Previously some mpc85xx boards printed indented messages such as the
following on bootup:
printf(" eTSEC4 is in sgmii mode.\n");
printf(" Serdes2 disalbed\n");
The bootup appearance looks cleaner if the indentation is removed which
aligns these messages with other bootup output.
CC: galak@kernel.crashing.org
Previously boards used a variety of indentations, newline styles, and
colon styles for the PCI information that is printed on bootup. This
patch unifies the style to look like:
NAND: 1024 MiB
PCIE1: connected as Root Complex
Scanning PCI bus 01
04 01 8086 1010 0200 00
03 00 10b5 8112 0604 00
02 01 10b5 8518 0604 00
02 02 10b5 8518 0604 00
08 00 1957 0040 0b20 00
07 00 10b5 8518 0604 00
09 00 10b5 8112 0604 00
07 01 10b5 8518 0604 00
07 02 10b5 8518 0604 00
06 00 10b5 8518 0604 00
02 03 10b5 8518 0604 00
01 00 10b5 8518 0604 00
PCIE1: Bus 00 - 0b
PCIE2: connected as Root Complex
Scanning PCI bus 0d
0d 00 1957 0040 0b20 00
PCIE2: Bus 0c - 0d
In: serial
CC: wd@denx.de
CC: sr@denx.de
The size of the other bank needed to be added to the br0 setting;
this got dropped in the LBC cleanup.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Tested-by: Wolfgang Denk <wd@denx.de>
Acked-by: Wolfgang Denk <wd@denx.de>
Display the 64-byte Reset Configuration Word (RCW) during boot, so that
there's no confusion as to what RCW U-boot is using.
Reset Configuration Word (RCW):
00000000: 4a500000 00000000 18181818 00008888
00000010: 28402400 00002000 fe800000 01200000
00000020: 00000000 00000000 00000000 000b0000
00000030: 00000000 00000000 00000000 00000000
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
SQW/INT pin in RTC can be used for generating square wave(by default) or
as interrupt line. U-boot is registering this pin for interrupts.
Configuring SQW/INT bit as interrupt line during board initialization
to avoid spurious interrupts generated by square wave.
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
Function omap3_evm_get_revision() - to identify the
board revision was called at end of setup_net_chip().
Board revision can be ascertained only by identifying
the Ethernet chipset - but combining setup operations
with revision detection isn't a good idea. So, moved
the function after call to setup_net_chip().
Function setup_net_chip() should be ideally be called
only when CONFIG_CMD_NET is defined. But this leaves
the board revision "undetected". This patch allows
static definition of revision or default fallback to
the latest revision.
Signed-off-by: Sanjeev Premi <premi@ti.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
The function omap3_evm_need_extvbus() is required
only when USB support is configured.
Wrapped this function in #ifdef CONFIG_USB_OMAP3.
This patch adds relocation support for omap3evm.
Content of the patch is based on changes for
Beagleboard.
This patch switches from the legacy mmc driver to the new generic mmc driver
Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
Beagle expansion boards contain an i2c eeprom to identify themselves.
This patch adds code to read and parse the eeprom contents. It prints
the expansion board name and revision and modifies environment variables
as appropriate. This patch is based on the Overo expansion board code.
Signed-off-by: Koen Kooi <k-kooi@ti.com>
Signed-off-by: Steve Sakoman <steve.sakoman@linaro.org>
Overo expansion boards contain an i2c eeprom to identify themselves.
as appropriate.
Signed-off-by: Steve Sakoman <steve@sakoman.com>
Commit 14d0a02a "Rename TEXT_BASE into CONFIG_SYS_TEXT_BASE" missed the
IGEP boards since they were just added.
include/configs/km_arm.h
When this define was introduced, the idea was to provide a soft
migration path for ARM boards to get adapted to the new relocation
support. However, other recent changes led to a different
implementation (ELF relocation), where this no longer works. By now
CONFIG_SYS_ARM_WITHOUT_RELOC does not only not help any more, but it
actually hurts because it obfuscates the actual code by sprinkling it
with lots of dead and non-working debris.
So let's make a clean cut and drop CONFIG_SYS_ARM_WITHOUT_RELOC.
Tested-by: Heiko Schocher <hs@denx.de>
Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
After moving the definition of CONFIG_SYS_TEXT_BASE to the respective
board config files, all Marvell kirkwood board have just a single and
common entry in their config.mk files:
KWD_CONFIG = $(SRCTREE)/board/$(BOARDDIR)/kwbimage.cfg
Replace the only reference to KWD_CONFIG in the top level Makefile by
an equivalent setting, and remove all kirkwood config.mk files.
Signed-off-by: Wolfgang Denk <wd at denx.de>
Cc: Prafulla Wadaskar <prafulla at marvell.com>
Cc: Siddarth Gore <gores at marvell.com>
Cc: Simon Kagstrom <simon.kagstrom at netinsight.net>
Cc: Heiko Schocher <hs at denx.de>
Cc: Eric Cooper <ecc at cmu.edu>
Acked-by: Wolfgang Denk <wd at denx.de>
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
This patch is to fix build breakage and support new relocation
scheme for mx51evk.
- Correct IRAM base address and add size definition
The IRAM starts from 0x1FFE0000 on final revsion i.mx51 than
0x1FFE8000 which is for older revision.
- Include imx-regs.h in mx51evk.h
Definitions like CSD0_BASE_ADDR and IRAM_BASE_ADDR can be
referred to.
- Define CONFIG_SYS_INIT_RAM_ADDR and CONFIG_SYS_INIT_RAM_SIZE
They are used to define init RAM layout.
