path: root/board
2014-12-18ARM: tegra: Enable PCIe on Jetson TK1Thierry Reding
The Jetson TK1 has an ethernet NIC connected to the PCIe bus and routes the second root port to a miniPCIe slot. Enable the PCIe controller and the network driver to allow the device to boot over the network. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-18ARM: tegra: Enable PCIe on CardhuThierry Reding
The PCIe bus on Cardhu is routed to the dock connector. An ethernet NIC is available on the dock over the PCIe bus. Enable the PCIe controller and the network device driver so that the device can boot over the network. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-18ARM: tegra: Enable PCIe on TrimSliceThierry Reding
The TrimSlice has an ethernet NIC connected to the PCIe bus. Enable the PCIe controller and the network driver so that the device can boot over the network. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-18ARM: tegra: Implement XUSB pad controllerThierry Reding
This controller was introduced on Tegra114 to handle XUSB pads. On Tegra124 it is also used for PCIe and SATA pin muxing and PHY control. Only the Tegra124 PCIe and SATA functionality is currently implemented, with weak symbols on Tegra114. Tegra20 and Tegra30 also provide weak symbols for these functions so that drivers can use the same API irrespective of which SoC they're being built for. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-16Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2014-12-16Merge branch 'master' of git://git.denx.de/u-boot-socfpgaTom Rini
2014-12-16arm: socfpga: board: Repair Micrel PHY tuningPavel Machek
Add proper error checking into the PHY tuning patch. Make the PHY tunning only happen in case the KSZ9021 PHY is enabled in config. Call the config callback after the tuning finished. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@opensource.altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Tom Rini <trini@ti.com> Cc: Pavel Machek <pavel@denx.de>
2014-12-15mpc85xx/t104xrdb: convert deep sleep to generic board interfaceTang Yuantian
A new interface is introduced to support generic board structure. Converts it to use new interface. Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-13x86: ich6-gpio: Move setup_pch_gpios() to board support codesBin Meng
Movie setup_pch_gpios() in the ich6-gpio driver to the board support codes, so that the driver does not need to know any platform specific stuff (ie: include the platform specifc chipset header file). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-13x86: Make ROM_SIZE configurable in KconfigBin Meng
Currently the ROM_SIZE is hardcoded to 8MB in arch/x86/Kconfig. This will not be the case when adding additional board support. Hence we make ROM_SIZE configurable (512KB/1MB/2MB/4MB/8MB/16MB) and have the board Kconfig file select the default ROM_SIZE. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-11Merge git://git.denx.de/u-boot-dmTom Rini
2014-12-11Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
Conflicts: board/freescale/mx6sxsabresd/mx6sxsabresd.c Signed-off-by: Tom Rini <trini@ti.com>
2014-12-11Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2014-12-11dm: i2c: tegra: Convert to driver modelSimon Glass
This converts all Tegra boards over to use driver model for I2C. The driver is adjusted to use driver model and the following obsolete CONFIGs are removed: - CONFIG_SYS_I2C_INIT_BOARD - CONFIG_I2C_MULTI_BUS - CONFIG_SYS_MAX_I2C_BUS - CONFIG_SYS_I2C_SPEED - CONFIG_SYS_I2C This has been tested on: - trimslice (no I2C) - beaver - Jetson-TK1 It has not been tested on Tegra 114 as I don't have that board. Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-11ARM: tegra: Add support for nyan-big boardAllen Martin
Nyan-big is a Tegra124 clamshell board that is very similar to venice2, but it has a different panel, the sdcard cd and wp sense are flipped, and it has a different revision of the AS3722 PMIC. This is the Acer Chromebook 13 CB5-311-T7NN (13.3-inch HD, NVIDIA Tegra K1, 2GB). The display is not currently supported, so it should boot on other nyan-based Chromebooks also, but only the device tree for nyan-big is provided here. The device tree file is from Linux but with features removed which are unlikely to be supported in U-Boot soon (regulators, pinmux). Also the addresses are updated to 32-bit. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> (rebase, change to 'nyan-big', fix pinmux that resets nyan-big)
