path: root/board
2008-06-03Merge remote branch 'u-boot-at91/for-1.3.4'Wolfgang Denk
2008-06-03Merge remote branch 'u-boot-avr32/master'Wolfgang Denk
2008-06-03Merge remote branch 'u-boot-mips/master'Wolfgang Denk
2008-06-02Merge remote branch 'u-boot-ppc4xx/master'Wolfgang Denk
2008-05-30[MIPS] <asm/mipsregs.h>: Update coprocessor register access macrosShinya Kuribayashi
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-05-27avr32: Rework SDRAM initialization codeHaavard Skinnemoen
This cleans up the SDRAM initialization and related code a bit, and allows faster booting. * Add definitions for EBI and internal SRAM to asm/arch/memory-map.h * Remove memory test from sdram_init() and make caller responsible for verifying the SDRAM and determining its size. * Remove base_address member from struct sdram_config (was sdram_info) * Add data_bits member to struct sdram_config and kill CFG_SDRAM_16BIT * Add support for a common STK1000 hack: 16MB SDRAM instead of 8. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-05-27avr32: Use the same entry point for reset and exception handlingHaavard Skinnemoen
Since the reset vector is always aligned to a very large boundary, we can save a couple of KB worth of alignment padding by placing the exception vectors at the same address. Deciding which one it is is easy: If we're handling an exception, the CPU is in Exception mode. If we're starting up after reset, the CPU is in Supervisor mode. So this adds a very minimal overhead to the reset path (only executed once) and the exception handling path (normally never executed at all.) Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-05-27avr32: Clean up the HMATRIX codeHaavard Skinnemoen
Rework the HMATRIX configuration interface so that it becomes easier to configure the HMATRIX for boards with special needs, and add new parts. The HMATRIX header file has been split into a general, chip-independent part with register definitions, etc. and a chip-specific part with SFR bitfield definitions and master/slave identifiers. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-05-27avr32: Add support for the ATSTK1006 boardHaavard Skinnemoen
This is a replacement for ATSTK1002 with 64MB SDRAM and NAND flash on board. It's currently in production and will be available soon. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-05-27avr32: Get rid of the .flashprog sectionHaavard Skinnemoen
The .flashprog section was only needed back when we were running directly from flash, and it's even more useless on NGW100 since it uses the CFI flash driver which never used this workaround in the first place. Remove it on STK1000 as well, and get rid of all the associated code and annotations. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-05-24Merging Stelian Pop AT91 patchesJean-Christophe PLAGNIOL-VILLARD
Merge branch 'testing-V2' Conflicts: board/atmel/at91cap9adk/Makefile Fixing copyright board/atmel/at91sam9260ek/Makefile Fixing copyright board/atmel/at91sam9260ek/u-boot.lds Delete no more needed ld script Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-21Merge branch 'quad100hd'Stefan Roese
2008-05-21Merge branch 'master' of git://git.denx.de/u-boot-testingWolfgang Denk
2008-05-21Fix some whitespace issuesWolfgang Denk
introduced by 53677ef18 "Big white-space cleanup." Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-05-21Merge branch 'socrates' of /home/wd/git/u-boot/projectsWolfgang Denk
2008-05-21Make ads5121 out-of-tree compiling safeYork Sun
Reuse the existing DIU driver in board/freescale/common. Signed-off-by: York Sun <yorksun@freescale.com>
2008-05-21Adding DIU support for Freescale 5121ADSYork Sun
Add DIU and cfb console support to FSL 5121ADS board. Use #define CONFIG_VIDEO in config file to enable fb console. Signed-off-by: York Sun <yorksun@freescale.com>
2008-05-21Replace DPRINTF with debugYork Sun
Remove DPRINTF macro and replace it with generic debug macro. Signed-off-by: York Sun <yorksun@freescale.com>
2008-05-21Move pixel clock setting to board fileYork Sun
The clock divider has different format in 5121 and 8610. This patch moves it to board specific code. Signed-off-by: York Sun <yorksun@freescale.com>
2008-05-20socrates: changes to support FDTSergei Poselenov
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-05-20Initial support for "Socrates" boardSergei Poselenov
2008-05-19Merge branch 'master' of git://www.denx.de/git/u-boot-ppc4xxWolfgang Denk
2008-05-19ppc4xx: Canyonlands: Disable PCIe0/SATA in dev-tree depending on selectionStefan Roese
When SATA is selected (via jumper J6) we need to disable the first PCIe node in the device tree, so that Linux doesn't initialize it. Otherwise the Linux SATA driver will fail to detect the devices. The same goes the other way around too. So if PCIe is selected we need to disable the SATA node in the device tree. This is because PCIe port 0 and SATA on 460EX share the same pins (multiplexed) and we have to configure in U-Boot which peripheral is enabled. Signed-off-by: Stefan Roese <sr@denx.de>
2008-05-19i386: Fix multiple definitions of __show_boot_progressJean-Christophe PLAGNIOL-VILLARD
2008-05-19sc530_spunk: add missing SOBJS entryJean-Christophe PLAGNIOL-VILLARD
2008-05-19sc520_spunk: Fix flashJean-Christophe PLAGNIOL-VILLARD
