path: root/board
2017-07-10ti: common: board_detect: Add function to determine if EEPROM was readCooper Jr., Franklin
When the EEPROM is first read its contents are stored in memory as a cache to avoid further I2C operations. To determine if the EEPROM was previously read the easiest way is to check the memory to see if the EEPROM's magic header value is set. Create a new function that can determine if the EEPROM was previously read or not without having to perform a I2C transaction. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-10ti: common: board_detect: Allow settings board detection variables manuallyNishanth Menon
In some situations the EEPROM used for board detection may not be programmed or simply programmed incorrectly. Therefore, it may be necessary to "simulate" reading the contents of the EEPROM to set appropriate variables used in the board detection code. This may also be helpful in certain boot modes where doing i2c reads may be costly and the config supports running only a specific board. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Keerthy <j-keerthy@ti.com> Signed-off-by: Franklin S Cooper Jr. <fcooper@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-10km/common: remove unused function declarationsHolger Brunck
Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de> Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2017-07-08MAINTAINERS: drop bcm283x/rpi maintainershipStephen Warren
It's been a while since I've touched U-Boot on the Raspberry Pi and other things have been taking my time. Drop my maintainership for this port. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2017-07-08powerpc, 8xx: Add support for MCR3000 board from CSSIChristophe Leroy
CS Systemes d'Information (CSSI) manufactures two boards, named MCR3000 and CMPC885 which are respectively based on MPC866 and MPC885 processors. This patch adds support for the first board. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2017-07-06avr32: Retire AVR32 for goodAndy Shevchenko
AVR32 is gone. It's already more than two years for no support in Buildroot, even longer there is no support in GCC (last version is heavily patched 4.2.4). Linux kernel v4.12 got rid of it (and v4.11 didn't build successfully). There is no good point to keep this support in U-Boot either. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-07-06km/common: remove unused codeHolger Brunck
The 82xx board mgcoge3ne was removed from the codebase, so this is dead code. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Cc: Heiko Schocher <hs@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-07-06igep003x: Falcon modeLadislav Michl
Implement spl_start_uboot to let Falcon mode work. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Acked-by: Heiko Schocher <hs@denx.de>
2017-07-06odroid-c2: Populate serial# environment variable from efuseMartin Böh
2017-07-03powerpc: remove 4xx supportHeiko Schocher
There was for long time no activity in the 4xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 4xx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-29pico-imx7d: Remove bouncing emailFabio Estevam
Wig Cheng's email bounces, so remove it from the maintainers list. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-06-29Merge git://git.denx.de/u-boot-arcTom Rini
2017-06-29ARM: at91: ma5d4: Support both SF and eMMC SoMsMarek Vasut
Discern the SoMs based on the presence of SPI flash to support both variants of the SoM, one booting from SPI NOR and one booting from eMMC. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2017-06-29ARM: at91: ma5d4: Boot from MMC2 when using SAM-BAMarek Vasut
Continue loading U-Boot from MMC2 when the SPL was loaded using SAM-BA loader. This allows the board to boot system from the removable media instead of the eMMC, which is useful for commissioning purposes. When booting from the eMMC, always boot from it as it is not possible to boot from the SD interface directly. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2017-06-29ARM: at91: ma5d4: Swap SD/MMC controller orderMarek Vasut
