ti-u-boot-2013.01.01-amsdk-05.07.00.00
Enable DDR PHY dynamic power down bit, which enables
powering down the IO receiver when not performing read.
This also helps in reducing overall power consumption in
low power states (suspend/standby).
Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com>
Signed-off-by: Satyanarayana, Sandhya <sandhya.satyanarayana@ti.com>
Cc: Tom Rini <trini@ti.com>
Reviewed-by: Tom Rini <trini@ti.com>
arch/arm/cpu/armv7/omap-common/boot-common.c
board/ti/am335x/board.c
We add USB (RNDIS gadget) SPL support as a separate target. We need to
pull out YMODEM support in order to be a small enough target binary.
We need to allow for a further call-out in spl_board_init. For now,
call this am33xx_spl_board_init. This function will depending on board
see if we know how to scale the core frequency up to 720MHz.
This is mostly copied from "support for TPS65217 PMIC" patches from the
old am33xx U-boot tree by Greg Guyyote with additions by Tom Rini, me
and others.
[trini: Remove the change that ...
Also drop DDR3 voltage level from 1.5V to 1.35V for beaglebone. DDR3
operation is verified at this lower voltage level.]
Signed-off-by: Joel A Fernandes <joelagnel@ti.com>
Adding new board files for DRA7XX socs.
The pad registers layout is changed completely from OMAP5
So introducing the new structure here and also adding the
minimal data.
Signed-off-by: Nishant Kamat <nskamat@ti.com>
Signed-off-by: R Sricharan <r.sricharan@ti.com>
This adds necessary config options and a new build target,
am335x_evm_usbspl, to enable usb booting and fixes board_eth_init()
function to take into account that we may have USB ether support in SPL
now. This uses the same MAC for both cpsw and USB, in order to match
ROM behavior.
The usbspl build target does not contain UART SPL, CPSW SPL or extra
environment settings, so that we may fit within our binary size
constraint.
In commit cfd4ff6 we implemented part of advisory 1.0.10 (internal delay
for RGMII mode not supported). This in turn however requires that we
set the tx clock delay feature in the PHY itself.
AM335x EVM 1.5A uses Micron MT41J512M8RH-125 SDRAM 4Gb (512Mx8) as the
DDR3 chip.
[Hebbar Gururaja <gururaja.hebbar@ti.com>]
- Resolve merge conflict while rebasing. File structure is
changed in the mainline. So re-arrange the code accordingly.
- Update commit message to reflect the DDR3 part number
Signed-off-by: Jeff Lance <j-lance1@ti.com>
Signed-off-by: Hebbar Gururaja <gururaja.hebbar@ti.com>
Add DVI output support and make it the default video output.
Currently the CLAA WVGA panel is supported, but this panel has to be purchased
separately, so using the DVI output as the default would allow more people to
try the splash screen feature on a mx51evk.
If someone still wants to use the CLAA WVGA, just set the panel variable as:
set panel claa
Use a common watchdog driver for all these cpus.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
u-boot compilation fails for smdk5250 when we deselect CONFIG_LCD
from the main config file.
Following error was observed:
drivers/video/libvideo.o: In function `exynos_lcd_init':
/home/ajay/u-boot-samsung/drivers/video/exynos_fb.c:68: undefined reference to `lcd_set_flush_dcache'
This is because exynos video drivers have dependency on CONFIG_LCD.
Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com>
Add panel_info structure required by LCD driver
and DP panel platdata for SMDK5250.
Add GPIO configuration for LCD.
Enable FIMD and DP support on SMDK5250.
DP Panel size: 2560x1600.
We use 16BPP resolution to get LCD console.
Acked-by: Simon Glass <sjg@chomium.org>
Add device node for MAX77686
Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com>
Add support for the Seiko 4.3'' WVGA panel on mx53loco.
By default, the CLAA WVGA panel is selected.
In order to support the Seiko panel, the enviroment variable 'panel' must be
set to 'seiko'.
Instead of using the serverip we get from the DHCP server, implicitly use
the broadcast address, which is automatically set when no ncip environment
variable is set. That way it isn't necessary to use a special DHCP
configuration to set the netconsole peer.
Signed-off-by: Michael Walle <michael@walle.cc>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
This saves stack and code memory for local copy, and
consumes initialized data memory. For 22 of the 29
kirkwood-based boards, this results in a global saving
of about 30 bytes. For 7 of them, it results in an
increase of 6 to 14 bytes.
