path: root/board
2017-03-17Merge git://git.denx.de/u-boot-rockchipTom Rini
This includes support for rk3188 from Heiko Stübner and and rk3328 from Kever Yang. Also included is SPL support for rk3399 and a fix for rk3288 to get it booting again (spl_early_init()).
2017-03-17ARM: DT: stm32f7: add qspi pin contol nodeVikas Manocha
It also removes the qspi pin configuration done during the board initialization. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
2017-03-17ARM: DT: stm32f7: add ethernet pin contol nodeVikas Manocha
It also removes the ethernet pin configuration done during the board initialization. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
2017-03-17ARM: DT: stm32f7: add pin control node for serial port pinsVikas Manocha
And remove the uart pin configuration from board initialization. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
2017-03-17stm32f7: clk: remove usart1 clock enable from board initVikas Manocha
Before clock driver availability it was required to enable usart1 clock for serial init but now with clock driver is taking care of usart1 clock. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
2017-03-17serial: stm32f7: add device tree supportVikas Manocha
This patch adds device tree support for stm32f7 serial driver & removes serial platform data structure. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-03-16rockchip: rk3328: add evb-rk3328 supportKever Yang
evb-rk3328 is an evb from Rockchip based on rk3328 SoC: - 2 USB2.0 Host port; - 1 USB3.0 Host port; - 1 HDMI port; - 2 10/100M eth port; - 2GB ddr; - 16GB eMMC; - UART to USB debug port; Signed-off-by: William Zhang <william.zhang@rock-chips.com> Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-03-16Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-03-14igep00x0: fixup FDT according to detected flash typeLadislav Michl
Leave only detected flash type enabled in FTD as otherwise GPMC CS is claimed (and never freed) by Linux, causing 'concurent' flash type not to be probed. Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2017-03-14board: Add STMicroelectronics STiH410-B2260 supportPatrice Chotard
This is a 96Board compliant board based on STiH410 SoC: - 1GB DDR - On-Board USB combo WiFi/Bluetooth RTL8723BU with PCB soldered antenna - Ethernet 1000-BaseT - SATA - HDMI - 2 x USB2.0 type A - 1 x USB2.0 type micro-AB - SD card slot - High speed connector (SD/I2C/USB interfaces) - Low speed connector (UART/I2C/GPIO/SPI/PCM interfaces) Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-03-14armv8: fsl-layerscape: Add vid support for LS2080AQDSPriyanka Jain
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Signed-off-by: Arpit Goel <arpit.goel@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-03-14armv8: fsl-lsch3: Update VID supportPriyanka Jain
VID support in NXP layerscape Chassis-3 (lsch3) compilant SoCs like LS2088A, LS2080A differs from existing logic. -VDD voltage array is different -Registers are different -VDD calculation logic is different Add new function adjust_vdd() for LSCH3 compliant SoCs Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Signed-off-by: Arpit Goel <arpit.goel@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-03-14armv8: layerscape: Update early MMU for DDR after initializationYork Sun
In early MMU table, DDR has to be mapped as device memory to avoid speculative access. After DDR is initialized, it needs to be updated to normal memory to allow code execution. To simplify the code, dram_init() is moved into a common file as a weak function. Signed-off-by: York Sun <york.sun@nxp.com>
2017-03-14armv8: layerscape: Rewrite memory reservationYork Sun
