i.MX6 uses the 'standard' board revision for things, i.e.
video decoding no longer works.
so don't interfere with the Apalis iMX6 HW Revision */
while at it remove warnings
We decided to have the MAC addr only in the configblock
change the bootcommand to the following boot order
- emmcboot
- nfsboot
- enable usb keyboard and go to command prompt
- add logic to check for an unprogrammed PMIC before programming
- add #ifdef debug section to dump all PMIC registers
- order the SD Controllers. eMMC, MMC1, SD1
- SD1 is on Controller 2, but some references went to Controller 4
- move current code in its own source file
- add OTP programming code, results to be tested
- add OTP settings file, generated from excel
check sed commands to convert from text output to c-code
Fix Ethernet by limiting Micrel KSZ9031 PHY to 10/100 Mbps for now.
This has been ported from the following mainline commit for the uDoo
board:
078813d21db0600d440625327a1728c32e9fcc90
While at it clean out some more irrelevant stuff.
- Switched on some PMIC rails until we fuse the PMIC
- Added/corrected pinmuxings
- ETH still not working
- Corrected board name were Colibri was used instead of Apalis
Used Nitrogen6x as a starting point
[trini: Drop changes for PEP 4 following python tools]
Add a MAC address create based on the OMAP die ID registers.
Then poplulate the ethaddr enviroment variable so that the device
tree alias can be updated prior to boot.
Signed-off-by: Dan Murphy <dmurphy@ti.com>
'actual_bank' is not used anymore, instead boot_bank is used.
Signed-off-by: Andreas Huber <andreas.huber@keymile.com>
commit a5510058 powerpc/83xx/km: make local functions and structs static
removed the staticness also from this struct. But this struct is needed
in arch/powerpc/cpu/mpc83xx/cpu_init.c and declared as extern.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
Adding the generated pin mux configuration by Preloader
Generator tool
Signed-off-by: Chin Liang See <clsee@altera.com>
Reviewed-by: Pavel Machek <pavel@denx.de>
Acked-by: Dinh Nguyen <dinguyen@altera.com>
CC: Pavel Machek <pavel@denx.de>
Cc: Dinh Nguyen <dinguyen@altera.com>
Cc: Tom Rini <trini@ti.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Adding System Manager driver which will configure the
pin mux for real hardware Cyclone V development kit
(not Virtual Platform)
omap1510inn is orphan and has been for years now.
Reove it and, as it was the only arm925t target,
also remove arm925t support.
Update doc/README.scrapyard accordingly.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Enables support for SPI SPL, QSPI and Spansion serial flash device
on the EVM. Configures pin muxes for QSPI mode.
Signed-off-by: Matt Porter <matt.porter@linaro.org>
Signed-off-by: Sourav Poddar <sourav.poddar@ti.com>
Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
Since 2bf36ac638ab2db9f0295aa47064976eeebf80c1 the BD ram address is
not hardcoded inside cpsw driver any more. Platforms have to supply
their bd_ram_ofs in the platform data to the driver. This commit does
this for pcm051 and igep0033 boards.
Tested-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
We can run the DDR at 400MHz, so update the timings for that purpose.
Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
Reviewed-by: Javier Martinez Canillas <javier@dowhile0.org>
To enable hypervisors utilizing the ARMv7 virtualization extension
on the Versatile Express board with the A15 core tile, we add the
required configuration variable.
Also we define the board specific smp_set_cpu_boot_addr() function to
set the start address for secondary cores in the VExpress specific
manner.
There is no need to provide a custom smp_waitloop() function here.
This also serves as an example for what to do when adding support for
new boards.
Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
If smc911x_initialize() fails we should return the error immediately.
While at it, also check the error from cpu_eth_init().
If cpu_eth_init() fails we should return the error immediately.
This patch add support for a new Samsung board Trats2.
Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com>
CC: Lukasz Majewski <l.majewski@samsung.com>
Add RNDIS gadget support to test atmel usba udc driver
Signed-off-by: Bo Shen <voice.shen@atmel.com>
This patch enables default I2S0 channel.And I2S platform
parameter has been moved to a common file viz exynos5.dtsi.
Signed-off-by: Dani Krishna Mohan <krishna.md@samsung.com>
In Errata 1.0.24, if the board is running at OPP50 and has a warm reset,
the boot ROM sets the frequencies for OPP100. This patch attempts to
drop the frequencies back to OPP50 as soon as possible in the SPL. Then
later the voltages and frequencies up set higher.
Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com>
Cc: Lars Poeschel <poeschel@lemonage.de>
Signed-off-by: Steve Kipisz <s-kipisz2@ti.com>
[trini: Adapt to current framework]
Add a am33xx_spl_board_init (and enable the PMICs) that we may see,
depending on the board we are running on. In all cases, we see if we
can rely on the efuse_sma register to tell us the maximum speed. In the
case of Beaglebone White, we need to make sure we are on AC power, and
are on later than rev A1, and then we can ramp up to the PG1.0 maximum
of 720Mhz. In the case of Beaglebone Black, we are either on PG2.0 that
supports 1GHz or PG2.1. As PG2.0 may or may not have efuse_sma set, we
cannot rely on this probe. In the case of the GP EVM, EVM SK and IDK we
need to rely on the efuse_sma if we are on PG2.1, and the defaults for
PG1.0/2.0.
Fix the following checkpatch warning:
$ ./tools/checkpatch.pl -F board/freescale/mx28evk/mx28evk.c
CHECK: Alignment should match open parenthesis
#109: FILE: freescale/mx28evk/mx28evk.c:109:
+ writel(CLKCTRL_ENET_TIME_SEL_RMII_CLK | CLKCTRL_ENET_CLK_OUT_EN,
+ &clkctrl_regs->hw_clkctrl_enet);
