The AM335x GP EVM can have one of 8 different profiles selected. Each
profile has a different set of peripherals and requires different pinmux
configurations that conflict with other profiles. i2c1 is an example of
a conflicted mux currently.
Fix build failure due the move of mx28 code to 'mxs' SoC.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
This i.MX28 platform supports the following:
* 2x FEC ethernet
* USB on USBH0
* I2C EEPROM
* SPI NVRAM
* LEDs
This gets us rid of duplication of the same file.
On this board, the console is always set to the serial line.
Do not allow to overwrite it when video is enabled.
CC: Fabio Estevam <fabio.estevam@freescale.com>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
This adds support for Bluegiga APX4 Development Kit. It is built around
Freescale i.MX28. Currently supported features are: ethernet, I2C, MMC,
RTC and USB. APX4 has only one ethernet port.
Signed-off-by: Veli-Pekka Peltola <veli-pekka.peltola@bluegiga.com>
Signed-off-by: Lauri Hintsala <lauri.hintsala@bluegiga.com>
This adds support for the AT91SAM9G20 boards by taskit GmbH.
Both boards, Stamp9G20 and PortuxG20, are integrated in one
file. PortuxG20 is basically a SBC built around the Stamp9G20.
Signed-off-by: Markus Hubig <mhubig@imko.de>
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Signed-off-by: Andreas Bießmann <andreas.deve@googlemail.com>
Add at91sam9x5ek board support, this board support the following SoCs
AT91SAM9G15, AT91SAM9G25, AT91SAM9G35, AT91SAM9X25, AT91SAM9X35
Using at91sam9x5ek_nandflash to configure for the board
Now only supports NAND with software ECC boot up
Signed-off-by: Bo Shen <voice.shen@atmel.com>
[move MAINTAINERS entry to right place]
The total RAM size of the IGEP-based boards is 512MiB not 1GiB, the
LPDDR memory consist on two dies of 256MiB.
Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com>
Tested-by: Javier Martinez Canillas <javier@dowhile0.org>
- Move definition of the EEPROM contents to <asm/arch/sys_proto.h>
- Make some defines a little less generic now.
- Pinmux must be done by done by SPL now.
- Create 3 pinmux functions, uart0, i2c0 and board.
- Add pinmux specific to Starter Kit EVM for MMC now.
- Board requires gpio0 #7 to be set to power DDR3.
- Board uses DDR3, add a way to determine which DDR type to call
config_ddr with.
- Both of the above require filling in the header structure early, move
it into the data section.
The intention has always been (and boards are to support) an i2c EEPROM
that will identify what hardware they are, allowing a single binary to
support multiple boards. As such, remove the 'evm.c' file as there is
nothing EVM centric in it currently, only SoC peripheral configuration.
This patch adds SPL support for IGEP-based boards.
Tested on an IGEPv2 Rev.C board with Micron NAND Flash memory.
Signed-off-by: Javier Martinez Canillas <javier@dowhile0.org>
IGEP-based boards can have two different flash memories, a OneNAND or a
NAND device. Add a configuration option for to choose which memory to use.
Acked-by: Enric Balletbo i Serra <eballetbo@gmail.com>
This patch adds board-specific initialization for CPSW on
TI AM335X based boards. Tested on BeagleBone.
Signed-off-by: Chandan Nath <chandan.nath@ti.com>
[Ilya: split board-specific part into separate patch]
Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
Read the on-board EEPROM during startup to detect the version
of the board we are running on (as for now only BeagleBone vs
EVM detection is supported).
This patch adds pin mux settings for CPSW switch found on
TI AM335X based boards (MII and RGMII modes).
[Ilya: split pinmux into separate patch]
Signed-off-by: Peter Meerwald <p.meerwald@bct-electronic.com>
This patch sets up pinmux, enables fclk, and
defines CONFIG_I2C_MULTI_BUS
Signed-off-by: Steve Sakoman <steve@sakoman.com>
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net>
static
Though Commit id a3f88293ddd13facd734769c1664d35ab4ed681f (da850evm:
setup the NAND flash timings) has configured the AEMIF timings, they
are not exactly in sync with the timings used in Linux. Linux is
configuring the timing register as 0x08222204, where as currently it
configured to 0x00100084 in U-Boot. This issue was found out when
support for NAND SPL is added in U-Boot. Without this patch U-Boot
does not come up with SPL.
