Rename CONFIG_SYS_DDR_CONFIG to include which CS it is configuring
Cleanup the setting of the csnbds to respect the setting of
CONFIG_SYS_DDR_SDRAM_BASE
Use __ilog2 instead of writing the code to compute it
Disable unused CS configs
Ensure ddrlaw.bar is configured
Cc: Joe Hershberger <joe.hershberger@gmail.com>
The common code should be valid for more than one architecture.
Therefore this code was reorganized and moved to the new
file km83xx_i2c.c
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
U-Boot Makefiles contain a number of tests for compiler features etc.
which so far are executed again and again. On some architectures
(especially ARM) this results in a large number of calls to gcc.
This patch makes sure to run such tests only once, thus largely
reducing the number of "execve" system calls.
Example: number of "execve" system calls for building the "P2020DS"
(Power Architecture) and "qong" (ARM) boards, measured as:
-> strace -f -e trace=execve -o /tmp/foo ./MAKEALL <board>
-> grep execve /tmp/foo | wc -l
Before: After: Reduction:
P2020DS 20555 15205 -26%
qong 31692 14490 -54%
As a result, built times are significantly reduced, typically by
30...50%.
Cc: Andy Fleming <afleming@gmail.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Albert Aribaud <albert.aribaud@free.fr>
cc: Graeme Russ <graeme.russ@gmail.com>
cc: Mike Frysinger <vapier@gentoo.org>
Tested-by: Graeme Russ <graeme.russ@gmail.com>
Tested-by: Matthias Weisser <weisserm@arcor.de>
Tested-by: Sanjeev Premi <premi@ti.com>
Tested-by: Macpaul Lin <macpaul@gmail.com>
Fix:
mv_eth.c: In function 'mv64460_eth_real_open':
mv_eth.c:471:6: warning: variable 'port_status' set but not used [-Wunused-but-set-variable]
mv_eth.c: In function 'mv64460_eth_stop':
mv_eth.c:722:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable]
mv_eth.c: In function 'mv64460_eth_xmit':
mv_eth.c:796:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable]
mv_eth.c: In function 'mv64460_eth_receive':
mv_eth.c:877:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable]
mv_eth.c: In function 'mv64460_eth_get_stats':
mv_eth.c:979:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable]
mv_eth.c: In function 'mv64460_eth_update_stat':
mv_eth.c:1006:24: warning: variable 'dummy' set but not used [-Wunused-but-set-variable]
mv_eth.c:1005:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable]
mv_eth.c: In function 'mv64460_eth_print_stat':
mv_eth.c:1087:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable]
mv_eth.c: In function 'eth_clear_mib_counters':
mv_eth.c:2141:15: warning: variable 'dummy' set but not used [-Wunused-but-set-variable]
Fix:
strataflash.c: In function 'flash_write_cfiword':
strataflash.c:669:11: warning: variable 'ctladdr' set but not used
Fix:
flash.c: In function 'flash_erase':
flash.c:304:24: warning: variable 'l_sect' set but not used
In addition, remove some dead code.
* 'master' of git://git.denx.de/u-boot-mmc:
tegra2: Move MMC clock initialization into MMC driver
mmc: sdhci: fix sdma bug for large file transfer
mmc: sdhci: add timeout for data transfer
mmc: sdhci: add mmc structure for host
mmc: sdhci: fix build warning
mmc: sdhci: fix cache flush
mmc: CMD7:MMC_CMD_SELECT_CARD response fix
mmc: test mmc bus width on startup
mmc: change magic number to macro define
mmc: mv_sdhci: fix 8bus width access for 88SV331xV5
mmc: retry the cmd8 to meet 74 clocks requirement in the spec
PXA: Add MMC driver using the generic MMC framework
This centralizes knowledge of MMC clocking into the MMC driver. This also
removes clock setup from the board files, which will simplify later changes
that modify the Harmony board to support the correct set of MMC controllers.
