If the UART is used in DTE mode the RI and DCD bits in UCR3 become
irq enable bits. Both are set to enabled after reset and both likely
are pending.
Disable the bits also on UARTs not used in the boot loader to prevent
an interrupt storm when Linux enables the UART interrupts.
This adds a Kconfig SPL_SILENCE_CONSOLE which allows to suppress any
console output which in the normal program flow is printed in the SPL.
Error messages and the likes will still be printed.
Move Freescale/NXP Vybrid to a standard arch/board approach, similar
to what has been done to i.MX 6 earlier in commit 89ebc82137be ("ARM:
mx6: move to a standard arch/board approach").
Use device-tree fixup to communicate the MTD partitions to the
kernel. Remove mtdparts from the kernel command line.
Disable 3.3V Ethernet and ARM rail when entering sleep mode.
Commit 3f353ceccbbb ("vf610: refactor DDRMC code") changed on-die
termination (ODT) values from 120 Ohm to 60 Ohm and enabled a static
read/write leveling which has not been tested with this board. This
commit reverts both changes and makes sure that memory gets
initialized as it has been done before the mentioned commit.
Fixes: 3f353ceccbbb ("vf610: refactor DDRMC code")
This adds a command which parses the SPL version from eMMC and
optionally compares it against a version string.
Usage:
Colibri iMX6 # splver
U-Boot SPL 2016.11-rc3-00017-gdf36bb9-dirty (Nov 01 2016 - 12:31:34)
Colibri iMX6 # splver "U-Boot SPL 2016" || echo update
Colibri iMX6 # splver "U-Boot SPL 2017" || echo update
update
Colibri iMX6 # splver "U-Boot SPL 2016.11-rc4" || echo update
update
Colibri iMX6 #
Implement board level USB PHY mode callback. On USB OTG Port 1
the Colibri standard foresees GPIO USBC_DET to decide whether the
port should run in Host or Device mode.
Use a completely independent USB Product ID for SPL. This allows
to differentiate a SDP running in SPL and SDP running in a U-Boot
which could not read the config block successfully.
Keep debug code at the end of the function.
Use a one line informational message for the PMIC only.
SATA is not accessible on the Colibri iMX6, so remove include and
conditionally executed code.
We rely on u-boot to patch up the "fsl,vf610-ddrmc" node to have
the fsl,has-cke-reset-pulls property without which the Vybrid PM
code does not enable suspend to mem option. If Toradex config
block option is enabled, patch up the device tree for the same.
Signed-off-by: Sanchayan Maity <sanchayan.maity@toradex.com>
In the linux device tree we use 40Ohm drive strenght. So use the same
value in U-Boot.
value in U-Boot.
Implement optional PCIe EvalBoard initialisation which properly reset the PLX
(now Avago) PEX 8605 PCIe switch plus PCIe devices on the Apalis Evaluation
carrier board.
Please note that you will have to enable the second PCIe port in the dts as well
e.g.:
diff --git a/arch/arm/dts/tegra30-apalis.dts b/arch/arm/dts/tegra30-apalis.dts
index be4f4d6..321c7d6 100644
--- a/arch/arm/dts/tegra30-apalis.dts
+++ b/arch/arm/dts/tegra30-apalis.dts
@@ -59,6 +59,7 @@
pci@2,0 {
+ status = "okay";
nvidia,num-lanes = <1>;
(cherry picked from commit 340f51a210df1da640a57267e6c7fa56b8a852ed)
If U-Boot was launched via USB recovery mode stop auto booting.
(cherry picked from commit 0a9606863b0e7b8edfad02467a4e63c6c68025ee)
Migrate Colibri T20 to U-Boot 2016.11.
(cherry picked from commit 92d747bf338ceb8d6dbdd3e5e5f7f72226ce0792)
Migrate Apalis/Colibri T30 to U-Boot 2016.11.
(cherry picked from commit 81a38df0631cfa6b3a85c97e631abf73dc0a2226)
Add our support email address as well as our developer website as
official maintenance point of contacts:
Toradex ARM Support <support.arm@toradex.com>
http://developer.toradex.com/software/linux/linux-software
(cherry picked from commit c675aa26ad6a4a25d09c1079dda61ef24abd3770)
Add environment variables for default framebuffer support using a
default VGA mode. Also remove memargs, since we use memory size to
reserve the framebuffer which does not get overwritten by the
Linux kernel.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Fix the framebuffer location to the very end of the available memory.
