path: root/board
2014-07-23stdio: Pass device pointer to stdio methodsSimon Glass
At present stdio device functions do not get any clue as to which stdio device is being acted on. Some implementations go to great lengths to work around this, such as defining a whole separate set of functions for each possible device. For driver model we need to associate a stdio_dev with a device. It doesn't seem possible to continue with this work-around approach. Instead, add a stdio_dev pointer to each of the stdio member functions. Note: The serial drivers have the same problem, but it is not strictly necessary to fix that to get driver model running. Also, if we convert serial over to driver model the problem will go away. Code size increases by 244 bytes for Thumb2 and 428 for PowerPC. 22: stdio: Pass device pointer to stdio methods arm: (for 2/2 boards) all +244.0 bss -4.0 text +248.0 powerpc: (for 1/1 boards) all +428.0 text +428.0 Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Marek Vasut <marex@denx.de>
2014-07-23stdio: Remove redundant code around stdio_register() callsSimon Glass
There is no point in setting a structure's memory to NULL when it has already been zeroed with memset(). Also, there is no need to create a stub function for stdio to call - if the function is NULL it will not be called. This is a clean-up, with no change in functionality. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2014-07-22m68k: fix an undefined behavior warning of M5253DEMO boardMasahiro Yamada
The latest GCC is so clever that it reports more warnings than old ones did: ------------------------------>8------------------------------ board/freescale/m5253demo/flash.c: In function 'flash_get_offsets': board/freescale/m5253demo/flash.c:65:23: warning: iteration 2047u invokes undefined behavior [-Waggressive-loop-optimizations] info->start[k + 1] = info->start[k] + CONFIG_SYS_SST_SECTSZ; ^ board/freescale/m5253demo/flash.c:64:3: note: containing loop for (k = 0, j = 0; j < CONFIG_SYS_SST_SECT; j++, k++) { ^ ------------------------------8<------------------------------ The cause of the warning is like this: The for statement iterates 2048 times in flash_get_offsets() func. (Notice CONFIG_SYS_SST_SECT is defined as 2048) The last iteration does info->start[2048] = info->start[2047] + CONFIG_SYS_SST_SECTSZ; causing an undefined behavior. (Please note the array size of info->start is 2048. CONFIG_SYS_MAX_FLASH_SECT is defined as 2048 for this board.) This commit fixes that so as not to overrun the info->start array. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Jason Jin <Jason.jin@freescale.com>
2014-07-22sparc: merge LEON2 and LEON3 linker scriptsMasahiro Yamada
There is only one line diff between LEON2 and LEON3 linker scripts: - arch/sparc/cpu/leon2/start.o (.text) + arch/sparc/cpu/leon3/start.o (.text) They can be written in the same way: */start.o (.text) So, board/gaisler/grsim_leon2/u-boot.lds and arch/sparc/cpu/leon3/u-boot.lds can be merged into arch/sparc/cpu/u-boot.lds. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Daniel Hellstrom <daniel@gaisler.com>
2014-07-22sparc: merge LEON3 linker scriptsMasahiro Yamada
The linker scripts of LEON3 - board/gaisler/grsim/u-boot.lds - board/gaisler/gr_cpci_ax2000/u-boot.lds - board/gaisler/gr_ep2s60/u-boot.lds - board/gaisler/gr_xc3s_1500/u-boot.lds are the same (except cosmetic differences such as indentation). This commit merges them into arch/sparc/cpu/leon3/u-boot.lds. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Daniel Hellstrom <daniel@gaisler.com>
2014-07-22esd:cmd_loadpci.c: Switch from "do_source" to "source"Tom Rini
Rather than calling do_source directly (which is not officially exported from cmd_source.c) call 'source' which is exported and requires a little less code to do so as well. Signed-off-by: Tom Rini <trini@ti.com>
2014-07-18board: rpi_b: include mmc header and fix prototypeJeroen Hofstee
While at it add fdt_support.h as well. cc: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-07-14ARM: DRA7xx: Update the board_name env variableLokesh Vutla
Update the board_name env variable and accordingly populate the dtb file. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2014-07-07board: iocon: Modify iocon hardware startupDirk Eibach
To avoid peer "ChReceivePathStatus"-messages on iocon startup, initialize PHYs as soon as possible. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2014-07-07board: gdsys: Enable scrambling on DP501Dirk Eibach
For proper displayport performance, scrambling has to be enabled, but is turned off on DP501 by default. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2014-07-07board: gdsys: Make gdsys osd hardware detection more robustDirk Eibach
2014-07-07board: gdsys: Configure bridge on DP501 to support DDC onlyDirk Eibach
The I2C bridge on DP501 supports EDID, MCCS and HDCP by default. Allow EDID only to avoid I2C address conflicts. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2014-07-07board: iocon: Support DisplayPort hardwareDirk Eibach
There is a new iocon hardware flavor, supporting DisplayPort finally. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2014-07-07board: controlcenterd: Use new API for setting i2c busDirk Eibach
2014-07-07board: gdsys: Adapt sdhc_boot.c to mmc_get_env_addr API changeDirk Eibach
2014-07-07board: controlcenterd: Fix pci accessDirk Eibach
readl was called with values instead of pointers to these values. Why this ever did work is a mystery... Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2014-07-07mpc8xx: remove spc1920 board supportMasahiro Yamada
This board is old enough and has no maintainer. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-07mpc8xx: remove v37 board supportMasahiro Yamada
2014-07-07mpc8xx: remove fads board supportMasahiro Yamada
These boards are old enough and have no maintainers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-07mpc8xx: remove netta, netta2, netphone board supportMasahiro Yamada
2014-07-07mpc8xx: remove rbc823 board supportMasahiro Yamada
2014-07-07mpc8xx: remove RPXlite_dw, quantum board supportMasahiro Yamada
2014-07-07mpc8xx: remove qs850, qs860t board supportMasahiro Yamada
2014-07-07vcma9/lowlevel_init.S: trivial: terminate commentJeroen Hofstee
2014-07-07am43xx: Tune the system to avoid DSS underflowsCooper Jr., Franklin
* This is done by limiting the ARM's bandwidth and setting DSS priority in the EMIF controller to ensure underflows do not occur.
