2005-09-14 | Update of new NAND code | Wolfgang Denk | |
Patch by Ladislav Michl, 13 Sep 2005 | |||
2005-08-16 | Enable PCI on hmi1001 board | Wolfgang Denk | |
2005-08-15 | Coding style cleanup | Wolfgang Denk | |
2005-08-15 | Add support for Silicon Turnkey eXpress XTc (mpc87x/88x) board. | Wolfgang Denk | |
Patch by Dan Malek and Pantelis Antoniou, 15 Aug 2005 | |||
2005-08-15 | Add Sandburst Metrobox and Sandburst Karef board support packages. | Stefan Roese | |
Second serial port on 440GX now defined as a system device. Add 'Short Etch' code for Cicada PHY within 440gx_enet.c Patch by Travis B. Sawyer, 12 Jul 2005 Check return value of malloc in 440gx_enet.c Patch by Travis B. Sawyer, 18 Jul 2005 | |||
2005-08-13 | Code cleanup. | Wolfgang Denk | |
2005-08-12 | Remove stale file entry | Wolfgang Denk | |
2005-08-12 | Minor code cleanup | Wolfgang Denk | |
2005-08-12 | Add forgotten new fils from latest VoiceBlue update | Wolfgang Denk | |
2005-08-12 | Fix Murray Jensen's mail address. | Wolfgang Denk | |
Patch by Murray Jensen, 30 Jun 2005 | |||
2005-08-12 | VoiceBlue update: eeprom tool can also store firmware version now. | Wolfgang Denk | |
eeprom.bin is runable by jumping at load address. Patch by Ladislav Michl, 23 May 2005 | |||
2005-08-12 | esd PCI405 board updated | Stefan Roese | |
Patch by Matthias Fuchs, 28 Jul 2005 | |||
2005-08-12 | esd WUH405 and DU405 board updated | Stefan Roese | |
Patch by Matthias Fuchs, 27 Jul 2005 | |||
2005-08-12 | Merge with /home/wd/git/u-boot/masterLABEL_2005_08_12_0050 | Wolfgang Denk | |
2005-08-11 | Update AMCC Yosemite to get a consistent setup for all AMCC eval | Stefan Roese | |
boards (baudrate, environment...). Flash driver fixed. Patch by Stefan Roese, 11 Aug 2005 | |||
2005-08-11 | Add NAND FLASH support for AMCC Bamboo 440EP eval board | Stefan Roese | |
2005-08-10 | Add configuration for IFM AEV FIFO board. | Wolfgang Denk | |
Minor coding style cleanup. | |||
2005-08-08 | Add common (with Linux) MTD partition scheme and "mtdparts" command | Wolfgang Denk | |
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning. | |||
2005-08-08 | Fix build problems for PM856 Board | Wolfgang Denk | |
2005-08-06 | Add support for Altera NIOS DK1C20 board | Wolfgang Denk | |
Patch by Shlomo Kut, 13 Dec 2004 | |||
2005-08-06 | Add support for ep8248 board | Wolfgang Denk | |
Patch by Yuli Barcohen, 12 Dec 2004 Minor code cleanup. | |||
2005-08-05 | Merge with /home/sr/git/u-boot | Wolfgang Denk | |
2005-08-05 | Merge with /home/wd/git/u-boot/jon_loeliger | Wolfgang Denk | |
2005-08-05 | Add support for MicroSys PM856 board | Wolfgang Denk | |
Patch by Josef Wagner, 03 Aug 2005 | |||
2005-08-05 | Minor fixes to PM854 board | Wolfgang Denk | |
2005-08-05 | Merge with /home/wd/git/u-boot/master | Wolfgang Denk | |
2005-08-04 | Add support for AMCC Bamboo PPC440EP eval board | Stefan Roese | |
Patch by Stefan Roese, 04 Aug 2005 | |||
2005-08-04 | (re)enabled scsi commands do_scsi() and do_scsiboot() | Wolfgang Denk | |
Patch by Denis Peter, 06 Dec 2004 | |||
2005-08-03 | Cleanup build problems (on Fedora Core x86_64 build host) | Wolfgang Denk | |
2005-08-02 | Merge with rsync://git-user@source.denx.net/git/u-boot.git | Jon Loeliger | |
2005-08-02 | Coding style cleanup | Wolfgang Denk | |
