It looks like we had a merge issue that duplicated a bit of code
in ft_board_setup. Also, we need to set CONFIG_HAS_ETH0 to get
the MAC address properly set in the device tree on boot for TSEC1
bzip2 requires a significant chunk of malloc space, and there isn't
enough room on mpc885ads (with only 8MB RAM) for both bzip2's malloc area
and a downloaded image at 0x400000.
This small CPCI750 update extends the board specific command
"show_config" to display the Marvell strapping registers and
extends the PCI IDE controller.
Signed-off-by: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
Minor path corrections needed to ensure buildability.
Signed-off-by: Sergey Kubushyn <ksi@koi8.net>
Merge to two at45.c files into a common file, split to at45.c and spi.c
Fix spelling error in DM9161 PHY Support.
Initialize at91rm9200 board (and set LED).
Add PIO control for at91rm9200dk LEDs and Mux.
Change dataflash partition boundaries to be compatible with Linux 2.6.
Signed-off-by: Peter Pearse <peter.pearse@arm.com>
Signed-off-by: Ulf Samuelsson <ulf@atmel.com>
The PCI ID select values on the Arcadia main board differ depending
on the version of the hardware. The standard configuration supports
Rev 3.1. The legacy target supports Rev 2.x.
Signed-off-by Randy Vinson <rvinson@mvista.com>
Author: Randy Vinson <rvinson@linuxbox.(none)>
Enable the PCI-to-ISA bridge in the VIA Southbridge located on the
Arcadia main board.
Signed-off-by: Randy Vinson <rvinson@mvista.com>
Signed-off-by: York Sun <yorksun@freescale.com>
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
This patch is against u-boot-mpc85xx.git of www.denx.com
Signed-off-by: Ebony Zhu <ebony.zhu@freescale.com>
Some patches had inserted warnings into the build:
* mpc8560ads declared data without using it
* cpu_init declared ecm and immap without using it in all CONFIGs
* MPC8548CDS.h had its default filenames changed so that they contained
"\m" in the paths. Made the defaults not Windows-specific (or
anything-specific)
Make the early L1 cache stack region guarded to prevent speculative
fetches outside the locked range.
Use _PHYS defines, not _MEM for cpu-side PCI memory mapped regions.
init.S whitespace cleanup.
Allow TEXT_BASE value to be specified on command line. This allows it
to be set to 0xfffc0000 which cuts the uboot binary in half.
Clear and enable lbc and ecm errors.
Update last_busno in device-tree for pci and pcie.
Remove load of obsolete cpu/mpc85xx/pci.0
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Acked-by: Andy Fleming <afleming@freescale.com>
PCI1 LAW mapping should use CFG_PCI1_MEM_PHY and not _BASE address.
Enable LBC and ECM errors and clear error registers.
Add tftpflash env var to get uboot from tftp server and flash it.
Add pci/pcie convenience env vars to display register space:
"run pcie3regs" to see all pcie3 ccsr registers
"run pcie3cfg" to see all cfg registers
Whitespace cleanup and MPC8544DS.h
Enable CONFIG_INTERRUPTS.
MAKEALL
With any luck, this is the last MAKEALL merge conflict!
PCI-Express sockets 1 and 2 verified working with Intel Pro/1000 PT
adapter.
Signed-off-by: Joe Hamman <joe.hamman@embeddedspecialties.com>
Signde-off-by: Jon Loeliger <jdl@freescale.com>
The update procedure was modified to turn off the USB subsystem
before exit for MCC200 and TRAB. This is necessary as otherwise the
USB controller continues to write periodically to system memory!
MCC200-specific notes:
- the patch disables the magic key check for MCC200
- the patch contains the configuration changes made
for the new revision of the board.
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
Add support for Wind River's SBC8641D reference board.
Signed-off by: Joe Hamman <joe.hamman@embeddedspecialties.com>
Acked-by: Wolfgang Denk <wd@denx.de>
Acked-by: Jon Loeliger <jdl@freescale.com>
Add support for the following DaVinci boards:
- DV_EVM
- SCHMOOGIE
- SONATA
Changes:
- Split into separate board directories
- Removed changes to MTD_DEBUG (or whatever it's called)
- New CONFIG_CMD party line followed
- Some cosmetic fixes, cleanup etc.
- Patches against the latest U-Boot tree as of now.
- Fixed CONFIG_CMD_NET in net files.
- Fixed CONFIG_CMD_EEPROM for schmoogie.
- Made sure it compiles and works (forceenv() link problem) on SCHMOOGIE and
DV_EVM. Can't check if it works on SONATA, don't have a board any more,
but it at least compiles.
Here is an excerpt from session log on SCHMOOGIE...
U-Boot 1.2.0-g6c33c785-dirty (Aug 7 2007 - 13:07:17)
DRAM: 128 MB
NAND: 128 MiB
In: serial
Out: serial
Err: serial
ARM Clock : 297MHz
DDR Clock : 162MHz
ETH PHY : DP83848 @ 0x01
U-Boot > iprobe
Valid chip addresses: 1B 38 3A 3D 3F 50 5D 6F
U-Boot > ping 192.168.253.10
host 192.168.253.10 is alive
U-Boot >
Acked-by: Dirk Behme <dirk.behme@gmail.com>
Acked-by: Zach Sadecki <Zach.Sadecki@ripcode.com>
When I rebased Ed's patch and cleaned up a few compilation
problems, I apparently rebased my brain on crack first.
Fix that by doing (char *) sized pointer math as needed.
Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
make: *** No rule to make target `/work/wd/tmp/board/mpc8349itx/u-boot.lds', needed by `/work/wd/tmp/u-boot'. Stop.
Both the ITX and ITX-GP fail when you use "make O=<some dir> ..." or
"BUILD_DIR=<some dir> ./MAKEALL ..."
Remove the duplicated source code of ecc command on the <board>.c,
for reused, move these code to cpu/mpc83xx directory.
Signed-off-by: Dave Liu <daveliu@freescale.com>
MPC8323E based board with 64MB fixed SDRAM, 16MB flash,
five 10/100 ethernet ports connected via an ICPlus IP175C
switch, one PCI slot, and serial. Features not supported
in this patch are SD card interface, 2 USB ports, and the
two phone ports.
Signed-off-by: Michael Barkowski <michael.barkowski@freescale.com>
..and not the global fdt. Rename local fdt vars to blob so as not to
be confused with the global var with the same three-letter name.
The new name matches more closely the kernel's name, which is also
a much better description.
These are the mpc83xx changes made necessary by the function name change.
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
Acked-by: Gerald Van Baren <vanbaren@cideas.com>
This change adds 8360 silicon revision 2.1 support to u-boot.
Signed-off-by: Lee Nipper <lee.nipper@freescale.com>
