Commit 2419169f removed support for legacy NAND and disk on chip but
missed to update the code for a few boards. This patch fixes the
resulting build issues.
Fix these:
pati.c: In function 'checkboard':
pati.c:358: warning: pointer targets in passing argument 2 of 'getenv_r' differ in signedness
../common/flash.c: In function 'write_word':
../common/flash.c:824: warning: dereferencing type-punned pointer will break strict-aliasing rules
cmd_pati.c: In function 'do_pati':
cmd_pati.c:279: warning: 'value' may be used uninitialized in this function
Currently the mpl boards duplicate the code to print the current
devices from common/console.c; use stdio_print_current_devices()
instead
Edited commit message.
The board/armltd/integrator/split_by_variant.sh script used to print
"Configuring for integrator*p board..." no matter which board name
was being compiled. This made it difficult to match MAKEALL output to
board names. This patch fixes this.
The "stdio/device: rework function naming convention" patch
(commit 52cb4d4f) broke the MIP405T board; this patch fixes it.
Commit bc0d3296 removed ppc_error_no.h from Marvell boards
but forgot to update board/esd/cpci750/mv_eth.h
So far the console API uses the following naming convention:
======Extract======
typedef struct device_t;
int device_register (device_t * dev);
int devices_init (void);
int device_deregister(char *devname);
struct list_head* device_get_list(void);
device_t* device_get_by_name(char* name);
device_t* device_clone(device_t *dev);
which is too generic and confusing.
Instead of using device_XX and device_t we change this
into stdio_XX and stdio_dev
This will also allow to add later a generic device mechanism in order
to have support for multiple devices and driver instances.
Since we have simple hwconfig interface now, we don't need
pci_external_arbiter variable any longer.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
This patch simply converts the board to the hwconfig infrastructure.
fdt_fixup_esdhc() will either disable or enable eSDHC nodes, and
also will fixup clock-frequency property.
Plus, since DR USB and eSDHC are mutually exclusive, we should
only configure the eSDHC if asked through hwconfig.
This patch adds support for eSDHC on MPC837XERDB boards. The WP
switch doesn't seem to work on RDB boards though, the WP pin is
always asserted (can see the pin state when it's in GPIO mode).
FSL DR USB and FSL eSDHC are mutually exclusive because of pins
multiplexing, so user should specify 'esdhc' or 'dr_usb' options
in the hwconfig environment variable to choose between the
devices.
p.s.
Now we're very close to a monitor len limit (196 bytes left using
gcc-4.2.0), so also increase the monitor len by one sector (64 KB).
Now that we have 3 boards for the MPC512x it turns out that they all
use the very same fixed_sdram() code.
This patch factors out this common code into cpu/mpc512x/fixed_sdram.c
and adds a new header file, include/asm-ppc/mpc512x.h, with some
macros, inline functions and prototype definitions specific to MPC512x
systems.
Cc: Stefan Roese <sr@denx.de>
Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
The mecp5123 board did not compile because the MSCAN Clock Control
Registers were missing; these got added, but as an array instead
of 4 individual registers. Adapt the code so it builds.
Signed-off-by: Peter Pearse <peter.pearse@arm.com>
AT91sam9g10 is an ARM 926ej-s SOC. It is an evolution of the at91sam9261 with a
faster clock speed: 266/133MHz.
Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
AT91sam9g45 series is an ARM 926ej-s SOC family clocked at 400/133MHz.
It embeds USB high speed host and device, LCD, DDR2 RAM, and a full set of
peripherals.
The first board that embeds at91sam9g45 chip is the AT91SAM9G45-EKES.
On the board you can find 2 USART, USB high speed,
a 480*272 LG lcd, ethernet, gpio/joystick/buttons.
Pandora is using both SDRC CSes. The MUX setting is needed
for the second CS clock signal to allow the 2 RAM parts to
be put in self-refresh correctly.
Based on similar patch for beagle and overo by
Jean Pihet and Steve Sakoman.
