There is no more tolerance issue on PFUZE, it will be only 25mV, so that we no
need increase VDDSOC_IN from 1.375V to 1.425V.
Signed-off-by: Robin Gong <B38343@freescale.com>
* Adding the config option CONFIG_SECURE_BOOT to the SabreSD board,
but defaulting it to be disabled. Removed the CONFIG_SECURE_BOOT
key from mx6q_arm2_android.h so that it is only in one file,
include/configs/mx6q_arm2.h
* Fixed up an address alignment check in authenticate_image(). The
test would fail in the event the address is already aligned.
Also, added some debug code which can be enabled to assist in
testing secure images.
* Added support for authenticating an image when using booti.
* Adding support for secure boot to the Sabre SD board.
* Added support for encrypted boot to mx6q arm2 board linker script.
Signed-off-by: Dan Douglass <dan.douglass@freescale.com>
the same as TKT104835 reported on MX6Q/DL
Need set Power Supply Glitch to 0x41736166 and clear Power Supply
Glitch Detect bit when POR or reboot or power on, otherwise system could
not be power off anymore, it will power up auto agian.
Signed-off-by: Lin Fuzhen <fuzhen.lin@freescale.com>
In some imx6sl evk boards, fec cannot work fine while doing
cycle reboot via to execute command "reboot" in kernel.
The root cause: phys clock source is closed when reboot system,
and LAN8720 status machine is in disorder. So it needs to do phy
hardware reset to make phy enter normal state machine.
Signed-off-by: Fugang Duan <B38611@freescale.com>
This patch removes the 'semiconductor' word in the freescale
reversed color logo to align with the standard(preferred) one
which can be found at the link:
http://media.freescale.com/phoenix.zhtml?c=196520&p=irol-logosdisclaim
Signed-off-by: Liu Ying <Ying.Liu@freescale.com>
1. Add matrix key support
2. Add recovery mode support by pressing power key and volume down key
when boot
SW10 on MX6SL-EVK board configed as volume down key.
SW1 on MX6SL-EVK board configed as power key
Signed-off-by: LiGang <b41990@freescale.com>
To save power, set all switches to PFM mode in standby,although PFM mode need
6% tolerance.But it will be implemented in kernel, and move the workaround
which all buck switches need be configured PWM mode on PF100 1.0
Another two change is:
1. u-boot will print PFUZE device id and revision id.
2. add value check for i2c write and read.
Fix build fail issue of sata.
mx6q_arm2.c: In function 'sata_initialize':
mx6q_arm2.c:261:6: error: 'sata_curr_device' undeclared (first use in
this function)
mx6q_arm2.c:261:6: note: each undeclared identifier is reported only
once for each function it appears in
mx6q_arm2.c:299:2: warning: implicit declaration of function
'__sata_initialize' [-Wimplicit-function-declaration]
mx6q_arm2.c: In function 'setup_sata':
mx6q_arm2.c:346:6: error: 'sata_curr_device' undeclared (first use in
this function)
mx6q_arm2.c: At top level:
mx6q_arm2.c:81:12: warning: 'system_rev' defined but not used
[-Wunused-variable]
make[1]: *** [mx6q_arm2.o] Error 1
Signed-off-by: Terry Lv <r65388@freescale.com>
Update the u-boot config for mx53 smd android to
include the correct boot env, enable boot splash,
increase the cmdline buffer, tokens and 1G DDR.
Signed-off-by: Nitin Garg <nitin.garg@freescale.com>
* disable SATA PHY in default
* add sata_initialize() func used to re-initialize SATA when
sata is used.
Signed-off-by: Richard Zhu <r65037@freescale.com>
Added support for 64bit DDR configuration
on DL chip. On ARD platform
Signed-off-by: Alejandro Sierra <b18039@freescale.com>
This patch adds the solo-ddr32bit config support. The DDR script got from:
http://compass.freescale.net/livelink/livelink/227589697/
MX6DL_init_DDR3_400MHz_32bit_For_SD_1.0.inc.txt?func=doc.Fetch&nodeid=227589697
Signed-off-by: Jason Liu <r64343@freescale.com>
This patch aligns IPU related clocks with imx_3.0.35(_android)
kernel setting to support smooth transition from uboot splash
screen to kernel stage.
