MAINTAINERS
Minor path corrections needed to ensure buildability.
We already had defines for LAWAR_TRGT_IF_* that we should use
rather than creating new ones. Also, added some missing defines for
PCIE targets.
In the future the offsets to various blocks may not be in same location.
Move to using CFG_MPC85xx_*_ADDR as the base of the registers
instead of getting it via &immap.
Updated the MPC8568 MDS config to use libfdt and assume use of aliases for
ethernet, pci, and serial for the various fixups that are done.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
Updated the MPC85xx CDS config to use libfdt and assume use of aliases for
Updated the MPC8540 ADS config to use libfdt and assume use of aliases for
Updated the MPC8560 ADS config to use libfdt and assume use of aliases for
Move to using CFG_MPC85xx_GUTS_ADDR as the base of the guts registers
instead of getting it via &immap->im_gur.
Updated the MPC8544DS config to use libfdt and assume use of aliases for
The IDS8247 got lost in the update and need an API update
do to rename of functions in libfdt.
drivers/Makefile
drivers/Makefile
Update libfdt to commit 8eaf5e358366017aa2e846c5038d1aa19958314e from
the device tree compiler (dtc) project.
lowlevel_init.S: Assembler messages:
lowlevel_init.S:413: Warning: Pretending global symbol used as branch target is local.
Looking at codes, the `memtest' and `clearmem' are intentional mixed
use of `global symbols' and `label' for debugging purpose. To make it
build, just disable global-symbols-use for now. As a result `memtest'
still remains as unused, but leave it be...
Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
gth2.c: In function 'misc_init_r':
gth2.c:434: warning: pointer targets in passing argument 2 of 'setenv' differ in signedness
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
rsdproto board support has wrong I2C frequency and wrong return value
handling.
Signed-off-by: Luotao Fu <l.fu@pengutronix.de>
Apply Grant Likely's backout to MPC5121 code, too.
Pointed out by Rafal Jaworowski <raj@semihalf.com>
Ugh. I *hate* to back this change out, but these compiler flags don't
work for relocation on all versions of GCC. I've not been able to
reproduce the environment in my setup (and hence, not been able to
find a combination that *does* work), so I've got no choice but to go
back to the old gcc flags and linker script.
This patch has been sent on:
- 29 Sep 2007
Although mips_io_port_base is currently a part of IDE command, it is quite
fundamental for MIPS I/O port access such as in[bwl] and out[bwl]. So move
it to MIPS general part, and introduce `set_io_port_base()' from Linux.
This patch is triggered by multiple definition of `mips_io_port_base' build
error on gth2 (and tb0229 also needs this fix.)
board/gth2/libgth2.a(gth2.o): In function `log_serial_char':
/home/skuribay/devel/u-boot.git/board/gth2/gth2.c:47: multiple definition of `mips_io_port_base'
common/libcommon.a(cmd_ide.o):/home/skuribay/devel/u-boot.git/common/cmd_ide.c:712: first defined here
make: *** [u-boot] Error 1
Basically, refactor the CFG_PIXIS_VBOOT_MASK values
into the separate board config files.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
usb_cpu_init() configures GPS USB pins, clocks, etc. and
is required for proper operation of kernel USB subsystem.
This setup was previously done in the kernel by the fixup
code which is being removed, thus low level init must be
done by U-boot now.
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
To get the IDS8247 board working following are done:
- FCC2 is deactivated
- FCC1 is activated
- I2C is activated
- CFI driver is activated
- Adapted for use with LIBFDT
Signed-off-by: Sergej Stepanov <Sergej.Stepanov@ids.de>