This patch removes 2 small portions of board specific code that are
duplicated with common ARM code and thus unnecessary. These 2 portions
of code concern the mach id that is given by u-boot to the Linux kernel
to identify the system's MACH.
The first one was the possibility to change the MACH thanks to the
'mach_id' enviroment variable. This is possible thanks to the 'machid'
env variable (see arch/arm/lib/bootm.c:boot_jump_linux()).
The seconde one is the setting of the bi_arch_number. This is already
done in arch/arm/lib/board.c:board_init_f() since km_arm.h does #define
CONFIG_MACH_TYPE.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Holger Brunck <holger.brunck@keymile.com>
cc: Prafulla Wadaskar <prafulla@marvell.com>
Acked-by: Prafulla Wadaskar <Prafulla@marvell.com>
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
On kmcoge5un we faced some serious problems with the memory during
temperature tests. Reason was that we overwrite some registers for
memory settings which have to leave untouched. These where registers
0x20148 , 0x2014c and 0x20154.
So writing these registers is prohibited and this patch removes them
from all km related config files. Even if the problem was only
seen on kmcoge5un.
This required manual merging drivers/mtd/nand/Makefile
and adding am335x_evm support for CONFIG_SPL_NAND_DRIVERS
This patch enables Vbus required for USB 2.0 controller.
Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com>
This patch adds aliases for SPI.
Adds sound and codec device node parameters
Signed-off-by: R. Chandrasekar <rcsekar@samsung.com>
This patch initialises I2C using FDT.
Acked-by: Heiko Schocher <hs@denx.de>
This patch adds aliases for I2C.
Make the error handling more robust.
Check if each one of the PMIC writes fail and if they do, just return
immediately.
Also, print the cause for the failures.
commit c73368150 (pmic: Extend PMIC framework to support multiple instances
of PMIC devices) introduced an extra 'retval' variable, but this is not
necessary since we have already the variable 'ret' in place.
So use 'ret' to store the return values from the pmic related calls and remove
'retval'.
The on-board number of available usdhc devices is something board
specific. The patch moves CONFIG_SYS_FSL_USDHC_NUM out of
mx6qsabre_common.h and adds usdhc2 and usdhc4 support for mx6qsabresd
board.
To keep the default mmc device for environment same as before (usdhc3),
it moves CONFIG_SYS_MMC_ENV_DEV out of mx6qsabre_common.h and changes
it to 1 for mx6qsabresd.
Use IMX_GPO_NR macro
Signed-off-by: Ashok Kumar Reddy <ashokkourla2000@gmail.com>
FALCON MODE
Support for a new command (defined at envs) - spl_export generates
the ATAGS image necessary for fast boot. Afterwards, it is stored
at ext4 partition.
Generated image format:
CRC [4B] SIZE [4B] PAYLOAD(ATAGS/DT) [SIZE]
Remarks:
- CRC is calculated only for PAYLOAD
- SIZE is the size of PAYLOAD
It is important to adjust ${splsize} when large image is generated.
It is defined as hex, since ext4 related commands expect it.
The ${spladdr} environment variable corresponds to
CONFIG_SYS_SPL_ARGS_ADDR
Additionally definitions for DFU have been refactored and support for
EFI has been added as well.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Since commit c733681 (pmic: Extend PMIC framework to support multiple instances
of PMIC devices) mx53loco fails to allocate the memory for PMIC:
U-Boot 2013.01-rc2-dirty (Dec 20 2012 - 15:55:01)
Board: MX53 LOCO
I2C: ready
DRAM: 1 GiB
pmic_alloc: No available memory for allocation!
pmic_init: POWER allocation error!
CPU: Freescale i.MX53 family rev2.0 at 800 MHz
Reset cause: POR
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Calling the PMIC related functions at a later stage, ie, from board_late_init()
fixes the issue.
Reported-by: Robert Nelson <robertcnelson@gmail.com>
Tested-by: Stefano Babic <sbabic@denx.de>
Add device tree based ethernet driver for SMC911X controller on
SMDK5250 boards.
Signed-off-by: Hatim Ali <hatim.rv@samsung.com>
This patch adds initial dts file for EXYNOS5250 SoC. This dts
file currently include only ethernet devices and properties. More
devices to be added in subsequent patches.
Also add the dts file for SMDK5250 board which uses the EXYNOS5250
dts file.
This commit merges branches from samsung, imx and tegra
meant to fix merge issues between u-boot/master and
u-boot-arm/master, as well as a few manual merge fixes.
Update usb host support to use new version of omap_ehci_hcd_init.
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
Add support for USB host ports on cm-t3530 and cm-t3730.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