Tested-by: Christian Riesch <christian.riesch@omicron.at>
Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com>
Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com>
Signed-off-by: Hadli, Manjunath <manjunath.hadli@ti.com>
AHCLKR/UART1_RTS/GP0[11] pin needs to be configured for
MMC and NOR to work on DA850/OMAP-L138 Rev.3 EVM. When
GP0[11] is low, the SD0 interface will not work, but NOR
flash will. When GP0[11] is high, SD0 will work but NOR
flash will not.
This patch adds support for MMC/SD on DA850/OMAP-L138.
UART_RESET, UART_CLK_RUNNING_MASK, and UART_SMART_IDLE_EN
are defined inn evm.c but not used. Also removes unnecessary
include of serial.h
PHYS_DRAM_1_SIZE is defined in am335x_evm.h but never used.
Detect hot-water-button to start a differnt image.
CC: Tom Rini <trini@ti.com>
Fix the comment to reflect the actual function call time.
Change the printf message to look nicer in the context it might be printed.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Parameters used for configuring certain SoC peripherals are parsed
from the cfg file and appended as part of the ais image's header. The
u-boot-spl.ais generated is flashed separately to the nand, so do not
delete the file after generation of u-boot.ais.
Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com>
This patch moves all bootcount implementations into a common
directory: drivers/bootcount. The generic bootcount driver
is now usable not only by powerpc platforms, but others as well.
Cc: Valentin Longchamp <valentin.longchamp@keymile.com>
Cc: Christian Riesch <christian.riesch@omicron.at>
Cc: Manfred Rudigier <manfred.rudigier@omicron.at>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Reinhard Meyer <reinhard.meyer@emk-elektronik.de>
Tested-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Acked-by: Rob Herring <rob.herring@calxeda.com>
Remove old o2dnt board without OF support. New support for this board
is added by the previous patch, O2I configuration.
Add common code for o2dnt and o2dnt2 based boards and add different
board configuration files for O2D, O2I, O2DNT2, O2D300, O2MNT and
O3DNT boards.
* rename board directory to eb_cpu5282
* rename EB+MCF-EV123_.*config to eb_cpu5282_.*config
* add Maintainer for EB+CPU5282 board
* rename prompt
Signed-off-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
PHYs on SGMII riser card are used in SGMII mode with different external
IRQs from eTSEC. This means in SGMII mode phy-handle and phy-connection-type
under ethernet node should be updated. Otherwise the PHY interrupt can not
be handled therefor PHY link state change can not be auto detected.
For we have seperate SGMII PHY nodes, ethernet PHY reg fixup is not needed
but it's still be kept to guarantee the sgmii mode could work with old
device tree.
Signed-off-by: Li Yang <leoli@freescale.com>
Signed-off-by: Jia Hongtao <B38951@freescale.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
Lane muxing on p2041 is controlled by a reg in CPLD, offset of this reg
is 0xc, CPLD supports SATA by default, we should re-configure the lane
muxing according to RCW, which indicates what SerDes protocol it is running.
Default lane muxing map is as below:
Lane G on bank1 routes to SGMII, controlled by bit 1 of the reg;
Lane A on bank2 routes to AURORA, controlled by bit 0 of the reg;
Lane C/D on bank2 routes to SATA0 and SATA1, controlled by bit 2
and bit 3 respectively.
Default value of these bits for lane muxing is '1', we should set or clear
these bits accoring to RCW.
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
Acked-by: Timur Tabi <timur@freescale.com>
In order for indirect mode on the PIXIS to work properly, both chip selects
need to be set to GPCM mode, otherwise writes to the chip select base
addresses will not actually post to the local bus -- they'll go to the
NAND controller instead. Therefore, we need to set BR0 and BR1 to GPCM
mode before switching to indirect mode.
Add TLB mappings, board target options, and configuration items
need for SPI/SD boot.
Since P1022DS RevB board, the NOR flash have been changed to 16 bit/28bit
address flash, therefore, when SDHC/ESPI booting and access to eLBC,
the PMUXCR[0~1] must be set to 10b, and PMUXCR[9~10] must be set to
00b for them.
Configure the PX_BRDCFG0[0~1] to 10b which is connected to
SPI devices as SPI_CS(0:3)_B.
Signed-off-by: Matthew McClintock <msm@freescale.com>
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
Signed-off-by: Jiang Yutang <b14898@freescale.com>
This patch adds SDRAM detection feature to km82xx boards.
To enable this feature, define CONFIG_SYS_SDRAM_LIST as the initializer
for an array of struct sdram_conf_s.
These structs will expose the bitfields within registers PSDMR and OR1 which
have to be different between configurations; common bitfields will be
defined, as usual, within CONFIG_SYS_PSDMR and CONFIG_SYS_OR1.
If CONFIG_SYS_SDRAM_LIST is not defined, then the usual behavior is retained.
Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com>
* 'master' of git://git.denx.de/u-boot-i2c:
km/common: remove printfs for i2c deblocking code
CONFIG: SMDK5250: I2C: Enable I2C
I2C: Add support for Multi channel
I2C: Modify the I2C driver for EXYNOS5
I2C: Move struct s3c24x0_i2c to a common place.
EXYNOS: PINMUX: Add pinmux support for I2C
EXYNOS5: define EXYNOS5_I2C_SPACING
EXYNOS: Add I2C base address.
EXYNOS: CLK: Add i2c clock
mx6qsabrelite: add i2c multi-bus support
imx-common: add i2c.c for bus recovery support
i.mx53: add definition for I2C3_BASE_ADDR
i.mx: iomux-v3.c: move to imx-common directory
i.mx: iomux-v3.h: move to imx-common include directory
iomux-v3: remove include of mx6x_pins.h
mxc_i2c: finish adding CONFIG_I2C_MULTI_BUS support
mxc_i2c: add bus recovery support
mxc_i2c: prep work for multiple busses support
mxc_i2c: add i2c_regs argument to i2c_imx_stop
mxc_i2c: add retries
mxc_i2c: check for arbitration lost
mxc_i2c: change slave addr if conflicts with destination.
mxc_i2c: don't disable controller after every transaction
mxc_i2c: place i2c_reset code inline
mxc_i2c: place imx_start code inline
mxc_i2c: remove redundant read
mxc_i2c: combine i2c_imx_bus_busy and i2c_imx_trx_complete into wait_for_sr_state
mxc_i2c.c: code i2c_probe as a 0 length i2c_write
mxc_i2c: call i2c_imx_stop on error in i2c_read/i2c_write
mxc_i2c: create i2c_init_transfer
mxc_i2c: clear i2sr before waiting for bit
mxc_i2c: create tx_byte function
mxc_i2c: remove ifdef of CONFIG_HARD_I2C
mxc_i2c: fix i2c_imx_stop
i2c: deblock i2c bus also if accessed before realocation
* 'master' of git://git.denx.de/u-boot-microblaze:
microblaze: Wire up SPI driver
spi: microblaze: Adds driver for Xilinx SPI controller
microblaze: intc: Clear interrupt code
microblaze: Call serial multi initialization
microblaze: Move __udelay implementation
microblaze: Remove extern from board.c
microblaze: Wire up dts configuration
fdt: Add board specific dts inclusion
microblaze: Move individual board linker scripts to common script in cpu tree.
microblaze: Add gpio.h
microblaze: Add missing undefs for UBI and UBIFS
microblaze: Expand and correct configuration comments
microblaze: Enable ubi support
microblaze: Avoid compile error on systems without cfi flash
microblaze: Remove wrong define CONFIG_SYS_FLASH_PROTECTION
drivers/spi/Makefile
This code will also be used before reallocation and during this time we
are not allowed to do these printings.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
Acked-by: Prafulla Wadaskar <Prafulla@marvell.com>
Acked-by: Heiko Schocher <hs@denx.de>
This enables I2C support on smdk5250.
Pinmux setting moved to board file to avoid repeated setting of
gpio lines.
Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com>
Signed-off-by: Doug Anderson <dianders@chromium.org>
Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com>
This includes bus recovery support.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Acked-by: Jason Liu <r64343@freescale.com>
* 'next' of git://git.denx.de/u-boot:
MPC8xx: Fixup warning in arch/powerpc/cpu/mpc8xx/cpu.c
doc: cleanup - move board READMEs into respective board directories
net: sh_eth: add support for SH7757's GETHER
net: sh_eth: modify the definitions of regsiter
net: sh_eth: add SH_ETH_TYPE_ condition
net: sh_eth: clean up for the SH7757's code
net: fec_mxc: Fix MDC for xMII
net: fec_mxc: Fix setting of RCR for xMII
net: nfs: make NFS_TIMEOUT configurable
net: Inline the new eth_setenv_enetaddr_by_index function
net: allow setting env enetaddr from net device setting
net/designware: Consecutive writes to the same register to be avoided
CACHE: net: asix: Fix asix driver to work with data cache on
net: phy: micrel: make ksz9021 phy accessible
net: abort network initialization if the PHY driver fails
phylib: phy_startup() should return an error code on failure
net: tftp: fix type of block arg to store_block
Also drop a few files referring to no longer / not yet supported
boards.
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Kim Phillips <kim.phillips@freescale.com>
Cc: Andy Fleming <afleming@gmail.com>
Cc: Jason Jin <jason.jin@freescale.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Acked-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
