path: root/board
2017-11-28arm: zynq: Add mini u-boot configuration for zynqMichal Simek
Add configuration files/dtses for mini u-boot configurations which runs out of OCM. ram top is calculated from 0 that's why +#define CONFIG_SYS_SDRAM_BASE 0xfffc0000 +#define CONFIG_SYS_SDRAM_SIZE 0x40000 was hardcoded. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-28arm: zynq: Return value from fdtdec_setup_memory_banksize directlyMichal Simek
There is no reason not to return return value from above function. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-11-28arm: zynq: Add support for SYZYGY Hub boardTom McLeod
Add the Zynq-based SYZYGY Hub board from Opal Kelly. The board contains a Xilinx Zynq xc7z012s SoC, 1GB DDR3 RAM, and supports booting from SD. Signed-off-by: Tom McLeod <tom.mcleod@opalkelly.com> Cc: Michal Simek <monstr@monstr.eu> CC: Albert Aribaud <albert.u.boot@aribaud.net> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-11-27Merge git://www.denx.de/git/u-boot-imxTom Rini
2017-11-27engicam: imx6q: Return mmc dev 0 for icoreJagan Teki
icorem6 has sd on usdhci1 which is devno 0 so return proper devno from board_mmc_get_env_dev for icorem6 and icorem_6rqs Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-11-27i.MX6: engicam: Add imx6q/imx6ul boards for existing boardsJagan Teki
Add new board names for existing board support imx6q - icore and icore_rqs boards imx6ul - geam6ul and isiot boards Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-11-27board: icore-rqs: Fix mmc get env deviceJagan Teki
As per USDHC boot eFUSE descriptions: USDHC3 => devno 2 USDHC4 => devno 3 Linux will detect mmc0, mmc1, mmc2 based on the status "okay" on usdhc so imx6qdl-icore-rqs.dtsi has enabled usdhc1, usdhc3 and usdhc4.But U-Boot can detect based on the aliases so add mmc1, mmc2 for usdhc3 and usdhc4 respectively and return the board_mmc_get_env_dev by subtracting -1 Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-11-27i.MX6UL: icore: Add SPL_OF_CONTROL supportJagan Teki
Add OF_CONTROL support for SPL code. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-11-27i.MX6Q: icore: Add SPL_OF_CONTROL supportJagan Teki
2017-11-27i.MX6Q: icorem6: Move spl load fit to common/splJagan Teki
Move spl load fit code into common/spl Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-11-27i.MX6: engicam: Move set_fdt_file to commonJagan Teki
setenv_fdt_file to common code and set dtb based on CONFIG_DEFAULT_DEVICE_TREE and cpu_type. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-11-26rockchip: board: lion-rk3368: update .its filePhilipp Tomsich
For the RK3368-uQ7, we can now update the .its file to mark the Trusted Firmware as out 'firmware' bootable and annotate both ATF and U-Boot with an OS-type. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-26rockchip: board: puma-rk3399: update .its file to use new featuresPhilipp Tomsich
This commit updates the .its file for the RK3399-Q7 to use the new features and demonstrates how to use those: * it marks the ATF as the 'firmware' * it tracks the OS-type for U-Boot and ATF * it loads the PMU (M0) firmware to DRAM and records the location to /fit-images (where our ATF reads it from) With the handoff of the next-stage FDT to ATF in place, we can now use this to pass information about the load addresses and names of each loadables to ATF: now we can load the M0 firmware into DRAM and avoid overwriting parts of the SPL stage. This is achieved by changing our .its-file to use an available area of DRAM as the load-address. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-21TI: am57xx; Remove am57xx_evm_nodt_defconfigTom Rini
We don't want this build anymore. Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-11-20odroid-c2: enable I2CBeniamino Galvani
Signed-off-by: Beniamino Galvani <b.galvani@gmail.com>
2017-11-20mx53: Add Board support for GE PPDPeter Senna Tschudin
Create board support for GE PPD, based on mx53loco. Use mx53ppd_defconfig make target to configure for this board. Signed-off-by: Peter Senna Tschudin <peter.senna@collabora.com> Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2017-11-20board: ge: make VPD code commonMartyn Welch
The VPD data is used on a number of GE products. Move the parsing code to a common location so that we can share this code. Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Acked-by: Stefano Babic <sbabic@denx.de>
2017-11-20Revert "wandboard: Remove unnecessary delay"Fabio Estevam