Also include some trivial related cleanups
* 'master' of git://git.denx.de/u-boot-arm:
ARM: Add Calxeda Highbank platform
dkb: make mmc command as default enabled
Marvell: dkb: add mmc support
ARM: pantheon: add mmc definition
davinci: remove config.mk file from the sources
ARM:AM33XX: Add support for TI AM335X EVM
ARM:AM33XX: Added timer support
ARM:AM33XX: Add emif/ddr support
ARM:AM33XX: Add clock definitions
ARM:AM33XX: Added support for AM33xx
omap3/emif4: fix registers definition
davinci: remove obsolete macro CONFIG_EMAC_MDIO_PHY_NUM
davinci: emac: add support for more than 1 PHYs
davinci: emac: add new features to autonegotiate for EMAC
da850evm: Move LPSC configuration to board_early_init_f()
omap4_panda: Build in cmd_gpio support on panda
omap: Don't use gpio_free to change direction to input
mmc: omap: Allow OMAP_HSMMC[23]_BASE to be unset
OMAP3: overo : Add environment variable optargs to bootargs
OMAP3: overo: Move ethernet CS4 configuration to execute based on board id
OMAP3: overo : Use ttyO2 instead of ttyS2.
da830: add support for NAND boot mode
dm36x: revert cache disable patch
dm644X: revert cache disable patch
devkit8000: Add malloc space
omap: spl: fix build break due to changes in FAT
OMAP3 SPL: Provide weak omap_rev_string
omap: beagle: Use ubifs instead of jffs2 for nand boot
omap: overo: Disable pull-ups on camera PCLK, HS and VS signals
omap: overo: Configure mux for gpio10
SPL: Add DMA library
omap3: Add interface for omap3 DMA
omap3: Add DMA register accessors
omap3: Add Base register for DMA
arm, davinci: add missing LSPC define for MMC/SD1
U-Boot/SPL: omap4: Make ddr pre-calculated timings as default.
DaVinci: correct MDSTAT.STATE mask
omap4: splitting padconfs into common, 4430 and 4460
omap4: adding revision detection for 4460 ES1.1
omap4: replacing OMAP4_CONTROL with OMAP4430_CONTROL
gplug: fixed build error as a result of code cleanup patch
kirkwood_spi: add dummy spi_init()
gpio: mvmfp: reduce include platform file
ARM: orion5x: reduce dependence of including platform file
serial: reduce include platform file for marvell chip
ARM: kirkwood: reduce dependence of including platform file
ARM: armada100: reduce dependence of including platform file
ARM: pantheon: reduce dependence of including platform file
Armada100: Add env storage support for Marvell gplugD
Armada100: Add SPI flash support for Marvell gplugD
Armada100: Add SPI support for Marvell gplugD
SPI: Add SPI driver support for Marvell Armada100
dreamplug: initial board support.
imx: fix coding style
misc: pmic: drop old Freescale's pmic driver
MX31: mx31pdk: use new pmic driver
MX31: mx31ads: use new pmic driver
MX31: mx31_litekit: use new pmic driver
MX5: mx53evk: use new pmic driver
MX5: mx51evk: use new pmic driver
MX35: mx35pdk: use new pmic driver
misc: pmic: addI2C support to pmic_fsl driver
misc: pmic: use I2C_SET_BUS in pmic I2C
MX5: efikamx/efikasb: use new pmic driver
MX3: qong: use new pmic driver
RTC: Switch mc13783 to generic pmic code
MX5: vision2: use new pmic driver
misc: pmic: Freescale PMIC switches to generic PMIC driver
misc:pmic:samsung Enable PMIC driver at GONI target
misc:pmic:max8998 MAX8998 support at a new PMIC driver.
misc:pmic:core New generic PMIC driver
mx31pdk: Remove unneeded config
mx31: provide readable WEIM CS accessor
MX51: vision2: Set global macros
I2C: Add i2c_get/set_speed() to mxc_i2c.c
ARM: Update mach-types
devkit8000: Add config to enable SPL MMC boot
devkit8000: protect board_mmc_init
arm, post: add missing post_time_ms for arm
cosmetic, post: Codingstyle cleanup
arm, logbuffer: make it compileclean
tegra2: Enable MMC for Seaboard
tegra2: Add more pinmux functions
tegra2: Rename PIN_ to PINGRP_
tegra2: Add more clock functions
tegra2: Clean up board code a little
tegra2: Rename CLOCK_PLL_ID to CLOCK_ID
* 'master' of git://git.denx.de/u-boot-microblaze:
microblaze: Fix strict-aliasing rules for in_be32
microblaze: Wire up axi_ethernet driver initialization
Cc: Mike Frysinger <vapier@gentoo.org>
interrupts.c: In function 'interrupt_init_cpu':
interrupts.c:40: error: 'ETHERNET0_INTERRUPT_CAUSE_REGISTER' undeclared (first
use in this function)
interrupts.c:40: error: (Each undeclared identifier is reported only once
interrupts.c:40: error: for each function it appears in.)