2005-08-02 | Merge with /home/sr/git/u-boot | Wolfgang Denk | |
2005-08-01 | Fix style issues primarily in 85xx and 83xx boards. | Jon Loeliger | |
- C++ comments - Trailing white space - Indentation not by TAB - Excessive amount of empty lines - Trailing empty lines | |||
2005-08-01 | Major cleanup for AMCC PPC4xx eval boards. | Stefan Roese | |
Patch by Stefan Roese, 01 Aug 2005 | |||
2005-08-01 | Add support for AMCC PPC440EP/GR eval boards Yosemite and Yellowstone. | Stefan Roese | |
Patch by Steven Blakeslee, 27 Jul 2005 | |||
2005-07-31 | Minor fixes for PPChameleon Board: | Wolfgang Denk | |
* fix alignment of NAND size * make code do what the comment says | |||
2005-07-30 | Implement h/w sector protection status synchronization at boot. | Wolfgang Denk | |
The code is provided for, and was tested on, the Yukon/Alaska and PM520 boards only. A bug in flash_real_protect() for the Yukon board was fixed by adding a function that tells if two banks are on one flash chip. | |||
2005-07-29 | * Patch by Ron Alder, 11 July 2005 | Lunsheng Wang | |
Add Xianghua Xiao and Lunsheng Wang's support for the GDA MPC8540 EVAL board. | |||
2005-07-28 | * Patch by Eran Liberty | Eran Liberty | |
Add support for the Freescale MPC8349ADS board. | |||
2005-07-25 | * Patch by Jon Loeliger, 2005-07-25 | Jon Loeliger | |
Move the TSEC driver out of cpu/mpc85xx as it will be shared by the upcoming mpc83xx family as well. | |||
2005-07-25 | * Patch by Jon Loeliger, 2005-05-05 | Jon Loeliger | |
Implemented support for MPC8548CDS board. Added DDR II support based on SPD values for MPC85xx boards. This roll-up patch also includes bugfies for the previously published patches: DDRII CPO, pre eTSEC, 8548 LBIU, Andy's TSEC, eTSEC 3&4 I/O | |||
2005-07-23 | * Patch by Jon Loeliger, Kumar Gala 2005-02-08 | Jon Loeliger | |
- Convert the CPM2 based functionality to use new CONFIG_CPM2 option rather than a myriad of CONFIG_MPC8560-like variants. Applies to MPC85xx and MPC8260 boards, includes stxgp3 and sbc8560. Eliminates the CONFIG_MPC8560 option entirely. Distributes the new CONFIG_CPM2 option to each 8260 board. | |||
2005-07-21 | Patch by Jon Loeliger, 20 Jul 2005: | Wolfgang Denk | |
Add missing PCI IO port definitions. author Kumar Gala <kumar.gala@freescale.com> Wed, 20 Jul 2005 15:39:52 -0500 committer Jon Loeliger <jdl@freescale.com> Wed, 20 Jul 2005 15:39:52 -0500 | |||
2005-07-21 | Adjust printed board ID for LWMON board. | Wolfgang Denk | |
2005-07-21 | Fix file permissions | Wolfgang Denk | |
2005-07-05 | * Patch by Stefan Roese, 5 Jul 2005: | stroese | |
Update uc100 board PHY setup | |||
2005-06-27 | * Fix baudrate calculation problem on MPC5200 systems | wdenk | |
* Add MPC8220 boards to MAKEALL script * Add EEPROM and RTC support for HMI1001 board * Patch by Detlev Zundel, 20 Jun 2005: Fix initialization of low active GPIO pins on inka4x0 board | |||
2005-06-10 | * Add support for HMI1001 board | wdenk | |
* Disable "date" and "sntp" commands on TQM866M which has no RTC | |||
2005-05-30 | Patch by Juergen Selent, 17 May 2005: | wdenk | |
Add support for Funkwerk VoVPN gateway module. | |||
2005-05-19 | Patch by Greg Ungerer, 19 May 2005: | wdenk | |
add support for the OpenGear CM4008 board |