For ARMv8 Layerscape SoCs, secure memory and MC memorey are reserved at the end of DDR. DDR is spit into two or three banks. This patch reverts commit aabd7ddb and simplifies the calculation of reserved memory, and moves the code into common SoC file. Secure memory is carved out first. DDR bank size is reduced. Reserved memory is then allocated on the top of available memory. U-Boot still has access to reserved memory as data transferring is needed. Device tree is fixed with reduced memory size to hide the reserved memory from OS. The same region is reserved for efi_loader. Signed-off-by: York Sun <york.sun@nxp.com>
2017-03-09TI: Migrate board/ti/common/Kconfig to implyTom Rini
The option that we had set in board/ti/common/Kconfig as default y are best done with imply under the appropriate main Kconfig option instead. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-09am335x_evm: Switch to using imply keywordTom Rini
These particular SPL options are part of what the ROM provides, but for compatibility with how we have previously used them, move them to being implied by the board being selected. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-02-17da850: Add instructions to copy AIS image to an MMC cardahaslam@baylibre.com
The da850 soc's can boot from a external mmc card, but the AIS image should be written to the correct sector. Add instructions to copy the AIS image to a MMC card. Signed-off-by: Axel Haslam <ahaslam@baylibre.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-02-17arm: am57xx: Set serial# variableSemen Protsenko
serial# variable is used to correctly display device ID in "fastboot devices". It also can be used further for displaying device ID in "adb devices" (should be passed as "androidboot.serialno" to kernel cmdline, via "bootargs" variable). Serial number generating algorithm is described at [1]. [1] http://lists.denx.de/pipermail/u-boot/2015-March/207462.html Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-02-11Merge git://git.denx.de/u-boot-samsungTom Rini
2017-02-10exynos: Drop large alignment for SDRAM parametersSimon Glass
We don't ever search for these so there is no need for a 4KB alignment. It just wastes space. Drop this and use the standard 4-byte alignment. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2017-02-09rockchip: rename miniarm to tinker boardEddie Cai
Miniarm is the internal project code. Now it is officially named Tinker board. So rename it. Signed-off-by: Eddie Cai <eddie.cai@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-02-09rockchip: Correct MAINTAINER entry for chromebook_minnieSimon Glass
This is wrong at present, so genboardscfg.py gives the following warnings: WARNING: no status info for 'chromebook_minnie' WARNING: no maintainers for 'chromebook_minnie' Fix it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-02-08Merge git://git.denx.de/u-boot-dmTom Rini
2017-02-08pcm052: fix DDR initialization sequenceAlbert ARIBAUD \(3ADEV\)
The sequence erroneously launched the DDR controller initialization before the pad muxing was done, causing DRAM size computation to hang. Configuring the pads first then launching DDR controller initialization prevents the DRAM hanging. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-02-07x86: qemu: Add a config for 64-bit U-BootBin Meng
Add a new board config which uses 64-bit U-Boot. Supported features are the same as the other 64-bit board (Google Chromebook Link). It is a start for us to test 64-bit U-Boot easily without the need to access a real hardware. Note CONFIG_SPL_ENV_SUPPORT is required for QEMU 64-bit as without this the SPL build fails at the end. This is just a workaround as CONFIG_SPL_ENV_SUPPORT is not needed at all. common/built-in.o:(.data.env_htab+0xc): undefined reference to 'env_flags_validate' lib/built-in.o: In function `hsearch_r': lib/hashtable.c:380: undefined reference to 'env_callback_init' lib/hashtable.c:382: undefined reference to 'env_flags_init' make[1]: *** [spl/u-boot-spl] Error 1 Except those SPL options required by 64-bit, compared to 32-bit config, the following options are different: - CONFIG_SYS_MALLOC_F_LEN has to be increased to 0x1000 for SPL. - CONFIG_DEBUG_UART has to be included due to the weird issue. See TODO comments in arch/x86/cpu/x86_64/cpu.c:arch_setup_gd(). Once this issue gets fixed, debug uart can be optional. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-02-07x86: qemu: Add a text base for 64-bit U-BootBin Meng