The SDHCI1 is the primary boot controller on rev. 2.1 SoM, which is the version available on the market. Swap the controller order to match this and future versions of the SoM. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2017-06-29ARM: at91: ma5d4: Init SD/MMC controller in SPLMarek Vasut
Init the controllers, otherwise the board cannot boot from SD/MMC. This boot option is new on rev. 2.1 SoM . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2017-06-29ARM: at91: ma5d4: Reset CAN controllers lateMarek Vasut
The CAN controllers need slight delay between toggling of their reset line. Move this action into board_init(), otherwise timer will not be initialized and the board might hang. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2017-06-29ARM: at91: ma5d4: Switch DDR2 controller to sequencial address decodingMarek Vasut
According to the datasheet, sequential mapping is used for DDR SDRAM, while interleaved mapping is used for regular SDRAM. Incorrect configuration of this bit does indeed cause sporadic memory instability. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Wenyou Yang <wenyou.yang@atmel.com>
2017-06-29ARM: atmel: Rename MA5D4EVKMarek Vasut
The board is now manufactured by Aries Embedded GmbH , rename it. Signed-off-by: Marek Vasut <marex@denx.de>
2017-06-29arc: Add support for HS Development Kit boardAlexey Brodkin
ARC HS Development Kit board is a new low-cost development platform sporting ARC HS38 in real silicon with nice set of features such as: * Quad-core ARC HS38 with 512 kB L2 cache and running @1GHz * 4Gb of DDR (we use only lowest 1Gb out of it now) * Lots of DesigWare peripherals * Different connectivity modules: - Synopsys HAPS HT3 - Arduino-compatible connector - MikroBUS This initial commit supports the following peripherals: * UART (DW 8250) * Ethernet (DW GMAC) * SD/MMC (DW Mobile Storage) * USB 1.1 & 2.0 Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2017-06-29atmel, at91: fix taurus boardHeiko Schocher
since commit: f8b7fff1d5c5 "serial: atmel_usart: Add clk support" taurus board comes not up anymore. Fix it. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-06-29at91, dfu, smartweb: set serial numberHeiko Schocher
since commit 842778a09104 dfu-util shows serial="UNDEFINED". to see here again a serial number, we have to call g_dnl_set_serialnumber(). Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-29atmel, at91: fix smartweb boardHeiko Schocher
since commit: f8b7fff1d5c5 "serial: atmel_usart: Add clk support" smartweb board comes not up anymore. Fix it. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-06-28ti816x: Enable ethernet supportTom Rini
The ti816x SoC revision of the ethernet IP block is handled by the "davinci_emac" driver, rather than the "cpsw" driver as done by later members of the family. Enable the relevant plumbing. Signed-off-by: Sriramakrishnan <srk@ti.com> Signed-off-by: Vitaly Wool <vitaly.wool@konsulko.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-27Merge git://www.denx.de/git/u-boot-imxTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: include/configs/imx6qdl_icore_rqs.h include/configs/imx6ul_geam.h include/configs/imx6ul_isiot.h
2017-06-23board/db410c: add missing linker map entries for efiRob Clark
Otherwise the loaded image would miss the efi_runtime sections, and fall over hard when grub (for example) tried to call runtime services located in this section. Signed-off-by: Rob Clark <robdclark@gmail.com>
2017-06-23controlcenterd_36BIT_SDCARD: Fix unused variable warningTom Rini
On the controlcenterd_36BIT_SDCARD config we get a warning about prg_stage1_prepare being unused. Move the declaration closer to usage and hide under the existing #if tests. Cc: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-22x86: minnowmax: Configure GPIO pins to turn on USB ports VBUSBin Meng
GPIO bank E pin 8 & 9 are used to control the on-board two USB ports VBUS on/off. Let's configure them in the misc_init_r(). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-06-21Merge tag 'xilinx-for-v2017.07' of git://www.denx.de/git/u-boot-microblazeTom Rini
Xilinx changes for v2017.07 ZynqMP: - config cleanup - SD LS mode support - psu_init* cleanup - unmap OCM - Support for SMC Zynq: - add ddrc to Kconfig - add topic-miamilite board support
