(common/cmd_ide.c, common/cmd_reiser.c, common/cmd_scsi.c).
* Enable USB and IDE support for INKA4x0 board
* Patch by Andrew Dyer, 28 February 2005:
fix ext2load passing an incorrect pointer to get_partition_info()
resulting in load failure for devices other than 0
* Add reset code for Coral-P on INKA4x0 board
* Patch by Martin Krause, 28 Jun 2004:
Update for TRAB board.
* Fix some missing "volatile"s in MPC5xxx FEC driver
* Add USB and PCI support for INKA4x0 board
Add standalone application to change SMC91C111 MAC addresses,
see examples/README.smc91111_eeprom
* Patch by Xiaogeng (Shawn) Jin, 12 Oct 2004:
Fix Flash support for ARM Integrator CP.
* Patch by Richard Woodruff, 10 Jan 2005:
Update support for OMAP2420 (ARM11) and H4 board:
o clean up and add new types to H4 memory probe code.
o fix to work with internal boot.
o added PRCM config III operation.
o fix marginal flash timings.
o add revison ATAG usage.
o enable voltage scaling at power chip.
o fix compile error for i2c.
* Fix network problem (error when receiving multiple ARP packets)
Add support for Wind River sbc405 board
* Patch by Rainer Brestan, 12 Oct 2004:
Make examples/Makefile more robust
- Add RESET/PREBOOT/AUTOBOOT support for RPXlite_DW board
- Adjust CPU:BUS frequency ratio 1:1 when core frequency
less than 50MHz
* Patch by Sam Song, 10 Oct 2004:
Fix a parameter error in run_command() in main.c
add support for the TI OMAP2420 processor and its H4 reference
board
* Patch by Christian Pellegrin, 24 Sep 2004:
Added support for NE2000 compatible (DP8390, DP83902) NICs.
add support for the AMD db1550 board
* Patch by Travis Sawyer, 15 Sep 2004:
Add CONFIG_SERIAL_MULTI support for ppc4xx,
update README.serial_multi
- add u-boot.hex target in the top level Makefile
- add support for the UNSW/NICTA PLEB 2 board (pleb2)
- use -mtune=xscale and -march=armv5 options for PXA
Add support for SenTec-COBRA5272-board (Coldfire).
Add Xilinx Spartan2E family FPGA support
* Patch by Jeff Angielski, 02 Sep 2004:
Add Added support for H2 revision of the EP8260 board.
Fixed formatting for some of the EP8260 related source files.
Reset monitor size back to 256 so environment can be written
to flash on MPC85xx ADS and CDS releases.
* Patch by Paolo Broggini, 02 Sep 2004:
Make BSS clearing on ARM systems more robust
* Patch by Yue Hu and Joe, 01 Sep 2004:
- add PCI support for ixp425;
- add EEPRO100 suppor tfor ixdp425 board.
* Fix problem with protected sector detection in driver/cfi_flash.c
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to
pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for
additional ethernet addresses.
* Cleanup drivers/i82365.c - avoid duplication of code
* Fix bogus "cannot span across banks" flash error message
* Add support for CompactFlash for the CPC45 Board.
* Adjust INKA 4x0 default settings
Fix typo in AT91 memory setup.