2014-12-11dm: rpi: Move serial to driver modelSimon Glass
Adjust the configuration to use the driver model version of the pl01x serial driver. Add the required platform data. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@wwwdotorg.org>
2014-12-11ARM: ls102xa: Setting device's stream id for SMMUs.Xiubo Li
LS1 has 4 SMMUs for address translation of the masters. All the SMMUs' stream IDs are 8-bit. The address translation depends on the stream ID of the incoming transaction. Each master has unique stream ID assigned to it and is configurable through SCFG registers. The stream ID for the masters is identical and share the same register field of STREAM ID registers. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11ARM: ls102xa: allow all the peripheral access permission as R/W.Xiubo Li
The Central Security Unit (CSU) allows secure world software to change the default access control policies of peripherals/bus slaves, determining which bus masters may access them. This allows peripherals to be separated into distinct security domains. Combined with SMMU configuration of the system masters privileges, these features provide protection against indirect unauthorized access to data. For now we configure all the peripheral access permissions as R/W. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11fsl/sleep: updated the deep sleep framework for QorIQ platformsTang Yuantian
With the introducing of generic board and ARM-based cores, current deep sleep framework doesn't work anymore. This patch will convert the current framework to adapt this change. Basically it does: 1. Converts all the Freescale's DDR driver to support deep sleep. 2. Added basic framework support for ARM-based and PPC-based cores separately. Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11ls1021aqds: add hwconfig setting to do pin muxYao Yuan
The Freescale LS1021AQDS share some pins, so Add the hwconfig option that allows the user to choose which the function he wants. The main pin mux IP is: eSDHC, SAI, IIC2, RGMII, CAN, SAI. Signed-off-by: Yuan Yao <yao.yuan@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11arm: ls102xa: Add NAND boot support for LS1021AQDS boardAlison Wang
This patch adds NAND boot support for LS1021AQDS board. SPL framework is used. PBL initialize the internal RAM and copy SPL to it, then SPL initialize DDR using SPD and copy u-boot from NAND flash to DDR, finally SPL transfer control to u-boot. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11arm: ls102xa: Add QSPI boot support for LS1021AQDS/TWR boardAlison Wang
This patch adds QSPI boot support for LS1021AQDS/TWR board. The QSPI boot image need to be programmed into the QSPI flash first. Then the booting will start from QSPI memory space. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11arm: ls102xa: Add SD boot support for LS1021ATWR boardAlison Wang
This patch adds SD boot support for LS1021ATWR board. SPL framework is used. PBL initialize the internal RAM and copy SPL to it, then SPL initialize DDR using SPD and copy u-boot from SD card to DDR, finally SPL transfer control to u-boot. Signed-off-by: Chen Lu <chen.lu@freescale.com> Signed-off-by: Alison Wang <alison.wang@freescale.com> Signed-off-by: Jason Jin <jason.jin@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11arm: ls102xa: Add SD boot support for LS1021AQDS boardAlison Wang
This patch adds SD boot support for LS1021AQDS board. SPL framework is used. PBL initialize the internal RAM and copy SPL to it, then SPL initialize DDR using SPD and copy u-boot from SD card to DDR, finally SPL transfer control to u-boot. Signed-off-by: Alison Wang <alison.wang@freescale.com> Signed-off-by: Jason Jin <jason.jin@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11ls102xa: qixis: Add CONFIG_QIXIS_I2C_ACCESS macroAlison Wang
Through adding CONFIG_QIXIS_I2C_ACCESS macro, QIXIS_READ(reg)/QIXIS_WRITE(reg, value) can be used for both i2c and ifc access to QIXIS FPGA. This is more convenient for coding. Signed-off-by: Jason Jin <jason.jin@freescale.com> Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11ls1021aqds: set the default I2C channel before DDR initChenhui Zhao
When resuming from deep sleep, the I2C channel may not be in the default channel. So, switch to the default channel before accessing DDR SPD. Signed-off-by: Chenhui Zhao <chenhui.zhao@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11arm: ls102xa: Update PCIe dts node statusMinghuan Lian
