path: root/board
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15arm: Use sections header to obtain link symbolsSimon Glass
Include this header to get access to link symbols, which are otherwise removed. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-15Replace __bss_end__ with __bss_endSimon Glass
Note this is a tree-wide change affecting multiple architectures. At present we use __bss_start, but mostly __bss_end__. This seems inconsistent and in a number of places __bss_end is used instead. Change to use __bss_end for the BSS end symbol throughout U-Boot. This makes it possible to use the asm-generic/sections.h file on all archs. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-15Merge branch 'u-boot-tegra/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-03-15Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-03-15nitrogen: Use unsigned long to specify the total RAM sizefabio.estevam@freescale.com
When building for the nitrogen boards with 2GiB the following warning happens: nitrogen6x.c:89:38: warning: integer overflow in expression [-Woverflow] 2GiB can not fit in 32-bits, so use ulong instead. Reported-by: Albert Aribaud <albert.u.boot@aribaud.net> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-03-14Tegra114: Dalmore: Add pad config tables/code based on pinmux codeTom Warren
Pad config registers exist in APB_MISC_GP space, and control slew rate, drive strengh, schmidt, high-speed, and low-power modes for all of the pingroups in Tegra30. This builds off of the pinmux way of constructing init tables to configure select pads (SDIOCFG, for instance) during pinmux_init(). Currently, no padcfg entries exist. SDIO3CFG will be added when the MMC driver is added as per the TRM to work with the SD-card slot on Dalmore E1611. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14Tegra114: fdt: Move aliases from dtsi to dts file as per other TegrasTom Warren
All other Tegra boards have their alias nodes in the .dts file Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14Tegra114: Dalmore: Always use DEFAULT instead of DISABLE for lock bitsTom Warren
The pinmux code issues a warning if the caller attempts to disable the lock bit in a pinmux register, since this is impossible (once it's locked, the only way to unlock it is to reset the device/pmt controller). The I2C/DDC/CEC/USB macros expect a lock setting to be passed in, and the previous setting of DISABLE caused the pinmux table parsing code to issue the warning. Changing the lock bits in these table entries to DEFAULT (i.e. don't touch it) fixes this. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14Tegra30: MMC: Add SD bus power-rail and SDMMC pad init routinesTom Warren
T30 requires specific SDMMC pad programming, and bus power-rail bringup. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14Tegra30: fdt: Add SDMMC (sdhci) nodes for T30 boards (Cardhu for now)Tom Warren
Took these values directly from the kernel dts files. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14Tegra30: Cardhu: Add pad config tables/code based on pinmux codeTom Warren
Pad config registers exist in APB_MISC_GP space, and control slew rate, drive strengh, schmidt, high-speed, and low-power modes for all of the pingroups in Tegra30. This builds off of the pinmux way of constructing init tables to configure select pads (SDIOCFG, for instance) during pinmux_init(). Currently, only SDIO1CFG is changed as per the TRM to work with the SD-card slot on Cardhu. Thanks to StephenW for the suggestion/original idea. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14Tegra114: pinmux: Update pinmux tables & code, fix a bug w/SDMMC3 initTom Warren
Use the latest tables & code from our internal U-Boot repo. The SDMMC3_CD, CLK_LB_IN and CLK_LB_OUT offsets in the pingroup table were off by a few indices, causing the pinmux init code to write bad data to the PINMUX_AUX_ regs. This also enabled the lock bit, which made it impossible to reconfig the pads correctly for SDMMC3 (SD card on Dalmore) operation. Also fixes SPI_CS2_N, USB_VBUS_EN0, HDMI_CEC and UART2_RXD/TXD muxes. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14Tegra30: Cardhu: Remove unneeded cardhu.c.mmc fileTom Warren
This was an older debug/developmental file that got added accidentally. Not needed/used in any Cardhu build. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14Tegra30: fdt: Sync DT nodes with kernel DT files (I2C, SPI, GPIO, clock)Tom Warren
Minor edits to clock, apbdma and SPI, make I2C match kernel DT, and add gpio Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14Tegra: fdt: Remove memreserve line from Cardhu/Seaboard DT filesTom Warren
Not used, and wrong in Cardhu's case Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14Tegra: MMC: Add DT support to MMC driver for all T20 boardsTom Warren
tegra_mmc_init() now parses the DT info for bus width, WP/CD GPIOs, etc. Tested on Seaboard, fully functional. Tamonten boards (medcom-wide, plutux, and tec) use a different/new dtsi file w/common settings. Signed-off-by: Tom Warren <twarren@nvidia.com> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14Tegra: fdt: Add/enhance sdhci (mmc) nodes for all T20 DT filesTom Warren
