Remove duplicated code in SBC8548 board and utilize the common
fsl_pcie_init_board(). We also now dynamically setup the LAWs for PCI
controllers based on which PCIe controllers are enabled.
Tested-by: Paul Gortmaker <paul.gortmaker@windriver.com>
Remove duplicated code in SBC8641 board and utilize the common
CC: Paul Gortmaker <paul.gortmaker@windriver.com>
Remove duplicated code in MPC8610HPCD board and utilize the common
Remove duplicated code in P1_P2_RDB boards and utilize the common
Remove duplicated code in MPC8569MDS board and utilize the common
Remove duplicated code in MPC8568MDS board and utilize the common
Remove duplicated code in TQM 85xx boards and utilize the common
CC: wd@denx.de
Remove duplicated code in MPC8xxx XES boards and utilize the common
CC: Peter Tyser <ptyser@xes-inc.com>
Remove duplicated code in MPC8548CDS board and utilize the common
Remove duplicated code in MPC8641HPCN board and utilize the common
Remove duplicated code in MPC8536DS board and utilize the common
Remove duplicated code in MPC8544DS board and utilize the common
fsl_pcie_init_ctrl(). We also now dynamically setup the LAWs for PCI
We don't use the full fsl_pcie_init_ctrl() since we have to handle PCIE3
specially to setup the additional memory map region and we utilize a
single LAW to cover the controller.
Remove duplicated code in P2020DS board and utilize the common
Signed-off-by: Li Yang <leoli@freescale.com>
Remove duplicated code in MPC8572DS board and utilize the common
Signed-off-by: Chenhui Zhao <b26998@freescale.com>
Since all the PCIe controllers are connected over SERDES on the SoCs we
can utilize is_serdes_configured() to determine if a controller is
enabled. After which we can setup the ATMUs and LAWs for the controller
in a common fashion and allow board code to specify what the controller
is connected to for reporting reasons.
We also provide a per controller (rather than all) for some systems that
may have special requirements.
Finally, we refactor the code used by the P1022DS to utilize the new
generic code.
Based on patch by: Li Yang <leoli@freescale.com>
Add spaces to cause the informational prints to line up with
the ones from init_func_ram() in board.c. Output now looks like
this:
DRAM: Detected 4096 MB of memory
This U-Boot only supports < 4G of DDR
You could rebuild it with CONFIG_PHYS_64BIT
DDR: 2 GiB (DDR2, 64-bit, CL=5, ECC off)
The prints from lbc_sdram_init() have also been modified to line
line up and changed to start with "LBC SDRAM" instead of the
confusing "SDRAM".
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
sdram_init() is used to initialize sdram on the lbc. Rename it
accordingly.
Correct initdram to use phys_size_t to represent the size of
dram; instead of changing this all over the place, and correcting
all the other random errors I've noticed, create a
common initdram that is used by all non-corenet 85xx parts. Most
of the initdram() functions were identical, with 2 common differences:
1) DDR tlbs for the fixed_sdram case were set up in initdram() on
some boards, and were part of the tlb_table on others. I have
changed them all over to the initdram() method - we shouldn't
be accessing dram before this point so they don't need to be
done sooner, and this seems cleaner.
2) Parts that require the DDR11 erratum workaround had different
implementations - I have adopted the version from the Freescale
errata document. It also looks like some of the versions were
buggy, and, depending on timing, could have resulted in the
DDR controller being disabled. This seems bad.
The xpedite boards had a common/fsl_8xxx_ddr.c; with this
change only the 517 board uses this so I have moved the ddr code
into that board's directory in xpedite517x.c
Also, change this code to use phys_size_t instead of long int.
Using common naming for this function will enable us to use the common
initdram() for 85xx going forward. Other than the type change,
this is just a code rearrange.
Use new is_serdes_configured to determine if TSECs are in SGMII mode and
report that on the various boards that use or can be configured in SGMII
mode in board_eth_init() instead of in the PCI init code.
Now that we have serdes support for all 85xx/86xx/Pxxx chips we can
replace the is_fsl_pci_cfg() code with the is_serdes_configured().
Mimic support that exists on MPC8536DS on the MPC8572DS to allow booting
from NAND.
Signed-off-by: Jin Qing <b24347@freescale.com>
This will help us go to a fixed initdram() for all 85xx boards going
forward. sdram_setup() had an argument that it didn't need, since the
value was #defined.
The PM854/PM856 boards are no longer maintained and thus we are removing
support for them.
Acked-by: Wolfgang Denk <wd@denx.de>
The MPC8540EVAL board is no longer maintained and thus we are removing
support for it.
The ATUM8548 board is no longer maintained and thus we are removing
support for it.
config.mk only mkdirs $(obj), but we have objects shared with other
boards located on other dirs.
This patch mkdirs the needed dirs for the xlnx-generic boards.
16MiB NAND TLB window is way too big. Reduce it to 1KiB.