2014-07-07am43xx: Update EMIF DDR3 Configuration for AM43x GPFranklin S. Cooper Jr
* Boot failures have been discovered due to a combination of routing issues and non optimal ddr3 timings in the EMIF * Since ddr3 timings are different after significant board layout changes different timings are required for alpha, beta and production boards. Signed-off-by: Franklin S. Cooper Jr <fcooper@ti.com>
2014-07-07board: ti: dra7xx: add mux data for UART3Felipe Balbi
J6 EVM can be built with UART3 as console, but currently there's nothing muxing UART3 correctly. Likely this only works because, based on commit log, author was only testing with UART3 boot and - I assume - ROM code leave UART3 correctly muxed in that case. If we want to boot from MMC and still use UART3 as console, then we need to mux those signals correctly. Signed-off-by: Felipe Balbi <balbi@ti.com>
2014-07-05socfpga: Relocate arch common functions away from boardChin Liang See
To move the arch common function away from board folder to arch/arm/cpu/armv7/socfpga folder. Its to avoid code duplication for other non Altera dev kit which is using socfpga device. Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Pavel Machek <pavel@denx.de> Cc: Dinh Nguyen <dinguyen@altera.com> Acked-by: Detlev Zundel <dzu@denx.de>
2014-07-05socfpga: Adding Scan Manager driverChin Liang See
Scan Manager driver will be called to configure the IOCSR scan chain. This configuration will setup the IO buffer settings Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Wolfgang Denk <wd@denx.de> CC: Pavel Machek <pavel@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2014-07-04arm: ep9315: Return back Cirrus Logic EDB9315A board supportSergey Kostanbaev
This patch returns back support for old ep93xx processors family Signed-off-by: Sergey Kostanbaev <sergey.kostanbaev@gmail.com> Cc: albert.u.boot@aribaud.net
2014-07-04ARMv8/ls2085a_emu: Add LS2085A emulator and simulator board supportYork Sun
LS2085A is an ARMv8 implementation. This adds board support for emulator and simulator: Two DDR controllers UART2 is used as the console IFC timing is tightened for speedy booting Support DDR3 and DDR4 as separated targets Management Complex (MC) is enabled Support for GIC 500 (based on GICv3 arch) Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Arnab Basu <arnab.basu@freescale.com> Signed-off-by: J. German Rivera <German.Rivera@freescale.com> Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com>
2014-07-03arm: Add support for semihosting for armv8 fastmodel targets.Darwin Rambo
The armv8 ARM Trusted Firmware (ATF) can be used to load various ATF images and u-boot, and does this for virtual platforms by using semihosting. This commit extends this idea by allowing u-boot to also use semihosting to load the kernel/ramdisk/dtb. This eliminates the need for a bootwrapper and produces a more realistic boot sequence with virtual models. Though the semihosting code is quite generic, support for armv7 in fastmodel is less useful due to the wide range of available silicon and the lack of a free armv7 fastmodel, so this change contains an untested armv7 placeholder for the service trap opcode. Please refer to doc/README.semihosting for a more detailed description of semihosting and how it is used with the armv8 virtual platforms. Signed-off-by: Darwin Rambo <drambo@broadcom.com> Cc: trini@ti.com Cc: fenghua@phytium.com.cn Cc: bhupesh.sharma@freescale.com
2014-07-01Merge remote-tracking branch 'u-boot-samsung/master'Albert ARIBAUD
Conflicts: boards.cfg Conflict was trivial between goni maintainer change and lager_nor removal.
