- Correct the hardware product id for the Colibri IMX7D (eMMC) module.
- Exclude IT check since Colibri IMX7D (eMMC) is always IT.
Related-to: ELB-4076
Signed-off-by: Oleksii Bidnichenko <oleksii.bidnichenko@toradex.com>
Enable dynamic DDR calibration to have a reliable behavior on edge
temperatures conditions.
Signed-off-by: Francesco Dolcini <francesco.dolcini@toradex.com>
This configuration creates an U-Boot which does not use any storage
device, i.e. no eMMC or NAND. It is used to boot U-Boot over recovery
aka. Serial Downloader without the need to know if the module
uses eMMC or NAND for storage. It detects the storage device type and
start the Toradex Easy Installer with the matching configuration.
Note that for NAND devices the mtd partitioning is not patched into
the device tree by U-Boot. It must be part of the provided device
tree.
Related-to: TEI-922
While at it complete the list of the known module product ids.
Related-to: ELB-4056, ELB-4057
| #if !defined(CONFIG_TARGET_VERDIN_IMX8MM) || !defined(CONFIG_TARGET_VERDIN_IMX8MN)
is never false. Fix that so that the condition is 'true' for any board
but the two verdins.
Fixes commit c0c3978cba3 ("toradex: tdx-cfg-block: add Verdin iMX8M
Mini/Nano support").
Add code to build the eMMC variant of the Colibri iMX6ULL, i.e. the
'Colibri iMX6ULL 1GB' which has a eMMC instead of the raw NAND used
on other SKUs.
Integrate new Toradex SKU 0062 Colibri iMX6ULL 1GB IT. This commit
basically adjusts three parameters of the RAM settings:
Increase density from 4Gb to 8Gb
Increase ROW address from 15 to 16
Increase tRFC (refresh command time) from 260 to 350
This timing is valid for all Toradex Colibri iMX6ULL SKUs
Related-to: ELB-4055, ELB-4057
The distro boot script in TEZI image is called boot-tezi.scr.
Enable using this particular script name for u-boot images
which are used as a part of TEZI.
Related-to: TEI-791
The distro boot script for TEZI has another name to prevent u-boot of
regular BSP trying to boot TEZI image. Expand the usage of
TDX_EASY_INSTALLER Kconfig option to seek and use the TEZI-specific
name of the script.
Related-to: TEI-791
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Allow setting Toradex Easy Installer aka Tezi specific configuration
options like not enabling SATA, directly continuing with the SDP command
upon recovery, distrobooting otherwise or not storing the environment.
(cherry picked from commit 8b2f82e2aca52bac5b67fbeddccef2dd44f21444)
board/toradex/common/Kconfig
added it on the end of the file and reworded the Kconfig entry so it
reflects what it is used for in this U-Boot.
Only one dtb is currently supported, so match with imx6-colibri.
Related-to: TOR-1704
Signed-off-by: Ming Liu <ming.liu@toradex.com>
The recovery image needs to support both Colibri-iMX7 NAND and
Colibri-iMX7 eMMC modules. Forward port the solution for this
from u-boot 2016.11, originally developed by
Stefan Agner <stefan.agner@toradex.com>.
Related-to: TEI-775
This patch fixes the following compiler warning:
board/toradex/colibri_vf/colibri_vf.c: In function 'ft_board_setup':
board/toradex/colibri_vf/colibri_vf.c:436:6: warning: unused variable 'ret' [-Wunused-variable]
If config block support is enabled, USB gadget modes unconditionally
use Toradex Product ID as USB PID. Some applications might prefer a
different and/or static USB PID. Add a Kconfig configuration option
to descide whether to use USB PID from config block or the fallback
config option CONFIG_G_DNL_PRODUCT_NUM.
Acked-by: Brandon Shibley <brandon.shibley@toradex.com>
(cherry-picked from commit f72fe627c3e7a97008b8dd5d9ceb6df1dcd347ee)
In case USB serial downloader has been used to load U-Boot start the
serial download protocol (SDP) emulation. This allows to download
complete images such as Toradex Easy Installer over USB SDP as well.
This code uses the boot ROM provided boot information to reliably
detect USB serial downloader.
(cherry-picked from a2e77a650a496e2be0b1630b874f531e9f394d47)
Forward-ported to 2020.07:
U-boot might display wrong module revision information
for modules with an assembly version 'K'. "cfgblock create"
does not takes into account all revision digits from PID8.
This fix takes into account 6th,7th digits of PID8
to store module revision.
Related-to: ELB-3893
Signed-off-by: Denys Drozdov <denys.drozdov@toradex.com>
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Drop show_boot_logo legacy function, as splashscreen functionality can
be used instead.
Set proper splashscreen env value instead of calling legacy function
to show embed boot logo.
Enable these Kconfig symbols:
TDX_CFG_BLOCK_EXTRA=y
TDX_HAVE_EEPROM_EXTRA=y
Add carrier board info printing during boot time:
U-Boot 2020.07-rc4-02435-g1756e05 (Jun 22 2020 - 22:43:59 +0300)
CPU: Freescale i.MX8MMQ rev1.0 at 1200 MHz
Carrier: Toradex Verdin Development Board V1.0A, Serial# 10622780
Verdin iMX8MM #
Add migration routine from PID8 pre-stored values on EEPROM
(including sane value checks).
This introduces support for EEPROM as a storage for the main Toradex
config block and additional config blocks on extra EEPROM chips (on
carrier board or video adapters).
To enable EEPROM as a storage for the main config block:
TDX_HAVE_EEPROM=y.
For additional EEPROMs please enable this Kconfig symbol:
TDX_CFG_BLOCK_EXTRA=y.
