixes for MPC8260ADSMatvejchikov Ilya
2008-07-08sh: Fix SH-boards compile errorNobuhiro Iwamatsu
By Cleanup out-or-tree building for some boards (.depend) (commit:c8a3b109f07f02342d097b30908965f7261d9f15) because filse ware changed, some SH-boards have compile error. I revised this problem. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-07-07sh: Cleanup source code of SH7763RDPNobuhiro Iwamatsu
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-07-07sh: Cleanup source code of R2DPlusNobuhiro Iwamatsu
2008-07-07sh: Cleanup source code of R7780MPNobuhiro Iwamatsu