The IPU related clock trees are:
1) MX6DQ SabreSD:
ipu1_clk --
osc_clk(24M)->pll2_528_bus_main_clk(528M)->periph_clk(528M)
->mmdc_ch0_axi_clk(528M)->ipu1_clk(264M)
ipu1_pixel_clk_x --
pll2_pfd_352M(452.57M)->ldb_dix_clk(64.65M)->
ipu1_di_clk_x(64.65M)->ipu1_pixel_clk_x(64.65M)
2) MX6DL SabreSD:
ipu1_clk --
osc_clk(24M)->pll3_usb_otg_main_clk(480M)->
pll3_pfd_540M(540M)->ipu1_clk(270M)
ipu1_pixel_clk_x --
This patch enables pwm backlight for LVDS panel and stops
using gpio backlight to align with kernel to avoid unstable
backlight when booting into kernel, as kernel usually uses
pwm backlight instead of gpio backlight. Following items
are done to support this:
1) Add PWM1 and PWM2 controller base addresses.
2) Change PIN SD1_DAT3 mux from GPIO to PWM1_PWMO.
3) Set default backlight density to 50%.
- mx6sl_evk_android.h is a new file, copied from mx6sl_arm2_android.h
- set default sdio port as mmc1
* Enable lvds backlight by default, configure
io_expander A to enable backlight.
* As weimnor_d18, spinor_d18, i2c3_sda share the pad
MX6Q_PAD_EIM_D18 if wiemnor or spinor is enabled
it overrides i2c3 settings and kernel fails to configure
io_expander causing read/write errors.
* This commit allows a default configuration on control
lines behind io_expander A.
Signed-off-by: Adrian Alonso <aalonso@freescale.com>
This patch sets CABC_EN0/1 pins to low to disable
LVDS panel CABC function. This function will turn backlight
automatically according to display content which may cause
potential unstable backlight phenomena.
From IC spec:
The Power down Counter inside WDOG-1 will be enabled out of reset.
This counter has a fixed time-out value of 16 seconds, after which
it will drive the WDOG-1 signal low.
To prevent this, the software must disable this counter by clearing
the PDE bit of Watchdog Miscellaneous Control Register (WDOG_WMCR)
within 16 seconds of reset de-assertion. Once disabled, this counter
cannot be enabled again until the next system reset occurs. This
feature is provided to prevent the hanging up of cores after reset, as
WDOG-1 is not enabled out of reset.
NOTE for the last sentence:
This feature requires a dedicated WDOG_B pin for it. The fact that changing
the IOMUX configuration can alter the WDOG_B functionality (GPIO by default)
is not ideal as it defeats the purpose of this feature. But it still
takes effect when the muxed pin is configured as WDOG_B within 16 seconds.
Clear PDE bit to avoid WDOG_B (aka, WDOG-1) assertion.
Tested on MX6SL. May add this for other MX6x.
Signed-off-by: Robby Cai <R63905@freescale.com>
- configure SD1 to support 8bit on evk
Signed-off-by: Ryan QIAN <b32804@freescale.com>
Set the default clock to 20MHz. The 11Mhz is too slow.
Signed-off-by: Huang Shijie <b32955@freescale.com>
Modify ODT values for Solo AI. Some Solo boards did not passed the "mtest"
from uboot using the previous configuration.
Old configuration:
MXC_DCD_ITEM(76, MMDC_P0_BASE_ADDR + 0x818, 0x00000007)
MXC_DCD_ITEM(77, MMDC_P1_BASE_ADDR + 0x818, 0x00000007)
MXC_DCD_ITEM(67, MMDC_P0_BASE_ADDR + 0x818, 0x00000007)
MXC_DCD_ITEM(68, MMDC_P1_BASE_ADDR + 0x818, 0x00000007)
New configuration:
MXC_DCD_ITEM(76, MMDC_P0_BASE_ADDR + 0x818, 0x00011117)
MXC_DCD_ITEM(77, MMDC_P1_BASE_ADDR + 0x818, 0x00011117)
MXC_DCD_ITEM(67, MMDC_P0_BASE_ADDR + 0x818, 0x00011117)
MXC_DCD_ITEM(68, MMDC_P1_BASE_ADDR + 0x818, 0x00011117)
Add mx6sl evk board support
- copied from ARM2 board support
- added a new board revision
- removed unused boot device detection
1.Considering pfuze tolerance and IR drop and board ripple, need rise from
1.375V to 1.425V. Only for Sabresd.
2.workaround pfuze1.0 ER1, set all buck regulator except SW1C to PWM mode.
now for mx6sl_arm2 and mx6_sabresd.
1. enable fastboot feature on mx6q-arm2 board
2. enlarge fastboot buffer to 320MB
3. correct some usb descriptors
This patch changes to use new 8bit 600x400 bmp boot logo.
As this boot logo has black background and white words,
the user experience will be better.