Set up the 64-bit U-Boot text base if building for that target. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-02-07x86: link: Add a config for 64-bit U-BootSimon Glass
Add a new board config which uses 64-bit U-Boot. This is not fully functional but is it a start. Missing features: - SDRAM sizing - Booting linux - EFI support - SCSI device init (and others) Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-02-07x86: link: Add a text base for 64-bit U-BootSimon Glass
Set up the 64-bit U-Boot text base if building for that target. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-02-03Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: configs/ls1046aqds_defconfig configs/ls1046aqds_nand_defconfig configs/ls1046aqds_qspi_defconfig configs/ls1046aqds_sdcard_ifc_defconfig configs/ls1046aqds_sdcard_qspi_defconfig configs/ls1046ardb_emmc_defconfig configs/ls1046ardb_qspi_defconfig configs/ls1046ardb_sdcard_defconfig
2017-02-03armv8: ls1012a: Add support of PPAPrabhakar Kushwaha
The PPA implements PSCI which requires for power managment. Added support of PPA for LS1012AQDS, LS1012ARDB and LS1012AFRDM. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Signed-off-by: Abhimanyu Saini <abhimanyu.saini@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-02-03board: freescale: ls1012a: Enable secure DDR on LS1012A platformsPrabhakar Kushwaha
PPA binary needs to be relocated on secure DDR, hence marking out a portion of DDR as secure if CONFIG_SYS_MEM_RESERVE_SECURE flag is set Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Signed-off-by: Abhimanyu Saini <abhimanyu.saini@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-02-01Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2017-02-01lib: tpm: Add command to flush resourcesMario Six
This patch adds a function to the TPM library, which allows U-Boot to flush resources, e.g. keys, from the TPM. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Stefan Roese <sr@denx.de>
2017-01-31armv7: ls1021aqds: Set cpo_sample for erratum A-009942York Sun
Set cpo_sample as suggested by the driver "WARN: pls set popts->cpo_sample = 0x58 in <board>/ddr.c to optimize cpo". Signed-off-by: York Sun <york.sun@nxp.com> CC: Shengzhou Liu <Shengzhou.Liu@nxp.com>
2017-01-30BOARD: MCCMON6: Provide support for iMX6q based mccmon6 boardLukasz Majewski
This patch provides u-boot support for Liebherr (LWN) mccmon6 board. Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-28ARM: SPI: stm32: add stm32f746 qspi driverMichael Kurz
This patch adds support for the QSPI IP found in stm32f7 devices. Signed-off-by: Michael Kurz <michi.kurz@gmail.com>
2017-01-28net: stm32: add designware mac glue code for stm32Michael Kurz
This patch adds glue code required for enabling the designware mac on stm32f7 devices. Signed-off-by: Michael Kurz <michi.kurz@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-01-28ARM: stm32: use clock setup function defined in clock.cMichael Kurz
Use the clock setup function defined in clock.c instead of setting the clock bits directly in the drivers. Remove register definitions of RCC in rcc.h as these are already defined in the struct in stm32.h Signed-off-by: Michael Kurz <michi.kurz@gmail.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Vikas Manocha <vikas.manocha@st.com>
2017-01-28ARM: stm32: cleanup stm32f7 filesMichael Kurz
Cleanup stm32f7 files: - use BIT macro - use GENMASK macro - use rcc struct instead of macro additions Add missing stm32f7 register in rcc struct Signed-off-by: Michael Kurz <michi.kurz@gmail.com> Acked-by: Vikas MANOCHA<vikas.manocha@st.com>
2017-01-28board/chiliboard: Add support for chiliBoardMarcin Niestroj