- Remove comment for CONFIG_SYS_GBL_DATA_SIZE which has been
buried by Wolfgang's commit below
25ddd1fb: Replace CONFIG_SYS_GBL_DATA_SIZE by auto-generated value
Signed-off-by: Shawn Guo <shawn.gsc@gmail.com>
The mx51evk u-boot has an issue that system will get reset
every 2 hours.
MC13892 has an inside charge timer which expires in 120 minutes.
If ICHRG and CHGAUTOB are not set properly, this timer expiration
will get system power recycled.
Since mx51evk has no Li-Ion battery on board, the patch sets
ICHRG in externally powered mode and sets CHGAUTOB bit to avoid
automatic charging, so that system will not get reset by this
timer expiration.
The patch also corrects the bit field definition of register 48
(Charger 0) per latest MC13892 Reference Manual.
Remove u-boot.lds from mx5 and use the common u-boot.lds
of cpu layer. This patch also fix the building errors:
arch/arm/cpu/armv7/start.o: In function `_rel_dyn_start_ofs':
arch/arm/cpu/armv7/start.S:283: undefined reference to `__rel_dyn_start'
arch/arm/cpu/armv7/start.o: In function `_rel_dyn_end_ofs':
arch/arm/cpu/armv7/start.S:283: undefined reference to `__rel_dyn_end'
arch/arm/cpu/armv7/start.o: In function `_dynsym_start_ofs':
arch/arm/cpu/armv7/start.S:283: undefined reference to `__dynsym_start'
Signed-off-by: Jason Liu <r64343@freescale.com>
Recent patch changed TEXT_BASE to CONFIG_SYS_TEXT_BASE and
vision2 board was not updated.
This patch adds generic support for the Samsung s3c2440 processor.
Global s3c24x0 changes to struct members converting from upper case to
lower case.
Signed-off-by: Craig Nauman <cnauman@diagraph.com>
Cc: kevin.morfitt@fearnside-systems.co.uk
Out of tree building of the Netstal mcu25 board failed like
that:
Configuring for mcu25 board...
Assembler messages: Fatal error: can't create /work/wd/tmp-ppc/board/netstal/mcu25/../common/fixed_sdram.o: No such file or directory
Assembler messages: Fatal error: can't create /work/wd/tmp-ppc/board/netstal/mcu25/../common/nm_bsp.o: No such file or directory
Adapt (and simplify) the Makefile.
Cc: Niklaus Giger <niklaus.giger@netstal.com>
Move CONFIG_SYS_TEXT_BASE to the board's config file, and remove the
now unnecessary config.mk file.
Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com>
Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be
some end address; to make the meaning more clear we rename it into
No other code changes are performed in this patch, only minor editing
of white space (due to the changed length) and the comments was done,
where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations
looks seriously broken. Last known maintainers on Cc:
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Martin Winistoerfer <martinwinistoerfer@gmx.ch>
Board support for the Guntermann & Drunck CATCenter Io.
Board support for the Guntermann & Drunck IoCon.
Signed-off-by: Dirk Eibach <eibach@gdsys.de>
Out of tree building of the Netstal hcu4 and hcu5 boards failed like
that:
Assembler messages:
Fatal error: can't create /work/wd/tmp-ppc/board/netstal/hcu4/../common/fixed_sdram.o: No such file or directory
Assembler messages:
Fatal error: can't create /work/wd/tmp-ppc/board/netstal/hcu4/../common/nm_bsp.o: No such file or directory
make[1]: *** [/work/wd/tmp-ppc/board/netstal/hcu4/../common/fixed_sdram.o] Error 2
Adapt (and simplify) the respective Makefiles.
Fix warning:
icecube.c: In function 'lite5200b_wakeup':
icecube.c:83: warning: format '%08lx' expects type 'long unsigned int', but argument 2 has type 'void (*)(void)'
Initial support for Extreme Engineering Solutions XPedite5500 -
a P2020-based PMC/XMC single board computer.
Signed-off-by: John Schmoller <jschmoller@xes-inc.com>
Some U-Boot images for X-ES boards support multiple products in the same
family. For example, the XPedite5370, XPedite5371, and XPedite5372 are
similar enough that one U-Boot image can work on all 3 cards. To make it
clear that a U-Boot image can work on boards of the same family, rename
the boards with the least significant digit of 'x'.
While we're at it, change the board config file and make targets to be
lowercase.
Also change the default uImage and fdt filenames to "board.uImage" and
"board.dtb" to be more generic.
Add board_flash_wp_on() to check a pca9557 gpio pin to see
if non-volatile memory write protection is enabled.
Previously, write protected NOR flashes would fail initialization which
resulted in a bootup error such as:
DTT: 53 C local / 64 C remote (adt7461@4c)
DTT: 54 C local (ds1621@48)
FLASH: Executed from FLASH1
POST memory PASSED
FLASH: ## Unknown FLASH on Bank 1 - Size = 0x00000000 = 0 MB
## Unknown FLASH on Bank 2 - Size = 0x00000000 = 0 MB
*** failed ***
### ERROR ### Please RESET the board ###
With this patch, NOR flash initialization is skipped:
POST memory PASSED
FLASH: Uninitialized - Write Protect On
L2: 1024 KB enabled
NAND: 1024 MiB
Note that flash related commands such as flinfo and saveenv will error
out when flash write protection is enabled.
Create a common checkboard() function to support all X-ES's Freescale
boards.
Also, add a get_board_derivative() function which reads hardware
strapping resistors to determine what model a board is. This allows one
U-Boot image to support multiple boards.
Common Freescale code for PCI initialization now exists, so migrate X-ES
boards to use it.
This board is broken and it's not possible to repair it.
This board is broken and impossible to repair without deep knowledge or
availability of the hardware.