This patch adds new boot 8bit 600x400 bmp logo
who has black background and white words.
The original secure boot implementation make a consumption that
u-boot.bin will not exceed 0x2F000. With this consumption, the hab data
is hard coded in linker script file to relative address 0x2F000 without
causing any problem.
But when this consumption don't hold, the hard coded way will cause
memory region overlap and break build. So we need to change to a dynamic
way of allocating hab_data. The new implementation put hab data at the
next 0x1000 alignment after u-boot data and text section, instead of
hard coded to 0x2F000.
Similar changes is made to uImage authentication implementation.
Changes in U-Boot includes:
- in u-boot.lds file, change "__hab_data" to dynamic align to 0x1000
- change authenticate_image implementation, originally the uImage
parameters are hard coded, now they are retrived from the
"load_addr" and the image_hdr
The new secure image layout:
U-Boot
+-------------------+ DDR_START
| U-Boot Image |
+-------------------+ DDR_START + UBOOT_SIZE
| PADDING |
+-------------------+ align to 0x1000
| CSF Data | -
+-------------------+ +-- CSF + Pad, Size : 0x2000
| PADDING | -
uImage
| uImage |
+-------------------+ DDR_START + UIMAGE_SIZE
| PADDING |
| IVT | ---- Size : 0x20
| CSF Data | -
| PADDING | -
Signed-off-by: Eric Sun <jian.sun@freescale.com>
This patch configures iomux gpr3 register to enable LVDS1
via IPU1 DI1 if user chooses to use it.
The silicon revision is not printed correctly, on ARM2
and sabrelite board, the log is just as the following:
CPU: Freescale i.MX6 family TO0.0 at 792 MHz
We need print the silicon revision correctly as:
CPU: Freescale i.MX6 family TO1.2 at 792 MHz
with i.mx6q TO1.2 chip
Fix the build warning in uboot build.
Fix bug of incorrect dereference to periph2 clock pre divider.
Fix incorrect type of maxpackage size assign, even it's
not used at all in fastboot.
Signed-off-by: Xinyu Chen <xinyu.chen@freescale.com>
This commit fix the linker error when enable more function(like CONFIG_NAND,
CONFIG_SPASHSCREEN,etc) in uboot ARM2 board, and a possable linker error for
other MX6 boards:
/home/lambert/share/SATA2/R13.3/prebuilt/linux-x86/toolchain/arm-eabi-4.4.3/
bin/arm-eabi-ld: section .bss [27831000 -> 278666e7] overlaps section
.rodata [2782387c -> 278609eb]
bin/arm-eabi-ld: section .rodata.str1.1 [278609ec -> 27867803] overlaps
One issue here is:
A recent gcc added a new unaligned rodata section called '.rodata.str1.1',
which needs to be added the the linker script. Instead of just adding this
one section, we use a wildcard ".rodata*" to get all rodata linker section
gcc has now and might add in the future.
Another issue is:
The secure boot feature require __hab_data section in uboot linker script,
but it's have a hard coding magic number, but if we enable more code, cause
.text section bigger, it will cross the line, so it report the
first linker error.
This commit disable SECURE_BOOT feature by default for android,
and comments if user want to use this feature, it needs change the
.lds by there configure.
Also, enlarge the magic number that this feature needs to cover
if more code is build in.
Signed-off-by: Zhang Jiejing <jiejing.zhang@freescale.com>
With the secure boot patch. MX6 NAND Boot is not functional. The root
cause is that, the original secure boot patch fills "0xFF' to spacing
regions, due to a issue in ROM code, read pages of all "0xff" will be
treated as a critical error. Thus prevent the U-Boot from booting
normally.
The fix adjust image copy size in IVT so that when secure boot is not
enabled, no unuseful data is copied by ROM code. Also the secure boot
option is default disabled. The end user won't enable it unless they
know what they are doing.
These prevent the ROM code from copied pages of "0xff" data, and fix the
issue.
enable SD3.0 support on SD1 and SD2 on mx6sl arm2 cpu board.
Move the secure boot related implementation code from mx6q_arm2.c to
mx6/generic.c. In this way the HAB feature can be shared by all MX6
platforms
IC Validation team release new LPDDR2 script V0.93 in the following link,
"http://compass.freescale.net/livelink/livelink?func=ll&objId=226733834/"
Make changes to align to it
1.enable I2C and I2C bus recovery support on mx6sl_arm2
2.enable LDO bypass on u-boot, by configuring 'CONFIG_MX6_INTER_LDO_BYPASS'
For MX6DL LPDDR2 board, in order to use both the 2 channels of the memory, the
"PL301_FAST2" must be set to 0x1. However this bit is not accessible using
DCD. Plugin mode must be utilized for this purpose.