interrupts.c:40: error: 'ETHERNET1_INTERRUPT_CAUSE_REGISTER' undeclared (first
interrupts.c:40: error: 'ETHERNET2_INTERRUPT_CAUSE_REGISTER' undeclared (first
interrupts.c:44: error: 'ETHERNET0_INTERRUPT_MASK_REGISTER' undeclared (first
interrupts.c:44: error: 'ETHERNET1_INTERRUPT_MASK_REGISTER' undeclared (first
interrupts.c:44: error: 'ETHERNET2_INTERRUPT_MASK_REGISTER' undeclared (first
pd67290.c: In function 'cirrus_set_opts':
pd67290.c:282: error: 'buf' undeclared (first use in this function)
pd67290.c:282: error: (Each undeclared identifier is reported only once
pd67290.c:282: error: for each function it appears in.)
flash.c: In function 'flash_init':
flash.c:54: warning: format '%08X' expects type 'unsigned int', but argument 4
has type 'struct flash_info_t *'
flash.c: In function 'flash_get_size':
flash.c:222: warning: format '%08lx' expects type 'long unsigned int', but
argument 3 has type 'int'
flash.c:238: warning: format '%08lx' expects type 'long unsigned int', but
pmc405de.c: In function 'do_painit':
pmc405de.c:444: warning: format '%08x' expects type 'unsigned int', but argument
2 has type 'phys_size_t'
cmd_pmc440.c: In function 'do_painit':
cmd_pmc440.c:371: warning: format '%08x' expects type 'unsigned int', but
argument 2 has type 'phys_size_t'
tqm834x.c: In function 'initdram':
tqm834x.c:126: warning: format '%d' expects type 'int', but argument 3 has type
'long int'
tqm834x.c: In function 'set_cs_bounds':
tqm834x.c:336: warning: format '%08x' expects type 'unsigned int', but argument
2 has type 'long int'
3 has type 'long int'
tqm834x.c: In function 'set_cs_config':
tqm834x.c:354: warning: format '%08x' expects type 'unsigned int', but argument
mpc8610hpcd.c: In function 'misc_init_r':
mpc8610hpcd.c:79: warning: format '%02lx' expects type 'long unsigned int', but
argument 2 has type 'int'
mpc8610hpcd.c:86: warning: format '%02lx' expects type 'long unsigned int', but
diu.c: In function 'diu_set_pixel_clock':
diu.c:77: warning: format '%lu' expects type 'long unsigned int', but argument 2
has type 'u32'
mpc5121ads.c: In function 'misc_init_r':
mpc5121ads.c:256: warning: format '%02lx' expects type 'long unsigned int', but
mpc5121ads.c:263: warning: format '%02lx' expects type 'long unsigned int', but
This renames BOARD_LATE_INIT to CONFIG_BOARD_LATE_INIT.
Along the way it removes some leftover
#define BOARD_LATE_INIT 1
and adds some basic documentation for board specific
callbacks in README.
Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
Add basic support for Calxeda Highbank platform. Only minimal support with
serial and SATA are included.
Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Signed-off-by: Lei Wen <leiwen@marvell.com>
This patch adds basic support for booting the board.
This patch adds support for the UART necessary to
get to the u-boot prompt.
Signed-off-by: Chandan Nath <chandan.nath@ti.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Since commit f1d2b313c9eb6808d30c16a9eb5251240452a56c the serial
port of the da850evm is accessed before the UART2 peripheral of
the SoC is powered on in the function board_init() in
board/davinci/da8xxevm/da850evm.c.
When u-boot is used in conjunction with the UBL (user boot loader, see
doc/README.davinci) on this board, the UART2 peripheral is already
turned on by UBL at the time u-boot is started. Hence, the wrong
initialization sequence is not noticed by most users. However, if UBL is not
used, u-boot must power on the peripheral before using it.