This allows to remove the area from available memory for the kernel,
which in turn allows to display the splash screen through the while
Linux kernel boot process.
Ideas has been taken from the sunxi display driver, e.g.
20779ec3a5 ("sunxi: video: Dynamically reserve framebuffer memory")
The Vybrid SoC family has the same display controller unit (DCU)
like the LS1021A SoC. This patch adds platform data, pinmux defines
and clock control to enable the driver for Vybrid based boards too.
Using linux,usable-memory the board code carves out 1MiB of memory
for the Cortex-M4 core at the end of the 256MiB block. However,
in case a board has 256MiB of memory (Colibri iMX7S), that is the
area where U-Boot gets relocated to... Use board_get_usable_ram_top
to avoid using that area as relocation target.
i.MX 7's Cortex-M4 core can run from DDR and uses DDR memory for
the rpmsg communication. Both use cases need a fixed location of
memory reserved. For the rpmsg use case the reserved area needs
to be in sync with the kernel's hardcoded vring descriptor location.
Use the linux,usable-memory property to carve out 1MB of memory
in case the M4 core is running. Also make sure that the i.MX 7
specific rpmsg driver does not get loaded in case we do not carve
out memory.
Use the proper config option to guard the USB Download Function
fixup callback.
(cherry picked from commit beaf40688ba7303e9db50558b3852c79437eecad)
This patch adds board support for the Toradex Apalis TK1 a computer on
module which can be used on different carrier boards.
The module consists of a Tegra TK1 SoC, a PMIC solution, 2 GB of DDR3L
RAM, a bunch of level shifters, an eMMC, a TMP451 temperature sensor
chip, an I210 gigabit Ethernet controller and a SGTL5000 audio codec.
Furthermore, there is a Kinetis MK20DN512 companion micro controller for
analogue, CAN and resistive touch functionality.
For the sake of ease of use we do not distinguish between different
carrier boards for now as the base module features are deemed
sufficient enough for regular booting.
The following functionality is working so far:
- eMMC boot, environment storage and Toradex factory config block
- Gigabit Ethernet
- MMC/SD cards (both MMC1 as well as SD1 slot)
- USB client/host (dual role OTG port as client e.g. for DFU/UMS or host,
other two ports as host)
This adds board support for the Toradex module family Colibri iMX6.
The familiy consists of a module with i.MX6 DualLite, i.MX6 Solo, both
with a version for commercial and industrial temperature range.
(cherry picked from commit a02d517b0182f83771565eba1329fb323674ec58)
This adds board support for the Toradex module family Apalis iMX6.
The familiy consists of a module with i.MX6 Dual, i.MX6 Quad with
(cherry picked from commit 592f4aed6db765172e21f228800b49f9a27ff201)
If the module is in serial downloader mode, we do no longer read the
environment from eMMC. Therefor, the eMMC is unitialized when trying
to read the config block. Use mmc_init to initialize the selected
MMC device before using it.
Note: In case the MMC has already been initialized, the mmc_init
detects that and returns immediately.
board/toradex/common/configblock.c
Currently a divider of 6 has been used, leading to following NAND
Flash Controller (NFC) clocks:
VF61: 27.7 MHz (166.7MHz bus clock)
VF50: 22 MHz (132MHz bus clock)
The NAND Flash Memory used on VF50 allows to use clock speed of
up to 33MHz, while the Flash Memory of VF61 allows 50MHz. We can
use the same divider of 4 on both modules to configure the maximal
possible clock speeds:
VF61: 41.7 MHz
VF50: 33 MHz
(cherry picked from commit 0eba4c41ca18f8f009126dcacc647927accaa63d)
Use the same preprocessor define to enable clocks as we use to
enable the driver. Make sure that the necessary PLL's are on
(they get enabled by boot ROM by default, so this is more for
completness).
(cherry picked from commit 9e73c1b7d11611d51f0026d375731f0316dd26e8)
kernel. U-Boot's mtdparts environment variable will be used as
partition source for the device-tree based partition table too.