flash.c:593: warning: dereferencing type-punned pointer will break strict-aliasing rules flash.c:398: error: label at end of compound statement Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-15TQM8272: fix out-of-tree buildingWolfgang Denk
...and add to MAKEALL script Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-05-14Merge branch 'master' of git://www.denx.de/git/u-boot-ppc4xxWolfgang Denk
2008-05-14Fix config files for out-of-tree buildingWolfgang Denk
Several board/<...>/config.mk files include dynamically built (by the Makefile) config files but used the wrong file name of $(TOPDIR)/board/$(BOARDDIR)/config.tmp instead if the correct $(OBJTREE)/board/$(BOARDDIR)/config.tmp The bug is nasty because the build result is correct for the (normal) in-tree builds, and because 'sinclude' is used no errors get raised even for out-of-tree build tests. But out-of-tree builds use an incomplete and thus usually incorrect configuration... Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-05-14ppc4xx: Fix bogus Canyonlands config.mkStefan Roese
This patch fixes the canyonlands config.mk file to enable correct out-of-tree builds. Thanks to Wolfgang Denk for spotting this. Signed-off-by: Stefan Roese <sr@denx.de>
2008-05-14linkstation_HGLAN: Fix out of tree building.Wolfgang Denk
2008-05-13ppc4xx: Add 405EX(r) revision C PVR definitions and detection codeStefan Roese
2008-05-10Support AT91CAP9 revC CPUsStelian Pop
The AT91CAP9 revC CPU has a few differences over the previous, revB CPU which was distributed in small quantities only (revA was an internal Atmel product only). The revC silicon needs a special initialisation sequence to switch from the internal (imprecise) RC oscillator to the external 32k clock. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9RLEK: hook up the ATMEL LCD driverStelian Pop
This patch makes the necessary adaptations (PIO configurations and defines in config header file) to hook up the Atmel LCD driver to the AT91SAM9RLEK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9263EK: hook up the ATMEL LCD driverStelian Pop
This patch makes the necessary adaptations (PIO configurations and defines in config header file) to hook up the Atmel LCD driver to the AT91SAM9263EK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9261EK: hook up the ATMEL LCD driverStelian Pop
This patch makes the necessary adaptations (PIO configurations and defines in config header file) to hook up the Atmel LCD driver to the AT91SAM9261EK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91CAP9ADK: hook up the ATMEL LCD driverStelian Pop
This patch makes the necessary adaptations (PIO configurations and defines in config header file) to hook up the Atmel LCD driver to the AT91CAP9ADK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9RLEK supportStelian Pop
This patch adds support for the AT91SAM9RL chip and the AT91SAM9RLEK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9263EK supportStelian Pop
This patch adds support for the AT91SAM9263 chip and the AT91SAM9263EK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9261EK supportStelian Pop
This patch adds support for the AT91SAM9261 chip and the AT91SAM9261EK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9260EK: Handle 8 or 16 bit NANDStelian Pop
The Atmel boards can handle 8 or 16 bit NAND memories. This patch makes the support configurable in the board config header file (CFG_NAND_DBW_8 or CFG_NAND_DBW_16). Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91CAP9ADK: Handle 8 or 16 bit NANDStelian Pop
2008-05-10Use a common u-boot.lds file across all AT91CAP9/AT91SAM9 platformsStelian Pop
All the AT91CAP9/AT91SAM9 boards have the same linker script. The patch below avoids the duplication of u-boot.lds by putting the file in the cpu directory instead of the board one. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10Add proper copyright notices in Atmel boards MakefilesStelian Pop
The Makefiles for the AT91CAP9/AT91SAM9 boards have an incomplete copyright notice. This patch adds the missing pieces. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10Add copyright information in Atmel boards partition.cStelian Pop
When Ulf did the dataflash.c cleanup, he didn't add his copyright on the new created files. This patch fixes the problem. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10Update origin and copyright information in arch-at91sam9 header filesStelian Pop
When doing the AT91CAP9/AT91SAM9 port, a number of header files were copied from the Linux kernel sources. This patch explicitly specifies this origin for all the copied headers, and for those missing copyright information, adds it. Additionaly, the header file 'at91sam926x_mc.h' has been superceeded in the latest kernel sources by 'at91sam9_smc.h'. The copyright information has been confirmed by the AT91 Linux kernel maintainer, Andrew Victor <avictor.za@gmail.com>. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10Fix @ -> <at> substitutionStelian Pop
When applying the AT91CAP9 patches upstream, something transformed the '@' character into the ' <at> ' sequence. The patch below restores the original form in all the places where it has been modified (the AT91CAP9 files, the AT91SAM9260 files which were copied from AT91CAP9, and a couple of other files where the ' <at> ' sequence was present). Signed-off-by: Stelian Pop <stelian@popies.net>
