This patch removes some ft_board_setup() functions from some 4xx boards.
This can be done since we now have a default weak implementation for this
in cpu/ppc4xx/fdt.c. Only board in need for a different/custom
implementation like canyonlands need their own version.
On the at91sam9260ep development board there is an EEPROM
connected to the TWI interface (PA23, PA24 Peripheral A
multiplexing), so we cannot use these pins as ETX2, ETX3.
This patch configures PA10, PA11 pins for ETX2, ETX3
instead of PA23, PA24 pins.
Signed-off-by: Manuel Sahm <Manuel.Sahm@feig.de>
The DIU_DIV register is 8 bit not 5 bit. This prevented large DIV values
so it was not possible to set a slow pixel clock and thus prevented
display on small screens.
Signed-off-by: Kenneth Johansson <kenneth@southpole.se>
Acked-by: John Rigby <jrigby@freescale.com>
board/ads5121/iopin.c
Replace bit fields in struct iopin_t with a single
field and intialize it via plain old macros.
This fixes the type pun warnings and makes the code
more readable.
board/ads5121/ads5121.c
Add include iopin.h to ads5121.c for the iopin_initialize
prototype.
Add an extern void ads5121_diu_init(void)
Signed-off-by: John Rigby <jrigby@freescale.com>
Rename int mii_init(void) to void mii_init(void)
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
ADS5121 Rev 3 board is now the default config
config targets are now
ads5121_config
Rev 3 board with
PCI
M41T62 on board RTC
512MB DRAM
ads5121_rev2_config
Rev 2 board with
No PCI
256MB DRAM
Signed-off-by: Martha Marx <mmarx@silicontkx.com>
Consolidate ADS5121 IO Pin configuration to one file
board/ads5121/iopin.c.
Remove pin config from cpu/mpc512x/fec.c
This patch fixes ppc4xx related printf format warning. Those warnings are
now visible since patch dc4b0b38d4aadf08826f6c31270f1eecd27964fd
[Fix printf errors.] by Andrew Klossner has been applied. Thanks, this is
really helpful.
Signed-off-by: Larry Johnson <lrj@acm.org>
ARM: Fix for incorrect version of patch applied when
adding support for the Lyrtech SFF-SDR board.
Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
Signed-off-by: Philip Balister, OpenSDR <philip@opensdr.com>
Remove useless print message at apollon
Signed-off-by: Matvejchikov Ilya <matvejchikov@gmail.com>
By Cleanup out-or-tree building for some boards (.depend)
(commit:c8a3b109f07f02342d097b30908965f7261d9f15)
because filse ware changed, some SH-boards have compile error.
I revised this problem.
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
Fix NAND FLASH timings for at91sam9x evaluation kits.
New timings are based on application note
"NAND Flash Support on AT91SAM9 Microcontrollers" available at
http://atmel.com/dyn/resources/prod_documents/doc6255.pdf
Signed-off-by: Patrice Vilchez <patice.vilchez@atmel.com>
Acked-by: Stelian Pop <stelian@popies.net>
AT91 RSTC registers are battery-backuped, so their values
are not reset across power cycles. One of those registers,
the AT91_RSTC_MR register, is being modified by U-Boot, in
the ethernet initialisation routine, to generate a 500ms
user reset.
Unfortunately, this value is not being restored afterwards,
causing subsequent resets to also last for 500ms.
This long reset sequence causes problems (at least) in the
boot sequence from NOR: by the time the CPU tries to load
a program from the NOR flash, the latter is still in reset
and not yet available.
Additionaly, this patch fixes a bug in the original code which
caused the reset delay to last for 2s instead of 500ms.
Signed-off-by: Stelian Pop <stelian@popies.net>
update mvBL-M7 config file to use UBOOT_VERSION.
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