The patch changes PCIe dts node status to 'disabled' if the corresponding controller is disabled according to serdes protocol. Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-10Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2014-12-10Merge branch 'rmobile' of git://git.denx.de/u-boot-shTom Rini
2014-12-10arm: rmobile: alt: Add support MMC and MMC commandNobuhiro Iwamatsu
Alt board has been connected to eMMC of 8GB to MMC port. This enables MMC port and MMC command. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-12-10arm: rmobile: lager: Add support MMC and MMC commandNobuhiro Iwamatsu
Lager board has been connected to eMMC of 8GB to MMC1 port. This enables MMC1 port and MMC command. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-12-09dm: stv0991: Move serial to driver modelVikas Manocha
Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
2014-12-09stv0991: enable ethernet supportVikas Manocha
2014-12-09stv0991: Add basic stv0991 architecture supportVikas Manocha
stv0991 architecture support added. It contains the support for following blocks - Timer - uart Signed-off-by: Vikas Manocha <vikas.manocha@st.com> [trini: Add arch/arm/cpu/armv7/Makefile hunk] Signed-off-by: Tom Rini <trini@ti.com>
2014-12-08Merge git://git.denx.de/u-boot-mpc85xxTom Rini
2014-12-08Merge branch 'master' of git://git.denx.de/u-boot-tiTom Rini
2014-12-08powerpc: mpc8xx: remove hermes board supportMasahiro Yamada
This board sprinkles #ifdef(CONFIG_HERMES) over various global files such as include/common.h, common/board_r.c, common/cmd_bdinfo.c. Let's zap such an ill-behaved board. It has not been converted to generic board yet and mpc8xx is old enough. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2014-12-08ARM: rpi: rename rpi_b to rpiStephen Warren
The U-Boot port runs on a variety of RPi models, not just the B. So, rename the port to something slightly more generic. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-12-08ARM: rpi_b: detect board revisionStephen Warren
Detect the board revision early during boot, and print the decoded model name. Eventually, this information can be used for tasks such as: - Allowing/preventing USB device mode; some models have a USB device on- board so only host mode makes sense. Others connect the SoC directly to the USB connector, so device-mode might make sense. - The on-board USB hub/Ethernet requires different GPIOs to enable it, although luckily the default appears to be fine so far. - The compute module contains an on-board eMMC device, so we could store the environment there. Other models use an SD card and so don't support saving the environment (unless we store it in a file on the FAT boot partition...) Set $fdtfile based on this information. At present, the mainline Linux kernel doesn't contain a separate DTB for most models, but I hope that will change soon. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-12-06arm: socfpga: set skew settings for ethernet phyDinh Nguyen
Set the PHY skew settings for the ethernet phy on the SOCFPGA Cyclone5 hardware. Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Vince Bridgers <vbridger@opensource.altera.com> Cc: Pavel Machek <pavel@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Wolfgang Denk <wd@denx.de>
2014-12-06arm: socfpga: Add myself as maintainer for the SoCrates boardStefan Roese
Signed-off-by: Stefan Roese <sr@denx.de> Cc: Marek Vasut <marex@denx.de> Acked-by: Pavel Machek <pavel@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Vince Bridgers <vbridger@altera.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-05powerpc/hydra: fix judging condition of RGMII selectionMinghuan Lian
BRDCFG1_EMI1_SEL_MASK has been changed to 0x78, which contains selection bits and connected status bit. So the Corresponding mux value of RGMII is changed to BRDCFG1_EMI1_SEL_RGMII | BRDCFG1_EMI1_EN. Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05powerpc/hydra: Update MDIO mux fixupsChunhe Lan
The new device trees use a more generic interface for supporting muxing mdio buses. The mux property is thus specified in "reg", rather than "fsl,hydra-mdio-muxval". In order to support using old device trees, we keep the old fixup in there. Linux will therefore see the both properties, but will ignore fsl,hydra-mdio-muxval. Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05board/t1024qds: add retimer support on t1024qdsShengzhou Liu
Initialize retimer for XFI on t1024qds. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05t1024qds: increase IO drive strengthShengzhou Liu