This patch adds a board_early_init_f() function for the LPSC
configuration to the da850evm board configuration.
Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Cc: Sandeep Paulraj <s-paulraj@ti.com>
Cc: Ben Gardiner <bengardiner@nanometrics.ca>
gpio_free() should not have the side effect of setting the line to input since this prevents the gpio command from being able to set a line as output.
By moving the CS4 configuration into the board specific configuration, it
is left free for custom carrier boards. The USRP-E1XX series uses
CS4 to control access to an FPGA, so without this patch the device driver
cannot claim CS4.
Signed-off-by: Philip Balister <philip@opensdr.com>
Tested-by: Steve Sakoman <steve@sakoman.com>
Add support for enabling NAND boot mode in configuration file and
add correspanding pinmux support, nand initialize function in board file.
The size required for environment variables not more than 10KB
the CONFIG_ENV_SIZE is set to 10KB from (512 << 10).
Acked-by: Nick Thompson <nick.thompson@ge.com>
Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com>
The level shifters used on the Caspa camera module have a 4k output
impedance. Combined with the 100uA pull-up resistors in the OMAP3,
this raises the ground level to 400mV. Adding crosstalk between the
pixel clock and the HS/VS signals on the flat cable (a ground line in
between would have been nice), logic 0 levels can raise up to 650mV.
This exceeds the camera input pins VIL maximum voltage. This change
suggested-by Laurent Pinchart
Signed-off-by: Steve Sakoman <steve@sakoman.com>
This pad was previously configured for sysclkout_1. This patch changes
the configuration to gpio_10 to reduce radiated noise from the 26Mhz
clock, as well as make the pin more generally useful.
Acked-by: Philip Balister <philip@opensdr.com>
Not all padconfs are the same between 4430 and 4460, so instead of
working around this with an if, we should have an specific padconf
structure for both chips (like handling the differences between the LEDs
GPIOs and TPS).
Signed-off-by: Ricardo Salveti de Araujo <ricardo.salveti@linaro.org>
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
For files like the drivers/serial/serial.c, it must include the
platform file, as the CONFIG_SYS_NS16550_COM1 must reference to the
definition in the platform definition files.
Include the platform definition file in the config file, so that it
would decouple the dependence for the driver files.
Updated cpu.h to remove build errors for gplugd board (by prafulla)
This patch add SPI driver support for Marvell gplugD
Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
Copied wholeheartedly from board/Marvell/guruplug and modified to add support
for SPI NOR flash.
CONFIG_MACH_DREAMPLUG defined in include/configs/dreamplug.h until Linus's
kernel.org tree adds it to mach-types.h. Once it trickles down, the definition
can be removed from include/configs/dreamplug.h.
Signed-off-by: Jason Cooper <u-boot@lakedaemon.net>
Fix checkpatch warning and errors in several i.MX related files.
While at it also address a checkpatch warning at arch/arm/cpu/armv7/mx5/soc.c
regarding the usage of extern in a C file.
Switch to new pmic generic driver.
CC: Jason Liu <jason.hui@linaro.org>
Acked-by: Jason Liu <jason.hui@linaro.org>
CC: Marek Vasut <marek.vasut@gmail.com>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Enable support for new PMIC driver at GONI reference target.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
setup_weimcs() and some macros are added to support the setup
for i.MX31 WEIM chip selects. As a compromise between verbosity
and readability an ASCII-art'ish bit comment is used instead of
bitfields.
All i.MX31 boards have been patched to use this approach using a
helper program to verify the changes.
This function is also defined in omap-common/spl_mmc.de so the implementation
in devkit8000.c was protected by a ifdef.
Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com>
This adds the required GPIO and pinmux configuration to make eMMC / SD work
on Seaboard.
Tested-by: Tom Warren <twarren@nvidia.com>
This adds support for changing pinmux functions of pin groups. This is done
by defining a PMUX_FUNC_... enum which can be used to select the function for
each group using pinmux_set_func(). It is also possible to enable
pullup/pulldown, and the existing tristate functionality is retained.
Also provided is a means of configuring a list of pingroups by providing a
configuration table to pinmux_config_table().
