path: root/board
2005-11-03Additional fix for external IRQ config on Yellowstone & YosemiteStefan Roese
Patch by Stefan Roese, 03 Nov 2005
2005-11-01Add support for Ocotea pass 3 with 440GX Rev. FStefan Roese
Patch by Stefan Roese, 01 Nov 2005
2005-11-01Merge with /git/u-boot.gitStefan Roese
2005-10-29Merge with /home/m8/git/u-bootWolfgang Denk
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-10-28Fix conflicting types (flash_write()) in trab auto_update.cMarian Balakowicz
2005-10-28Fix external IRQ configuration on Yellowstone & YosemiteStefan Roese
The multiplexed signals Ext IRQ0...3 have to be configured as IRQ, because they default to GPIOx (440EP/GR). Patch by Stefan Roese, 28 Oct 2005
2005-10-21Merge with /home/wd/git/u-boot/masterWolfgang Denk
2005-10-20Fix conflicting types (flash_write()) in esd auto_update.cStefan Roese
Patch by Stefan Roese, 20 Oct 2005
2005-10-17Add PCI support for the TQM834x board.Rafal Jaworowski
2005-10-15Merge with /home/m8/git/u-bootWolfgang Denk
2005-10-13Add missing files for Pantelis Antoniou's patchWolfgang Denk
Patch by Pantelis Antoniou, 04 Sep 2005
2005-10-13Merge with /home/sr/git/u-bootWolfgang Denk
2005-10-13CleanupWolfgang Denk
2005-10-13Add support for OF flat tree for the STXtc board.Wolfgang Denk
2005-10-13Support passing of OF flat trees to the kernel.Wolfgang Denk
2005-10-11Added support for TQM834x boards.Marian Balakowicz
2005-10-09Add support for NetSilicon NS7520 processor.Wolfgang Denk
Patch by Art Shipkowski, 12 May 2005 Cleanup.
2005-10-09Add support for AP1000 board.Wolfgang Denk
Patch by James MacAulay, 07 Oct 2005
2005-10-09Eliminate hard-coded address of Ethernet transfer buffer on at91rm9200Wolfgang Denk
Patch by Anders Larsen, 07 Oct 2005 The Atmel errata #11 states that the transfer buffer descriptor table must be aligned on a 16-word boundary. As it turned out, this is insufficient - it seems the table must be aligned on a boundary at least as large as the table itself (in Linux this is not an issue - the table is aligned on a PAGE_SIZE (4096) boundary).
2005-10-09Cleanup warnings for cpu/arm720t & cpu/arm1136 files.Wolfgang Denk
sed the linker scripts, rather than pre-process them. Patch by Peter Pearse, 07 Oct 2005
2005-10-08Fix gzip bmp support (test if malloc fails, warning when truncated).Stefan Roese
Increase CFG_VIDEO_LOGO_MAX_SIZE on HH405 board. Patch by Stefan Roese, 08 Oct 2005
2005-10-06CleanupWolfgang Denk
2005-10-06Make "split_by_variant.sh" executable.Wolfgang Denk
2005-10-06Update make target for ARM supported boards.Wolfgang Denk
Use lowlevel_init() instead of platformsetup() [rename]. Patch by Peter Pearse, 06 Oct 2005
2005-10-06Fix the machine-id of the Cogent csb637 boardWolfgang Denk
Patch by Anders Larsen, 05 Oct 2005
2005-10-05Add support for Cogent csb637Wolfgang Denk
Patch by Anders Larsen, 29 Apr 2005
2005-10-05* Move dm9161.c and lxt972.c into cpu/arm920t/at91rm9200Wolfgang Denk
Patch by Anders Larsen, 29 Apr 2005 * Fix problems introduced by Patch by Steven Scholz, 02 Mar 2005 (8e2be51de8dd03c1ce4d06cbb18ad06133d47cd5)
2005-10-05Added support for KwikByte KB920x boards (based on AT91RM9200)Wolfgang Denk
Patch by Matt ?? <kb9200_dev@kwikbyte.com>, 27 Apr 2005
2005-10-05Add support for S29GL064M-R3 flash chip on xsengine boardWolfgang Denk
Patch by Kurt Stremerch, 18 Apr 2005
2005-10-04Update ARM Integrator boards:Wolfgang Denk
Correct addessing errors in platform files. Split off common core module data from Integrator header files to include/armcoremodule.h. Patch by Peter Pearse, 04 Oct 2005
2005-10-03Change board message on AMCC Yosemite & Yellowstone to common styleStefan Roese
Patch by Stefan Roese, 3 Oct 2005
2005-09-30Fix problem with SM501 init on HH405 board.Stefan Roese
Patch by Stefan Roese, 30 Sep 2005
2005-09-26Add support for MP2USB board.Wolfgang Denk
Patch by Eric Benard, 07 Apr 2005
2005-09-26Add board support for armadillo HT1070Wolfgang Denk
Patch by Rowel Atienza, 06 Apr 2005
2005-09-25Add Barco Streaming Video Card (SVC) and Sample Compress Network (SCN) boardWolfgang Denk
Patch by Marc Leeman, 04 Mar 2005
2005-09-25CleanupWolfgang Denk
2005-09-25OMAP242x H4 board updateWolfgang Denk
- fix for ES2 differences. - switch to using the cfi_flash driver. - fix SRAM build address. - fix for GP device operation. - unlock SRAM for GP devices. - display more device information. - fix potential deadlock in omap24xx_i2c driver. - fix DLL load values to match dpllout*1 operation. - fix 2nd chip select init for combo DDR device. - add support for CFI Intel 28F256L18 on H4 board. Patch by Richard Woodruff, 03 Mar 2005
2005-09-25Fix VOH405 SupportWolfgang Denk
Patch by Matthias Fuchs, 25 Sep 2005
2005-09-25Added support for PCI bridge on MPC8272ADSWolfgang Denk
Patch by Vitaly Bordug, Feb 09 2005
2005-09-25Update multicore CM9XX support for Integrator AP to allow booting from flashWolfgang Denk
Patch by Jean-Paul Saman, 8 Feb 2005
2005-09-25Add Vibren (was Accelent) PXA255 IDP SupportWolfgang Denk
Patch by Cliff Brake, 04 Feb 2005
2005-09-25Add ARM946E cpu and core module targets; remap memory to 0x00000000Wolfgang Denk
Patch by Peter Pearse, 2 Feb 2005
2005-09-25OMAP242x fix for GP device bootingWolfgang Denk
- Add SRAM unlock for GP devices. - Change DDR DLL unlock value to allow DPLLout*1 operation. Patches by Richard Woodruff, 21 Jan 2005:
2005-09-25Add support for AMD's Pb1x00 eval board;Wolfgang Denk
add MII routines to the au1x00 ethernet driver; add USB ohci driver (work in progress) Patch by Thomas Sailer, 20 Jan 2005
2005-09-25Update omap5912osk board:Wolfgang Denk
Use drivers/cfi_flash.c instead of private flash driver; Remove hardcoded personalized settings from omap5912osk.h; Fix spacing with (RO) marks in 'flinfo' output. Patch by Michael Bendzick, 14 Jan 2005
2005-09-25Fix warnings for PCI code on ixpWolfgang Denk
Patch by Joe <lgxue@yahoo.com>, 13 Jan 2005
2005-09-24* Fix PHY address argument passing with mii info commandWolfgang Denk
Patch by Andrew Dyer, 28 Dec 2004 * Cleanup: fix broken builds