Increase IO drive strength to fix FCS error on RGMII ports on T1024QDS. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05board/t1024qds: update pin multiplexingShengzhou Liu
Add multiplexing support among SPI flash, TDM riser card and SDXC. it routes SPI pins to SPI flash by default. Route SPI pins to SD slot if "adaptor=sdxc" is set in hwconfig. Route SPI pins to TDM riser card and do fixup for dts if "pin_mux=tdm" is set in hwconfig. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Xie Xiaobo <X.Xie@freescale.com> Signed-off-by: Zhao Qiang <B45475@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05powerpc/t1024rdb: Add T1024 RDB board supportShengzhou Liu
T1024RDB is a Freescale Reference Design Board that hosts the T1024 SoC. T1024RDB board Overview ----------------------- - T1024 SoC integrating two 64-bit e5500 cores up to 1.4GHz - CoreNet fabric supporting coherent and noncoherent transactions with prioritization and bandwidth allocation - 32-/64-bit DDR3L SDRAM memory controller with ECC and interleaving support - Accelerator: DPAA components consist of FMan, BMan, QMan, DCE and SEC - Ethernet interfaces: - Two 10M/100M/1G RGMII ports on-board - one 10Gbps XFI interface - PCIe: Three PCIe controllers: one PCIe Slot and two Mini-PCIe connectors. - SerDes: 4 lanes up to 10.3125GHz - IFC: 128MB NOR Flash, 512MB NAND Flash and CPLD - eSPI: 64MB N25Q512 SPI flash. - Deep Sleep power implementaion (wakeup from GPIO/Timer/Ethernet/USB) - USB: Two Type-A USB2.0 ports with internal PHY - eSDHC: Support SD, SDHC, SDXC and MMC/eMMC - I2C: Four I2C controllers - UART: Two UART serial ports Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> [York Sun: Fix ft_board_setup() type, fix MAINTAINERS for SECURE_BOOT Fix Kconfig by adding SUPPORT_SPL] Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05powerpc/t1024qds: Add T1024 QDS board supportShengzhou Liu
T1024QDS is a high-performance computing evaluation, development and test platform for T1024 QorIQ Power Architecture processor. T1024QDS board Overview ----------------------- - T1024 SoC integrating two 64-bit e5500 cores up to 1.4GHz - CoreNet fabric supporting coherent and noncoherent transactions with prioritization and bandwidth allocation - 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and interleaving support - Accelerator: DPAA components consist of FMan, BMan, QMan, DCE and SEC - Ethernet interfaces: - Two 10M/100M/1G RGMII ports on-board - Three 1G/2.5Gbps SGMII ports - Four 1Gbps QSGMII ports - one 10Gbps XFI or 10Base-KR interface - SerDes: 4 lanes up to 10.3125GHz Supporting SGMII/QSGMII, XFI, PCIe, SATA and Aurora - PCIe: Three PCI Express controllers with five PCIe slots. - IFC: 128MB NOR Flash, 2GB NAND Flash, PromJet debug port and Qixis FPGA - Video: DIU supports video up to 1280x1024x32 bpp. - Chrontel CH7201 for HDMI connection. - TI DS90C387R for direct LCD connection. - Raw (not encoded) video connector for testing or other encoders. - QUICC Engine block - 32-bit RISC controller for flexible support of the communications peripherals - Serial DMA channel for receive and transmit on all serial channels - Two universal communication controllers, supporting TDM, HDLC, and UART - Deep Sleep power implementaion (wakeup from GPIO/Timer/Ethernet/USB) - eSPI: Three SPI flash devices. - SATA: one SATA 2.O. - USB: Two USB2.0 ports with internal PHY (one Type-A + one micro Type mini-AB) - eSDHC: Support SD, SDHC, SDXC and MMC/eMMC. - I2C: Four I2C controllers. - UART: Two UART on board. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> [York Sun: Fix ft_board_setup() type, fix MAINTAINERS for SECURE_BOOT Fix Kconfig by adding SUPPORT_SPL] Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05powerpc/t2080: updating rcw for silicon v1.1Shengzhou Liu
T2080 v1.1 requires different MEM_PLL_RAT from previous v1.0, and also update core frequency to 1.8GHz for v1.1. We reserve the support for T2080 v1.0 and enable v1.1 by default. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05B4860QDS: Enable enet port as per fsl_b4860_serdes2 string in hwconfigSuresh Gupta
In B4860QDS board SerDes2 lanes EFGH either go to SFP or AMC riser card slot2 so either DTSEC3/DTSEC4 or TGEC1/TGEC2 should be accessible. This Patch enables DTSEC3/DTSEC4 or TGEC1/TGEC2 on bases of user specified string fsl_b4860_serdes2:sfp_amc=amc or fsl_b4860_serdes2:sfp_amc=sfp respectively in hwconfig. Signed-off-by: Suresh Gupta <suresh.gupta@freescale.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
