Some DDR related structures present in fsl_ddr_dimm_params.h, fsl_ddr_sdram.h, ddr_spd.h
has various parameters with embedded acronyms capitalized that trigger the CamelCase
warning in checkpatch.pl
Convert those variable names to smallcase naming convention and modify all files
which are using these structures with modified structures.
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
Use a default RCW of protocol 0x2A_0x98, and a PBI configure file which
uses CPC1 as 512KB SRAM, then PBL tool can be used on B4860 to build a
pbl boot image.
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
Default configuration has been changed, the most important one is DDR
ref_clock which is changed from 66.67MHz to 133.33MHz. so the ratio need to
change from 24x to 12x to keep the DDR frequency. There are also some
other optimise to align with default configuration.
Enable TPL for p1_p2_rdb_pc nand boot.
Signed-off-by: Ying Zhang <b40530@freescale.com>
Enable p1_p2_rdb_pc to start from eSPI with SPL.
Enable p1_p2_rdb_pc to start from eSDHC with SPL.
Fix PHY addresses for QSGMII Riser Card working in
SGMII mode on board P3041/P5020/P4080/P5040/B4860.
QSGMII Riser Card can work in SGMII mode, but
having the different PHY addresses.
So the following steps should be done:
1. Confirm whether QSGMII Riser Card is used.
2. If yes, set the proper PHY address.
Generally, the function is_qsgmii_riser_card() is
for step 1, and set_sgmii_phy() for step 2.
However, there are still some special situations,
take P5040 and B4860 as examples, the PHY addresses
need to be changed when serdes protocol is changed,
so it is necessary to confirm the protocol before
setting PHY addresses.
Signed-off-by: Zhao Qiang <B45475@freescale.com>
SGMII5/6 and SGMII7/8 are not on the same slot on P5040
according to the serdes protocol.
So it is not proper to organize SGMII5/6 and SGMII7/8
on one bus and SGMII5/6 can't work.
So a new bus SUPER_HYDRA_FM3_SGMII_MDIO is added for
SGMII5/6
DDR parameters clk_adjust were changed. This can make the DDR
run more stable. The new value were gotten by the DDR testing
tool.
Signed-off-by: Po Liu <Po.Liu@freescale.com>
[trini: Drop changes for PEP 4 following python tools]
Add a MAC address create based on the OMAP die ID registers.
Then poplulate the ethaddr enviroment variable so that the device
tree alias can be updated prior to boot.
Signed-off-by: Dan Murphy <dmurphy@ti.com>
'actual_bank' is not used anymore, instead boot_bank is used.
Signed-off-by: Andreas Huber <andreas.huber@keymile.com>
commit a5510058 powerpc/83xx/km: make local functions and structs static
removed the staticness also from this struct. But this struct is needed
in arch/powerpc/cpu/mpc83xx/cpu_init.c and declared as extern.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
Adding the generated pin mux configuration by Preloader
Generator tool
Signed-off-by: Chin Liang See <clsee@altera.com>
Reviewed-by: Pavel Machek <pavel@denx.de>
Acked-by: Dinh Nguyen <dinguyen@altera.com>
CC: Pavel Machek <pavel@denx.de>
Cc: Dinh Nguyen <dinguyen@altera.com>
Cc: Tom Rini <trini@ti.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Adding System Manager driver which will configure the
pin mux for real hardware Cyclone V development kit
(not Virtual Platform)
omap1510inn is orphan and has been for years now.
Reove it and, as it was the only arm925t target,
also remove arm925t support.
Update doc/README.scrapyard accordingly.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Enables support for SPI SPL, QSPI and Spansion serial flash device
on the EVM. Configures pin muxes for QSPI mode.
Signed-off-by: Matt Porter <matt.porter@linaro.org>
Signed-off-by: Sourav Poddar <sourav.poddar@ti.com>
Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
Since 2bf36ac638ab2db9f0295aa47064976eeebf80c1 the BD ram address is
not hardcoded inside cpsw driver any more. Platforms have to supply
their bd_ram_ofs in the platform data to the driver. This commit does
this for pcm051 and igep0033 boards.
Tested-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
We can run the DDR at 400MHz, so update the timings for that purpose.
Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
Reviewed-by: Javier Martinez Canillas <javier@dowhile0.org>
To enable hypervisors utilizing the ARMv7 virtualization extension
on the Versatile Express board with the A15 core tile, we add the
required configuration variable.