Linux dts files were used for those boards that didn't already have sdhci info populated. Tamonten has their own dtsi file with common sdhci nodes (sourced from Linux). Signed-off-by: Tom Warren <twarren@nvidia.com> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14Tegra: fdt: tamonten: Add common tamonten.dtsi file from linuxTom Warren
Tamonten boards (medcom-wide, plutux, and tec) use a different/new dtsi file w/common settings. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Thierry Reding <thierry.reding@avionic-design.de> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14Tegra: fdt: Change /include/ to #include for C preprocessorTom Warren
dts Makefile has the arch & board include paths added to DTS_CPPFLAGS. This allows the use of '#include "xyz"' in the dts/dtsi file which helps the C preprocessor find common dtsi include files. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14Tegra114: fdt: Update DT files with I2C info for T114/DalmoreTom Warren
T114, like T30, does not have a separate/different DVC (power I2C) controller like T20 - all 5 I2C controllers are identical, but I2C5 is used to designate the controller intended for power control (PWR_I2C in the schematics). PWR_I2C is set to 400KHz. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14tegra: usb: move implementation into right directoryLucas Stach
This moves the Tegra USB implementation into the drivers/usb/host directory. Note that this merges the old /arch/arm/cpu/armv7/tegra20/usb.c file into ehci-tegra.c. No code changes, just moving stuff around. v2: While at it also move some defines and the usb.h header file to make usb driver usable for Tegra30. NOTE: A lot more work is required to properly init the PHYs and PLL_U on Tegra30, this is just to make porting easier and it does no harm here. Signed-off-by: Lucas Stach <dev@lynxeye.de> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-03-13Add Boundary Devices Nitrogen6X boardsEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2013-03-12Refactor linker-generated arraysAlbert ARIBAUD
Refactor linker-generated array code so that symbols which were previously linker-generated are now compiler- generated. This causes relocation records of type R_ARM_ABS32 to become R_ARM_RELATIVE, which makes code which uses LGA able to run before relocation as well as after. Note: this affects more than ARM targets, as linker- lists span possibly all target architectures, notably PowerPC. Conflicts: arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds arch/arm/cpu/armv7/omap-common/u-boot-spl.lds board/ait/cam_enc_4xx/u-boot-spl.lds board/davinci/da8xxevm/u-boot-spl-da850evm.lds board/davinci/da8xxevm/u-boot-spl-hawk.lds board/vpac270/u-boot-spl.lds Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-03-12arm: make __bss_start and __bss_end__ compiler-generatedAlbert ARIBAUD
Turn __bss_start and __bss_end__ from linker-generated to compiler-generated symbols, causing relocations for these symbols to change type, from R_ARM_ABS32 to R_ARM_RELATIVE. This should have no functional impact, as it affects references to __bss_start and __bss_end__ only before relocation, and no such references are done. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-03-12Remove linker lists (LGAs) from SPL linker scriptsAlbert ARIBAUD
Many SPL linker scripts needlessly include linker lists (aka LGAs). Remove them whenever possible; keep it only in the seven am335x_evm variants (am335x_evm, am335x_evm_uart[1-5], am335x_evm_spiboot), where there is actual content in output section .u_boot_list. This commit keeps all u-boot.bin and u-boot-spl.bin in ARM targets byte-identical. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-03-12Merge branch 'u-boot-atmel/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-03-11ppc: Remove PCIPPC2 and PCIPPC6 boardsStefan Roese
These boards seem to be unmaintained for quite some time. So lets remove support for them completely. This also cleans up some common drivers/files. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Guillaume Alexandre <guillaume.alexandre@gespac.ch> Acked-by: Wolfgang Denk <wd@denx.de>
2013-03-11Merge u-boot/master into u-boot-ti/masterTom Rini
In master we had already taken a patch to fix the davinci GPIO code for CONFIG_SOC_DM646X and in u-boot-ti we have additional patches to support DA830 (which is CONFIG_SOC_DA8XX && !CONFIG_SOC_DA850). Resolve these conflicts manually and comment the #else/#endif lines for clarity. Conflicts: arch/arm/include/asm/arch-davinci/gpio.h drivers/gpio/da8xx_gpio.c Signed-off-by: Tom Rini <trini@ti.com>
2013-03-11arm: dra7xx: Add board files for DRA7XX socsLokesh Vutla
Adding new board files for DRA7XX socs. The pad registers layout is changed completely from OMAP5 So introducing the new structure here and also adding the minimal data. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishant Kamat <nskamat@ti.com> Signed-off-by: R Sricharan <r.sricharan@ti.com> Reviewed-by: Tom Rini <trini@ti.com> [trini: Adapt omap_mmc_init call for last 2 params] Signed-off-by: Tom Rini <trini@ti.com>
2013-03-10Merge branch 'master' of git://git.denx.de/u-boot-mpc82xxTom Rini
2013-03-09powerpc/82xx/km: removed unneeded ifdefHolger Brunck
