The cross compiler is responsible for providing the correct libraries
and the logic to find the linking libraries.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Before the first call of ide_reset(), the level of the IDE reset
signal on the TQM5200 is low (reset asserted). This patch sets the
default value to high (reset not asserted).
Currently this patch fixes no real problem, but it is cleaner to
assert the reset signal only on demand, and not permanently.
Signed-off-by: Martin Krause <martin.krause@tqs.de>
This patch is based on the port by Mihai Georgian (see linkstation.c for
Copyright information) and implements support for LinkStation / KuroBox HD
and HG PPC models from Buffalo Technology, whereby HD is deactivated at
the moment, pending network driver fixing.
Notice to users: this is pretty much a barebone port. Support for network
on HG models is already in the U-Boot mainline, but you might also want
patches to switch fan / phy modes depending on the negotiated ethernet
parameters. This patch also doesn't support console switching, booting EM
mode, Buffalo specific ext2 magic number. So, if you want to use any of
those, you need additional patches. Otherwise this patche provides a fully
functional u-boot with a network console on your system.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
Replace CONFIG_8xx and CONFIG_MCF532x to CONFIG_MII_INIT in
cmd_init.c. Add CONFIG_MII_INIT to board configuration files
that use mii_init() in cmd_init.c.
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
Acked-by: Ben Warren <biggerbadderben@gmail.com>
This patch adds support for the Phytec Phycore-i.MX31 board
This patch adds support for the mx31 litekit board
Currently the serdes will not be initializated due to the
partid's error.
Signed-off-by: Dave Liu <daveliu@freescale.com>
Reverting became necessary after it turned out that the patches in
the u-boot-arm repo were modified, and in some cases corrupted.
This reverts the following commits:
066bebd6353e33af3adefc3404560871699e9961
7a837b7310166ae8fc8b8d66d7ef01b60a80f9d6
c88ae20580b2b01487b4cdcc8b2a113f551aee36
a147e56f03871bba4f05058d5e04ce7deb010b04
d6674e0e2a6a1f033945f78838566210d3f28c95
8c8463cce44d849e37744749b32d38e1dfb12e50
c98b47ad24b2d91f41c09a3d62d7f70ad84f4b7d
8bf69d81782619187933a605f1a95ee1d069478d
8c16cb0d3b971f46fbe77c072664c0f2dcd4471d
a574a73852a527779234e73e17e7597fd8128882
1377b5583a48021d983e1fd565f7d40c89e84d63
1704dc20917b4f71e373e2c888497ee666d40380
targets. See www.gaisler.com for information.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
exchangeable but a standard LEON3 design is assumed. See www.gaisler.com for information.
Edition) with GRLIB template design. See www.gaisler.com for information.
design. See www.gaisler.com for board information.
lib_ppc/board.c
Canyonlands (460EX) shares the first PCIe interface with the SoC SATA
interface. This usage can be configured with the jumper J6. This patch
correctly configures the SATA/PCIe PHY for SATA usage when this jumper
is installed.
Support for booting from internal DataFlash, external DataFlash card
or NAND flash is available.
Signed-off-by: Stelian Pop <stelian@popies.net>
Adapt the existing AT91CAP9 code to the new headers and APIs.
Acked-by: John Rigby <jrigby@freescale.com>
This board never went into production
Signed-off-by: Zachary P. Landau <zachary.landau@labxtechnologies.com>
Acked-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
Signed-off-by: Matthew Fettke <mfettke@videon-central.com>
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Add support for the ptm1la, ptm1ms, ptm2la and ptm2ms
environment variables.
Cleanup pci_target_init.
All of the duplicated code for Blackfin processors and boot modes have been
unified. After all, the core is the same for all processors, just the
peripheral set differs (which gets handled in the drivers).
This punts the old spi flash driver for a new/generalized one until the
common one can be integrated.
This fixes a naming bug for at91rm9200 lowlevel init code:
NOR boot flash is on chipselect 0, not chipselect 2. This
makes code use the register name from chip datasheets.
This patch adds support for the MX31ADS evaluation board from Freescale,
initialization code is copied from RedBoot sources, also provided by Freescale.
Signed-off-by: Pieter Voorthuijsen <pv@prodrive.nl>
This patch fixes eeprom page size so that you can now write more than
64 bytes at a time.
It also makes the board take MAC addresses, if found, from EEPROM.
User should place up to 4 addresses at offset 0x7f00, for
eth{,1,2,3}addr. Any unused addresses should be zero. This group of
four six-byte values should have it's CRC at the end. crc32 and
eeprom commands can be used to accomplish this.
If CRC fails, MAC addresses come from the environment. If CRC
succeeds, the environment is overwritten at startup.
Signed-off-by: Michael Barkowski <michael.barkowski@freescale.com>
in the spirit of commit 1ced121600b2060ab2ff9f0fddd9421fd70a0dc6,
85xx's "Update SVR numbers to expand support", simplify SPRIDR processing
and processor ID display. Add REVID_{MAJ,MIN}OR macros to make
REVID dependent code simpler. Also added PARTID_NO_E and IS_E_PROCESSOR
convenience macros.