2017-06-20arm: zynq: Add support for the topic-miamilite system-on-moduleMike Looijmans
The topic-miamilite SoM contains a Zynq xc7z010 SoC, 1GB DDR3L RAM, 64MB dual-parallel QSPI NOR flash and clock sources. Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-06-20arm64: zynqmp: Check pmufw versionMichal Simek
If PMUFW version is not v0.3 then panic. ZynqMP switch to CCF based clock driver which requires PMUFW to be present at certain version. This patch ensure that you use correct and tested PMUFW binary. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-06-20arm64: zynqmp: Add empty sleep.h file for psu_init* compilationMichal Simek
psu_init* contain sleep.h header which is not present in u-boot. Instead of keep comment sleep.h in psu_init* it is easier to add empty file which is included. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-06-19arm64: zynqmp: Fix psu_init* external functionsMichal Simek
In older vivado version some psu_init* files didn't contain mask*() which were missing. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-06-19Merge branch 'master' of git://git.denx.de/u-boot-sunxiTom Rini
2017-06-16powerpc, 5xxx, 512x: remove support for mpc5xxx and mpc512xHeiko Schocher
There was for long time no activity in the mpx5xxx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in mpc5xxx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-16board/BuR/brxre1: fix MMC bootHannes Schmelzer
since commit 'd5abcf94c7123167725fc22ace342f0d455093c1' - ti: boot: Register the MMC controllers in SPL in the same way as in u-boot MMC boot on brxre1 board is broken, with this commit we make our board working again. Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2017-06-16treewide: remove unneeded semicolonsMasahiro Yamada
2017-06-14Merge git://git.denx.de/u-boot-mpc85xxTom Rini
2017-06-14Merge branch 'master' of git://git.denx.de/u-boot-tegraTom Rini
2017-06-14sun50i: h5: Add initial NanoPi NEO2 supportJagan Teki
NanoPi NEO2 is designed and developed by FriendlyElec using the Allwinner 64-bit H5 SOC. NanoPi Neo2 key features - Allwinner H5, Quad-core 64-bit Cortex-A53 - 512MB DDR3 RAM - microSD slot - 10/100/1000M Ethernet - Serial Debug Port - 5V 2A DC MicroUSB power-supply Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2017-06-14sun50i: a64: Add initial Orangepi Win/WinPlus supportJagan Teki
Orangepi Win/WinPlus is an open-source single-board computer using the Allwinner A64 SOC. A64 Orangepi Win/WinPlus has - A64 Quad-core Cortex-A53 64bit - 1GB(Win)/2GB(Win Plus) DDR3 SDRAM - Debug TTL UART - Four USB 2.0 - HDMI - LCD - Audio and MIC - Wifi + BT - IR receiver - 5V DC power supply Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2017-06-14sun50i: h5: Add initial Orangepi Zero Plus 2 supportJagan Teki
Orangepi Zero Plus 2 is an open-source single-board computer using the Allwinner h5 SOC. H5 Orangepi Zero Plus 2 has - Quad-core Cortex-A53 - 512MB DDR3 - micrSD slot and 8GB eMMC - Debug TTL UART - HDMI - Wifi + BT - OTG+power supply Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2017-06-12ARM: tegra: remove Whistler supportStephen Warren
Whistler is an ancient Tegra 2 reference board. I may have been the only person who ever used it with upstream software, and I've just recycled the board hardware. Hence, it makes sense to remove support from software. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2017-06-12powerpc: fsl: Update maintainersYork Sun
Update maintainers for B4860QDS, P1010RDB, P1_TWR, T104xRDB. Signed-off-by: York Sun <york.sun@nxp.com>
2017-06-12powerpc: mpc8569mds: Update config and maintainerYork Sun
Enable DHCP command by default. Update maintainer info. Signed-off-by: York Sun <york.sun@nxp.com>
2017-06-12powerpc: mpc8568mds: Update board configYork Sun
Enable DHCP command by default. Move environmental variable location to before U-Boot image. Enlarge reserved mem for malloc. Update maintainer. Signed-off-by: York Sun <york.sun@nxp.com>
2017-06-12powerpc: mpc8536ds: Update maintainerYork Sun
2017-06-12powerpc: mpc8544ds: Update maintainerYork Sun
2017-06-12powerpc: mpc8548cds: Update maintainerYork Sun
2017-06-12powerpc: mpc86xx: Update maintainer for MPC8610HPCD and MPC8641HPCNYork Sun