Signed-off-by: Felix Radensky <felix@embedded-sol.com>
The include/miiphy.h header duplicates a lot of things from linux/mii.h.
So punt all the things that overlap to keep the API simple and to make
merging between U-Boot and Linux simpler.
Commit 98e6956 "mpc52xx: add support for tqm52xx based board charon"
caused build warnings on some systems. Fix these.
This patch supports T-SH7706LSR board.
This is constitution almost same as shmin (T-SH7706LAN).
Therefore, most functions work by a change of the setting of config.
http://web.kyoto-inet.or.jp/people/takagaki/T-SH7706/T-SH7706LSR.htm
Change lib$(BOARD).a to lib$(BOARD).o
This adds support for the SHMIN SH7706 board(T-SH7706LAN).
The CPU of this board is SH7706.
There are SDRAM of 32M byte, Flash memory of 512K byte, Serial,
10Base Ether and MMC.
http://web.kyoto-inet.or.jp/people/takagaki/T-SH7706/T-SH7706.htm
It can be optimised out by the compiler otherwise resulting
in obscure errors like a board not booting.
This has been documented in README since 2006 when these were
first fixed up for GCC 4.x.
Signed-off-by: John Rigby <john.rigby@linaro.org>
Fix some additional places.
Acked-By: Albert ARIBAUD <albert.aribaud@free.fr>
Convert the variable omap3_evm_version to u32 to work around
some broken linkers from older tool chains. E.g. CodeSourcery's
2009q1-203 ld 2.19.51.20090205. Without this, these linkers
stop linking 'omap3_evm' or at least issue a warning. Like
arm-none-linux-gnueabi-ld: section .bss [8003f5e0 -> 8007e337] overlaps section .rel.dyn [8003f5e0 -> 80044e57]
arm-none-linux-gnueabi-ld: section .dynsym [80044e58 -> 80044ef7] overlaps section.bss [8003f5e0 -> 8007e337]
arm-none-linux-gnueabi-ld: u-boot: section .bss vma 0x8003f5e0 overlaps previous sections
CC: Sanjeev Premi <premi@ti.com>
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
The following commit:
commit 882b7d726febe65579d6502c271412ecb05821d7
Author: Mike Frysinger <vapier@gentoo.org>
Date: Wed Oct 20 03:41:17 2010 -0400
do_reset: unify duplicate prototypes
missed the 74xx_7xx and mpc86xx arches and the ppmc7xx board do_reset()
functions which resulted in build errors such as:
cpu.c:128: error: conflicting types for 'do_reset'
include/command.h:102: error: previous declaration of 'do_reset' was here
Use common ppc4xx linker script for xilinx ppc440 and ppc405 related boards.
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
This patch includes the following changes for the lwmon5 board support:
- Enable cache in SDRAM
- Use common EHCI driver instead of the PPC4xx specific OHCI driver
This can be done since only high-speed devices are connected.
- Remove cached TLB entry again after ECC setup
- Use correct define for cache enabling
(CONFIG_4xx_DCACHE instead of CONFIG_SYS_ENABLE_SDRAM_CACHE)
- Enable FIT image support
The t3corp board has an Xilinx DS617 flash chip connected to the
onboard FPGA. This patch adds support for these chips. Board
specific flash accessor functions are needed, since the chips
can only be read correctly in 16bit mode.
Additionally the FPGA chip-selects are configured for device-paced
transfers (ready is enabled).
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
Aspenite is a Development Board for ASPEN/ARMADA168(88AP168) with
* Processor upto 1.2GHz
* Parallel 1Gb x8 DDR2-1066 MHz
* 16 Mb x16 NOR, 4Gb x8 SLC NAND, footprint for SPI NOR
* Footprints for eMMC/eSD NAND & MMC x8 card
* 4-in-1 card reader (xD, MMC/SD/MS Pro), CF True IDE socket
* SEAF memory board, subset of PISMO2
With Peripherals:
* 4.3” WVGA 24-bit LCD
* Audio codecs (AC97 & I2S), TSI
* VGA camera
* Video in via 3 RCA jacks, and HDMI type C out
* Marvell 88W8688 802.11bg/BT module
* GPS RF IC
* Dual analog mics & speakers, headset jack, LED, ambient light sensor
* USB2.0 HS host (A), OTG (micro AB)
* FE PHY, PCIE Mini Card slot
* GPIO, GPIO expander with DIP switches for easier selection UART serial over USB, CIR
This patch adds basic board support with DRAM and UART functionality
The patch is tested for boot from DRAM using XDB
Signed-off-by: Mahavir Jain <mjain@marvell.com>
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
- serial console in PSC1
- 128MiB DRAM
- 32MiB Flash
- FEC Ethernet
- 2 I2C busses
- FPGA on CS3
- IDE
- VGA SMI501
Signed-off-by: Asen Dimov <dimov@ronetix.at>