Also we define the board specific smp_set_cpu_boot_addr() function to
set the start address for secondary cores in the VExpress specific
manner.
There is no need to provide a custom smp_waitloop() function here.
This also serves as an example for what to do when adding support for
new boards.
Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
If smc911x_initialize() fails we should return the error immediately.
While at it, also check the error from cpu_eth_init().
If cpu_eth_init() fails we should return the error immediately.
This patch add support for a new Samsung board Trats2.
Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com>
CC: Lukasz Majewski <l.majewski@samsung.com>
Add RNDIS gadget support to test atmel usba udc driver
Signed-off-by: Bo Shen <voice.shen@atmel.com>
This patch enables default I2S0 channel.And I2S platform
parameter has been moved to a common file viz exynos5.dtsi.
Signed-off-by: Dani Krishna Mohan <krishna.md@samsung.com>
In Errata 1.0.24, if the board is running at OPP50 and has a warm reset,
the boot ROM sets the frequencies for OPP100. This patch attempts to
drop the frequencies back to OPP50 as soon as possible in the SPL. Then
later the voltages and frequencies up set higher.
Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com>
Cc: Lars Poeschel <poeschel@lemonage.de>
Signed-off-by: Steve Kipisz <s-kipisz2@ti.com>
[trini: Adapt to current framework]
Add a am33xx_spl_board_init (and enable the PMICs) that we may see,
depending on the board we are running on. In all cases, we see if we
can rely on the efuse_sma register to tell us the maximum speed. In the
case of Beaglebone White, we need to make sure we are on AC power, and
are on later than rev A1, and then we can ramp up to the PG1.0 maximum
of 720Mhz. In the case of Beaglebone Black, we are either on PG2.0 that
supports 1GHz or PG2.1. As PG2.0 may or may not have efuse_sma set, we
cannot rely on this probe. In the case of the GP EVM, EVM SK and IDK we
need to rely on the efuse_sma if we are on PG2.1, and the defaults for
PG1.0/2.0.
Fix the following checkpatch warning:
$ ./tools/checkpatch.pl -F board/freescale/mx28evk/mx28evk.c
CHECK: Alignment should match open parenthesis
#109: FILE: freescale/mx28evk/mx28evk.c:109:
+ writel(CLKCTRL_ENET_TIME_SEL_RMII_CLK | CLKCTRL_ENET_CLK_OUT_EN,
+ &clkctrl_regs->hw_clkctrl_enet);
mx6slevk has a SMSC8720 connected in RMII mode.
Add support for it.
Currently board_eth_init() always return 0, but we should propagate the error
when cpu_eth_init() fails.
If a HDMI cable is not connected, the following message is seen on boot:
CPU: Freescale i.MX6Q rev1.1 at 792 MHz
Reset cause: POR
Board: MX6-SabreSD
DRAM: 1 GiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
No panel detected: default to HDMI
unsupported panel HDMI
Reset the 'i' variable to fix the 'unsupported panel' message.
This follows the same idea of commit 47ac53d7ae (imx: nitrogen6x/mx6qsabrelite:
Fix bug in board_video_skip).
Since commit d9b894603 (mx6sabresd: Add LVDS splash screen support) the
following hang happens if the HDMI cable is not connected or the 'panel'
variable is not set:
U-Boot 2013.10-rc2-12978-g47ac53d-dirty (Sep 11 2013 - 15:07:38)
CPU: Freescale i.MX6Q rev1.2 at 792 MHz
Reset cause: POR
Board: MX6-SabreSD
DRAM: 1 GiB
Provide a check to 'dev->detect' in order to prevent the hang.
Reported-by: Pardeep Kumar Singla <b45784@freescale.com>
Suggested-by: Eric BĂ©nard <eric@eukrea.com>
The SPDX License List version 1.19 now contains an official entry for
the IBM-pibs license. However, instead of our suggestion "ibm-pibs",
the SPDX License List uses "IBM-pibs", with the following rationale:
"The reason being that all other SPDX License List short identifiers
tend towards using capital letters unless spelling a word. I'd prefer
to be consistent to this end".
Change the license IDs to use the official name.
Fix various misspellings of things like "environment", "kernel",
"default" and "volatile", and throw in a couple grammar fixes.
MAINTAINERS
boards.cfg
tools/Makefile