(cherry picked from commit 6119b0f764eb8b68d6148d4c017cbd343408c2d8)
The config block support currently uses the ft_board_setup function
to patch the device tree with config block information. However, this
does not allow to patch the device tree with board specific information.
Rename the common setup function to ft_common_board_setup and use the
call it from the board files directly.
(cherry picked from commit 37fa41256bd756f3652e7479b976982092a4f9bc)
Add serial platform data to board file.
Enable driver model for PXA serial driver.
(cherry picked from commit 136179bec19f4bc84227cba138214ea392a723ea)
remove now unused CONFIG_TRDX_PID_XXX
(cherry picked from commit 877ea607a8e07a9ed308e44a58e8e2b9028f01f2)
With our common code in place actually make use of it across all our
modules.
(cherry picked from commit b891d01038abcc8b25f12e1b91ff889b06eb07a2)
Add Toradex factory configuration block handling. The config block is a
data structure which gets stored to flash during production testing. The
structure holds such information as board resp. hardware revision,
product ID and serial number which is used as the NIC part of the
Ethernet MAC address as well. The config block will be read upon boot by
the show_board_info() function, displayed as part of the board
information and passed to Linux via device tree or ATAGs.
(cherry picked from commit a2777ecb9d11882dba696035defa35c70dd26733)
Only a certain set of PLLM/D values are recommended to configure the DDR
at the required speeds for a given clock input frequency. Updating these
values as specified in Data Sheet[1] Table 5-18
[1] http://www.ti.com/lit/ds/symlink/66ak2g02.pdf
Add a README file to help users getting started with the board.
Signed-off-by: Diego Dorta <diego.dorta@nxp.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
If the MAC address specified on the EEPROM is invalid (multicast or
zero address), then u-boot fails to boot. Having a bad MAC address
in the EEPROM should not prevent the system from booting.
This commit changes the error path to just print an error messages
in case of bad MAC address.
Signed-off-by: Fabien Parent <fparent@baylibre.com>
In most cases, the SPL and u-boot.img will be on the same boot media.
Since the SPL was loaded by the boot rom, the pinmux will already have
been configured for this media. This, the board will still be able to
boot successfully, or at least reach the u-boot console, where more
recovery options are available.
I've encountered this on a beaglebone black with a corrupted EEPROM.
Removing this check allowed the board to boot successfully. I've also
seen this on EVM-based boards with an unprogrammed EEPROM. On those
boards, for some reason there were no UART messages. This made it look
as if the SOC was dead.
Remove the hang(), as it is not a fatal error. Also reformat the error
message to be clearer as to the cause. The original message made it
appear as if the wrong binary was being loaded.
Signed-off-by: Alexandru Gagniuc <mr.nuke.me@gmail.com>
Tested on IGEPv2 with Micron MT29F4G16ABBDA3W and
Hynix H27S4G6F2DKA-BM
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Reviewed-by: Javier Martinez Canillas <javier@samsung.com>
Tested-by: Javier Martinez Canillas <javier@samsung.com>
As a single U-Boot binary can now run on various board modifications,
drop CONFIG_DISPLAY_BOARDINFO as it prints flash memory information
too early to give us chance to easily detect it. Also saves few bytes
as a bonus.
Since commit ce412b79e7255770 ("drivers: net: phy: atheros: add separate
config for AR8031") ethernet does not work on mx6sabresd.
This commit correctly assigns ar8031_config() as the configuration
function for AR8031 in the same way as done in the Linux kernel.
However, on wandboard design we need some additional configuration,
such as enabling the 125 MHz AR8031 output that needs to be done
in the board file.
This also aligns with the same method that the kernel performs
the AR8031 fixup in arch/arm/mach-imx/mach-imx6q.c.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
However, on mx6sabresd design we need some additional configuration,
in the board file.
Config file names on MAINTAINERS and README in
board/engicam/icorem6 seems to be wrong, hence fixed the same.
Cc: Michael Trimarchi <michael@amarulasolutions.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
Acked-by: Angelo Dureghello <angelo@sysam.it>
The autodetect feature doesn't allow users to specify the device tree.
This fix will make it only autodetect if 'fdtimage' is not defined.
