- Show on the Status LEDs, some States of the board.
- Get the MAC addresses from the EEProm
- use PREBOOT
- use the CF on the board.
- check the U-Boot image in the Flash with a SHA1
checksum.
- use dynamic TLB entries generation for the SDRAM
This patch adds NAND booting support for the AMCC Acadia eval board.
Please make sure to configure jumper J7 to position 2-3 when booting
from NOR, and to position 1-2 when booting for NAND.
I also added a board command to configure the I2C bootstrap EEPROM
values. Right now only 267MHz is support for booting either via NOR
or NAND FLASH. Here the usage:
=> bootstrap 267 nor ;to configure the board for 267MHz NOR booting
=> bootstrap 267 nand ;to configure the board for 267MHz NNAND booting
e600 does not have a bootpg restriction.
Move the version string to beginning of image at fff00000.
Resetvec.S is not needed.
Update flash copy instructions.
Add tftpflash env variable
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
This patch undoes the patch by Jeff Mann with commit-id ada4697d. As
suggested by AMCC it is not recommended to dynamically change the EBC
speed after bootup. So we undo this change to be on the safe side.
This patch updates the "normal" Bamboo NOR booting port, so
that it is compatible with the coming soon NAND booting
Bamboo port.
It also enables the 2nd NAND flash on the Bamboo.
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
After being reset in mpc5xxx_fec_init_phy(), PHY goes into FX mode, in which
networking does not function. This commit switches PHY to TX mode by clearing
the FX_SEL bit of Mode Control Register. It also reverses commit
008861a2f3ef2c062744d733787c7e530a1b8761, i.e., a temporary workaround.
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
Acked-by: Bartlomiej Sieka <tur@semihalf.com>
Signed-off-by: Jan Wrobel <wrr@semihalf.com>
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
This patch updates the Acadia (405EZ) support for the new 1.1 board
revision. It also adds support for NAND FLASH via the 4xx NDFC.
Please note that the jumper J7 must be in position 2-3 for this
NAND support. Position 1-2 is for NAND booting only. NAND booting
support will follow later.
Because the Sequoia board does not boot with an EBC faster than 66MHz,
the clock divider are changed after the initial boot process.
This allows for maximum clocking speeds to be achieved on newer boards.
Sequoia boards with 666.66 MHz processors require that the EBC divider
be set to 3 in order to start the initial boot process at a slower EBC
speed. After the initial boot process, the divider can be set back to 2,
which will cause the boards to run at 83.333MHz. This is backward
compatible with boards with 533.33 MHz processors, as these boards will
already be set with an EBC divider of 2.
Signed-off-by: Jeffrey Mann <mannj@embeddedplanet.com>
The OBJTREE != SRCTREE build scenario was broken.
This fixes it.
to allow booting of FDT-expecting kernels.
include/asm-microblaze/microblaze_intc.h
include/linux/stat.h
FSL_Has_data is connected to INTC.
Using cpu/ppc4xx/speed.c to calculate the bus frequency is too big
for the 4k NAND boot image so define bus_frequency to 133MHz here
which is save for the refresh counter setup.