Information about existing EEPROM chips is provided via Device Tree
using aliases.
You can also write configuration for the carrier board using
create_carrier subcommand for cfgblock. Example:
Verdin iMX8MM # cfgblock create_carrier
Supported carrier boards:
UNKNOWN CARRIER = [0]
Verdin Carrier Board = [1]
Choose your carrier board (provide ID): 1
Enter carrier board version (e.g. V1.1B): V1.0A
Enter carrier board serial number: 10622780
Also with barcode:
Verdin iMX8MM # cfgblock create carrier -y 0156100010622780
Add defines for supported carrier boards and display adapters.
These functions wrap functionality for storing config blocks in EEPROM.
1. Configure white on black for video console.
2. Enable printing bmp logo during late board init stage.
3. Use iomux configuration from device tree.
1. Show boot logo embed in U-Boot blob.
2. Drop iomux configration for LCD, and use the one provided in device
tree.
1. Move u-boot specific nodes to u-boot dts include: legacy lcdif
node and aliases.
2. Add iomux configuration for LCD.
3. Drop un-needed u-boot,dm-pre-reloc for alias node.
4. Fix display-timings, use the one from Toradex downstream kernel [1]
[1]: https://git.toradex.com/cgit/linux-toradex.git/tree/arch/arm/boot/dts/imx7-colibri-eval-v3.dtsi?h=toradex_4.9-2.3.x-imx#n206
Add function for showing boot logo, embed into u-boot blob.
Add L2 cache node to enable all cache ways from U-Boot proper.
Signed-off-by: Pragnesh Patel <pragnesh.patel@sifive.com>
Tested-by: Bin Meng <bmeng.cn@gmail.com>
The HiFive Unleashed board wires GPIO pin#10 to the input of the
system reset signal. This adds gpio reboot support.
Signed-off-by: Bin Meng <bin.meng@windriver.com>
Reviewed-by: Sagar Kadam <sagar.kadam@sifive.com>
Tested-by: Sagar Kadam <sagar.kadam@sifive.com>
Reviewed-by: Pragnesh Patel <pragnesh.patel@sifive.com>
After enabling SPL_OF_CONTROL, SPL_DM and SPL_DM_MMC the MMC
initialization code is not longer needed.
This patch removes the unused code.
Signed-off-by: Walter Lozano <walter.lozano@collabora.com>
In SPL legacy code only one MMC device is created, based on BOOT_CFG
register, which can be either SD or eMMC. In this context
board_boot_order return always MMC1 when configure to boot from
SD/eMMC. After switching to DM both SD and eMMC devices are created
based on the information available on DT, but as board_boot_order
only returns MMC1 is not possible to boot from eMMC.
This patch customizes board_boot_order taking into account BOOT_CFG
register to point to correct MMC1 / MMC2 device. Additionally, handle
IO mux for the desired boot device.
Update README to extract firmware from scripts
Signed-off-by: Oliver Graute <oliver.graute@kococonnector.com>
This is needed to obtain the MAC from EEPROM/OTP only after the final
env is populated, otherwise the ethaddr might be overriden.
Cc: Claudius Heine <ch@denx.de>
Cc: Harald Seiler <hws@denx.de>
Cc: Ludwig Zenz <lzenz@dh-electronics.com>
For using a debug UART on the Wandboard CONFIG_MXC_UART=y must be set in
the .config file.
To avoid duplicate definitions move the setting from
include/configs/wandboard.h to configs/wandboard_defconfig.
Document the debug UART settings in the README.
Reviewed-by: Fabio Estevam <festevam@gmail.com>
It appears that MMC access on the Sabrelite has been broken since
cdcaee9518:
Loading Environment from MMC... Card did not respond to voltage select!
*** Warning - No block device, using default environment
Remove the board_mmc_init() and related entries now that we should be
using DM_MMC, add PINCTRL so that things work as expected.
Signed-off-by: Martyn Welch <martyn.welch@collabora.com>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Tested-by: Troy Kisky <troy.kisky@boundarydevices.com>
Acked-by: Troy Kisky <troy.kisky@boundarydevices.com>
Migration to DM_ETH is mandatory, so convert mx6cuboxi to Ethernet
Driver Model.
This also brings the benefit of restoring Ethernet functionality.
Reported-by: Tom Rini <trini@konsulko.com>
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Tested-by: Tom Rini <trini@konsulko.com>
Take over maintainership for Colibri T20 module.
Acked-by: Lucas Stach <dev@lynxeye.de>
Add the recently added reStructuredText board documentation in the
appropriate MAINTAINERS files.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Move the natural text Amlogic board README files to doc/board/amlogic
into reStructuredText and :
- add reStructuredText markup for bash code
- fix secondary titles markup
- move board support into global support matrix
s/booot/boot/g
The first ase is booot instead of boot and second u-booot instead of
u-boot.
OF_CONTROL, DM_SPI and other driver model migration deadlines
are expired for this board.
Remove it.
Acked-by: Lars Poeschel <poeschel@lemonage.de>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Remove it.
Acked-by: Grazvydas Ignotas <notasas@gmail.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
Fixes for 2020.07
- mx53: mx53menlo Convert to DM_ETH, fix fail boot
- imx8mp_evk: fix boot issue
- MX6, display5: fix environment
- drop warnings (watchdog) for i.MX8mm i.mx8mp
- enable bootaux for i.MX8M
Travis: https://travis-ci.org/github/sbabic/u-boot-imx/builds/695929999
- DM_ETH support for P2041RDB, T1024RDB, P5040DS, P3041DS, P4080DS, bug
fixes
- Add TBI PHY access through MII
- DDR: Rework errata workaround for A008109, A008378, 009942