2014-07-01Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-06-30Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-06-25Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-06-19omap3: overo: Select fdtfile for expansion boardAsh Charles
The u-boot Overo board actually supports both Overo (OMAP35xx) and Overo Storm (AM/DM37xx) COMs with a range of different expansion boards. This provides a mechanism to select the an appropriate device tree file based on the processor version and, if available, the expansion board ID written on the expansion board EEPROM. To match the 3.15+ kernels, fdtfile names have this format: "omap3-overo[-storm]-<expansion board name>.dtb" By default, we use "omap3-overo-storm-tobi.dtb". Signed-off-by: Ash Charles <ashcharles@gmail.com> Conflicts: include/configs/omap3_overo.h
2014-06-19board: ti: am43xx: enable QSPI and Gbit Ethernet on AM437x SKFelipe Balbi
AM437x Starter Kit has a qspi flash and gbit ethernet support. By muxing those signals, we can use those interfaces from u-boot. Signed-off-by: Felipe Balbi <balbi@ti.com>
2014-06-19board: ti: am43xx: add AM437x SK PHY AddressFelipe Balbi
pass correct PHY Address when running on SK so that we have working ethernet with this board too. Signed-off-by: Felipe Balbi <balbi@ti.com>
2014-06-19board: ti: am43xx: add support for AM43xx Starter KitFelipe Balbi
AM43xx Starter Kit is a new board based on AM437x line of SoCs. Being a low-cost EVM and small size EVM are intended to provide an entry level development platform on a full fledged Hardware System. Signed-off-by: Felipe Balbi <balbi@ti.com>
2014-06-19board: ti: am43xx: print unsupported board nameFelipe Balbi
when porting u-boot to a new am43xx board, it helps to know the name of the current unsupported board so we don't have to hunt for design documents to figure out what's written in the EEPROM. Signed-off-by: Felipe Balbi <balbi@ti.com>
2014-06-19ARM: keystone: aemif: move aemif driver to drivers/memory/ti-aemif.cKhoronzhuk, Ivan
Move AEMIF driver to drivers/memory/ti-aemif.c along with AEMIF definitions collected in arch/arm/include/asm/ti-common/ti-aemif.h Acked-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-06-19mtd: nand: davinci: add header file for driver definitionsKhoronzhuk, Ivan
The definitions inside emif_defs.h concern davinci nand driver and should be in it's header. So create header file for davinci nand driver and move definitions from emif_defs.h and nand_defs.h to it. Acked-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com> [trini: Fixup more davinci breakage] Signed-off-by: Tom Rini <trini@ti.com>
2014-06-19Remove nios-32 arch remnantsVasili Galka
nios-32 arch was removed back in 2010 (1117cbf). Code depending on its headers (nios.h, nios-io.h) can't possibly compile since then. As it wasn't fixed till now it is safe to remove. Signed-off-by: Vasili Galka <vvv444@gmail.com>
2014-06-19includes: move openssl headers to include/u-bootJeroen Hofstee
commit 18b06652cd "tools: include u-boot version of sha256.h" unconditionally forced the sha256.h from u-boot to be used for tools instead of the host version. This is fragile though as it will also include the host version. Therefore move it to include/u-boot to join u-boot/md5.h etc which were renamed for the same reason. cc: Simon Glass <sjg@chromium.org> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-06-19freescale: m5253demo: fix unused-but-set-variable warningsMasahiro Yamada
Fix the following warning messages: In function 'flash_erase': 180:21: warning: variable 'last' set but not used [-Wunused-but-set-variable] In function 'write_buff': 322:10: warning: variable 'port_width' set but not used [-Wunused-but-set-variable] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2014-06-19Fix bug in io64 target (introduced by commit aba27ac)Vasili Galka
From comparison of current logic and the logic that was prior to commit aba27ac, we see that first parameter of FPGA_GET_REG() shall be the FPGA index and not channel number. The re-factoring in commit aba27ac accidentally changed that. Cc: Stefan Roese <sr@denx.de> Acked-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Vasili Galka <vvv444@gmail.com>
2014-06-19trats/trats2: exynos_power_init: return 0 if no battery detected.Przemyslaw Marczak
Generic board support is now enabled for Exynos 4, and if any init function returns an error then the init process is stopped. This makes a boot issue on the Trats and Trats2 devices. If the device is supplied by USB cable or an external power supply then it can't boot because function exynos_power_init returns an error. Now this function returns 0 if battery is not connected. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Piotr Wilczek <p.wilczek@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-06-17mx28evk: Add documentation on how to boot from SPI NORFabio Estevam
Explain the necessary steps in order to boot from SPI NOR. Based on a earlier submission from Mårten Wikman. Signed-off-by: Mårten Wikman <marten.wikman@novia.fi> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-06-11board:keymile: remove unnecessary double bracesJeroen Hofstee
Clang interpretes an if condition like "if ((a = b) == NULL) as it tries to assign a value in a statement. Hence if you do "if ((something)) it warns you that you might be confused. Hence drop the double braces for plane if statements. cc: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