Set pullups or pulldowns for GPIOs which need them.
Disable them for others, which have external pulls.
Also make disabled pull setting consistent (some pins had
type set to "up" even if pull type selection was disabled).
Setup pin mux for GPIO pins connected on rev3 or later
boards. Also change NUB2 IRQ pin. This should not affect
older boards because they don't have any nubs (analog
controllers) attached to them.
Remove configuration of not unused pins, effectively
leaving them in safe mode.
ESPT-Giga is SH7763-based reference board.
Board support is relatively sparse, presently supporting serial,
gigabit ethernet, USB host, and MTD.
More information (in Japanese) available at:
http://www.cente.jp/product/cente_hard/ESPT-Giga.html
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
Add support for the Phytec phyCORE-MPC5200B-tiny.
Code originally from Pengutronix.de.
Created CONFIG_SYS_ATA_CS_ON_TIMER01 define for when IDE CS is on
Timer 0/1
Signed-off-by: Jon Smirl <jonsmirl@gmail.com>
This patch use blackfin errno.h implementation which
correspond Linux kernel one.
MIPS implemetation is different that's why I keep it.
I removed ppc_error_no.h from Marvell boards which
was the same too.
I have got ack from ppc40x, blackfin, arm, coldfire and avr custodians.
This patch fixes 2 problems with FDT EBC mappings on Canyonlands.
First, NAND EBC mapping was missing, making Linux NAND driver
unusable on this board. Second, NOR remapping code assumed that
NOR is always on CS0, however when booting from NAND NOR is on CS3.
Signed-off-by: Felix Radensky <felix@embedded-sol.com>
The check of data became severe from newest gcc.
This patch checked in gcc-4.2 and 4.3 .
all sh boards use the same cpu linker script so move it to cpu/$(CPU)
that could be overwrite in following order
SOC
BOARD
via the corresponding config.mk
tested on r2dplus
Cc: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
currently we need to sync the linker script enty and TEXT_BASE manualy
and the reloc_dst is based on it
instead provide it now from the ldflags
tested on r2dplus
The BF537-STAMP Blackfin board had a driver for working with NAND devices
that are simply memory mapped. Since there is nothing Blackfin specific
about this, generalize the driver a bit so that everyone can leverage it.
Update chipselect handling in davinci_nand.c so that it can
handle 2 GByte chips the same way Linux does: as one device,
even though it has two halves with independent chip selects.
For such chips the "nand info" command reports:
Device 0: 2x nand0, sector size 128 KiB
Switch to use the default chipselect function unless the board
really needs its own. The logic for the Sonata board moves out
of the driver into board-specific code. (Which doesn't affect
current build breakage if its NAND support is enabled...)
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
drivers/spi/Makefile
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
The evaluation kit has both Nand and OneNand, both drivers are there
and the two configurations only select a different default for the
jffs partition. This adds the OneNand driver and cleans up storage.
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
This is an error in my side in the initial submission: nobody
calls it ""nmdk8815", it's "nomadik hardware kit", nhk8815, instead.
The Polaris board is based on the TrizepsIV module of
Keith & Koep (http://www.keith-koep.com).
Due to change in the usb_board_init() prototype, the USB for
the TrizepsIV was not correctly initialized.
Removed dummy print from usb_board_stop().
This patch adds support for esd gmbh MEESC board.
The MEESC is based on an Atmel AT91SAM9263 SoC.
Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
Add support for Freescale's i.MX31 PDK board (a.k.a. 3 stack board).
This patch assumes that some other program performs the actual
NAND boot.
Acked-by: Fabio Estevam <fabioestevam@yahoo.com>
Signed-off-by: Matthias Ludwig <mludwig@ultratronik.de>
On the boards at91sam9260ek, at91sam9263ek and afed9260, the rstc register was
set to 0 after being set to 500 ms for the PHY reset.
Do backup the old reset length and restore it after the MACB initialisation.
Signed-off-by: Stelian Pop <stelian@popies.net>