All boards from this serie uses i2c. So we can drop these unneeded defines. Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2013-03-09powerpc/82xx/km: make handle_mgcoge3un_reset staticHolger Brunck
2013-03-09mpc512x: pdm360ng: drop not needed memory node fixupAnatolij Gustschin
ft_cpu_setup() already does memory node fixup, no need to do it again. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-03-09mpc512x: add ifm ac14xx boardAnatolij Gustschin
Add new mpc5121e based ac14xx board and a new pinmux config function for setting individual pinmux bit groups. This function is used in ac14xx board code. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-03-09mpc512x: use common code for clock setting for all mpc512x boardsAnatolij Gustschin
Only define enabled clocks in the config file and enable the clocks in common code. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com> Cc: Wolfgang Denk <wd@denx.de>
2013-03-09mpc512x: use common code for CSx configurationAnatolij Gustschin
Remove CSx configurations from board code and only define required CSx macros in the board config file to configure chip select windows and parameters. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com> Cc: Wolfgang Denk <wd@denx.de>
2013-03-09mpc5200: a4m2k: Implement custom "dynamic" watchdog supportStefan Roese
This patch adds a custom U-Boot command "wdogtoggle" which enables the external hardware watchdog toggling via an GPIO pin on the a4m2k board. After issuing this commands, the watchdog will be serviced by U-Boot so that the user can use all U-Boot commands from the prompt. Signed-off-by: Stefan Roese <sr@denx.de>
2013-03-09mpc5200: Add a4m2k board portStefan Roese
This patch adds the a4m2k MPC5200B board port. Its a derivate of the a3m071 board with only minor changes. Additionally this patch includes some clean-up changes: - Remove I2C support from a3m071 as its unused - Fix/enhance default env variables - Fix some comments - Add newly introduced CONFIG_SPL_TARGET to automatically build "u-boot-img.bin" - Fix dtb patching in READ desciption for SPL Linux booting: "fdt chosen" needs to get called to patch/create the chosen node. - Add missing call to spl_board_init(): Define CONFIG_SPL_BOARD_INIT so that spl_board_init() will get called in the SPL version. Signed-off-by: Stefan Roese <sr@denx.de>
2013-03-08cm-t35: add support for user defined lcd parametersNikita Kiryanov
Add support for user defined lcd parameters for cm-t35 splash screen. Cc: Jeroen Hofstee <jeroen@myspectrum.nl> Cc: Anatolij Gustschin <agust@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-03-08cm-t35: add support for dvi displaysNikita Kiryanov
Add support for dvi displays with user selectable dvi presets. Cc: Wolfgang Denk <wd@denx.de> Cc: Jeroen Hofstee <jeroen@myspectrum.nl> Cc: Anatolij Gustschin <agust@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-03-08omap3: allow dynamic selection of gfx_formatNikita Kiryanov
Currently, omap3_dss_panel_config() sets gfx_format to a value that is hardcoded in the code. This forces anyone who wants to use a different gfx_format to make adjustments after calling omap3_dss_panel_config(). This could be avoided if the value of gfx_format were parameterized as input for omap3_dss_panel_config(). Make gfx_format a field in struct panel_config, and update existing structs to set this field to the value that was originally hard coded. Cc: Wolfgang Denk <wd@denx.de> Cc: Jeroen Hofstee <jeroen@myspectrum.nl> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-03-08omap_hsmmc: add driver check for write protectionNikita Kiryanov
Add check for write protection in omap mmc driver. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-08cm-t35: implement board specific card detect checkNikita Kiryanov
Implement a card detection check for cm-t35. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-03-08omap_hsmmc: implement driver check for card detectionNikita Kiryanov
Implement driver check for card detection. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-03-08am335x_evm: Add am335x_evm_usbspl build targetTom Rini
We add USB (RNDIS gadget) SPL support as a separate target. We need to pull out YMODEM support in order to be a small enough target binary. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-07mx23_olinuxino: Fix warning for implicit declarationOtavio Salvador
Fixes a build warning of implicit declaration of gpio_direction_output, as bellow: ,---- | mx23_olinuxino.c: In function 'board_early_init_f': | mx23_olinuxino.c:51:2: warning: implicit declaration | of function 'gpio_direction_output' | [-Wimplicit-function-declaration] `---- Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2013-03-07mx6: Provide a structure for accessing HDMI registersFabio Estevam
Provide a structure for accessing HDMI registers, so that we can use proper read/write accessors. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Eric Nelson <eric.nelson@boundarydevices.com>
2013-03-07mx23_olinuxino: Enable USB supportOtavio Salvador
This enabled USB support for the mx23_olinuxino board. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2013-03-07mx23_olinuxino: Add support for status LEDOtavio Salvador
This allow user to know if the bootloader is running, even without a serial console. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