The patch can be verified this way:
Enter U-boot console
> mw.l 0x80000000 0xC0 10
> mw.l 0x10000000 0xC1 10
> md.l 0x10000000 10
> md.l 0x80000000 10
Before the patch, 0x10000000 and 0x80000000 in fact point to the
same memory location. So the last 2 dump will show memory content of
both 0x000000C1
After the patch, 0x80000000 ponit to channel 0, 0x10000000 point to
channel 1. the last 2 dump will show memory content of 0x000000C0
and 0x000000C1 respectively
Move IPU QoS and VDOA/IPU/VPU AXI Cache config
to linux kernel in order to reduce code duplicate
Signed-off-by: Wayne Zou <b36644@freescale.com>
Validation team released lateset LPDDR2 script V0.91, See
k?func=ll&objId=226435628&objAction=browse&viewType=1"
This change is necessary for bus freq scaling
Apply it for both DCD mode and plugin mode.
We can use weak ODT setting, it will save about 50% DDR
power in runtime. Now we use 0x00007
MMDC0_MPODTCTRL MMDC1_MPODTCTRL, (Ohm)
Setting DDR_ODT imx_ODT Max_overclocking
0x22227 120 060 615MHz
0x11117 120 120 604MHz
0x00007 120 000 576MHz
0x00000 000 000 556MHz
Signed-off-by: Anson Huang <b20788@freescale.com>
- EPDC Splash support for MX6DL/S Sabre SD
- EPDC Splash support for MX6DL/S ARM2
- Currently, splash screen consists of a simple black border
around a white screen. Done this way to save in memory footprint.
Signed-off-by: Danny Nold <dannynold@freescale.com>
- move recovery.h to common inlcude place.
- move supported_reco_envs to soc related, not board related,
- user can change this via configure header,
don't needs this in every board file.
- pass build for all mx5/mx6 android configs.
- add android build config for mx6sl_arm2 board.
- add gpio support for mx6sl
- add boot image support
- add android recovery support
- add fastboot support, but fastboot cannot transfer file.
Signed-off-by Zhang Jiejing <jiejing.zhang@freescale.com>
Add generic gpio interface in uboot.
Seems more and more gpio operation invoke in uboot,
without RAW register operation, we should
use generic gpio interface.
you should define the CONFIG_MXC_GPIO
use generic gpio interface:
gpio_request,
gpio_direction_output,
gpio_direction_input,
gpio_set_value,
gpio_get_value, etc.
Test on MX6Q, MX6DL.
Other MX6X should also define this config.
set IPU AXI-id0 Qos=0xf(bypass) and AXI-id1 Qos=0x7,
mx6q use AXI-id0 for IPU display channel, it should has
highest priority(bypass), and AXI-id1 for other IPU channel,
it has high priority.
1. add check asrc register to enter recovery mode,
rather then check the file.
2. fix the boot.img can not fastboot flash function.
3. consolidate and cleanup fastboot code.
4. clean up many build warnning message.
This issue have been found in mx53_smd(ENGR00163704), and found in sabresd
if accessing pfuze while system reboot or reset, I2C bus will be blocked
even if reboot,then pfuze will be failed to be probed, all device driver
which use pfuze regulator will be impacted. In u-boot, we can check the
SDA line low or high, if low, generate SCL and STOP signal to tell I2C
device release I2C bus. Please check ENGR00163704
1.fix build error :
mx6q_sabresd.c: In function 'setup_i2c':
mx6q_sabresd.c:382: error: expected ')' before ';' token
mx6q_sabresd.c:393: error: expected ';' before '}' token
mx6q_sabresd.c: In function 'setup_pmic_voltages':
mx6q_sabresd.c:399: warning: unused variable 'val'
make[1]: *** [mx6q_sabresd.o] Error 1
2.modify mx6dl_sabresd_config to support pfuze on mx6dl sabresd board
add pfuze and I2C support, support cpu internal LDO bypass which can be
enabled by CONFIG_MX6_INTER_LDO_BYPASS
Since FEC_RX_ER is not connected with PHY(LAN8720A), we need
either configure FEC_RX_ER PAD to other mode than FEC_RX_ER,
or configure FEC_RX_ER PAD to FEC_RX_ER but need pull it down,
otherwise, FEC MAC will report CRC error always. We configure
FEC_RX_ER PAD to GPIO mode here and remove the SW hack which
ignore the CRC error in fec driver