chiliBoard is a development board which uses chiliSOM as its base. Hardware specification: * chiliSOM (TI AM335x, DRAM, NAND) * Ethernet PHY (id 0) * USB host (usb1) * MicroSD slot (mmc0) Signed-off-by: Marcin Niestroj <m.niestroj@grinn-global.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-28aspeed: Support for ast2500 Eval Boardmaxims@google.com
ast2500 Eval Board device tree and board specific configuration. Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-28arm: Note vendor-required status of certain MACH_TYPE valuesTom Rini
In the cases of some boards, a MACH_TYPE number is used which is either not registered upstream or worse (for functionality) is re-using the number of a different (or reference) platform instead. Make sure we have a comment in these cases. Cc: Albert ARIBAUD <albert.aribaud@3adev.fr> Cc: Walter Schweizer <swwa@users.sourceforge.net> Cc: Stefan Roese <sr@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de>
2017-01-28arm: Clean up MACH_TYPE_xxx usage after re-sync of mach-typesTom Rini
With the latest mach-types values we have many instances where we no longer need to define a value and a few cases where the name (but not value) have changed slightly. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-28Revert "arm: Remove unregister MACH_TYPE_xxx uses"Tom Rini
This reverts commit 70b26cd057f42c7126088b49d4285955c8a00eae. This is not a strict revert as it is easier to fix board/atmark-techno/armadillo-800eva/armadillo-800eva.c to now the correct name (same value) than to revert that change too. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-27imx: mx6sxsabreauto: enable more dm driversPeng Fan
Enable MMC/I2C/GPIO/PMIC/REGULATOR/PCA953X DM drivers for mx6sxsabreauto board. Drop non-DM code. Note: The i.MX DM drivers has such dependency. MXC GPIO -> MXC I2C -> PFUZE/REGULATOR MXC GPIO -> PCA953X MXC GPIO -> FSL_USDHC So the drivers needs to be enabled all to avoid compiling error. The uboot dm tree log: => dm tree Class Probed Name ---------------------------------------- root [ + ] root_driver thermal [ ] |-- imx_thermal simple_bus [ + ] |-- soc simple_bus [ + ] | |-- aips-bus@02000000 simple_bus [ ] | | |-- spba-bus@02000000 gpio [ + ] | | |-- gpio@0209c000 gpio [ + ] | | |-- gpio@020a0000 gpio [ + ] | | |-- gpio@020a4000 gpio [ + ] | | |-- gpio@020a8000 gpio [ + ] | | |-- gpio@020ac000 gpio [ + ] | | |-- gpio@020b0000 gpio [ + ] | | |-- gpio@020b4000 simple_bus [ ] | | |-- anatop@020c8000 simple_bus [ ] | | |-- snvs@020cc000 pinctrl [ + ] | | `-- iomuxc@020e0000 pinconfig [ + ] | | `-- imx6x-sabreauto pinconfig [ + ] | | |-- i2c2grp-1 pinconfig [ + ] | | |-- i2c3grp-2 pinconfig [ ] | | |-- uart1grp pinconfig [ + ] | | |-- usdhc3grp pinconfig [ ] | | |-- usdhc3grp-100mhz pinconfig [ ] | | |-- usdhc3grp-200mhz pinconfig [ + ] | | |-- usdhc4grp pinconfig [ + ] | | `-- vccsd3grp simple_bus [ + ] | |-- aips-bus@02100000 mmc [ + ] | | |-- usdhc@02198000 mmc [ + ] | | |-- usdhc@0219c000 i2c [ + ] | | |-- i2c@021a4000 i2c_generic [ + ] | | | |-- generic_8 i2c_generic [ + ] | | | `-- generic_4e i2c [ + ] | | `-- i2c@021a8000 gpio [ + ] | | |-- gpio@30 gpio [ + ] | | `-- gpio@32 simple_bus [ ] | `-- aips-bus@02200000 simple_bus [ ] | `-- spba-bus@02200000 simple_bus [ + ] `-- regulators regulator [ + ] `-- regulator@0 Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2017-01-27ARM: imx6ul: Move liteSOM source to SoC directoryMarcin Niestroj
Moving arch/arm/mach-litesom/ to arch/arm/cpu/armv7/mx6/ was requested in [1] during discussion of chiliSOM support patches. [1] http://lists.denx.de/pipermail/u-boot/2017-January/279137.html Suggested-by: Tom Rini <trini@konsulko.com> Signed-off-by: Marcin Niestroj <m.niestroj@grinn-global.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-25Drop CONFIG_CMD_DOCSimon Glass
This is not used in U-Boot, and the only usage calls a non-existent function. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