This reverts commit b8b9790e23a7d6eec08d66192853ecb61bcae095. Some wandboard variants no longer boot after this commit, so keep the original delay to avoid the boot regression. Reported-by: Varga Zsolt <vazso@vazso.hu> Tested-by: Varga Zsolt <vazso@vazso.hu> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-11-17omap3: omap3_logic: Move pinmuxing to header fileAdam Ford
To keep the board file smaller and clean, let's move the pinmux to the header file. Signed-off-by: Adam Ford <aford173@gmail.com>
2017-11-17mmc: arm_pl180_mmci: update arm_pl180_mmci_init() prototypePatrice Chotard
Update arm_pl180_mmci_init() prototype by adding struct mmc** param. This is needed before converting this driver to driver model in order to use arm_pl180_mmci_init() in driver model and in none driver model implementation Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-11-17arm: amlogic: p212: Add support for Ethernet with Internal PHYNeil Armstrong
This patch adds support for the Internal RMII Ethernet PHY on the Amlogic P212 Reference Board. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2017-11-17arm: add initial support for Amlogic P212 based on Meson GXL familyNeil Armstrong
This adds platform code for the Amlogic P212 reference board based on a Meson GXL (S905X) SoC with the Meson GXL configuration. This initial submission only supports UART and MMC/SDCard, support for the internal Ethernet PHY in Work In Progress. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Reviewed-by: Beniamino Galvani <b.galvani@gmail.com>
2017-11-17board: ti: dra71x-evm: Hook LDO1 of LP8733 to EN_PINKeerthy
All regulators are hooked to EN_Pin at reset so that EN Pin controls their state. Hook the LDO1 regulator to EN pin which at reset is not hooked. This applies only to LP8733. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-11-16Merge git://www.denx.de/git/u-boot-marvellTom Rini
2017-11-16mvebu: usb: xhci: a38x supportJon Nettleton
This makes the initial changes need to support the a38x series of SOCs. It adds the device-tree identifier as well as changing the board_support function to take the IO address designated by device-tree. Signed-off-by: Jon Nettleton <jon@solid-run.com> [baruch: use fdt_addr_t; update 37xx and 8K implementations] Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Stefan Roese <sr@denx.de>
2017-11-16ARM: imx6: Adjust DDR DRAM settings on DHCOM i.MX6 PDKMarek Vasut
The board uses T-topology for the four x16 DRAM chips, so remove the write-leveling from the SPL as that is only usefly on fly-by topology and can be harmful on T-topology. Also update the DRAM timing with values from calibration on multiple boards. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2017-11-15armv8: ls1088aqds: Add SD boot support for ls1088qdsAshish Kumar
Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Signed-off-by: Raghav Dogra <raghav.dogra@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-11-15armv8: ls1088ardb: Add SD boot support for ls1088Ashish Kumar
Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Signed-off-by: Raghav Dogra <raghav.dogra@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-11-10sunxi: SATA link timeout fixWerner Böllmann
After updating u-boot from v2016.01 to 2017.09, issue with "SATA link 0 timeout." on my Cubietruck board. mdelay milled after moving satapwr code to board. "sunxi: Turn satapwr on from board_init" (sha1: 9fbb0c3aa49f4604b0342cb527a6bd099f92eaeb) After adding the "mdelay(500);" line that was lost in the path the error is gone. Signed-off-by: Werner Böllmann <Werner.Boellmann@fh-dortmund.de> [Rebased and updated change and commit message] Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-11-09imx:display5: Add support for LWN's DISPLAY5 boardLukasz Majewski
This commit provides support for LWN's IMX6Q based DISPLAY5 board. Signed-off-by: Lukasz Majewski <lukma@denx.de>
2017-11-09board: imx6: marsboard: Remove doubled #include <asm/arch/sys_proto.h>Lukasz Majewski
The sys_proto.h file has been included earlier in this file. Signed-off-by: Lukasz Majewski <lukma@denx.de>
2017-11-07i.MX6: engicam: Fix MAINTAINERS/READMEJagan Teki
- Update newly added include/configs file in MAINTAINERS - Update newly added defconfig file in README Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-11-06MAINTAINERS: Add missing boards and config entriesTom Rini
As part of my usual round of build testing, output about missing MAINTAINERS information was not logged, and thus often overlooked. Correct that mistake by ensuring that I log the output of genboardscfg.py every time. As part of that, address a number of missing MAINTAINERS entires. In the case of a missing file, I have put the original submitter down. In the rest of the cases I have added the config (and sometimes relevant header file) to the existing set of file globs. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-11-06stv0991: fix STMicroelectronics copyrightPatrice Chotard
Uniformize STMicroelectronics copyrights headers for STV0991 related code. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-11-06stm32: fix STMicroelectronics copyrightPatrice Chotard
Uniformize STMicroelectronics copyrights headers for STM32 related code. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-11-06sti: fix STMicroelectronics copyrightPatrice Chotard
Uniformize all STMicroelectronics copyrights headers for STi related code. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-10-31mx6slevk: Call gpio_request()Fabio Estevam
We should call gpio_request() prior to reading the GPIO value. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-10-31udoo: Remove cpu type check prior to setup_sata()Fabio Estevam
Inside setup_sata() there is a cpu type check, so there is no need to do this check in the board file. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-10-31wandboard: Remove cpu type check prior to setup_sata()Fabio Estevam
Inside setup_sata() there is a cpu type check, so there is no need to do this check in the board file. This also brings the benefit to allowing setup_sata() to be called for the mx6qp wandboard variant. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-10-31ARM: imx6: Enable UMS and DFU on DHCOM i.MX6 PDKMarek Vasut
Enable UMS and DFU, so that the eMMC can be accessed via the USB gadget port on the board. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2017-10-31imx: mx6slevk: cleanup board usb codePeng Fan
Since DM_USB enabled, no need the usb code in board file. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-10-31wandboard: Add support for the MX6QP variantFabio Estevam
Add support for the latest MX6QP wandboard variant. Based on Richard Hu's work from Technexion's U-Boot tree. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-10-27Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-10-27armv8: ls1088aqds: Change phy mode to PHY_INTERFACE_MODE_RGMII_IDAshish Kumar
Since TX delay is now enabled only in PHY_INTERFACE_MODE_RGMII_ID PHY_INTERFACE_MODE_RGMII_TXID. These change where introduced in phy driver in commit 05b29aa0cb68 ("net: phy: realtek: fix enabling of the TX-delay for RTL8211F"). Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-10-27omap4: sdp4430: match the #endif comment to #ifdefMasahiro Yamada
This comment creates a wrong entry in config_whitelist.txt. I did not touch config_whitelist.txt - the CONFIG will be dropped by the next re-sync. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-10-20net: Add SMC911X driver to Kconfig, convertAdam Ford
We add the various SMC91XX symbols to drivers/net/Kconfig and then this converts the following to Kconfig: CONFIG_SMC911X CONFIG_SMC911X_BASE CONFIG_SMC911X_16_BIT CONFIG_SMC911X_32_BIT Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Apply to the rest of the tree, re-squash old and new patch] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-19x86: baytrail: fsp: Move Azalia update codes to boardBin Meng
Azalia configuration may be different across boards, hence it's not appropriate to do that in the SoC level. Instead, let's make the SoC update_fsp_azalia_configs() routine as a weak version, and do the actual work in the board codes. So far it seems only som-db5800-som-6867 board enables the Azalia. Move the original codes into som-db5800-som-6867.c. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-10-16Drop CONFIG_HAS_DATAFLASHTuomas Tynkkynen
Last user of this option went away in commit: fdc7718999 ("board: usb_a9263: Update to support DT and DM") Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-10-12Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-10-12ARM: imx6: Add DHCOM i.MX6 PDK board supportMarek Vasut
Add support for the DHCOM i.MX6 PDK board. This board has: - FEC ethernet - EHCI USB host - 3x SDMMC Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
